Old 15th October 2007, 15:34   #81  |  Link
Gabriel_Bouvigne
L.A.M.E. developer
Gabriel_Bouvigne's Avatar
Originally Posted by wizboy11 View Post
btw, what do the bchanges and bssd patch do?
http://mailman.videolan.org/pipermai...st/003559.html
bssd:
when using --direct auto in multipass mode, in case of tie between direct auto and direct temporal, use SSD as an extra criterion to choose direct mode
Gabriel_Bouvigne is offline   Reply With Quote
Old 15th October 2007, 20:10   #82  |  Link
Sagekilla
x264aholic
Originally Posted by Dark Shikari View Post
Not worthwhile. Proven to give dubious benefits in only some cases.
The --fpel patch with ESA is not much slower than regular ESA and somewhat better, so its "worthwhile" as an insane option.
Useful as a higher-end option in place of using absurd numbers of refs. Can give a roughly 1-3% quality boost with the most recent version.
Pretty much useless with ESA now threaded.
But IMH would be better then ESA if you want a sort of middle ground with not too huge of a speed loss, correct?
Sagekilla is offline   Reply With Quote
Old 15th October 2007, 20:14   #83  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
no... IMH is practically useless. the difference in speed is so small it isnt worthwhile.
Sharktooth is offline   Reply With Quote
Old 15th October 2007, 23:25   #84  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
I agree with these guys here. Sharktooth and Shikari made me realize that it's virtually useless when you now have esa multithreaded.
Terranigma is offline   Reply With Quote
Old 16th October 2007, 01:28   #85  |  Link
Sagekilla
x264aholic
Wow good point.. I just tried out the threaded esa and I must say it's insanely fast!
Old 16th October 2007, 03:24   #86  |  Link
Raere
Will esa's multithreading be useful on single-cores, or is it only good for multi-cores?
Raere is offline   Reply With Quote
Old 16th October 2007, 03:48   #87  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Multicores as usual.
Old 19th October 2007, 04:01   #88  |  Link
Raere
So, imh is still useful on single-cores then?
Old 19th October 2007, 14:21   #89  |  Link
Terranigma
*Space Reserved*
Terranigma's Avatar
Sorta, but who has a single-core processor nowadays?
Old 19th October 2007, 15:09   #90  |  Link
lexor
Aw, my pride...
Lots of people still use single core, I'd hazard a guess, majority is still on single core. (majority in the world, not just on these boards)
Geforce GTX 260
Windows 7, 64bit, Core i7
MPC-HC, Foobar2000
lexor is offline   Reply With Quote
Old 19th October 2007, 16:22   #91  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
single core ppl should not bother using ESA or IMH...
They should stick to saner settings unless they dont care about encoding speed at all...
Old 19th October 2007, 16:28   #92  |  Link
Unearthly
Encoder in Training
Unearthly's Avatar
Not really. The reason IMH was useful before was because it offered higher quality than UMH, but was multi-threaded. At the time, ESA was only single threaded, so the speed difference on a mutli-core systems was very large.
In other words, IMH was never really useful on single core machines. Just use ESA if you want more than UMH.
Unearthly is offline   Reply With Quote
Old 30th October 2007, 13:49   #93  |  Link
SpAwN_gUy
Junglist
SpAwN_gUy's Avatar
i'm sorry...
is there somebody who will update first-post, so all changes to the patches would be more "in one place" and i'd be happy to use them with 681 (as seen on x264.nl)
reason for this: i've noticed some chat about changing option names in Dark Shikari's patches..
Rule Number 6: Concentrate!!!
(c)Hercules, Disney
"I like to build planes.... in the air" (c) some ADV.
tutorials
How to Setup agent-based encoding with x264farm (the easy way)
SpAwN_gUy is offline   Reply With Quote
Old 30th October 2007, 15:15   #94  |  Link
fields_g
x264... Brilliant!
Another idea to add to the OP is limitations of the patch and/or an explanation of why it hasn't been added to SVN. Really help point out the maturity and support of each patch. This might need the help of akupenguin.
fields_g is offline   Reply With Quote
Old 30th October 2007, 16:19   #95  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Subme7 is ready to add to SVN, hopefully it'll be done soon.
ME-Prepass is next.
Old 30th October 2007, 17:49   #96  |  Link
Inventive Software
Turkey Machine
Location: Lowestoft, UK (but visit lots of places with bribes [beer])
From the x264 changelog:
use hex instead of dia for rdo mv refinement. ~0.5% lower bitrate at subme=7.
patch by Dark Shikari.
That the patch you're on about?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 30th October 2007, 18:06   #97  |  Link
Dark Shikari
x264 developer
Yup, that's it.
Old 30th October 2007, 22:50   #98  |  Link
morph166955
Originally Posted by SpAwN_gUy View Post
i'm sorry...
If someone gives me a list of them I'll be happy to update my post.
morph166955 is offline   Reply With Quote
Old 3rd February 2008, 05:48   #99  |  Link
bob0r
Pain and suffering
bob0r's Avatar
x264.736.modified.01.exe
General thread:
http://forum.doom9.org/showthread.php?t=130364
x264_aq_var.48.diff
http://forum.doom9.org/showthread.php?t=132760
x264.gaussian.cplxblur.01.diff
Dark Shikari: - gaussian cplxblur: gives a tiny improvement in 2pass ratecontrol
x264_me-prepass_DeathTheSheep.01.diff
http://forum.doom9.org/showthread.php?p=1093523
x264_2pass_vbv.4.MatMaul.diff
http://mailman.videolan.org/pipermai...ry/004015.html
x264_hrd_pulldown.04.diff
- HRD and pulldown for HD compatibility
Edit:
Link to x264 patches collected: http://files.x264.nl/x264_patches/
bob0r is offline   Reply With Quote
Old 4th February 2008, 15:13   #100  |  Link
bob0r
Pain and suffering
bob0r's Avatar
x264.736.modified.02.exe
General thread:
x264_aq_var.48.diff
http://thread.gmane.org/gmane.comp.v...093/focus=3521
x264_hrd_pulldown.04_interlace.diff
- HRD and pulldown for HD compatibility, updated patch for interlacing
http://forum.doom9.org/showthread.ph...19#post1047919
Edit:
Last edited by bob0r; 6th February 2008 at 00:18. Reason: updated 2pass_vbv.4 patch url
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
