Old 10th October 2018, 19:09   #6401  |  Link
hajj_3
are we ever going to get a changelog for v2.9 then?
Old 10th October 2018, 20:05   #6402  |  Link
birdie
birdie's Avatar
Version 2.9
Release date - 05/10/2018
New features
  • Support for chunked encoding
    Option:`--chunk-start and --chunk-end` Frames preceding first frame of chunk in display order will be encoded, however, they will be discarded in the bitstream. Frames following last frame of the chunk in display order will be used in taking lookahead decisions, but, they will not be encoded. This feature can be enabled only in closed GOP structures. Default disabled.
  • Support for HDR10+ version 1 SEI messages.
Encoder enhancements
  • Create API function for allocating and freeing x265_analysis_data.
  • CEA 608/708 support: Read SEI messages from text file and encode it using userSEI message.
Bug fixes
  • Disable noise reduction when vbv is enabled.
  • Support minLuma and maxLuma values changed by the commandline.
Old 10th October 2018, 20:14   #6403  |  Link
katzenjoghurt
@Forteen88:
Thanks, man. That's where I'm usually grabbing my builds from. But no 2.9 yet.
But there are cool guys here too, providing builds.
@nevcairiel:
Moin nevcairiel,
thanks for the insights! Huh.
The x265.exe --V output made me think that there are some AVX2 optimizations in the project's code itself. That's why I'm asking.
But you're saying it's just about compiler optimizations. Hm.
Old 10th October 2018, 20:18   #6404  |  Link
Forteen88
Herr
Originally Posted by katzenjoghurt View Post
@Forteen88:
Np. There are 2.9 builds there under "x265 binaries for Win64/32 ó stable branch"!
Forteen88 is offline   Reply With Quote
Old 10th October 2018, 20:20   #6405  |  Link
@katzenjoghurt:
For the core functions of the x265 encoder (especially those which are most often called in tight loops), some of the following sentences may be true, depending on performance gain, development progress in different bit depths, etc.:
  • There is basic C/C++ code. It depends on the compiler options which instruction set is used. If your CPU supports it, x265 can use this code. If not, it will crash due to unsupported instructions.
  • There is hand-optimized assembler code with MMX/SSE2 optimization. If your CPU supports it, x265 can use this code. If not, x265 should use simpler code.
  • There is hand-optimized assembler code with SSSE3/SSE4 optimization. If your CPU supports it, x265 can use this code. If not, x265 should use simpler code.
  • There is hand-optimized assembler code with AVX optimization. If your CPU supports it, x265 can use this code. If not, x265 should use simpler code.
  • There is hand-optimized assembler code with AVX2 optimization. If your CPU supports it and you enable it explicitly, x265 can use this code.
Well, for any x86-64 CPU today, SSE2 should be the minimum sensible supported instruction set. But already there are small differences. I remember the Athlon 64 (AMD K8) family being a threshold of providing an SSE2 implementation which is considered relatively "fast", but despite supporting SSE3 in specs, x264 and x265 will refuse to use it.
Usually all these code variants are present in a binary of (lib)x265, except they are excluded during compilation (e.g. you may disable all assembler code paths; but why would you want that?).
Old 10th October 2018, 22:35   #6406  |  Link
katzenjoghurt
Originally Posted by Forteen88 View Post
Np. There are 2.9 builds there under "x265 binaries for Win64/32 — stable branch"!
OMG! You are right.
I ignored the right table as I always pick my versions from the left side.
Thanks again!
Thanks, LigH!
I understand this as: Unless a build mentions something else all optimizations are enabled. (?)
I just was looking for some way to verify.
Some context: What led me to the question was a current version of StaxRip which contained an x265.exe and a "x265 AVX2" zip file - and I couldn't tell if the zip was just some oversight or if the "normal" x265.exe is a version without AVX2 optimiziations.
I will just replace it and be done with it... though... I was wondering how to make sure an unknown x265.exe is indeed the "right" version for my machine.
Old 10th October 2018, 23:40   #6407  |  Link
Just a hint:
x265.exe --no-asm --version
x265 [info]: HEVC encoder version 2.9+1-169e76b6bbcc
x265 [info]: build info [Windows][GCC 8.2.0][64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: none!
All assembler optimizations forbidden = only basic C/C++ code used.
But if all assembler optimizations are enabled (and all of them are usually linked in the encoder), it only means they are available in case your CPU supports them (which is detected at runtime). It doesn't mean all of them are used on every hardware. If you don't limit them with the --asm mask parameter, x265 detects what your CPU supports while starting, and selects the code paths with the optimal speed supported by your specific CPU.
x265.exe --version
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT
This x265.exe contains code paths for time-critical assembler routines for MMX+SSE2, SSSE3+SSE4, AVX, and even AVX2. But it runs on an AMD Phenom-II, so it is limited to MMX+SSE2 by the CPU auto-detection.
The very same x265.exe can use AVX or even AVX2 code if you copy it onto a PC with a CPU that supports AVX or even AVX2 and run it there.
{EDIT}If your CPU even supports AVX512, and you insist in using AVX512 instructions, then you need to enable it with an additional parameter --asm avx512 in your command line because it is a bit risky and does not always provide better performance, especially not when your CPU gets temperature throttled. And it will crash if your CPU does not support AVX512.{/EDIT}
So what are these special executables provided on a few sites? In addition to multiple code paths for time-critical assembler routines, also non-critical C/C++ routines get optimized for a modern instruction set, which limits their compatibility; these builds will not even start on older CPU's.
If I would use an x265.exe which was built with C/C++ compiler optimizations for AVX (that is probably what you read for special binaries), it would crash right at the start if run on an AMD Athlon/Phenom which doesn't support AVX, because it would use AVX instructions already for the initialization, already before the encoding even starts. But this is not a time-critical part. There is no serious need to speed up code which runs only once or a few times. – (Jedi mind powers) "This is not the build you are looking for."
Rather generic builds, like mine or Barough's or Midzuki's, are fine for a large range of PC's; builds for x86-64 are probably optimized at least for SSE2 in the code generated by the C/C++ compiler, which is the minimal widely supported instruction set of AMD64 compatible CPU's. And the selection of highly optimized assembler routines for the really time-critical parts is done in the encoder at runtime.
Old 11th October 2018, 01:19   #6408  |  Link
benwaggoner
If your CPU even supports AVX2, and you insist in using AVX2 instructions, then you need to enable it with an additional parameter --asm avx2 in your command line because it is a bit risky and does not always provide better performance, especially not when your CPU gets temperature throttled. And it will crash if your CPU does not support AVX2.
I thought that AVX2 would be used automatically, but AVX512 would only be activated via --asm (which appears to be undocumented in x265.readthedocs.io)
Do I have that wrong?
AVX-512 is only useful with slower UHD resolutions, so it makes sense for it to require an opt in.
Do we have any ballpark sense for how much platform-specific compilation can help encoding performance? I've heard some speculation about ~5% but that was a while ago before the current-gen AMD and Intel processors were out.
Ben Waggoner
My Compression Book
Old 11th October 2018, 08:16   #6409  |  Link
Oops, my mistake ... yes, AVX2 is automatic, only AVX512 is manual.
Old 11th October 2018, 11:55   #6410  |  Link
I would like to see how useful is AVX-512 on 28 core xeon I'm expecting negative speed-up
Old 12th October 2018, 01:15   #6411  |  Link
benwaggoner
If you aren't doing Main10 UHD with a slower+ preset, you are almost certainly correct.
That said, an updated microarchitecture could potentially make AVX-512 be more generally useful. AVX2 became a lot more useful with (IIRC) Skylake's microarchitectural change which reduced thermal throttling doing AVX2, really improving throughput.
Ben Waggoner
My Compression Book
Old 12th October 2018, 01:57   #6412  |  Link
qyot27
qyot27's Avatar
So, expect a reasonably-mature AVX-512 ca. Sapphire Rapids?
Old 12th October 2018, 03:47   #6413  |  Link
benwaggoner
Plausibly. But x265 maybe the most CPU stressful real software in the world, hitting the cores, caches, and SIMD super hard at once. Hopefully Intel is benchmarking x265 during development!
It is hard to predict the optimal performance tuning of a given CPU without actually having it, as theoretical improvements donít always work as expected.
Iím curious if anyone has benchmarked performance improvements from arch-specific and profile-driven builds.
X265 is also pretty stressful for compilers too.
Ben Waggoner
My Compression Book
Old 12th October 2018, 04:04   #6414  |  Link
alex1399
The x265 reported an error that the file "F:\x265" is not found(maybe it shows file could not open if I recall correctly) when I use --analysis-reuse-file F:\x265 during the second pass encoding.
Great, now I couldn't reproduce this error again.
It has been five days that zeranoe ffmpeg does not release a new version with x265 2.9.
alex1399 is offline   Reply With Quote
Old 12th October 2018, 09:58   #6415  |  Link
Nah... They will ask Principled Technology to do "proper" benchmarks They are very good at disabling cores before testing...
Old 12th October 2018, 10:22   #6416  |  Link
Fresh build by media-autobuild_suite, GPL v3, Zeranoe-like selection.
ffmpeg version N-92161-gf6d48b618a Copyright (c) 2000-2018 the FFmpeg developers
built with gcc {7.3.0|8.2.0} (Rev3, Built by MSYS2 project)
configuration: --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv
libavutil 56. 19.101 / 56. 19.101
libavcodec 58. 33.100 / 58. 33.100
libavformat 58. 18.104 / 58. 18.104
libavdevice 58. 4.105 / 58. 4.105
libavfilter 7. 33.101 / 7. 33.101
libswscale 5. 2.100 / 5. 2.100
libswresample 3. 2.100 / 3. 2.100
libpostproc 55. 2.100 / 55. 2.100
Old 12th October 2018, 18:56   #6417  |  Link
Forteen88
Herr
x265 2.9+2 released now!
http://www.msystem.waw.pl/x265/
Old 12th October 2018, 21:59   #6418  |  Link
^ ffmpeg contains v2.9+2.
Old 14th October 2018, 15:10   #6419  |  Link
DotJun
Is there a downside to enabling avx512 on an intel X chip?
Sent from my iPhone using Tapatalk
DotJun is offline   Reply With Quote
Old 14th October 2018, 17:12   #6420  |  Link
As far as I remember from previous discussions...
Most of all: Temperature throttling. AVX512 can be a heavy burden.
Furthermore, switching the CPU into and out of AVX modes can be quite time consuming, which has to be considered in the optimization efforts, and it can make it less efficient for lower resolutions.
Please try to read back, and I believe a thread about AVX512 and AMD Ryzen got even separated from this generic x265 encoder thread.
