#26621 | Link |
I've been doing some testing and I noticed something in the new version. I haven't checked older versions yet. If IVTCFLG=[whatever 0's and 1's] is in a project and there aren't any IVTC switches, IVTC_PULLDOWN=1, ...BD-RB does an IVTC anyway when the project file is reopened. When it's deleted from the file, IVTC isn't done.
#26622 | Link | |
![]() Join Date: Oct 2001
BTW -- that isn't meant to be a user-modifiable item. Last edited by jdobbs; 28th October 2017 at 01:24. |
#26623 | Link |
Oh, okay... I was thinking if there isn't a switch there then perhaps that's a bug. I wasn't meaning to reflect it as user modifiable, merely removed the 0's and 1's...to whatever in the post..not the Project file. Pardon, didn't me to give that impression.
#26624 | Link |
The IVTC can be set in a transient manner (for example, from the list) and could change (like if you exit and reenter BD-RB). All that setting does is record the state of the IVTC selection for each M2TS at the point in time you added it to the batch list or saved it to a project file.
#26625 | Link |
Records the state - right. With it in the Project File (or as the new new INI if edited through BD-RB and the saved), and there aren't any other IVTC switches for BD-RB to notice, it still enabled IVTC. It was once I removed that line that it didn't anymore. IVTC from Setup not active, or any hidden options being used...it still did the IVTC. So, what you mean is with that line there..BD-RB does a logic "It's there...so preform a normal IVTC." Gotcha. I was thinking that should not happen unless it's enabled in Setup or Hidden Opt. You have a built in logic happening I didn't figure into play.
#26626 | Link | |
This is what I mean by a "self inflicted injury". |
#26628 | Link | ||
#26629 | Link |
Haha, I appreciate the comment. I wasn't offended (very challenging to do) at all. I thought you'd missed my point that I understood all that and was only making a comment about a possible bug. As Lathe, I appreciate the further humor. I've used that before at times. Pardon if I seemed bothered. That wasn't my intent.
#26630 | Link |
... and they all lived happily ever after, together in peaceful harmony, gathering each morning at JD's Tinker shop to drink espresso and tell each other little stories of fancy and imagination...
Well, all except Varekai and gonca... sadly they were a little slow and missed the train... ![]() |
#26631 | Link |
Thank you that the me was to no answered to questions below:
A little I'm searched and to internet found same version codec X264, but with other size see. link. http://www.digital-digest.com/softwa...story.html#471 This codec at processing not once no srasch. It is possible codecs version 2665 compare and give here know in what are other and whether it is possible use and me found codec without reduction in quality output videos? Yet I'm found out that the at option "Use DirectshowSource frame serving" at two pass uses latest version codec X264 (file X264.exe) how for frame serving so and for encoding, but at options "Use X264s internal LAVF for frame serving" uses older versuses older version codec X264 (file X264L - 64.exe) how for frame serving so and for encoding. Which option is then for quality better? |
#26632 | Link | |
#26633 | Link | |
#26634 | Link | |
You do remember that he has this condition with anal tweaks, whatever that means |
#26635 | Link | |
![]() That ALONE should be reason for concern... ![]() |
#26636 | Link | |
Lathe, he has a troubled mind and you're the one that trashes you're "wretched self"?? What a hoot! Anyway, back to BD-RB.. I'm processing Game of Thrones S1 D1 BD, and so far it's showing an oversize overall progress, but isn't done. Update: OOps...looks like I left a switch in I shouldn't have. We'll have to retest. Update 2: Removing the switch didn't make any difference. I'll post soon..in more Detail. Time to enjoy Samhain.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 1st November 2017 at 07:10. |
#26637 | Link |
Hi jdobbs and hi dear people I have seven 1080p MKVs movies, that I like to pass it to Bluray but the size of this movies is almost 5gb, 8gb, and I was thinking if Bd rebuilder, in some how can create a fully Bluray with maybe simply menus just for playing each movie?
All I want to do is put on one disc all the seven movies or maybe fourth or less, per disc but can I do that? could you tell me how? Thank you in advance!! |
#26638 | Link | |
2. Use the IMPORT function from the FILE menu. 3. Choose the files you want to import. 4. Edit the popup list to give each the name you want on the menu. 5. Import. This will create a pseudo-BD to use for input. 6. Choose an output size -- and run a full backup. You will end up with a BD structure that can be burned to a disc that matches your selected output size. There are other options you can use, such as choosing a background, background sound, fonts, colors, etc. Last edited by jdobbs; 1st November 2017 at 19:38. |
#26639 | Link | |
The instructions will depend upon you wanting to really keep them on a single 25GB disc, or spread them over two discs. |
#26640 | Link | |
http://www.digital-digest.com/softwa...story.html#471 |
