#162 | Link |
Thank you very much. Everything works great!
BTW, can anyone explain me why newer Ogg encoders produce significially larger files than the older ones? I compared files produced by LameXP 3.18, LameXP 4.00, and jetAudio 8.0.11. I encode music at Q8 (e.g. Mana - "Arde el Cielo - Vivo"). The sizes of the compressed CD are: LameXP 3.18 - 130 megabytes, LameXP 4.00 - 158 megabytes, and jetAudio 8.0.11.1600 - 159 megabytes. |
#163 | Link | |
Thanks for the new LameXP |
#164 | Link | ||||
Software Developer
![]() Join Date: Jun 2005
![]() Also this has nothing do with "paranoia". This forum has clear rules that all users accept when signing up. And the job of the moderators is to uphold these rules. The sensitivity for "warez" is high, yes. And that's for good reason. We don't want that the people who are running this board get into serious trouble! But if a user thinks his post/thread was removed/closed for no good reason, then he can always send a PM to the moderator in order to clarify the situation... Quote:
In any case the 'JUNK' chunk has to be written at the beginning of the file, because we must be prepared for writing the "ds64" chunk later, if necessarily. And to make this clear again: When the final size is below 4 GB, then ValibDec writes a perfectly valid RIFF/Wave file. The 'JUNK' chuck doesn't matter, as all reading application must ignore that chunk. It is evident that that applications which fail to read the Wave file just because of the additional 'JUNK' chunk are broken! Consequently the one and only question here is: Do we care enough about these broken applications to implement a workaround? Or should we encourage the authors to fix their RIFF/Wave parsers? (If we modified the Wave writer to not write the 'JUNK' chunk, we couldn't turn the file into a RF64 file later anymore, which means we would kill support for output files larger than 4 GB) Quote:
![]() Quote:
The differing output sizes with VBR mode can be explained by different versions of OggEnc (libvorbis) being used. However comparing only the file sizes between the different versions doesn't tell you anything! Instead you would have to adjust the VBR values, until both files have the same file size again. Then (and only then) you can compare the sound quality and decide which version is better... (Alternatively you could adjust the VBR values until both files have the same sound quality and then compare the files sizes. But that's probably hard to do ^^)
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 23rd February 2011 at 12:33. |
#165 | Link |
What I'm saying is that since you're modifying that tool to add Unicode support, you could in theory add a switch in the command line options (or some way to pass this to the tool, not sure how your app interacts with it), so that the tool will "TRUST" you that the output wav file will NOT exceed 4 GB or whatever the limit is. If the flag/switch in the command line is missing, just work like it works now. You should be able to determine based on number of seconds and channels the mp3/ac3/etc how much data you will have so you could pass this switch safely for files you know they won't reach that limit.
So if you pass that flag, let's say "-force-old-wav", the wav output class/whatever stores it, does not write the junk bytes at all and when closing the file, if the actual data is larger that what's allowed, enter the maximum allowed. If total length and data is smaller than the limit for the format, it will play on all software, no junk, no ds64 chunk if total lenght and data is larger, it will still play on all software, no junk or ds64 chunk but the data in the header will record the maximum number of samples allowed (basically truncating everything over max samples). So the rest of the data in the wav file would be ignored by players (not sure, maybe you'd need to seek to the end of the maximum samples and write there the ending for the chunk). |
#166 | Link | |
Software Developer
Still that option would only be helpful as a workaround for broken reading applications, which do not handle the 'JUNK' chunk as they are supposed to ![]() Fortunately most applications are not broken in this regard. So I currently think this wouldn't be worth the effort. Especially when considering that, in case you really encounter one of the broken applications, the solution is very easy: Re-save the file with SoX once and that's it. Probably I will add a short note about this issue to the F.A.Q. document and then let the matter rest... [EDIT] Done! [/EDIT]
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 23rd February 2011 at 15:46. |
#170 | Link |
Any particular reason for including unstable alpha to supposedly stable and final GUI?
LAME 3.99a is on heavy alpha development and far from any beta release right now. It's untested. No warning or any message for user? No choice between stable 3.98.4/unstable 3.99? A huge thanks for the final release. Last edited by IgorC; 24th February 2011 at 00:51. |
#171 | Link | |
Software Developer
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 24th February 2011 at 01:09. |
#173 | Link |
Software Developer
The last time I checked (before the LameXP v4.00 release), the latest tag in LAME's CVS repository was "lame3_99alpha11". Consequently that was the version I built. I just checked again and there is a "lame3_99alpha12" tag now (and HEAD is developed as 3.99a13 currently). But since my time machine is currently out of order, I will update to the latest LAME tag in the next LameXP release version.
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 24th February 2011 at 12:24. |
#174 | Link |
about LAME 3.99 alpha
http://www.hydrogenaudio.org/forums/...dpost&p=744961 since alpha_12 newer --vbr--new is set by default. Last alpha 13 is here http://www.rarewares.org btw, Mulder, if you are interested there is a new version of Aotuv Vorbis with a lot of tunings. Last edited by IgorC; 24th February 2011 at 12:46. |
#175 | Link | |
Software Developer
http://lamexp.git.sourceforge.net/gi...3c5d3e5b563617 |
#177 | Link |
Software Developer
New snapshot available:
http://sourceforge.net/projects/lame...A)/2011-02-25/
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 25th February 2011 at 02:12. Reason: Bugfix |
#179 | Link | |
I meant, if the updating of lame.exe could be done by the users or if You have any reasons not to recommend this. You do not need a time machine for that. |
#180 | Link |
Software Developer
Generally it wouldn't be a very good idea to encourage "Newbie" users to replace the built-in LAME encoder with an arbitrary build that hasn't been tested to cooperate with GUI properly. There are all kinds of problems that might occur. At the same time "Advanced" users who can't wait for the next update and who know what they are doing can make their own builds at any time (the advantage of OSS).
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 25th February 2011 at 14:20. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
