Old 16th December 2010, 01:35   #3421  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
it should be noted that for those that are doing comparisons of pthread-win32 threading against native windows threading that the windows threading takes different codepaths depending on the version of windows:
A) 2000/XP
B) Vista/7/(anything beyond this)
as such, comparing pthread-win32 against win32thread should take this into account.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 16th December 2010, 02:16   #3422  |  Link
aegisofrime
Any improvement no matter how small is welcomed
Thanks rack04 for the 64-bit builds. Neither x264.nl nor fushizen has them yet.
aegisofrime is offline   Reply With Quote
Old 16th December 2010, 02:23   #3423  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
A) 2000/XP
May I ask: What was the main motivation to implement support for native Win32 threads? Speedup? Getting rid of pthreads?
Old 16th December 2010, 02:53   #3424  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
pthread-win32 is LGPL, this causes a conflict with --disable-gpl x264 builds.
it was not done for performance reasons.
though since we were doing it, might as well use windows for all its worth when it's available (for vista+ platforms) so there might be a very small performance increase there.
[Edit]
the windows threading might be more important later when support for windows 7 x86_64's (and similar/later x86_64 platforms) way of handling systems with over 64 logical cores is added
(yes, microsoft totally made things a bit odd to extend support to 256 logical cores on the x86_64 systems starting with 7/server 2008 R2).
[/Edit]
Old 16th December 2010, 02:56   #3425  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
No it doesn't. Even a commercial x264 can link fine with LGPL libs.
It caused a conflict with a customer who didn't like LGPL libs
Old 23rd April 2011, 08:47   #3426  |  Link
upyzl
zj262144
upyzl's Avatar
Excuse me, is it still worth patching ME-prepass(#5) now? (or can the patch be available now? Of course manually -- ignore patch's line numbers)
Because of large changes in x264, I want to patch it myself manually
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14
Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated)
upyzl is offline   Reply With Quote
Old 24th April 2011, 04:08   #3427  |  Link
upyzl
zj262144
upyzl's Avatar
...and another question
Is ME prepass patch (rev 680, #1) the latest?
Old 21st July 2011, 05:43   #3428  |  Link
Kurosaki Ichigo
Kurosaki Ichigo's Avatar
Hi there, I'm new. I don't know if I'm writing in the right place. I have a problem with Lagarith Lossless Codec. I tried the 1.3.2.0 version and the last 1.3.2.5, but when the process finished, the output file is too small
This is the source RAW
General
Unique ID                        : 235762869933910293037496416019526284763 (0xB15E46EFE5A7B520951159776D4175DB)
Complete name                    : J:\[IM9 & FTF] RAW Anime\Freezing\[Yousei-raws] Freezing 01 [BDrip 1920x1080 x264 FLAC].mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 2.26 GiB
Duration                         : 23mn 41s
Overall bit rate                 : 13.6 Mbps
Encoded date                     : UTC 2011-04-02 07:30:50
Writing application              : mkvmerge v4.6.0 ('Still Crazy After All These Years') сборка от Mar 10 2011 02:50:32
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Muxing mode                      : Header stripping
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 23mn 41s
Nominal bit rate                 : 12.9 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.259
Writing library                  : x264 core 114 r1924 08d04a4
Encoding settings                : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=12860 / ratetol=1.0 / qcomp=0.65 / qpmin=9 / qpmax=32 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=30000 / vbv_bufsize=27000 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Language                         : Japanese
Audio
Format                           : FLAC
Format/Info                      : Free Lossless Audio Codec
Codec ID                         : A_FLAC
Duration                         : 23mn 41s
Bit rate mode                    : Variable
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Writing library                  : libFLAC 1.2.1 (UTC 2007-09-17)
Language                         : Japanese
And this, the output with Lagarith, in Full Processing Mode:
General
Complete name                    : J:\Freezing 01.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
Format profile                   : OpenDML
File size                        : 37.5 GiB
Duration                         : 23mn 41s
Overall bit rate                 : 226 Mbps
Writing application              : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                  : VirtualDubMod build 2540/release
Video
Format                           : Lagarith
Codec ID                         : LAGS
Duration                         : 23mn 41s
Bit rate                         : 226 Mbps
Color space                      : RGB
Bit depth                        : 8 bits
Bits/(Pixel*Frame)               : 4.552
Stream size                      : 37.5 GiB (100%)
For what I know about Lagarith, this file size is too small. I don't know if I missed something when installed it. I have the last version of K-lite codec pack for 32 bit, on Windows 7 32 bit without SP1. Anyone Have an idea?
Kurosaki Ichigo is offline   Reply With Quote
Old 21st July 2011, 06:24   #3429  |  Link
@Kurosaki Ichigo
Please read and follow forum rules, especially rule 6 regarding downloaded files, torrents, etc. Further violations will incur strikes.
@all
No help on this. Thank you.
Old 21st July 2011, 06:36   #3430  |  Link
Kurosaki Ichigo
I get it for rule number 6. I'll pay attention in future! ^^ Thanks anyway...
Old 21st July 2011, 06:41   #3431  |  Link
Thank you for your understanding.
Old 21st July 2011, 08:36   #3432  |  Link
Kurosaki Ichigo
Don't say it! It's a rule, it's just normal! ^^
Old 5th December 2015, 18:16   #3433  |  Link
RipFan
Thanks for all the information and effort.
I have only one question, I use Megui 2624 (latest version) downloaded x264 2638 Kmod and replaced it by the "x264_64.exe" that was placed inside megui folder "tools".
My question is: to use a fade_compensate CLI do I have to download the patch as well?
If the answer is yes, where do I have to place this Patch?
Best regards and many thanks once again
RipFan is offline   Reply With Quote
Old 5th December 2015, 19:43   #3434  |  Link
sneaker_ger
The patch file (.diff) is not needed, that's just what the kMod creator used to build x264.exe from.
Old 5th December 2015, 23:14   #3435  |  Link
RipFan
Thanks a lot, just what I nedded to know
Old 6th December 2015, 20:30   #3436  |  Link
benwaggoner
That said, it's been about 8 years since the first post was updated. It'd be nice to have a current version of this thread with up-to-date info.
Ben Waggoner
My Compression Book
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
