Old 16th March 2009, 19:57   #4501  |  Link
topsham
Help! What's happening please?
I have just installed the latest version using Ajax's installer and on my first job, just before I get to the configuration screen Media Player Classic pops up with the following message: DirectShowSource : Timeout waiting for graph to start. (J:\temp\RipBot264temp\job1\getinfo.avs, line 2)
Can someone advise what the problem is please?
topsham is offline   Reply With Quote
Old 16th March 2009, 23:18   #4502  |  Link
jhmac
jhmac's Avatar
Hey I just found this program BDSup2Sub v1.9 and it works great in conjunction with RipBot264 to get subs working. You must have Java installed. It is very fast and also supports commandline so maybe it could be added as a tool in RipBot264.
Heres a link: http://forum.doom9.org/showthread.php?t=145277
jhmac is offline   Reply With Quote
Old 17th March 2009, 16:55   #4503  |  Link
ricky man
the program was working fine on win 7 32bit & 64bit. when i refromated and reinstalled win 7 ,i started to get the error msg as Topsham. i am running the same win 7 as before. so dont know why i get this error msg when i dont have it before.
ricky man is offline   Reply With Quote
Old 17th March 2009, 22:20   #4504  |  Link
Joe-RequiresJob
Originally Posted by laserfan View Post
According to this page, there are 1,463,386,112 bytes in a miniDVD, therefore the number of megabytes is 1,463,386,112/1,048,576(number of bytes in a MB)=1395.59375MB
Since Atak has rounded down from 4482+ to 4480, and 8152 to 8150, if I were you I'd try rounding down to 1393 or 1394.
P.S. To be absolutely precise about your particular media, you should look at what ImgBurn has to say about its precise capacity in bytes, then divide by 1,048,576 as above.
Thanks for that - I will go for 1390 to be on the safe side!
Joe-RequiresJob is offline   Reply With Quote
Old 18th March 2009, 05:50   #4505  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
We may need more info.. When do you start getting that Error?
~DarC
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 18th March 2009, 06:26   #4506  |  Link
ricky man
~DarC
i started getting error right after reinstalling win 7. i installed ffdshow , haali splitter and avisynth. then ran ripbot264 and i getting directshow error. however i got an error when doing bourne ultraim blu-ray but it works fine with converant blu-ray. bourne ultraim video is vc-1 and converant is mpeg2.
i can use ripbot with bourne with vista just not win 7.
Old 18th March 2009, 09:13   #4507  |  Link
Ajax_Undone
Can you post the log. It should be in the log folder inside the folder that ripbot264 is installed. (ie ripbot264\logs\Log.log) (Ill bet it a security problem with Win7.) Are you running the latest build or the beta.
It might have something to do with the patched UAC...
~DarC
My Installer's ||
Old 18th March 2009, 15:51   #4508  |  Link
ricky man
Since i cannot send you the log.log because there isn't a log when i got the message. but i can send you the getinfo.avs and video-log.log file to see what is wrong with it. I installed windows 7 build 7057 right now. this is when i got the same error msg " DirectShowSource : Timeout waiting for graph to start. (J:\temp\RipBot264temp\job1\getinfo.avs, line 2)." when i try to encode again.
i dont know if it is true, i just tried another vc-1 movies. Ripbot still say the same error msg about Directshow. is there anyway i can fix the error msg for vc-1.
this is this what is inside the avs file:
video=DirectShowSource("F:\temp\RipBot264temp\job1\video.mkv",audio=false).ConvertToYV12()
LoadPlugin("C:\Program Files\RipBot264v1.13.3\tools\AviSynth plugins\NicAudio\NicAudio.dll")
audio=NicDTSSource("F:\temp\RipBot264temp\job1\audio.1.dts")
AudioDub(video,audio)
WriteFile("F:\temp\RipBot264temp\job1\info.txt","Framecount")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","Framerate")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","AudioRate")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","AudioChannels")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","AudioLength")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","Width")
WriteFile("F:\temp\RipBot264temp\job1\info.txt","Height ")
Trim(0,-1)
File Type: txt video - Log.txt (838 Bytes, 16 views)
Old 18th March 2009, 20:15   #4509  |  Link
Ajax_Undone
Post the Video - log.log info... Attachments are don't work... Open up the log with notepad or other text editor copy whats in side then post it... Use the [Code][/code] Tags.
~DarC
My Installer's ||
Old 18th March 2009, 20:28   #4510  |  Link
ricky man
eac3to v3.12
command line: "C:\Program Files\RipBot264v1.13.3\Tools\eac3to\eac3to.exe" "E:\b3.m2ts" 1: "F:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 2: "F:\temp\RipBot264temp\job1\audio.1.dts" -core -progressnumbers
M2TS, 1 video track, 1 audio track, 1:55:19, 24p /1.001
1: VC-1, 1080p24 /1.001 (16:9)
2: DTS, English, 5.1 channels, 24 bits, 1509kbps, 48khz
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[v01] Muxing video to Matroska...
[a02] Creating file "F:\temp\RipBot264temp\job1\audio.1.dts"...
[a02] The last DTS frame is incomplete and thus gets skipped. <WARNING>
Added fps value to MKV header.
Video track 1 contains 165899 frames.
eac3to processing took 12 minutes, 38 seconds.
Done.
Old 18th March 2009, 22:28   #4511  |  Link
I have no problems with vc-1 streams on my laptop (windows 7 build 7000). make sure wmv9 decoder is set in ffdshow for vc-1
Old 18th March 2009, 22:49   #4512  |  Link
ricky man
i have try to enable it for vc-1. and i still have the same error.
i am wondering what version of ffdshow and haali splitter and avisynth do you install in order to work?
Old 18th March 2009, 22:59   #4513  |  Link
vc-1 decoding should work even without ffdshow because Vista and Windows 7 have microsoft's decoder installed by default.
Try to install this http://www.free-codecs.com/Windows_M...1_download.htm
Old 18th March 2009, 23:17   #4514  |  Link
ricky man
should i uninstall haali to see if it works or not?
Old 18th March 2009, 23:26   #4515  |  Link
don't uninstall anything. Maybe you should go back to build 7000? Like I said before. I have absolutely no problems. (as always BTW
Old 18th March 2009, 23:33   #4516  |  Link
ricky man
are you using windows 7 32bit or 64bit?
Old 18th March 2009, 23:42   #4517  |  Link
32bit
Old 19th March 2009, 00:05   #4518  |  Link
Ajax_Undone
I am using x64 with no problems so it has nothing to do with architecture.
My Installer's ||
Old 19th March 2009, 01:16   #4519  |  Link
Killerattacks
I just started using Ripbot and imho it's the best tool among all the conversion tools I have tried. Thanks for this great application
And if I might ask a question, I noticed that when ffdshow isn't the h264 decoder with the highest priority (I'm using the DivX decoder), then the framereate-detection fails. Just wanted to know if this behavior is intended. It's no big issue. And thanks again!
(My System: Vista 64, CCCP and DivX 7 H264 Decoder)
Killerattacks is offline   Reply With Quote
Old 19th March 2009, 01:41   #4520  |  Link
Blame DivX guys Therefore I prefer ffmpeg-mt
