#221 | Link |
No, in my case the temp wav generated before sox was 3.78 GB (4,069,374,056 bytes) . lamexp crashed it when triggering sox, but when i did it manually it worked fine. I didn't use the folders in the parameters though, so the whole command line was much smaller (could it be the case?)
Anyway, it's risky to use by default the C: drive.. i usually have a few GB only - now I had 7 GB... if someone rips a dts from a movie, you're making a 4 GB wav, then a 1.25 GB with sox ... People will start to buy 40-80GB SSDs just for the OS and the situation probably won't improve in the future ps. The length of the path to the temp files in my case is 170. You're getting close to the 256 limit on Windows - some programs have issues with that. |
#222 | Link | ||
Software Developer
![]() Join Date: Jun 2005
As far as I know, there is no way around the MAX_PATH limit on Windows. The limit is 260 tough ^^ |
#223 | Link |
For people that just start the application and just upgrade when the message pops up, well, they don't know such feature has been added without reading about it somewhere. I don't know how many people check each menu with every upgrade. Maybe a small window below the "new update available" or when the new version starts for the first time describing the significant changes would be useful?
Regarding file names. The actual limit is 256, because the MAX_PATH is 260 and you're using 3 for "X:\" and the fourth for the terminating NULL character. Anyway, this is an API limit, and it's no longer the case for the Unicode versions of most functions - see this article: http://msdn.microsoft.com/en-us/library/Aa365247 - you can use up to about 32767 *bytes* (utf8 characters can take 1 to 3-5 bytes, normally maximum 3, more utf8 accepts and is valid according to standard, but for simplicity you're not supposed to use them) The problem is you can't reliably know those command line tools are compiled and know how to read files with such long file names, without checking each one and building your own version, I'd say it's at least unreliable. |
#224 | Link | |||
Software Developer
![]() Quote:
Anyway, on Windows 7 the length of the path to the default %TEMP% folder is 28 characters + length of the user account name (35 in total here). That's enough room for LameXP to create its temporary files.
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 21st March 2011 at 01:18. |
#225 | Link |
It's quite possible to create and work with such files, it's just that you need to use the unicode functions instead of the default ANSI ones. Oh, and I think you have to be sure each segment of the path is below 260 ansi characters.
Here's a code I wrote right now in a few minutes... it's visual basic 6 but uses the windows api: Code:
Private Type SECURITY_ATTRIBUTES nLength As Long lpSecurityDescriptor As Long bInheritHandle As Long End Type Private Const FILE_SHARE_READ = &H1 Private Const FILE_SHARE_WRITE = &H2 Private Declare Function CreateDirectory Lib "kernel32" Alias "CreateDirectoryW" (ByVal lpPathName As String, lpSecurityAttributes As SECURITY_ATTRIBUTES) As Long Private Declare Function CreateFile Lib "kernel32" Alias "CreateFileW" (ByVal lpFileName As String, ByVal dwDesiredAccess As Long, ByVal dwShareMode As Long, ByVal lpSecurityAttributes As Long, ByVal dwCreationDisposition As Long, ByVal dwFlagsAndAttributes As Long, ByVal hTemplateFile As Long) As Long Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long Private Sub Form_Load() Dim ret As Long Dim s As String Dim sec As SECURITY_ATTRIBUTES Const folname As String = "This is a folder with a very long name because I like very long names and nobody can stop me from making them, they are so cool and magical" Const filname As String = "This is a file with a very long name because I like very long names and nobody can stop me from making them, they are so cool and magical" ret = CreateDirectory(s, sec) MsgBox "Created folder " & folname & ", got reply " & CStr(ret) & " (0 means failure)" s = StrConv("\\?\C:\" & folname & "\" & filname, vbUnicode) ret = CreateFile(s, GENERIC_WRITE, FILE_SHARE_READ Or FILE_SHARE_WRITE, ByVal 0&, CREATE_ALWAYS, 0, 0&) MsgBox "Created file ::" & folname & "::, in the previously created folder, got handle " & CStr(ret) ret = CloseHandle(ret) end sub ![]() Total length 281 characters. Funny though, stuff like echo "1" >"This..." doesn't work, as it won't find the file... same with copy con "this..." Code:
C:\This is a folder with a very long name because I like very long names and nob ody can stop me from making them, they are so cool and magical>copy CON "This is a file with a very long name because I like very long names and nobody can stop me from making them, they are so cool and magical" The file name is too long. 0 file(s) copied. Last edited by mariush; 21st March 2011 at 02:26. |
#226 | Link |
@mulder
as mariush already said, it's wav to mp3/vorbis bug (haven't tested with other). my wav is only 3gb, less than mariush's. I have 20gb free space so I don't think space is the problem and I'm using the latest lamexp #326. I think there's also no problem with long filenames, I have longer filenames before and it worked. Like I said before, I tried to convert to wav first, after that convert it to mp3/vorbis but still failed. Code:
"C:/Documents and Settings/Leon Lanford/Local Settings/Application Data/Temp/0903bfae0f0d4faa8bdb392e36f54688.tmp/tool_oggenc2_sse2.exe" -b 56 -o "C:\Documents and Settings\Leon Lanford\Desktop\[Keroro].Movie.03.[CC0F1970]_track2_jpn.ogg" "C:\Documents and Settings\Leon Lanford\Desktop\[Keroro].Movie.03.[CC0F1970]_track2_jpn.wav" Skipping chunk of type "JUNK", length 28 Opening with wav module: WAV file reader Mode initialisation failed: invalid parameters for bitrate Exited with code: 0x0001 Sorry I cannot provide sample because my upload speed is really slow, maybe you can ask mariush. |
#227 | Link |
Software Developer
Hmm, I would understand if SoX failed to process Wave files with a size of 4+ GB, as normal Wave files can't exceed a size of 4 GB (a limitation to the underlying RIFF format).
So AC3Filter/Valibdec will output "RF64" Wave files, if the final size actually exceeds 4 GB. Wouldn't be a surprise of SoX failed to process such RF64 files, but with ~3GB files it should work. I will try to re-produce the issue with a bigger Wave file. But if that turns out to be a limitation in SoX, there's not much I can do about it... |
#228 | Link |
Software Developer
Okay, I just converted an 6ch AC3 file, which I had extracted from one of my DVD's, to the MP3 format with LameXP.
Everything went through just fine: http://pastie.org/private/r3u9ngl7p875mm5p1j6pyg ![]() The size of the source AC3 file is 316 MB, the intermediate Wave file was like ~3 GB in size, the downmixed version was still about 1 GB in size. As you can see, the decoding (Valibdec), the downmixing (SoX) and the encoding (LAME) all completed successfully... BTW: I just fixed a minor bug in LameXP's code for parsing the Valibdec output. This bug caused the log to be flooded with messages like this: [ 0.5%] Frs: 3560 Err: 0 Time: 0:01.203 Level: 0 dB FPS: 2959 CPU: 17.9%
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 21st March 2011 at 15:30. |
#229 | Link |
What's with the
Duration : 01:34:07.97 = 271102464 samples ~ 423598 CDDA sectors File Size : 42949672.00G Bit Rate : 42949672.442949672.00G |
#230 | Link | |
Software Developer
Meanwhile: First attempt for cover artwork support.
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 25th March 2011 at 12:55. |
#231 | Link | |
Software Developer
LameXP v4.01 Final
![]() https://github.com/lordmulder/LameXP/downloads Quote:
#232 | Link |
Software Developer
New experimental snapshot available:
This is the first build compiled with Visual Studio 2010, so please report any issues you may encounter. Due to a limitation of Visual Studio 2010, the minimum supported operating system is Windows XP with Service Pack 2 from now on. Furthermore we have a new translation: Korean!
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 11th April 2011 at 14:40. |
#233 | Link |
Software Developer
I overhauled the initialization routine, so the startup should be slightly faster now, as fewer files need to be extracted.
(BTW: Is anybody else experiencing that SourceForge suddenly takes extremely long, like 5 hours or so, to make new downloads available?)
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 14th April 2011 at 11:42. |
#234 | Link |
re Source Forge
"(BTW: Is anybody else experiencing that SourceForge suddenly takes extremely long, like 5 hours or so, to make new downloads available?)"
For what it is worth I have been offered and downloaded updates using LameXP 'Check For Updates' before they appeared on the beta folder list @ http://sourceforge.net/projects/lame...%20%28BETA%29/ |
#235 | Link | |
Software Developer
And I usually push updates to the auto-update server first, before uploading them to other mirrors. However no updates have been pushed to auto-update since the v4.01 final release. So all builds prior to #418 should still update #418 (aka "v4.01 final") and later snapshot builds should not update at all, at the time being...
#236 | Link | |
I'm liking the new Lame build 4.01 especially now the "hanging when selecting output folder is fixed" but talking of ogg...
When using abr bitrate, at very low bitrates (32k) speech sounds like it has a tiny but noticeable "echo" to it. Has anyone else heard this? Is there a setting to get round this? Apart from that - great! |
#237 | Link | ||
Software Developer
![]() Quote:
![]() (BTW: Maybe you want to try a Speech-Codec, like Speex, for ultra-low bitrate speech encodes)
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 14th April 2011 at 01:02. |
#238 | Link |
Software Developer
LAME v3.99 has finally gone Beta. Please see the LAME Changelog for details ![]()
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 19th April 2011 at 22:07. |
#239 | Link |
Software Developer
http://sourceforge.net/projects/lame...A)/2011-04-19/ Updated to Qt SDK v1.1 (Qt v4.7.3). |
#240 | Link |
I just Updated to the newest Version and everytime i encode with CBR/320kbit/s the Final File is encoded @ 160kbit/s
I tried it a few times but everytime i encode it the 160kbit/s File is the Result Is this a Bug? Greetings! |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
