#26871 | Link | |||
IVTC_METHOD=0 causes the green lines with this video and not changing any other deinterlacing settings (default). I removed METHOD from my settings and replaced with IVTC_TELECIDE=0 and that did a great job! There are some "combed" frames but, and seem to be right at the scene change places..and 1 frame that goes by very qickly, so not a big deal. Looks really good at the start of the video and where the ship is and other spots, all smooth. Everything seems smooth except for those single frames. Best output so far...and I've noticed. I'm still checking.
#26872 | Link |
#26873 | Link |
Where I'm from that's called breaking it. We don't soften it with "neutered", like problems are still problems not issues.
#26874 | Link |
MrVideo & JD:
IVTC_480i=1 is doing a great so far but it still leaves some repeat frames. IVTC_TELECIDE=0 does a great job also, but leaves some "combed" frames. Frames with some lines in them. If IVTC_480i and IVTC_TELECIDE would work together, then it would be a great match probably. :-) I use Media Player Classic: Home Cinema x64 for almost all playback desires, including .m2ts.. With Space (Pause) and CTRL+Right/Left Arrows you get great stepping through frames.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 29th December 2017 at 03:46. |
#26877 | Link | |
I then remembered that MakeMKV gives the option to not select the core audio with TrueHD when making the MKV and that's what I had done with Elf. Wondering if that was the problem, I reran MakeMKV on another movie (Wonder Woman) this time keeping the core DD audio with TrueHD audio. But importing that MKV into Rebuilder still errors out in the same way. Hmm...has me stumped. Wonder Woman Mediainfo: Code:
General Unique ID : 94179604944481923328649044234372096176 (0x46DA55068ECAB6181051CC82FD43A0B0) Complete name : /Volumes/500GB/Rip/Wonder Woman.mkv Format : Matroska Format version : Version 2 File size : 25.4 GiB Duration : 2 h 21 min Overall bit rate mode : Variable Overall bit rate : 25.8 Mb/s Movie name : Wonder Woman Encoded date : UTC 2017-12-29 01:18:03 Writing application : MakeMKV v1.10.8 darwin(x64-release) Writing library : libmakemkv v1.10.8 (1.3.5/1.4.7) darwin(x64-release) Original source medium : Blu-ray Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2 h 21 min Bit rate mode : Variable Bit rate : 20.9 Mb/s Maximum bit rate : 30.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.421 Stream size : 20.7 GiB (81%) Language : English Default : No Forced : No Audio #1 ID : 2 ID in the original source medium : 4352 (0x1100) Format : Atmos / TrueHD Codec ID : A_TRUEHD Duration : 2 h 21 min Bit rate mode : Variable Bit rate : 4 279 kb/s Maximum bit rate : 7 509 kb/s Channel(s) : Object Based / 8 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE Sampling rate : / 48.0 kHz Frame rate : 1 200.000 FPS (40 spf) Bit depth : 24 bits Compression mode : Lossless Stream size : 4.22 GiB (17%) Title : Surround 7.1 Language : English Default : Yes Forced : No Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 2 h 21 min Bit rate mode : Constant Bit rate : 448 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 453 MiB (2%) Title : Surround 5.1 Language : English Default : No Forced : No Text #1 ID : 4 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 20 min Bit rate : 31.4 kb/s Count of elements : 3654 Stream size : 31.5 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 6 ID in the original source medium : 4609 (0x1201) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 20 min Bit rate : 22.7 kb/s Count of elements : 2924 Stream size : 22.8 MiB (0%) Language : French Default : No Forced : No Text #3 ID : 8 ID in the original source medium : 4610 (0x1202) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 20 min Bit rate : 25.9 kb/s Count of elements : 3174 Stream size : 26.0 MiB (0%) Language : Spanish Default : No Forced : No Text #4 ID : 10 ID in the original source medium : 4611 (0x1203) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 20 min Bit rate : 27.1 kb/s Count of elements : 3200 Stream size : 27.2 MiB (0%) Language : Portuguese Default : No Forced : No Text #5 ID : 12 ID in the original source medium : 4612 (0x1204) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 19 min Bit rate : 448 b/s Count of elements : 50 Stream size : 459 KiB (0%) Language : French Default : No Forced : No Text #6 ID : 14 ID in the original source medium : 4613 (0x1205) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 19 min Bit rate : 287 b/s Count of elements : 36 Stream size : 295 KiB (0%) Language : Spanish Default : No Forced : No Text #7 ID : 16 ID in the original source medium : 4614 (0x1206) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 19 min Bit rate : 367 b/s Count of elements : 42 Stream size : 376 KiB (0%) Language : Portuguese Default : No Forced : No Menu 00:00:00.000 : en:Chapter 01 00:10:26.917 : en:Chapter 02 00:23:12.557 : en:Chapter 03 00:33:10.738 : en:Chapter 04 00:43:55.132 : en:Chapter 05 00:54:25.553 : en:Chapter 06 01:07:38.262 : en:Chapter 07 01:22:30.195 : en:Chapter 08 01:34:02.845 : en:Chapter 09 01:45:37.998 : en:Chapter 10 01:57:43.765 : en:Chapter 11 02:10:41.416 : en:Chapter 12 |
#26878 | Link | |
#26879 | Link |
"Then take THAT rendered audio file..." -- That doesn't come across as rerendered. That comes across as rejoined. Rerendering is a reconstruction. ;-)
