#8521 | Link | |
From the first post in this thread .....
#8522 | Link |
Hi jdboos:
Suggestion: Is there a way to set an option to compress more the bonus features and previews to limit size compression for the movie? If not, can it be a constructive suggestion ?
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
#8523 | Link |
![]() Join Date: Oct 2001
I've had some strangeness happening on my Windows 7 64 bit machine and I'm wondering if anyone else has seen this. When I start an encode with BD Rebuilder (pass 2), my quad-cores are pegged with X264 using 99% of the CPU time as viewed from the Windows Task Manager/Processes dialog. After a short while of running I look at it again and the X264 process is then only at about 70-75% of the CPU time -- and the process SYSTEM ("NT Kernal and System) is using 23-29% of the CPU. My FPS reading on X264 has dropped equivalently.
Why would the system suddenly demand so much of my processor time? This seems to have started only recently and the same thing happens if I just run X264 from the command line. Any ideas? Last edited by jdobbs; 5th June 2010 at 23:38. |
#8524 | Link |
Hi jdboos:
Check with this: In the process tab; the x264.exe *32 can have a priority changed for each process. Right click; "Define Priority" i dont know if named like that in english because my windows are in french; and set to normal. You will see that windows have set the priority to "low". I have set to normal and the process stay over 90%. I don't know why Windows appriopriate "low" priority but i think that is basic from windows to keep using windows for surfing, chat, etc. regular internet used. Check with that if your process will be corrected. 8ternity
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 6th June 2010 at 00:53. |
#8525 | Link | |
@jdobbs;
#8526 | Link | |
I have experienced that when Seven runs its regular backups it creates heavy cpu load for this task. For the first pass, however, i have taken it for granted that x264 runs way below full throttle. |
#8529 | Link | |
Looking at "Resource Monitor", the CPU is averaging 86+% for x264. The second highest load is "System Interrupts" at 11%. If I look at Task Manager, those two numbers get combined at 97-98% for x264. My "NT Kernel" is at 0%. |
#8530 | Link |
I have troubles backing up Karate Kid:
[01:40:02] BD Rebuilder v0.33.09 (beta) - Source: THE_KARATE_KID - Input BD size: 37,72 GB - Approximate total content: [02:18:25.225] - Target BD size: 23,60 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [01:40:03] PHASE ONE, Encoding - [01:40:03] Extracting A/V streams [VID_00011] - [02:03:06] Reencoding: VID_00011 (1 of 3) - [02:03:06] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 196.674 frames - Bitrate: 18.255 Kbs - [02:03:07] Reencoding: VID_00011, Pass 1 of 1 - [11:43:07] Video Encode complete - [11:43:07] Reencoding audio tracks (if req'd) - [11:43:07] Multiplexing M2TS - Error in attempt to multiplex: MUX_00011.meta - Can't open file: D:\BD REBUILDER\WORKFILES\VID_00011_2.AVS.MKV [11:43:09] - Failed to build structure, aborted I disabled the second video stream with the hidden option. The Mux_00011.meta looks like this, MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "D:\BD REBUILDER\WORKFILES\VID_00011.AVS.264", fps=23.976, insertSEI, contSPS V_MPEG4/ISO/AVC, "D:\BD REBUILDER\WORKFILES\VID_00011_2.AVS.MKV", fps=23.976, track=1, secondary, insertSEI, contSPS A_DTS, "D:\BD REBUILDER\WORKFILES\00011.track_4352.DTS", lang=eng S_HDMV/PGS, "D:\BD REBUILDER\WORKFILES\00011.track_4609.sup", lang=nld |
#8531 | Link | |
[Added note] Wow. I guess this has been building for a while. I'm getting about 30-40% higher speed than I was a couple of weeks ago now. Cool. ![]() Last edited by jdobbs; 6th June 2010 at 17:07. |
#8534 | Link |
Sorry not sure if this is officially a 'bug report' or not...could be, you tell me:
Running a new install of Windows 7 Pro 64-bit (all latest patches/updates), had my BD-Rebuilder 'suite' working flawlessly for months under prev install XP Pro 32-bit on same hardware (Mac Pro quad-core, 10GB RAM, Boot Camp install of OS) along w/ SlySoft apps. Downloaded all the latest versions of the various software components per sticky instructions. Successfully get through all rebuild phases (1&2), but run into an error at the burn stage. Can't seem to get ImgBurn to launch properly to finish the job. Any ideas? I have both BD-Rebuilder and ImgBurn set to 'run as admin', btw. ImgBurn should be compatible w/ Win 7 64-bit--any clues as to errors in install, seemed straightforward before in XP, but I know Win 7 has gotchas I may not be familiar with aside from the admin issues... Thanks! UPDATE: ImgBurn launched via help below: http://bit.ly/c8fRz9 Seems anti-virus that worked fine in XP now creates a conflict in Win7. Hmmm. Pain to have to shut down BitDefender before every BD-Rebuild w/ AutoBurn session, but if it works... Nope. ImgBurn is not being launched properly from w/in the BD-Rebuilder app... nothing in the ImgBurn Log, either. Here's are the LOGs: ----------------------- [00:08:19] BD Rebuilder v0.34.02 (beta) - Source: WHERE_THE_WILD_THINGS_ARE - Input BD size: 17.67 GB - Approximate total content: [01:41:01.930] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), One Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [00:08:22] PHASE ONE, Encoding [00:08:22]PHASE ONE complete [00:08:22]PHASE TWO - Rebuild Started - [00:08:22] Rebuilding BD file Structure [00:18:58] - Encode and Rebuild complete [00:18:58] BURNING BD structure to disc - ImgBurn WAS NOT COMPLETED successfully [00:19:00]JOB: WHERE_THE_WILD_THINGS_ARE finished. Here is the opening log for manually launched ImgBurn: I 00:19:39 ImgBurn Version 2.5.1.0 started! I 00:19:39 Microsoft Windows 7 Professional x64 Edition (6.1, Build 7600) I 00:19:39 Total Physical Memory: 10,475,556 KB - Available: 8,670,132 KB W 00:19:39 AnyDVD can interfere with ImgBurn's ability to verify accurately, please ensure it's disabled! I 00:19:40 Initialising SPTI... I 00:19:40 Searching for SCSI / ATAPI devices... I 00:19:40 -> Drive 1 - Info: PIONEER DVD-RW DVR-112D BC14 (E ![]() I 00:19:40 -> Drive 2 - Info: ELBY CLONEDRIVE 1.4 (H ![]() I 00:19:40 -> Drive 3 - Info: HL-DT-ST BD-RE GGW-H20N XJ03 (I ![]() I 00:19:40 Found 1 DVD±RW, 1 BD-ROM/HD DVD-ROM and 1 HD DVD-ROM/BD-RE! I turned off AnyDVD (much as I hadn't needed to turn off my anti-virus, BitDefender in XP, this is apparently a new needed step in Windows 7 pro 64-bit). Ran BD-Rebuilder once more... Same result. Any ideas on what to try next? Note: Only difference between this Win 7 install and the identical software suite I'm running under my migrated XP Pro partition (running under Parallels on my OSX boot drive, fully functional but slower of course), is that the BD-Rebuilder folder is NOT in the Programs directory (as suggested by the sticky), it's on the Desktop, while ImgBurn is installed in the programs directory. Last edited by ellusian; 7th June 2010 at 17:40. |
#8535 | Link |
Rebuilder hangs computer
Installed v0.34.02 and now it continuously fails at the Disk Rebuild stage. No mater where the original files come from or where the new files are written to eg Sata.Ide.Network. Fails everytime.
PC runs perfectly fine other than this. Vista 64. 8MB Mem. |
#8536 | Link | |
Does it work to a local drive? |
#8537 | Link |
I connected it to a USB HD connected on a USB Bus all by itself and it has now worked. If I put it back to ANY other drive it fails at the Rebuilding stage.
I have to go out for a couple of hours, but I have left it running with the USB dive. so I wiill let you know what happens when I get back. The previous version worked fine. Al |
#8538 | Link | |
#8540 | Link |
@ jdobbs
This is my new try about THE HANGOVER, I do a BD25 full backup, but the UNRATED VERSION has the audio desync. The teatrical version does not present any problem. I tried all the versions of BD-rebuilder for the last two months. But every backup has the same problem. Code:
13:49:58] BD Rebuilder v0.34.02 (beta) - Source: THE_HANGOVER - Input BD size: 37,39 GB - Approximate total content: [04:16:27.622] - Target BD size: 22,66 GB - Windows Version: 6.0 [6001] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:49:58] PHASE ONE, Encoding - [13:49:58] Extracting A/V streams [VID_00000] - [13:56:09] Reencoding: VID_00000 (1 of 18) - [13:56:09] Reencoding secondary video [TRK_02] - [14:16:06] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 143.521 frames - Bitrate: 7.666 Kbs - [14:16:07] Reencoding: VID_00000, Pass 1 of 2 - [16:30:30] Reencoding: VID_00000, Pass 2 of 2 - [21:10:52] Video Encode complete - [21:10:52] Reencoding audio tracks (if req'd) - [21:10:52] Multiplexing M2TS - [21:18:42] Extracting A/V streams [VID_00001] - [21:23:36] Reencoding: VID_00001 (2 of 18) - [21:23:36] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 155.209 frames - Bitrate: 7.958 Kbs - [21:23:36] Reencoding: VID_00001, Pass 1 of 2 - [23:45:53] Reencoding: VID_00001, Pass 2 of 2 - [04:39:16] Video Encode complete - [04:39:16] Reencoding audio tracks (if req'd) - [04:39:16] Multiplexing M2TS - [04:46:42] Extracting A/V streams [VID_00004] - [04:46:45] Reencoding: VID_00004 (3 of 18) - [04:46:45] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 1.705 frames - Bitrate: 6.597 Kbs - [04:46:45] Reencoding: VID_00004, Pass 1 of 2 - [04:48:20] Reencoding: VID_00004, Pass 2 of 2 - [04:51:19] Video Encode complete - [04:51:19] Reencoding audio tracks (if req'd) - [04:51:20] Multiplexing M2TS - [04:51:22] Extracting A/V streams [VID_00005] - [04:51:36] Reencoding: VID_00005 (4 of 18) - [04:51:36] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 11.898 frames - Bitrate: 5.969 Kbs - [04:51:36] Reencoding: VID_00005, Pass 1 of 2 - [05:02:20] Reencoding: VID_00005, Pass 2 of 2 - [05:22:06] Video Encode complete - [05:22:06] Reencoding audio tracks (if req'd) - [05:22:06] Multiplexing M2TS - [05:22:18] Extracting A/V streams [VID_00006] - [05:22:30] Reencoding: VID_00006 (5 of 18) - [05:22:31] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 11.419 frames - Bitrate: 5.956 Kbs - [05:22:31] Reencoding: VID_00006, Pass 1 of 2 - [05:32:26] Reencoding: VID_00006, Pass 2 of 2 - [05:54:27] Video Encode complete - [05:54:27] Reencoding audio tracks (if req'd) - [05:54:27] Multiplexing M2TS - [05:54:44] Extracting A/V streams [VID_00007] - [05:54:46] Reencoding: VID_00007 (6 of 18) - [05:54:46] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.005 frames - Bitrate: 5.946 Kbs - [05:54:46] Reencoding: VID_00007, Pass 1 of 2 - [05:56:50] Reencoding: VID_00007, Pass 2 of 2 - [06:00:43] Video Encode complete - [06:00:43] Reencoding audio tracks (if req'd) - [06:00:43] Multiplexing M2TS - [06:00:45] Extracting A/V streams [VID_00010] - [06:00:57] Reencoding: VID_00010 (7 of 18) - [06:00:57] Reencoding secondary video [TRK_02] - [06:01:55] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 14.498 frames - Bitrate: 1.320 Kbs - [06:01:55] Reencoding: VID_00010, Pass 1 of 2 - [06:12:59] Reencoding: VID_00010, Pass 2 of 2 - [06:26:58] Video Encode complete - [06:26:58] Reencoding audio tracks (if req'd) - [06:26:58] Multiplexing M2TS - [06:27:01] Extracting A/V streams [VID_00012] - [06:27:04] Reencoding: VID_00012 (8 of 18) - [06:27:04] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.511 frames - Bitrate: 6.164 Kbs - [06:27:04] Reencoding: VID_00012, Pass 1 of 2 - [06:29:34] Reencoding: VID_00012, Pass 2 of 2 - [06:34:27] Video Encode complete - [06:34:27] Reencoding audio tracks (if req'd) - [06:34:27] Multiplexing M2TS - [06:34:30] Extracting A/V streams [VID_00013] - [06:34:32] Reencoding: VID_00013 (9 of 18) - [06:34:32] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 1.729 frames - Bitrate: 6.260 Kbs - [06:34:32] Reencoding: VID_00013, Pass 1 of 2 - [06:36:13] Reencoding: VID_00013, Pass 2 of 2 - [06:39:36] Video Encode complete - [06:39:36] Reencoding audio tracks (if req'd) - [06:39:36] Multiplexing M2TS - [06:39:38] Extracting A/V streams [VID_00015] - [06:39:41] Reencoding: VID_00015 (10 of 18) - [06:39:41] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.714 frames - Bitrate: 6.128 Kbs - [06:39:41] Reencoding: VID_00015, Pass 1 of 2 - [06:42:12] Reencoding: VID_00015, Pass 2 of 2 - [06:47:17] Video Encode complete - [06:47:17] Reencoding audio tracks (if req'd) - [06:47:17] Multiplexing M2TS - [06:47:20] Extracting A/V streams [VID_00016] - [06:47:23] Reencoding: VID_00016 (11 of 18) - [06:47:23] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.320 frames - Bitrate: 6.496 Kbs - [06:47:23] Reencoding: VID_00016, Pass 1 of 2 - [06:49:26] Reencoding: VID_00016, Pass 2 of 2 - [06:53:49] Video Encode complete - [06:53:49] Reencoding audio tracks (if req'd) - [06:53:49] Multiplexing M2TS - [06:53:52] Extracting A/V streams [VID_00017] - [06:53:55] Reencoding: VID_00017 (12 of 18) - [06:53:55] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.233 frames - Bitrate: 6.045 Kbs - [06:53:55] Reencoding: VID_00017, Pass 1 of 2 - [06:56:05] Reencoding: VID_00017, Pass 2 of 2 - [07:00:30] Video Encode complete - [07:00:30] Reencoding audio tracks (if req'd) - [07:00:30] Multiplexing M2TS - [07:00:32] Extracting A/V streams [VID_00020] - [07:00:36] Reencoding: VID_00020 (13 of 18) - [07:00:36] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.917 frames - Bitrate: 5.591 Kbs - [07:00:36] Reencoding: VID_00020, Pass 1 of 2 - [07:02:59] Reencoding: VID_00020, Pass 2 of 2 - [07:07:22] Video Encode complete - [07:07:23] Reencoding audio tracks (if req'd) - [07:07:23] Multiplexing M2TS - [07:07:25] Extracting A/V streams [VID_00026] - [07:07:30] Reencoding: VID_00026 (14 of 18) - [07:07:30] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 3.444 frames - Bitrate: 6.379 Kbs - [07:07:30] Reencoding: VID_00026, Pass 1 of 2 - [07:10:28] Reencoding: VID_00026, Pass 2 of 2 - [07:16:30] Video Encode complete - [07:16:30] Reencoding audio tracks (if req'd) - [07:16:30] Multiplexing M2TS - [07:16:33] Extracting A/V streams [VID_00027] - [07:16:37] Reencoding: VID_00027 (15 of 18) - [07:16:37] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 3.460 frames - Bitrate: 6.330 Kbs - [07:16:37] Reencoding: VID_00027, Pass 1 of 2 - [07:19:54] Reencoding: VID_00027, Pass 2 of 2 - [07:26:25] Video Encode complete - [07:26:25] Reencoding audio tracks (if req'd) - [07:26:25] Multiplexing M2TS - [07:26:29] Extracting A/V streams [VID_00028] - [07:26:32] Reencoding: VID_00028 (16 of 18) - [07:26:32] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 3.312 frames - Bitrate: 6.291 Kbs - [07:26:33] Reencoding: VID_00028, Pass 1 of 2 - [07:29:36] Reencoding: VID_00028, Pass 2 of 2 - [07:35:57] Video Encode complete - [07:35:57] Reencoding audio tracks (if req'd) - [07:35:57] Multiplexing M2TS - [07:36:00] Extracting A/V streams [VID_00029] - [07:36:02] Reencoding: VID_00029 (17 of 18) - [07:36:02] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 1.138 frames - Bitrate: 6.470 Kbs - [07:36:02] Reencoding: VID_00029, Pass 1 of 2 - [07:37:00] Reencoding: VID_00029, Pass 2 of 2 - [07:39:02] Video Encode complete - [07:39:02] Reencoding audio tracks (if req'd) - [07:39:02] Multiplexing M2TS - [07:39:03] Extracting A/V streams [VID_00030] - [07:39:07] Reencoding: VID_00030 (18 of 18) - [07:39:07] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 2.901 frames - Bitrate: 7.043 Kbs - [07:39:07] Reencoding: VID_00030, Pass 1 of 2 - [07:41:36] Reencoding: VID_00030, Pass 2 of 2 - [07:46:32] Video Encode complete - [07:46:32] Reencoding audio tracks (if req'd) - [07:46:32] Multiplexing M2TS [07:46:35]PHASE ONE complete [07:46:35]PHASE TWO - Rebuild Started - [07:46:35] Rebuilding BD file Structure [07:47:04] - Encode and Rebuild complete - WORKFILES folder removed. [07:47:05]JOB: THE_HANGOVER finished. Code:
[Status] LABEL=THE_HANGOVER VERSION=v0.34.02 (beta) SOURCE_SIZE=40152130398 SOURCE_VIDEO_SIZE=39101546496 TARGET_SIZE=24326963200 REDUCTION=.595280273642914 RESIZE_1080=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=18 REBUILD_COMPLETE=1 [00000] AUDIO=11111 PGS=1111111 M2TS_TARGET=10924506167 RATE=7666 NSIZE=10651656192 FLINK=0 MLINK=0 [00001] AUDIO=11 PGS=1111 M2TS_TARGET=10176417504 RATE=7958 NSIZE=9861249024 FLINK=0 MLINK=0 [00004] AUDIO=1 PGS=1111 M2TS_TARGET=67226706 RATE=6597 NSIZE=65427456 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS=1111 M2TS_TARGET=424313493 RATE=5969 NSIZE=416704512 FLINK=0 MLINK=0 [00006] AUDIO=1 PGS=1111 M2TS_TARGET=408879257 RATE=5956 NSIZE=402296832 FLINK=0 MLINK=0 [00007] AUDIO=1 PGS=1111 M2TS_TARGET=71970357 RATE=5946 NSIZE=71442432 FLINK=0 MLINK=0 [00010] AUDIO=11 PGS= M2TS_TARGET=137485399 RATE=1320 NSIZE=140888064 FLINK=0 MLINK=0 [00012] AUDIO=1 PGS=1111 M2TS_TARGET=93040650 RATE=6164 NSIZE=91373568 FLINK=0 MLINK=0 [00013] AUDIO=1 PGS=1111 M2TS_TARGET=64933515 RATE=6260 NSIZE=64057344 FLINK=0 MLINK=0 [00015] AUDIO=1 PGS=1111 M2TS_TARGET=100227444 RATE=6128 NSIZE=98199552 FLINK=0 MLINK=0 [00016] AUDIO=1 PGS=1111 M2TS_TARGET=91255837 RATE=6496 NSIZE=89382912 FLINK=0 MLINK=0 [00017] AUDIO=1 PGS=1111 M2TS_TARGET=82313489 RATE=6045 NSIZE=80209920 FLINK=0 MLINK=0 [00020] AUDIO=1 PGS=1111 M2TS_TARGET=98373142 RATE=5591 NSIZE=97185792 FLINK=0 MLINK=0 [00026] AUDIO=1 PGS= M2TS_TARGET=127237358 RATE=6379 NSIZE=125122560 FLINK=0 MLINK=0 [00027] AUDIO=1 PGS= M2TS_TARGET=126871618 RATE=6330 NSIZE=124446720 FLINK=0 MLINK=0 [00028] AUDIO=1 PGS= M2TS_TARGET=120730840 RATE=6291 NSIZE=118548480 FLINK=0 MLINK=0 [00029] AUDIO=1 PGS= M2TS_TARGET=42623363 RATE=6470 NSIZE=42141696 FLINK=0 MLINK=0 [00030] AUDIO=1 PGS= M2TS_TARGET=117973159 RATE=7043 NSIZE=115998720 FLINK=0 MLINK=0 - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3133, Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Last edited by jdobbs; 7th June 2010 at 18:49. |
