#30001 | Link |
@Ch3vr0n: WOW Congrats for that!
Anyway here's an update on that file from "The Natural" that gives TSmuxer4k a mild to, at times, severe headaches.. Code:
General ID : 1 (0x1) Complete name : B:\WORK\NATURAL__THE Format : Blu-ray Clip info / Blu-ray Clip info File size : 1.14 KiB Duration : 2 min 8 s Overall bit rate mode : Variable Overall bit rate : 22.5 Mb/s Maximum Overall bit rate : 35.5 Mb/s OverallBitRate_Precision_Min : 22462713 OverallBitRate_Precision_Max : 22462888 Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : 36 Duration : 2 min 8 s Bit rate : 21.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.043 Stream size : 328 MiB Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Source : 00337.m2ts / 00337.m2ts Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : 129 Duration : 2 min 8 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 2.95 MiB Language : English Service kind : Complete Main bsid : 8 Dialog Normalization : -31 Dialog Normalization : -31 dB compr : -0.28 compr : -0.28 dB dsurmod : 1 dsurmod : Not Dolby Surround encoded acmod : 2 lfeon : 0 dialnorm_Average : -31 dialnorm_Average : -31 dB dialnorm_Minimum : -31 dialnorm_Minimum : -31 dB dialnorm_Maximum : -31 dialnorm_Maximum : -31 dB dialnorm_Count : 1153 compr_Average : 0.67 compr_Average : 0.67 dB compr_Minimum : -4.08 compr_Minimum : -4.08 dB compr_Maximum : 5.74 compr_Maximum : 5.74 dB compr_Count : 1072 dynrng_Average : 0.66 dynrng_Average : 0.66 dB dynrng_Minimum : -4.08 dynrng_Minimum : -4.08 dB dynrng_Maximum : 5.88 dynrng_Maximum : 5.88 dB dynrng_Count : 1133 format_identifier : AC-3 Source : 00337.m2ts / 00337.m2ts Last edited by LowDead; 25th September 2020 at 13:55. Reason: minor editing |
#30002 | Link | |
Got my hands on a disc that also consists of 24p and 60p videos.
Couldn't find any issues with x265 or nvenc: Quote:
#30003 | Link | |
![]() Join Date: Oct 2001
#30004 | Link |
Not anymore. A majority of movies are shot on video, using cameras specifically designed for movies. Some directors still like shooting on film, but the film is digitally transferred and edited.
One such company making digital cameras is Red (red.com). The other is Arri (www.arri.com/en/camera-systems/cameras). Shooting at 60fps would result in the movie not getting shown in many theaters, as they are not equipped with the very expensive projectors to do so. Even 48fps movies are limited. |
#30007 | Link | |
#30008 | Link |
no worries. Was just a question. In the mean time i've been tinkering with nvenc, sad to say i can't reproduce your problem. Maybe its because your GPU is actually of a newer generation than mine. That'll change though when my 3090 hopefully arrives in a couple weeks ^^
#30009 | Link |
I got a strange error today:
MapSMtoCores undefined SMversion 7.5! It happens when I try to encode a movie with X264. It's related to CUVID on my NVIDIA card. If I turn CUVID off it works. Oddly, it worked fine yesterday and I don't see anything that has changed (no updates etc.). Is anyone familiar with this? Is there a fix? [Edit] Well... it seems to have gone away with the installation of an updated version of LAV Filters. I may have to update the first post of the thread with a newer version for download. I'll need to do some testing first. Unfortunately that may delay release of the new version. Still wondering what changed overnight, though. Last edited by jdobbs; 27th September 2020 at 15:24. |
#30012 | Link | |
[Edit] I tried it with another 2160p source and it ran fine. I think the issue is related to that specific source. It was an odd UHD file without HDR that I'd downloaded for a specific bug fix test. I think it is fine the way it is. Last edited by jdobbs; 27th September 2020 at 17:23. |
#30013 | Link |
BD Rebuilder v0.61.17 Test Release
I think this version is ready for release, but since using the new version of TSMUXER to do all muxing actions can affect a lot of things, I'd like to post it as a test version so some of you experienced users can run it through the ringer before I officially release it.
You can download it from this link: BD-RB v0.61.17 Please provide feedback as to whether or not you find any anomalies. Thanks. Changes for this release: Code:
- Corrected an issue in which attempts to perform a size-correcting second pass on an AVC source could result in an error "PredictAndEncode() 00011 2994". - Made adjustments to correct for bad time codes in .SUP files that could result in certain oddly formatted multi-part sources (shows itself as subtitles that extend well beyond the lenght of the movie) - Added changes that will prevent occurance of some "Bitstream exception" errors. - Implemented default use of v2.6.16 of TSMUXER for all TSMUXER functions. In order to disable and return to v2.6.12 use hidden option "ENABLE_NEW_TSMUXER=0". - Added a routine that catches previously undetected errors in AAC encoding and then attempts reencoding via a new method. - Corrected a setting used with HEVC that could assert HDR when it is not present in the original source. - Updated TSMUXER4K to the 2020-09-25 build. - Other minor corrections and cosmetic fixes. |
#30014 | Link |
a few quick questions @jdobbs
* is this switch SPECIAL_3D_MUX=1 still needed for in-mux 3D or even at all? (maybe make it a setting instead of hidden option?) * i'm trying to create movie-only output type but i can't figure it out. I'd like "MKV, Full-SBS (3D), but recoded audio (aac or ac3, but surround intact or recoded to 5.1, codec don't care)". Ideally for an estimated filesize of around 4-8gb. Is this doable? |
#30015 | Link |
Big Bit Savings Now !
Might still be lurking around: The tsMuxeR 2.6.16 beta versions I tested (from December 2019 until July 2020) were not able to mux 1280x720x50p without packet loss. I kept tsMuxeR 1.10.6 in my toolbox for such reason, muxed ok.
Right now I have no such project, If I find time I will start trying newer tsMuxeR versions on such files. P.S. Found my test project. Looks good for now. No packet loss anymore with tsMuxeR git-32db2aa x64 2020-09-25--02-25-44. P.P.S. And a concatenated ~5h 1280x720x50p project was muxed fine too. BDEdit 0.49b finds no more packet loss.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..." Last edited by Emulgator; 28th September 2020 at 22:04. |
#30016 | Link | |
#30017 | Link | |
It's been a while since I've done 3D, but In order to output SBS, you should just add: OUTPUT_SBS=1 to your BDREBUILDER.INI file. Alternatively you can set it by selecting "Output SBS/OU Movie-Only Output" from the SETTINGS dialog (it sets/resets OUTPUT_SBS). On my system I also have to add: FRIM_SW_DECODE=1 You should then be able to pick any of the "No Resize" options for output. For example you might choose "MKV Container, NO_RESIZE, AutoGOP, Auto-AC3". In order to set to a certain output size you can select "VBR Target Size..." when you are selecting the ALTERNATE output. You could also choose "One Pass CRF Target Size...". [Edit] You'll have to use either X264 or X265. I just tried one using NVENCC and it choked on the input. Not sure why, but I'm guessing it either doesn't like the sizing or it has an issue with the AVS. I'll look at it for the next release. Last edited by jdobbs; 29th September 2020 at 00:13. |
#30019 | Link |
i thought that switch was needed for was needed for in-mux 3D, or is that another one? I can find alternate. I have enabled the SBS switch. The 2 profiles that semi match what i want i believe are "MP4/MKV Full-SBS (3D)" but they both use intact audio. I don't mind it being downscaled to 5.1 ac3/aac. There's no profile for that.
#30020 | Link | |
