Old 7th October 2017, 22:38   #46301  |  Link
dvd1
The settings for the 2nd image are NGU Standard with a bit of grain added (in the upscaling refinement settings).
Please note that this test image is very sharp, sharper than most movies, and the upscaling factor is very large (400%). The difference between various upscaling algos will be much smaller if you have a smaller upscaling factor, and if the video is softer.
which means (400%) maybe SD to 4k?
the more the SD source is of good quality the more you notice the differences between the various scalers as well on a full only (1080p)?
and if sd source is of low quality how to improve?
dvd1 is offline   Reply With Quote
Old 7th October 2017, 22:54   #46302  |  Link
madshi
Originally Posted by arrgh View Post
to the flashig frequency, I tried to answer here https://forum.doom9.org/showthread.p...27#post1820027
but i have some "new" details; after those different tests, also with the 32bit versions and a hint by ryrynz to try d3d9, I just today rechecked the madVR settings in that respect (0.92.4) with 64bit software;
outcome :
if I deactivate in renderer/general all Options, especially "full exclusive" and "direct3D11", than there is no studder anymore (not in 2D and not in 3D);
if I activate "exclusive" then 2D still works but 3D starts to studder every 1-2 sec; if I add 3d11 the studder becomes hectic in 3D and regular, but slower, in 2D
Generally, the Intel GPU driver is buggy when using D3D11 presentation, and when using the "use a separate device for presentation" option. So you should ideally disable those 2 options. Sadly, 3D playback requires D3D11 <sigh>.
I did implement a workaround for the Intel driver bug, which helped on my PC and for some other Intel users, but seemingly not for all Intel users.
in all settings the player does not come clean out of 3D and hangs
Did you already upload freeze reports for this? I don't recall right now.
Originally Posted by aufkrawall View Post
To my eyes, default setting of 400nits looks too dim for sRGB displays with gamma of 2.2, even in a room with dimmed lights. I prefer 350nits.
The high quality hue preservation seems to be totally worth the costs, as it prevents yellow and orange from turning into reddish.
I'm not sure about measuring each frame's peak luminance. It can prevent some overly glaring look, but the result can also be less spectacular.
"restore details in compressed highlights" can lead to extreme ringing and more aliasing, I don't think the more detailed look of bright areas is worth this.
There's extreme ringing even with anti-ringing enabled? Do you have a screenshot, or ideally a small sample?
Originally Posted by mzso View Post
I have one more issue with ProgDVB+madVR though. The OSD doesn't appear right. I set it to HD but it's SD (and stretched to full width).
I reported it to the author, he concluded: "Thren MadVR working with 720x576 but not working with 1980x1080 bitmaps."
Of course I can't tell whether he's right or wrong.
I don't understand what he's saying, to be honest.
Originally Posted by FDisk80 View Post
Does 3D work for anyone with madVR after latest Windows 10 and nvidia driver update?
3D Vision crashes as soon as you click next on the Stereoscopic 3D wizard.
madVR switches to 24hz, ctrl+j says content is 3D but the TV is not initiating 3D mode.
Have you tried the "enable nvidia 3d.reg"?
400% means e.g. 100x100 upscaled to 400x400.
Yes.
Depends on the quality problem. For soft sources maybe some sharpening. For aliased sources I'd recommend NGU Anti-Alias.
Old 7th October 2017, 23:02   #46303  |  Link
madshi
teaser:
Two new algorithms coming in the next build, probably out tomorrow:
blocking -> cleaned
mosquito -> cleaned
Old 7th October 2017, 23:08   #46304  |  Link
Asmodian
Amazing! The last option I wanted for remove artifacts and with very good quality.
madVR options explained
Old 7th October 2017, 23:10   #46305  |  Link
ABDO
yeah madshi, finally
ABDO is offline   Reply With Quote
Old 7th October 2017, 23:16   #46306  |  Link
FDisk80
I did. It let me skip the nvidia 3D Vision Wizard. But if I do the nvidia image test it still crashes the same as the wizard crashed and madVR does not initiate 3D mode. I get no 3D logo on the TV as before. It just switches to 24hz and says that the content is "running in 3D".
I think this has started after latest Windows 10 update.
Reinstalled latest nvidia driver, cleaned with DDU, tried going back to DXVA copy-back... No go.
Can anyone try with Windows 10 v10.0.15063 & 385.69 drivers?
Was working beautify before. I'm lost at what is going on here.
Edit:
ok, WTH. I just pulled the power for the TV for 10 seconds, plugged it back in and 3D logo appeared as soon as I started a 3D movie.
What on earth could cause this? Maybe I messed with custom resolutions in madVR too much? I did have a couple of unsuccessful refresh rate switches, but it always recover back to normal and let me continue messing with it.
A restart for my non-smart 5 year old Samsung TV, hmm.. What's next a restart to my toaster. ¯\_(ツ)_/¯
The 3D vision wizard still crashes btw, but that's nvidia being nvidia I guess.
FDisk80 is offline   Reply With Quote
Old 7th October 2017, 23:28   #46307  |  Link
Sebastiii
Nice nice for the teaser
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 7th October 2017, 23:34   #46308  |  Link
dvd1
aliased sources
what does that mean?
Old 7th October 2017, 23:41   #46309  |  Link
sauma144
teaser:
blocking -> cleaned
mosquito -> cleaned
More deblock examples, please.
sauma144 is offline   Reply With Quote
Old 7th October 2017, 23:50   #46310  |  Link
el Filou
el Filou's Avatar
those blocking and noise filters may make MPEG2 SD cable watchable again (damn you, cable provider! ), this is fantastic.
HTPC: Windows 10 1909, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 8th October 2017, 00:00   #46311  |  Link
Asmodian
aliased sources
Old 8th October 2017, 00:02   #46312  |  Link
70MM
X Cinema Projectionist NZ
With "crop black bars" active, madVR actually cuts the black bar pixels away, so madVR has less pixels to process. With "crop black bars" unchecked, madVR is aware of which pixels belong to the black bar and which don't, but the pixels are not cut away, so they're still being processed, they might just be zoomed away, eventually.
madshi so does this mean if we tick the box and zoom the black bars away, the image would be better again since there is no processing going on of the black bars as well?
70MM is offline   Reply With Quote
Old 8th October 2017, 00:15   #46313  |  Link
dvd1
thanks for the example, but you can not make an example with pictures of a video?
thank you very much
Old 8th October 2017, 00:25   #46314  |  Link
Originally Posted by Anime Viewer View Post
What temperatures should be of concern?
From running monitoring tools default GPU temp is 47* C and max its running at appears to be 69* C. From what I recall from the past 90-100+* C might be of concern.
CPU cores are reporting temperatures from 69*C to 88*C.
I'm not familiar with what a "tile" size is. They are small little lines (don't go very far across the screen) that seem to be randomly spread in their location.
88 sounds high but it is the cpu. gpu looks ok but that doesn't mean it is not defect.
one thing you could try is running a torture benchmark and see if you get the same artifacts to exclude a problem with madVR.
You're saying they're not 4:3, but maybe 3.9:3 or something like that? Must be the fault of the studio doing the encoding then.
dvd/broadcast is/was created with a "overscan" part: https://en.wikipedia.org/wiki/Safe_area_(television)
there can be anything in there cameras uneven blackbars random noise what ever not a mastering error just a bad spec.
it just means rendertimes will be low if blackbars are removed and nothing else changes because madVR processes less pixel now. with zooming it may need more processing.
Old 8th October 2017, 00:32   #46315  |  Link
70MM
So one gains in one area but then looses in another. lower render times but higher processing due to the zoom thats required.
Old 8th October 2017, 00:36   #46316  |  Link
you either loose performance and you win it. it depends on the zooming.
if you are presenting a 21/9 movie from a BD on a 16/9 screen and you don't zoom black bars but crop them than you clearly win performance.
Old 8th October 2017, 00:53   #46317  |  Link
AngelGraves13
teaser:
blocking -> cleaned
mosquito -> cleaned
Yay! Finally...I've been saying we needed a deblocking filter for years now.
What kind of performance hit are we looking at with these enabled?
I'm guessing each setting will have its own checkbox?
AngelGraves13 is offline   Reply With Quote
Old 8th October 2017, 00:56   #46318  |  Link
70MM
I never tick any of the zoom black bars away. I use an Isco anamorphic III lens with motorised masking to 16:9 and 4:3.
Old 8th October 2017, 01:49   #46319  |  Link
dvd1
576 to 1080 p
all bilinear
What devrei improve?
Old 8th October 2017, 03:00   #46320  |  Link
if you give me the source 720x576 unscaled image i can show you.
