#882 | Link |
Light problem with xysubfilter.
With this video https://www.nyaa.se/?page=view&tid=861780 at 0min58s "part 2 of 3" change position with xyvsfilter and not with internal sub renderer of mpc-hc (normal) xyvsfilter ![]() mpc sub renderer ![]() |
#884 | Link | |
Quality Checker
I love Doom9 |
#885 | Link | |
#891 | Link | |
I try the last bulid version of mpc-hc and others versions: same problem. |
#893 | Link | |
I am happy because the sub renderer of mpc-hc is not bug free. Sometimes subs flashs. |
#894 | Link |
I load extrenal subtitles in IDX/SUB format (the first subtitle should appear at 03:04) for a movie in MKV format (sample). If I set the delay higher than -20 ms (e. g. -21 ms) the subtitles disappear at all.
MPC-HC 1.7.10.264 / EVR (CP) / XySubFilter 3.1.0.746 / Windows XP SP3 x86
Magically yours Raistlin |
#895 | Link |
How can I make the subtitles always look the same regardless of the video resolution, like with the internal subtitle renderer of mpc-hc?
I'm trying to set up XySubFilter (3.1.0.746) + madVR (0.91.4) + mpc-hc (1.7.10.269) and I cannot get it to work. If I use the render layout option "Customize" then the subtitles get squashed or stretched depending on the video aspect ratio, and with "AR adjusted" or "Original video" the border options start depending on the video resolution, so if you set it up to look OK on a 1920x1080 video the border becomes super-thick on a 640x480 video. This is with regular SRT. In addition the style override setting "Force default" seems to be completely unusable as with sane font settings the subtitles become super-tiny on 1920x1080 videos for some reason, and if you increase the default font size and margins to look decent there, then they'll of course be humongous for low-res videos and SRT subtitles instead. Am I missing some obvious setting that would fix these issues? Last edited by Piyoko; 17th December 2016 at 08:28. |
#896 | Link |
Hyperthread
No Text in Properties
I opened the XySubFilter 3.1.0.746 x64 BETA3 properties, and there was no text on any of the tab's pages. However, the tab itself has text.
I'm running Windows 10 1703 "Creator's Update". I'm wondering if it has anything to do with the update? Is anyone else experiencing this issue? Any help would be greatly appreciated! I have included some screenshots below. ![]() ![]() |
#897 | Link |
#898 | Link |
Anyone can help me? I think I did an idiotic mistake. I was using xy-vsfilter. I had a movie with embedded subtitles with colors. I wanted to try to disable all colors, but couldn't find a way. Ended up going to xy-vsfilter options by double-clicking the green vobsub arrow in the tray. Went to Colors, and I disable everyhing, just to see if something would happen. Unfotunately, I can't get any subtitle to load anymore (and thus cannot access the menu). Tried to unregister and reregister, no go. Tried to install xy-subfilter, won't work either. How can I get to that menu and re-enable the colorspaces?
Thx! |
#900 | Link |
YES. thank you! And yes, using MPC-HC.
Is there a way to have the renderer discard the color information from the subtitles file? I have a file where the text is white in general, but switches to other colors when there are several characters speaking, which is really annoying... Would prefer to have it white all the time. |
