#7601 | Link |
Sorry to repost, MediaInfo.NET supports a special presentation for x265 parameters, it can be enabled in the settings.
Meanwhile, it was ported to run on .NET Framework 4.8 (so people don't need to install .NET Core) and it has a PowerShell based folder view. https://github.com/stax76/MediaInfo.NET https://forum.doom9.org/showthread.php?t=176886 ![]() |
#7603 | Link |
SuperVirus
x265.exe 3.3+26-193db49
http://msystem.waw.pl/x265/ Code:
Fix bug in frame-dup + multi pass Add save-load regression test CLI for Frame Duplication |
#7605 | Link | |
Testeur de codecs
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
#7607 | Link |
SuperVirus
x265.exe 3.3+29-1e3dbf0
--- Cleanup --- save-load-tests: Fix CLI --- EQT Updates. 1. Improves documentation in help and x265readthedocs for rskip cli options. 2. Renamed rskip variable in x265_param structure & rectified regression clis. 3. Removed rskip mode 3 which is same as mode 2 with min-cu-size 16. |
#7608 | Link |
Updated (git source):
x265-3.3+4-g6a7df3229-* (marked as 3.4 branch, but the version shows 3.3+4 / maybe stable) [* built with msvc1925 and gcc11.0.0] x265-3.3+27-g4780a8d99-* (master branch) [* built with msvc1925 and gcc11.0.0] Downloadlink, see my sig |
#7609 | Link | |
![]() Is there a reason why they no longer support raw .avs (no piping) input? |
#7611 | Link |
Are there builds that support both avs and vpy? libavformat supports both, that's how mpv opens avs and vpy, but does not support portable mode, blocks DLL loading from path env var.
#7612 | Link | |
In any case, be good if you can make your x265 builds work with raw input too. Thanks ![]() |
#7613 | Link | |
#7614 | Link |
![]() I've now remembered how I was previously using raw input with x265... It was when Stax was using Wolfberry's builds. So seems it is possible to implement at least, unless something's changed with x265 itself since then. I'll leave it in your capable hands anyway ![]() |
#7616 | Link |
If somebody is looking for vpy code:
https://github.com/rigaya/NVEnc/blob..._input_vpy.cpp https://github.com/FFmpeg/FFmpeg/blo.../vapoursynth.c Last edited by stax76; 11th May 2020 at 23:26. |
#7617 | Link |
Maybe I build a chunk encoding console app as it seems to be relatively simple and nobody else seems to be interested in building it. Are there any special x265 settings needed? x264 has a --stitchable option. How does ripbot264 do it? vspipe and avs2pipemod allow defining start and end frame. Are two chunks enough?
#7618 | Link | |
#7619 | Link |
x265 3.3+27-g4780a8d99 (multilib, GCC 10.1)
#7620 | Link |
Thanks, so --chunk-start and --chunk-end, would be helpful if somebody can share experience with it. How many extra frames are needed? I'll use vspipe and avs2pipemod for trimming, modifying the avs/vpy file has too many implications.
