#10321 | Link | ||
I also used TotalMedia Theatre 3 on my htpc to playback the bdmv folder from my hard drive. Quote:
Not sure but I'll do a full backup to see if that makes a difference. Thanks for the information. |
#10322 | Link | ||
![]() Join Date: Oct 2001
It's one of those "how you interpret it" things... according to spec AVCHD will support Level 4.1 up to 24Mbs or Level 4.0 up to 18Mbs. DVD media (as defined in this context) is limited to 18Mbs -- so some people read that as "DVD must be Level 4.0". On the other hand, some would say there should no reason you can't use Level 4.1 -- since you can limit the bitrate as you see fit without changing the level. There's really no disadvantage to using Level 4.0 when outputting to DVD, so I changed the code to make it more compatible. Last edited by jdobbs; 28th November 2010 at 16:06. |
#10323 | Link | |
#10324 | Link | |
#10325 | Link |
Thanks Jdobbs, and everyone concerned. I did realize that there is a great deal of video space on the disc(5+hrs). The BD-50 was after all 46+Gb. One of the largest I've dealt with.
Just over 7hrs eh? Hmmm, perhaps you removed things I did not. Most the time, it averages between 5 - 8 hrs. If 1090t can average 1.5hrs, Bulldozer WILL be justified. I guess I should wait and see though. I think they're figuring quarter one on Bulldozer release ![]() I guess I could see how my 965 @ 3.9Ghz fairs by comparison. Could be an interesting experiment ![]() |
#10326 | Link | |
I ussually use the Automatic quality settings and my 1.5 hr comparison was with the 1090T OC'd to 4200ghz where I was averaging 48fps 1st pass and 42 fps 2nd pass when needed. The last Airbender and Sorcerers Aprentice. I am stock right now with all 6 core maxed which I couldn't do when OC'd @ 4200 (about 60 - 70%) and have not had time to get the bugs out of the system yet and Asus has left a few in the MB. I found when I upgraded from the 965 also OC'd to 3900 I gained about 10 - 15 fps all around depending on the source. the 1090T loves to be OC'd compared to the 965. |
#10327 | Link |
Thanks for the info. I generally don't like running long processes on my primary machine(Phenom 965). But perhaps in the not too distant future, I can retire 940(sell on ebay), and purchase 1090t. Really depends on Bulldozers cost, and how much money I can make over the next month. Hopefully I pick up some overtime
#10328 | Link |
When I select 'Alternate Output' and for example one of the MKV containers, I can activate both 'Constant Rate Factor Output (CRF)' AND 'Two Pass Bitrate Encoding'. I thought the 2 should be exclusive.
When I unselect 'Constant Rate Factor Output (CRF)' and select 'Two Pass Bitrate Encoding', I cannot edit the target bitrate, but only the CRF. Is this a bug? |
#10329 | Link | |
[Edit] I just tested it, and I can't activate both... the checkbox can only be set on one or the other. You can never edit the bitrate (currently), it is set in the ALTERNATE.TXT file that holds all the profiles. You can always edit the CRF, but it is only applicable if you have CRF encoding selected. Last edited by jdobbs; 29th November 2010 at 01:05. |
#10330 | Link |
Has something changed since the 4th of November, page 502, and now, with the Inspect tool?
I don't think i've ever seen "FFDSHOW_RAW_AUDIO" listed in the Inspect tool, but it's not often I use BD-Rebuilder, and generally it gets removed when i'm done, and a new version is out when I need it again. FFDSHOW_RAW_AUDIO is not mentioned in the Inspect tool here. Should it be? Edit: I'm also hesistant to ask this next question, because it's probably been repeated many times. Why is "FFMPEG encoder" unselectable in "Encoder"? Is there any condition in which it is selectable? Last edited by MickJT; 29th November 2010 at 13:35. |
#10331 | Link | |
Sorry jdobbs, any comments ? Has anyone been through this ??? |
#10332 | Link | |
----------------------- [23:11:53] BD Rebuilder v0.35.01 (beta) - Source: HARRY_POTTER_6 - Input BD size: 28.97 GB - Approximate total content: [03:23:33.284] - Target BD size: 22.66 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [23:11:53] PHASE ONE, Encoding - [23:11:53] Extracting A/V streams [VID_00067] - [23:11:57] Reencoding: VID_00067 (1 of 17) - [23:11:57] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,824 frames - [23:11:57] Reencoding: VID_00067, Pass 1 of 1 - [23:13:26] Video Encode complete - [23:13:26] Reencoding audio tracks (if req'd) - [23:13:28] Multiplexing M2TS - [23:13:30] Extracting A/V streams [VID_00004] - [23:13:34] Reencoding: VID_00004 (2 of 17) - [23:13:34] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,998 frames - [23:13:34] Reencoding: VID_00004, Pass 1 of 1 - [23:15:08] Video Encode complete - [23:15:08] Reencoding audio tracks (if req'd) - [23:15:09] Multiplexing M2TS - [23:15:11] Extracting A/V streams [VID_00009] - [23:15:15] Reencoding: VID_00009 (3 of 17) - [23:15:15] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 2,991 frames - [23:15:15] Reencoding: VID_00009, Pass 1 of 1 - [23:16:49] Video Encode complete - [23:16:49] Reencoding audio tracks (if req'd) - [23:16:51] Multiplexing M2TS - [23:16:52] Extracting A/V streams [VID_00072] - [23:16:57] Reencoding: VID_00072 (4 of 17) - [23:16:57] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,021 frames - [23:16:57] Reencoding: VID_00072, Pass 1 of 1 - [23:18:28] Video Encode complete - [23:18:28] Reencoding audio tracks (if req'd) - [23:18:30] Multiplexing M2TS - [23:18:31] Extracting A/V streams [VID_00007] - [23:18:35] Reencoding: VID_00007 (5 of 17) - [23:18:35] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,062 frames - [23:18:35] Reencoding: VID_00007, Pass 1 of 1 - [23:20:13] Video Encode complete - [23:20:13] Reencoding audio tracks (if req'd) - [23:20:15] Multiplexing M2TS - [23:20:17] Extracting A/V streams [VID_00069] - [23:20:21] Reencoding: VID_00069 (6 of 17) - [23:20:21] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,590 frames - [23:20:21] Reencoding: VID_00069, Pass 1 of 1 - [23:22:18] Video Encode complete - [23:22:18] Reencoding audio tracks (if req'd) - [23:22:19] Multiplexing M2TS - [23:22:22] Extracting A/V streams [VID_00010] - [23:22:27] Reencoding: VID_00010 (7 of 17) - [23:22:27] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,154 frames - [23:22:27] Reencoding: VID_00010, Pass 1 of 1 - [23:24:13] Video Encode complete - [23:24:13] Reencoding audio tracks (if req'd) - [23:24:14] Multiplexing M2TS - [23:24:17] Extracting A/V streams [VID_00680] - [23:24:29] Reencoding: VID_00680 (8 of 17) - [23:24:29] Reencoding secondary video [TRK_02] - [23:25:17] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 14,498 frames - [23:25:17] Reencoding: VID_00680, Pass 1 of 1 - [23:31:08] Video Encode complete - [23:31:08] Reencoding audio tracks (if req'd) - [23:31:11] Multiplexing M2TS - [23:31:13] Extracting A/V streams [VID_00005] - [23:31:17] Reencoding: VID_00005 (9 of 17) - [23:31:17] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,965 frames - [23:31:17] Reencoding: VID_00005, Pass 1 of 1 - [23:33:25] Video Encode complete - [23:33:25] Reencoding audio tracks (if req'd) - [23:33:27] Multiplexing M2TS - [23:33:30] Extracting A/V streams [VID_00003] - [23:33:34] Reencoding: VID_00003 (10 of 17) - [23:33:34] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,029 frames - [23:33:34] Reencoding: VID_00003, Pass 1 of 1 - [23:35:43] Video Encode complete - [23:35:43] Reencoding audio tracks (if req'd) - [23:35:45] Multiplexing M2TS - [23:35:47] Extracting A/V streams [VID_00006] - [23:35:52] Reencoding: VID_00006 (11 of 17) - [23:35:52] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,075 frames - [23:35:52] Reencoding: VID_00006, Pass 1 of 1 - [23:38:03] Video Encode complete - [23:38:03] Reencoding audio tracks (if req'd) - [23:38:05] Multiplexing M2TS - [23:38:07] Extracting A/V streams [VID_00008] - [23:38:12] Reencoding: VID_00008 (12 of 17) - [23:38:12] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,239 frames - [23:38:12] Reencoding: VID_00008, Pass 1 of 1 - [23:40:30] Video Encode complete - [23:40:30] Reencoding audio tracks (if req'd) - [23:40:32] Multiplexing M2TS - [23:40:34] Extracting A/V streams [VID_00068] - [23:40:39] Reencoding: VID_00068 (13 of 17) - [23:40:39] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,312 frames - [23:40:39] Reencoding: VID_00068, Pass 1 of 1 - [23:42:58] Video Encode complete - [23:42:58] Reencoding audio tracks (if req'd) - [23:43:00] Multiplexing M2TS - [23:43:02] Extracting A/V streams [VID_00071] - [23:43:07] Reencoding: VID_00071 (14 of 17) - [23:43:07] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,942 frames - [23:43:07] Reencoding: VID_00071, Pass 1 of 1 - [23:45:35] Video Encode complete - [23:45:35] Reencoding audio tracks (if req'd) - [23:45:37] Multiplexing M2TS - [23:45:40] Extracting A/V streams [VID_00001] - [23:45:46] Reencoding: VID_00001 (15 of 17) - [23:45:46] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 4,965 frames - [23:45:46] Reencoding: VID_00001, Pass 1 of 1 - [23:48:24] Video Encode complete - [23:48:24] Reencoding audio tracks (if req'd) - [23:48:26] Multiplexing M2TS - [23:48:29] Extracting A/V streams [VID_00070] - [23:48:35] Reencoding: VID_00070 (16 of 17) - [23:48:35] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 5,320 frames - [23:48:35] Reencoding: VID_00070, Pass 1 of 1 - [23:51:18] Video Encode complete - [23:51:18] Reencoding audio tracks (if req'd) - [23:51:21] Multiplexing M2TS - [23:51:24] Extracting A/V streams [VID_00000] - [00:02:38] Reencoding: VID_00000 (17 of 17) - [00:02:38] Reencoding secondary video [TRK_02] - [00:24:12] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 220,841 frames - Bitrate: 15,418 Kbs - [00:24:12] Reencoding: VID_00000, Pass 1 of 1 - [02:40:41] Video Encode complete - [02:40:41] Reencoding audio tracks (if req'd) - [02:45:41] Multiplexing M2TS [02:59:15]PHASE ONE complete [02:59:15]PHASE TWO - Rebuild Started - [02:59:15] Rebuilding BD file Structure [02:59:25] - Encode and Rebuild complete - WORKFILES folder removed. [02:59:27]JOB: HARRY_POTTER_6 finished. Code:
[Options] MODE=1 ENCODE_QUALITY=1 ONEPASS_ENCODING=0 AUTO_QUALITY=1 TARGET_SIZE=8032 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=T:\PELICULAS BD\DARKN_BD25_WWW.SVERDOS.COM\ WORKING_PATH=T:\PELICULAS BD\DARK KNIGHT RECDIFICADO\ the inf for the disc [Status] LABEL=HARRY_POTTER_6 VERSION=v0.35.01 (beta) SOURCE_SIZE=31102790871 SOURCE_VIDEO_SIZE=30885642240 TARGET_SIZE=24326963200 REDUCTION=.780615613612702 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=1 ENCODE_STEP=0 COMPLETED=17 REBUILD_COMPLETE=1 [00067] AUDIO=1 PGS=11 M2TS_TARGET=127106304 NSTART=27000000 NEND=32300640 NSIZE=120809472 FLINK=0 MLINK=0 [00004] AUDIO=1 PGS=11 M2TS_TARGET=133969526 NSTART=27000000 NEND=32627520 NSIZE=127672320 FLINK=0 MLINK=0 [00009] AUDIO=1 PGS=11 M2TS_TARGET=134075041 NSTART=27000000 NEND=32613120 NSIZE=110739456 FLINK=0 MLINK=0 [00072] AUDIO=1 PGS=11 M2TS_TARGET=134583427 NSTART=27000000 NEND=32670720 NSIZE=112558080 FLINK=0 MLINK=0 [00007] AUDIO=1 PGS=11 M2TS_TARGET=136310024 NSTART=27000000 NEND=32747040 NSIZE=131438592 FLINK=0 MLINK=0 [00069] AUDIO=1 PGS=11 M2TS_TARGET=159556732 NSTART=27000000 NEND=33737760 NSIZE=182212608 FLINK=0 MLINK=0 [00010] AUDIO=1 PGS= M2TS_TARGET=178285512 NSTART=27000000 NEND=32919840 NSIZE=227106816 FLINK=0 MLINK=0 [00680] AUDIO=11 PGS= M2TS_TARGET=178482152 NSTART=27000000 NEND=54209056 NSIZE=147707904 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS=11 M2TS_TARGET=178654812 NSTART=27000000 NEND=34441920 NSIZE=156469248 FLINK=0 MLINK=0 [00003] AUDIO=1 PGS=11 M2TS_TARGET=180995310 NSTART=27000000 NEND=34561440 NSIZE=151007232 FLINK=0 MLINK=0 [00006] AUDIO=1 PGS=11 M2TS_TARGET=184347785 NSTART=27000000 NEND=34647840 NSIZE=180873216 FLINK=0 MLINK=0 [00008] AUDIO=1 PGS=11 M2TS_TARGET=190170253 NSTART=27000000 NEND=34956000 NSIZE=206966784 FLINK=0 MLINK=0 [00068] AUDIO=1 PGS=11 M2TS_TARGET=193503545 NSTART=27000000 NEND=35092800 NSIZE=176019456 FLINK=0 MLINK=0 [00071] AUDIO=1 PGS=11 M2TS_TARGET=218481646 NSTART=27000000 NEND=36275040 NSIZE=184694784 FLINK=0 MLINK=0 [00001] AUDIO=1 PGS=11 M2TS_TARGET=222505575 NSTART=27000000 NEND=36318240 NSIZE=211550208 FLINK=0 MLINK=0 [00070] AUDIO=1 PGS=11 M2TS_TARGET=238874673 NSTART=27000000 NEND=36984960 NSIZE=215482368 FLINK=0 MLINK=0 [00000] AUDIO=1011 PGS=10110 M2TS_TARGET=21466506025 RATE=15418 NSTART=27000000 NEND=441534240 NSIZE=20569491456 FLINK=0 MLINK=0 and the process is, fullbackup, "Quicker encode extras", encoder "x264 encoder", output options "BD25", verbose status reporting let me know if you need more info Last edited by jdobbs; 29th November 2010 at 15:00. |
#10333 | Link | |
#10334 | Link | |
#10335 | Link |
1. You're using an old version that is out of date. There have been four newer releases since then. I only accept bug reports on current versions.
2. Have you tried it on a standalone player? PC codecs and playback can be flakey... 3. It looks like the only language you have selected in SETUP is English. It could be this (from v0.36.03): Code:
- Corrected an error in which audio streams that contained delays, and were not in the initial (SETUP defined) list of selections, could (if later selected from the streams list) be muxed out-of-sync. Code:
- Corrected an issue in which stopping BD-RB during audio encoding would leave the WAVI and AFTEN processes running. As a result, restarting soon afterward could cause unpredictable anomalies in the audio, including sync and size issues. Last edited by jdobbs; 29th November 2010 at 15:12. |
#10336 | Link | |
#10337 | Link |
BD Rebuilder doesn't like languages other than english
Unfortunately, an encode with version 3604 still shows the problem. I tried it with some other BDs (e.g. Alice in Wonderland), and it worked well. So this seems to be a special problem of the CARS BD.
Besides, is there a way to downgrade to an earlier version of BD-Rebuilder for testing purposes? I tried but got a message that there is anewer version and I should use it. |
#10338 | Link | |
#10340 | Link |
Sorry, but I have to continue to treat this as a beta program -- I make the old versions expire so I don't keep getting reports on things that have been fixed. I have to believe that the copy of "CARS" you have is corrupted -- because your report is the only one in which there is an issue. An old version isn't going to act any differently.
