Old 24th June 2016, 14:24   #1821  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by MysteryX View Post
I've also been having issues with SMDegrain(prefilter=4) working terrible with MT; working faster with a single thread. I suppose this script will have the same problem.
Try to remove AVP.dll
@turment on Telegram
tormento is offline
Old 24th June 2016, 14:31   #1822  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by DJATOM View Post
Strange, but in avspmod x64 it only shows the first 800 pixels for height. Applying SMDegrain (with lsb) didn't change it, still 1920x800. 32-bit version works fine. Need to investigate.
Upd: made a new index and problem is fixed now (tested with avs+ r1873, x64; index made with DGIndexIM beta 50 X64). Still can't see any corruption :\
Just tried with DGIndexIM beta 50 x64 and I see the same corruption.
This is the script I used:
PHP Code:
SetMemoryMax(8000)
SetFilterMTMode("DEFAULT_MT_MODE"2)
SetFilterMTMode("ChangeFPS"3)
SetFilterMTMode("DGSourceIM"3)
LoadPlugin("D:\eseguibili\media\DGDecIM\x64\dgdecodeim.dll")
DGSourceIM("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursAV26.dgi"silent=true)
ChangeFPS(last,last,true)
Crop(01400, -140)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8
Have you tried a preview only or real encoding?
Are you under Windows 8 or 10?
tormento is offline
Old 24th June 2016, 14:42   #1823  |  Link
DJATOM
DJATOM's Avatar
Preview in avspmod.
Windows 7 Ultimate.
DJATOM is offline
Old 24th June 2016, 14:58   #1824  |  Link
Reel.Deel
Here is the original sample from BD.
When I use AviSynth+, I have image corruption.
13HoursAVS+.dgi
PHP Code:
SetMemoryMax(8000)
SetFilterMTMode("DGSource"3)
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursAVS+.dgi")
#SetFilterMTMode("DGSourceIM", 3)
#LoadPlugin("D:\eseguibili\media\DGDecIM\x64\dgdecodeim.dll")
#DGSourceIM("E:\in\2_24 13 hours — The secret soldiers of Benghazi\13HoursCUT.dgi", silent=true)
#Crop(0, 140, 0, -140)
Prefetch(8
I also cannot reproduce the corruption. I tried the script exactly as is. However, if I randomly seek multiple times back and forward to random spots it makes VDub freeze. The script finishes without problems in AvsMeter though. No problems in VDub's 'Run video analysis pass' also. What version of SMDegrain are you using? I'll do a bit more testing over the weekend.
I'm using Windows 7, with Windows 10 some problems have been reported:
Originally Posted by Khanattila View Post
FAQ
  • Q) I can't make DGNV and KNLmeansCL work together in avs script.
    A) Post #650, Post #664.
Reel.Deel is offline
Old 24th June 2016, 15:05   #1825  |  Link
tormento
Acid fr0g
tormento's Avatar
Preview in avspmod.
Windows 7 Ultimate.
Problems arose with Windows 10, AFAIK.
Try to do a real encode.
tormento is offline
Old 24th June 2016, 15:08   #1826  |  Link
tormento
Acid fr0g
tormento's Avatar
Latest. To make it work with x64 I had to do little tunings for prefilter=2.
FAQ
It works in a pure x64 environment. Moreover, the same behaviour happens with DGIndexIM.
P.S: I have tried AVSPmod_x64 in a pure x64 environment. Corruption happens in frame 24 and others.
Thanks for reporting me that on obsolete OS, it works. And, ABOVE ALL, try it in a pure x64 environment.
tormento is offline
Old 24th June 2016, 15:31   #1827  |  Link
DJATOM
DJATOM's Avatar
http://www114.zippyshare.com/v/zj9xTEWa/file.html
DJATOM is offline
Old 24th June 2016, 16:21   #1828  |  Link
tormento
Acid fr0g
tormento's Avatar
Not windows 10
tormento is offline
Old 24th June 2016, 16:28   #1829  |  Link
DJATOM
DJATOM's Avatar
Indeed, I just don't want to use the worst OS ever.
DJATOM is offline
Old 24th June 2016, 17:21   #1830  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by djatom View Post
indeed, i just don't want to use the worst os ever.
omg lol
tormento is offline
Old 25th June 2016, 18:43   #1831  |  Link
pinterf
Artifact hunting mode ON
Reproduced.
Converted the .h264 into mp4 with ffmpeg because I couldn't get work any dgdecxxx.
Find my input source here
Script:
SetFilterMTMode("DEFAULT_MT_MODE", 2)
SetFilterMTMode("lsmashvideosource", 3)
lsmashvideosource("13HoursCUT.mp4", format="YUV420P8")
Prefetch(8)
Let's edit SMDegrain.avsi.
We remove and simplify the non-relevant lines (assuming the SMDegrain calling parameters)
So we replace the whole
pref=eval(""" ......
part with
NL_in   = input8.Dither_convert_8_to_16()
NL_W    = width(NL_in)
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
NL_lsb  = StackVertical(StackVertical(Dither_get_msb(u8),Dither_get_msb(v8)),\
                        StackVertical(Dither_get_lsb(u8),Dither_get_lsb(v8)))
Y8      = StackHorizontal(ConvertToY8(NL_in),NL_lsb)
#PF remark:
# We created a big image, assuming that U and V is half the height in YV12
# Y8:
# Y_msb U_msb
# Y_msb V_msb
# Y_lsb U_lsb
# Y_lsb V_lsb
Y8      = Y8.KNLMeansCL(D=1, A=1, h=7.0,lsb_inout=true,device_type="GPU") # D=0/1 nochange GPU/CPU:nochange
u_h = u8.height()/2
v_h = v8.height()/2
u16 = StackVertical(Dither_get_msb(Y8).crop(NL_W,0,0,-v_h),Dither_get_lsb(Y8).crop(NL_W,0,0,-v_h))
v16 = StackVertical(Dither_get_msb(Y8).crop(NL_W,u_h, 0,0),Dither_get_lsb(Y8).crop(NL_W,u_h, 0,0))
pref=YToUV(u16,v16,Y8.crop(0,0,-u8.width(),0))
Ok. Now let's comment out the KNLMeansCL call.
Y8=Y8#.KNLMeansCL(D=1,A=1,h=7.0,lsb_inout=true,device_type="GPU")
No more artifact.
I don't know how KNLMeans work but the idea that all planes are stuffed into one greyscale image and is sent to the plugin may fail sometimes.
Now I really wonder why only avs+ is affected.
pinterf is offline
Old 25th June 2016, 19:14   #1832  |  Link
Reel.Deel
I think the script is doing that because KNLMeansCl does not process chroma unless the input format is YV24 or RGB. I wonder why Dogway didn't separate the planes, process them indivdually, and then merge them?
I wish I could help but I still cannot reproduce the corruption even with the simplified script. :/
Are you using Windows 10?
Old 25th June 2016, 19:27   #1833  |  Link
pinterf
No, Win7Prof.
Built a special avisynth.dll in which I switched off SSE3 and newer cpuid detection but the problem remained.
pinterf is offline
Old 25th June 2016, 19:53   #1834  |  Link
pinterf
O.K.
Still smdegrain.avsi, Dither_Luma_Rebuild
Replaced the line with 56064 (219*256) with 61184 (239*256)
(and the 219 with 239 but it does not play now).
The artifact disappeared.
There is another thing that may not be intentional:
String(lsb?65536:255)
For me 65535 would be more logical, but I'm far from fluently reading the avisynth expression syntax
function Dither_Luma_Rebuild (clip src, float "s0", float "c",int "uv", bool "lsb", bool "lsb_in", bool "lsb_out", int "mode", float "ampn", bool "slice"){
lsb_in  = Default( lsb_in  ,false)
lsb_out = Default( lsb_out ,false)
lsb     = Default( lsb     ,lsb_in || lsb_out)
mode    = Default( mode ,6)
uv      = Default(uv,    3)
s0      = Default(s0,  2.0)
c       = Default(c,  1.0/16)
ampn    = Default(ampn, 0.0)
slice   = Default(slice, true)
    k = (s0 - 1) * c
    t = lsb_in ? "x 4096 - 61184 / 0 1 clip" : "x 16 - 239 / 0 1 clip"
#    t = lsb_in ? "x 4096 - 56064 / 0 1 clip" : "x 16 - 219 / 0 1 clip"
    e = String(k)+" "+String(1+c)+" "+String((1+c)*c)+" "+t+" "+String(c)
\       +" + / - * "+t+" 1 "+String(k)+" - * + "+String(lsb?65536:255)+" *"
src
lsb ? (lsb_in ? Dither_lut16 (yexpr=e,expr="x 32768 - 32768 * 28672 / 32768 +",y=3, u=uv, v=uv)   : \
                Dither_lut8  (yexpr=e,expr="x 128 - 32768 * 112 / 32768 +"    ,y=3, u=uv, v=uv))  : \
                mt_lut       (yexpr=e,expr="x 128 - 128 * 112 / 128 +"        ,y=3, u=uv, v=uv)
lsb_out ? last : (lsb ? Ditherpost(mode=mode,ampn=ampn,slice=slice,staticnoise=ampn!=0.0?true:false,u=uv,v=uv) : last)}
I don't know what is the right constant there, the creators of this script can correct it for the right value.
pinterf is offline
Old 25th June 2016, 21:34   #1835  |  Link
pinterf
Or 220*256-1? instead of 219*256? Anyway it can be different rounding in evaluation than in classic avisynth?
pinterf is offline
Old 25th June 2016, 21:39   #1836  |  Link
Reel.Deel
Have you look at cretindesalpes original script: http://forum.doom9.org/showthread.ph...18#post1548318
Old 26th June 2016, 02:16   #1837  |  Link
real.finder
this with TV_range bool http://pastebin.com/vz6Ewuvv
# In a more lucid state I could probably have laid out this block much better... or not...
NL_in   = Dither_convert_8_to_16()
NL_W    = width(NL_in)
U8      = UToY8(NL_in)
V8      = VToY8(NL_in)
NL_lsb  = StackVertical(StackVertical(Dither_get_msb(u8),Dither_get_msb(v8)),StackVertical(Dither_get_lsb(u8),Dither_get_lsb(v8)))
u_h = u8.height()/2
v_h = v8.height()/2
prefilter4 = YToUV(u16,v16,Y8.crop(0,0,-u8.width(),0))
try first
SMDegrain (tr=4,PreFilter=prefilter4,TV_range=false,thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8)
then try
SMDegrain (tr=4,PreFilter=prefilter4.SmoothCustom16("Y>60160?y:y","u>61440?u:u","v>61440?v:v",limiter=true),thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8)
and
SMDegrain (tr=4,PreFilter=prefilter4.Ditherpost(mode=6,ampn=0.0,staticnoise=false).Limiter(),thSAD=400,contrasharp=false,refinemotion=false,plane=4,chroma=true,lsb=true,mode=6)
Prefetch(8)
See My Avisynth Stuff
real.finder is offline
Old 26th June 2016, 18:37   #1838  |  Link
The typical "ternary operator" (boolean_expression ? true_case_result : false_case_result)... inside a function of a C-like language, you could expand this to:
if(lsb) return String(65536); else return String(255);
LigH is offline
Old 26th June 2016, 18:44   #1839  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
@ultim or someone
I have a question about multi-threading.
Is it possible to implement a temporal IIR filter as MT_NICE_FILTER ?
my repositories
Chikuzen is offline
Old 26th June 2016, 19:07   #1840  |  Link
real.finder
he mean the value, 65536 is full 16 bit range, 256 is full 8 bit range, so he say that it should (65536 -1) like (256 -1)
