Old 12th December 2017, 06:19   #26801  |  Link
Lathe
Lathe's Avatar
Try it without the subtitles and see if there any issues at those points
I'm sorry... but, did anyone ask you...?
Old 14th December 2017, 02:45   #26802  |  Link
Video Dude
Senior Member
I have it working -- and in fact have done a couple backups. But there is still a lot of work to be done in automating the entire process and lots and lots of testing. I'm also sure I will find that there is a lot of tweaking to be done when I try more sources. I also have to consider that the holidays are coming up and which I will be entertaining visitors. I'm guessing I might have a UHD-BD version released by the end of the month -- but more probably it will be some time in January.
Will a standalone 4K Ultra HD Blu-ray player accept and play UHD backup discs that are on BD-R 50 discs?
Video Dude is offline   Reply With Quote
Old 14th December 2017, 08:18   #26803  |  Link
MrVideo
MrVideo's Avatar
That is a damn good question, which might be vendor specific.
For example, my Samsung BD players will not accept BD authored material on DVD media.
Old 14th December 2017, 16:18   #26804  |  Link
drmih
I have used dvdfab to compress the same source to bd-50 and bd-25 and both play on an Xbox One S and a Panasonic standalone. However, a Playstation 4 Pro, which supports hdr / uhd (albeit with only a blu ray drive) tries but hangs on a black screen.
Old 14th December 2017, 17:17   #26805  |  Link
Ch3vr0n
what does that have to do with bdrb, this isn't a dvdfab problem thread
Old 14th December 2017, 17:44   #26806  |  Link
drmih
Why don't you spend more time reading the two posts above mine than being a pillock!
Old 14th December 2017, 18:16   #26807  |  Link
4K on BD-50 is part of the standard -- so yes. My Sony standalone also plays 4K on BD-25 -- and I suspect most do.
Old 15th December 2017, 00:15   #26808  |  Link
Lathe
Lathe's Avatar
Old 15th December 2017, 13:24   #26809  |  Link
LowDead
Elit Amans
My Samsung UBD-K8500 have no problem at all with UHD on BD50. Haven't tried BD25 but I don't see why not. What I want to know if anyone of the standalone players accepts BDXL..
//LD
Old 15th December 2017, 14:57   #26810  |  Link
//LD
I suspect UHD on BD-25 will work on every player... as BD-50 is included in the specification, and I don't think players distinguish between BD-25/50 (except capacity, of course). BD-25 plays perfectly on my Sony UBP-X800. Since the spec increased the maximum bitrate on BD for UHD-BD, I'm thinking UHD-BD discs always spin at 2x too, but that's just a guess.
Old 15th December 2017, 15:07   #26811  |  Link
ocean
//LD
Maybe oppo 203 with jailbreak firmware support BD-XL, others standalone i do not know.
@jdobbs
For UHD projects, the disk types are:
BD_50_LTR: this output will 50GB, double layer disc with a maximum allowable bitrate multiplex of 64 Mbps
BD_50_DTR: this output will 50GB, double layer disc with a maximum allowable bitrate multiplex of 81.7 Mbps
BD_66_LTR :: This will produce a 66IT, double layer disc with a maximum allowable bitrate multiplex of 81.7 Mbps
BD_66_DTR: this output will a 66IT, double layer disc with a maximum allowable bitrate multiplex of 109 Mbps
BD_66_HTR: this output will a 66IT, double layer disc with maximum allowed bitrate up to 109 Mbps in the LTR area and 127.9 Mbps in the HTR zone
BD_100_LTR: this output will a 100GB, triple layer disc with a maximum allowable bitrate multiplex of 81.7 Mbps
BD_100_DTR: this output will a 100GB, triple layer disc with a maximum allowable bitrate multiplex of 109 Mbps
BD_100_HTR: this output will a 100GB, triple layer disc with maximum allowed bitrate of up to 109 Mbps in the LTR area and 127.9 Mbps in the HTR zone.
ocean is offline   Reply With Quote
Old 15th December 2017, 15:16   #26812  |  Link
//LD
I have a BD-XL burner and BD-XL rewritable disc -- I'll give it a try. I can say for sure, though, that my BD-XL drive won't read a standard UHD-BD disc.
Old 15th December 2017, 15:22   #26813  |  Link
@ocean -- Thanks. Yeah, I got that and some other good information related to the specification from the "White Paper Blu-ray Disc Read-Only Format (Ultra HD Blu-ray) Audio Visual Application Format Specifications for BD-ROM Version 3.1" which is publicly available for download.
Old 15th December 2017, 15:36   #26814  |  Link
ocean
Thank you for everything you did for all of us, if necessary, I have a compatible system full Blu-Ray UHD: Mainboard ASRock Z270, CPU Kaby Lake I7 7700 iGPU 630, drive Pioneeer BDR-S11J-BK and LG BH16NS55, Samsung UBD-K8500, Xbox ONE X.
Old 16th December 2017, 01:31   #26815  |  Link
LowDead
Elit Amans
Thanks.. And maybe I should say that I tried BDXL on the Samsung but it didn't work.
//LD
Old 18th December 2017, 00:54   #26816  |  Link
I'm still working on the UHD-BD capability in BD-RB -- but I thought some of you might find this post interesting in the meantime.
Merry Christmas!
Old 18th December 2017, 07:41   #26817  |  Link
Acerjen
Merry Christmas to you too, Jdobbs.
Quick question on UHD-BD...when re-encoding video streams to fit onto a BD-25 or BD-50, do you lose HDR or is it somehow retained? Thanks.
Later,
Acerjen
Acerjen is offline   Reply With Quote
Old 18th December 2017, 15:48   #26818  |  Link
Later,
Acerjen
That would depend upon what you are using to serve the frames. But, yes, you can retain it when reencoding with X265.
Old 18th December 2017, 15:54   #26819  |  Link
sneaker_ger
Do you mean x265? x264 cannot set master display information AFAIK.
Old 18th December 2017, 16:24   #26820  |  Link
Yep. My mistake. I corrected it.
