Old 29th July 2009, 16:04   #2061  |  Link
mopurist
Originally Posted by Trahald View Post
@mopurist
Hmm... i couldnt duplicate the issue, but i'll keep trying.
Except for wasting a few bits.. rev 13 of the patch is fine to use.
Thanks for taking a look.
Unfortunately, 13 doesn't apply cleanly to latest git (x264.c changes) and my work schedule will leave me only an hour or so each day to check it out.
I did notice that if I don't specify --fps (with version 15 of the patch) I don't get the assertion failure. But it assumes 25fps, which is incorrect, and seems to encode at about 1/4th the rate that I was previously getting with x264+hrd version 9 from several months ago.
mopurist is offline   Reply With Quote
Old 29th July 2009, 16:10   #2062  |  Link
imk
|ン、)
imk's Avatar
x264-r1195M-imk-win.7z
win_build_info.txt
imk is offline   Reply With Quote
Old 29th July 2009, 17:21   #2063  |  Link
Trahald
Wewkiee
Trahald's Avatar
@mopurist
http://forum.doom9.org/showthread.ph...66#post1306166 <-the 13 in this post. it was modified by one of the other builders to patch post preset era x264.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 29th July 2009, 18:30   #2064  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1195 64bit unpatched:
download ; hash
  • built on Jul 29 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
  • fprofiled, otherwise defaults
________________________________________________________________________________
x264 r1195 32bit
download ; release notes
  • built on Jul 29 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
  • fprofiled, -march=i686
x264 r1195 64bit
  • fprofiled, -march=core2
patched with:
  • x264_win_zone_parse_fix_05.diff
  • x264_hrd_pulldown.15_interlace.diff
[I'm human, no debug]
Old 29th July 2009, 21:31   #2065  |  Link
moviefan
I'm using Techouse's build r1195 and I'm still getting the same error "This application has requested the Runtime to terminate in an unusual way. Please contact the application's support team for more information." using subme 10. Something is seriously wrong... The last working revision for me was r1187 (I think).
moviefan is offline   Reply With Quote
Old 29th July 2009, 21:32   #2066  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
I can't do anything without a gdb backtrace, sorry.
Old 29th July 2009, 21:40   #2067  |  Link
moviefan
Do I need to compile x264 for performing the backtrace with gdb? I have never done this before... Or is it too difficult do it right away for the first time?
Old 29th July 2009, 21:51   #2068  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
x264 w/ debug symbols
you can use this with mingw's gdb and provide a backtrace upon the crash (if it does still crash)
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 29th July 2009, 21:59   #2069  |  Link
moviefan
OK, what's this? ".../gdb/dwarf2read.c:985: gdb-internal-error: read_comp_unit_head: dwarf from non elf file" "An internal GDB error was detected. This may make further debugging unreliable."
Old 29th July 2009, 22:03   #2070  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
A. if you aren't already, be sure to be using mingw gdb 6.8-3
B. if you are, then post a sample that you can consistently crash with and the command line you're using to cause the crash.
Old 29th July 2009, 22:06   #2071  |  Link
Dark Shikari
x264 developer
gdb --args ./x264_debug_build --all --your --normal --options
<it crashes>
bt
Old 29th July 2009, 22:06   #2072  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Maybe a problem with "SJLJ" -vs- "Dwarf-2" Unwinding?
Old 29th July 2009, 22:08   #2073  |  Link
moviefan
A. is the problem. I used the current gdb version of DevCpp which is old. Do I have to run x264 in the gdb environment with my current x264 settings? So is this like a normal encode only under supervision of gdb?
Old 29th July 2009, 22:09   #2074  |  Link
LoRd_MuldeR
Software Developer
Do it like proposed here:
http://forum.doom9.org/showpost.php?...postcount=2071
BTW: You may need to type "run" or "c" to make the program start/resume until it crashes...
Old 29th July 2009, 22:11   #2075  |  Link
moviefan
Sorry, parallel posting
I'll report back when results have arrived.
Edit: Sorry, it's strange... Now gdb says, "gdb: unrecognized option --threads"
Edit2: Oh, @DarkShikari: --args was meant literally... now it works, but I get massive output in the console. Does it terminate and show the error, when there is an abnormal termination? kemuri-_9's debug build does not include the --nal-hrd patch, so the situation is not identical to my crash situation.
Edit3: I got to go to bed, exam tomorrow, but I'll post the results in about 8 hours. Encoding is slow, duplicating the encoding situation (1 fps...), but it'll probably have crashed by tomorrow morning (if it crashes).
Old 29th July 2009, 22:53   #2076  |  Link
LoRd_MuldeR
Software Developer
Yes, Avisynth spams the gdb console with debugging messages
But if x264 crashes, gdb will interrupt, show an error message and return to the propmpt. Then you can type "bt" to get a stacktrace, so we see where exactly it crashed.
If that doesn't happen, the crash simply doesn't occur with kemuri's debug build.
Good luck !!!
Old 30th July 2009, 08:10   #2077  |  Link
moviefan
x264 crashed.
"Program received signal SIGSEGV, Segmentation fault. [Switchting to thread 2268.0x20c] 0x6fb775f6 in libavcodec!dspuitl_init () from ...\DGAVCDec\libavcodec.dll"
Hm, it seems, that x264 is OK and DGAVCDec is the problem, right? Strange, since I had done encodes with exactly the same .dga-file and exactly this DGAVCDec version.
Good luck !!!
Thanks, I hope it'll be good. Stochastic processes...
Old 30th July 2009, 09:42   #2078  |  Link
LoRd_MuldeR
Software Developer
When the "Segmentation fault" happens, type bt to get a Stacktrace and post the result back here...
Old 30th July 2009, 18:44   #2079  |  Link
moviefan
Hm, I did type bt at that point, but it didn't reveal any new information. There were some thread messages (or whatever they are) and the message about libavcodec. What should have been written there? In case, I missed something, I will repeat the backtrace.
Old 30th July 2009, 18:56   #2080  |  Link
Dark Shikari
x264 developer
You were able to backtrace but you can't paste the results here so we can read them?
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
