#25821 | Link |
@jdobbs
Maybe a bug?: I have just finished testing a bit the Quick-play menu feature of BD-RB. After importing my complete Tom&Jerry Classic DVD Collection Volume 1. I just wanted to burn them (6xDVD5) directly to a BD-25 media. I have used my own menu page for this job. The bug I recognized described in steps as follows to be able to repeat: - I played an item from the Quick-play menu; - During play I changed audio from English to e.g. Hungarian and the subtitle language to e.g. Hungarian; - After watching 3 items sequentially I entered the Quick-play menu to play an other item from the end; - During watching that one I realized that both the audio and subtitle language had set back to English, however I finished playing the previous item with a Hungarian audio and subtitle language chosen; It seems after entering the Quick-play menu both the audio and subtitle language tracks chosen set back to the defaults due to some unknown reason. If I play items sequentially without entering the menu, the tracks will not be set back. It is not really convenient because each time I enter the menu (for the purpose of playing an other item among the 70-80pcs in this case) and play an other item I have to set back my preferred language manually using my remote controller both for the subtitle and the audio tracks which has already been done previously. Please help. Thank you very much. Last edited by mparade; 9th April 2017 at 17:56. |
#25822 | Link | |
If not what is the fastest setting when not using x264 LAVF ? Also tried replacing the x264L-64 with the x264 version RipBot is using and just renamed it to x264L-64, and encoding with that version of x264 using x264/LAVF as fremserver caused no crashing, ut it had a painfully slow first pass with around 40fps and with the original x264L-64 i get aroud 160fps in the first pass..... |
#25823 | Link | |
![]() Join Date: Oct 2001
My own tests of X264 don't show much difference between X264/LAVF and DirectshowSource -- but different processors can make a big difference. |
#25824 | Link | |
#25825 | Link |
With BDRB, multiple menu items cannot be selected. If you click on one item and then do a ctrl-left-mouse click on another item, the first one is deselected. (Or shift-left-mouse click to select a range of items).
The selection of an item is to allow for editing of the text and potential moving of the item within the menu. If multiple items are selected, just blank the area that is used for text editing until only a single item is selected. This will still allow for the move of the selected items to a new location in the menu. |
#25826 | Link | |
#25827 | Link |
It must be because of something with my personal system or setup, but like when I've used CC Cleaner before, I always have to come back and choose 'instant e'mail notifications' on the threads or I won't get notified. Perhaps whatever happened here had the same effect where in MY case it didn't come back on.
#25828 | Link | |
#25831 | Link | |
Maybe you should even consider adding hidden opts (to help for the Quick-Play Menu to choose the language required at first loading) like: IMPORT_DEFAULT_SUB_LANG=s IMPORT_DEFAULT_AUDIO_LANG=s Your help is much appreciated. |
#25832 | Link | |
On ryzen 8 core cpu the difference is huge... Noticed that when encoding with DirectshowSource x264 32bit version is used, is this normal or am i doing something wrong? Last edited by Denner; 10th April 2017 at 09:11. |
#25835 | Link | |
![]() Thanks for the help so far ![]() |
#25836 | Link |
Yep. I've been occupied by other things and hadn't gotten a message in a bit. Recently I got 2 and there were more than 2 new replies.
#25837 | Link |
A quick update, I found a version of x264, that seemes to be optimal for encoding with Ryzen 8 core cpu's, where I am hitting 40 to 60fps, slowest setting, on the second pass, depending on the encoding bitrate and it almost maxes out all 8 cores in both first and second pass... and most important no crashes....
If any one am having the same problems with Ryzen and bd-rb crashing I would be glad to help and share the x264 version I am using ![]() |
#25839 | Link | |
