#14301 | Link | |
Hi burt123!
1. No itīs not, itīs a AMD3+ running at originaly @ 4,7Ghz 2. Inside is pretty Clean and case is open all the time. Also had the idéa of it gettin overheated, but have changed the CPU Fan, Motherboard also tryed differnt ramīs just to figure out what could be wrong, and this only happens with RipBot264 when it runs 100% of all cores on the CPU. After Writing this Q last night I started a new rip with only 4 cores activated just to see how it worked and adjusted it to 6/8 cores just Before 2-pass started, and PC keeps going without any crash/Freez! ![]() ![]() ![]() image hosting free But would be easyer to be able to set the nr. of cores to be used from within RipBot264 otherwise one have to set it manually everytime RipBot264 starts. ![]() Regards MaistroX Quote:
#14302 | Link |
If this crash is related to x265, you can add '--pools 6' option to x265 command line. If it helps, you can try '-F2' option instead of '--pools 6' (if '-F2' helps, you can also try to use x265 compiled by VS 2015 instead of GCC 5.3).
#14305 | Link |
@Maistrox
What happens if you run LINX from first post for couple minutes? Check cpu temps during strest test. CPU should be rock stable even at 100%.
#14306 | Link |
Just tryed that and the result is here ->
![]() windows screen capture Also, just finnished a encode with RipBot264 and set the cores to 6/8, that worked just fine. Regards MaistroX |
#14308 | Link | |
https://github.com/sanekgusev/LinX-o.../LinX-0.6.5.7z Regarding --threads. By default x264 on your CPU uses 12 threads (8 * 1.5). You may also try --threads 8 instead of 6.
#14309 | Link | |
I will try 0.6.5 also, just finnished a 5 step test with ALL RAM avalible and biggest Problem Size, see here ->
![]() image hosting over 5mb with the following log: " Intel(R) LINPACK 64-bit data - LinX 0.6.4 Current date/time: Mon Mar 21 13:35:50 2016 CPU frequency: 4.690 GHz Number of CPUs: 8 Number of threads: 8 Parameters are set to: Number of tests : 1 Number of equations to solve (problem size) : 60083 Leading dimension of array : 60088 Number of trials to run : 5 Data alignment value (in Kbytes) : 4 Maximum memory requested that can be used = 3113540512, at the size = 60083 ============= Timing linear equation system solver ================= Size LDA Align. Time(s) GFlops Residual Residual(norm) 60083 60088 4 3864.765 37.4164 3.101542e-009 3.065849e-002 60083 60088 4 3892.257 37.1521 3.101542e-009 3.065849e-002 60083 60088 4 3906.159 37.0199 3.101542e-009 3.065849e-002 60083 60088 4 3906.839 37.0135 3.101542e-009 3.065849e-002 60083 60088 4 3924.515 36.8468 3.101542e-009 3.065849e-002 Performance Summary (GFlops) Size LDA Align. Average Maximal 60083 60088 4 37.0897 37.4164 End of tests " Regards MaistroX Quote:
#14310 | Link |
I've recently been encoding using H265 but am getting much bigger files sizes than expected, with only a small decrease from the original BR rip. I use CQ and CRF set to 16, profile is [High 4.0] FHD. Progressive. Taking a 20.2GB video file (sound tracks removed) H265 ends up at 24.4GB and H264 ends up at 15.7GB using the same settings.
I thought one of the big improvements with H265 was a reduction in file size, am I misunderstanding or do I just have CRF set to low? I watch on a 120" screen so like to keep good quality. PS. MaistroX, try lots of different stress tests, recently overclocking my X99 rig it would crash on one particular stress test but not another, and I had to increase the voltage slightly, by reducing the core count your reducing the load and thus the voltage won't drop so much. Video transcoding is considered by many as a form of stress testing. Last edited by Ronski; 22nd March 2016 at 21:55. Reason: Quoted wrong size starting file. |
#14311 | Link |
I've never used the x265 but I understand the standard crf values for the two encoders to generate the same visual quality are quite different. ie, you are using a high value.
x264 default = CRF23 x265 default = CRF28 |
#14313 | Link | |
Got to say I've just had one of those moments that makes you smile. I have an old i750 running at 3.6Ghz and my new X99 5820K running at 4.5Ghz. Now I had 1 encoding server on the i750 and two on the X99, I'm now running 6 encoding servers on the X99, each time I added a server the FPS increased, tried adding another on the i750 and it made no difference, but boy it does work well on the X99. Currently cruising at just over 43FPS between them all in H265, gained about another 10FPS by adding the 4 additional servers. Last edited by Ronski; 22nd March 2016 at 21:57. |
#14314 | Link | |
We need more servers, Atak ![]() |
#14315 | Link |
I do not have conditions to run that way then do my conversions using my old 980X, or 4790K. Lately I have used only the 4790K for this kind of work because it is slightly faster and consumes less power.
Let them work and go to sleep. |
#14316 | Link |
Atak, is there any way to include a setting to have the first pass handled by one machine for the entire file and then split the file (and stats file) into chunks for distributed encoding? I've been testing with the current distributed encoding but am seeing massive bitrate drops in high action scenes where the scene fell into different chunks. I'm hoping that a first pass pre-chunking would allow for proper bitrate determination relative to the file as a whole before encoding. This will obviously bottleneck the process to the speed of the server doing the first pass, but is more ideal since it yields a better encode in the end.
#14317 | Link |
I think It would be better if you increased chunk size from 1 min to old 10 min value. This method would be much faster than first pass on single machine.
#14318 | Link |
I'll give it a try but the problem would still remain if the action scene falls at the 10 minute mark and is split and the second chunk has an otherwise low level of action (so lower average bitrate). Also, since most shows aren't exactly a multiple of 10, the last chunk will always be smaller and might present the same issue. Unless I'm missing something and there is some error handling for that.
#14319 | Link | |
I have no problems with 8C / 16T CPU even with cropped frame (1920x800). ![]()
#14320 | Link | |
Last chunk is always the biggest. Otherwise We could end up with 1 frame chunk ![]() Longer chunk sizes should help in better bitrate distribution (less aggressive)
