#12501 | Link |
Atak... You should consider working on enabling drag and drop for the batch window
![]() Loving this app more and more every day as I am gettiing more and more PC's networked to use. Up to 4 now. Today should add another one. This really helps me cut down on the size of my home videos. |
#12503 | Link |
yes if your keyboard is still working
#12507 | Link |
Hello guys once again.
I'm having difficult encoding this sample (40 mb) http://www12.zippyshare.com/v/15596813/file.html It is interlaced and I don't know how to deinterlace it. Also I'd like to know which is the best crop for it. Just think I didn't crop it well becouse of the age of the movie (maybe a different AR then usual old movies) I can't solve it by myslef so please help! |
#12508 | Link |
The source looks like this (PROGRESSIVE FRAME and INTERLACED)
PP I PPP I PPP I PP II I think you will have to accept duplicated frames because this movie was originally recorded at 12 - 15 fps.(I'm guessing). So you will have to use TFF -> 29.97 fps.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th June 2013 at 15:40. |
#12509 | Link | ||
They say: Quote:
PP I PPP I PPP I PP II - What's the place I should enter this code for deinterlacing? |
#12510 | Link |
Correction. It turns out that Inverse Telecine + Decimate may work better. You will still have one duplicated frame due to original fps (22 fps vs 23.976 fps)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 18th June 2013 at 20:03. |
#12511 | Link |
Just a quick question, which is the newest RipBot Version where I have the Codec Settings like in this picture: http://www.videohelp.com/toolsimages/ripbot264_1039.jpg
and not with the --x264 parameters? Thanks in advance. |
#12512 | Link |
1.16.x if i'm not wrong
#12516 | Link |
More audio option(s) required!
Hi, to all, but to "Atak" expecially!
Rip-bot video options are really sufficient. (Without 4K yet!) But, how about adding more sound options? I want to see choosable bitrate options not only for aac upto 256bit with the latest build. For example my mobile phone Sony xperia Z doesn't support aac. With software aac codec from MX Player causes jumps, not stable, or the proccesor power is not sufficient. I need to re-use BeLight to convert aac to ac3. Why not adding just a couple of more audio options inside audio menu? ![]() (By the way, I am waiting to see 4K support soon...) Last edited by blacksapprow; 22nd June 2013 at 08:39. |
#12517 | Link |
Hmmm, Ripbot doesnt appear to like my new Haswell CPu chip that much, causes my PC to BSOD, but other encoders dont. Seems to use use 100% cpu load on all the cores as well, but again other encoders dont use anywhere neat 100% load
#12519 | Link |
your cpu or memory is unstable . see first post for appropriate diagnostic tools.
#12520 | Link | |
and Xperia Z does support AAC |
