12th June 2020, 05:45 | #7641 | Link | ||
Pig on the wing
I checked a couple of frames where I found some onion artifacting -- happened to be next to edges -- and rskip 2 did fix them. So it's definitely helpful. Quote:
And if the band you're in starts playing different tunes I'll see you on the dark side of the Moon... Last edited by Boulder; 12th June 2020 at 08:52. |
12th June 2020, 14:11 | #7642 | Link | |
Thanks for all the suggestions guys!
I will try them out as soon as I can. Quote:
Will try this too. Last edited by K.i.N.G; 12th June 2020 at 14:57. |
12th June 2020, 20:25 | #7645 | Link |
I just meant to say it surprised me, but forgot a word. For most of the stuff I've tried it one (just my personal collection, nothing terribly interesting) rskip 2 produces slightly larger but very similar looking encodes, so realizing that it was making such different files on a basic level was a jolt.
IDK how it behaves when you have studio-grade clean/detailed sources, but for me rskip mode 2 needs an annoying amount of tuning, because with the default edge threshold some clips are a little better than with mode 2, while others just fall apart entirely. |
12th June 2020, 22:08 | #7646 | Link | |
It'd be good to try with some files that used to have artifacts with rskip and see if and how they are improved with --rskip 2. |
17th June 2020, 20:11 | #7648 | Link |
Do following x265 crf values still make sense?
--crf 10 Super High --crf 12 Very High --crf 14 Higher --crf 16 High --crf 18 Medium --crf 20 Low --crf 22 Lower --crf 24 Very Low --crf 26 Super Low I think the values were established many years ago when 4K was not popular. There is a request to increase the value by 4: --crf 14 Super High --crf 16 Very High --crf 18 Higher --crf 20 High --crf 22 Medium --crf 24 Low --crf 26 Lower --crf 28 Very Low --crf 30 Super Low It would be identical to the x264 values then which also start at 14 and end at 30. Change or not?
17th June 2020, 20:39 | #7649 | Link |
Sorry for the late reply but our remote desktop software crashed and didn't have access to the servers...
After a quick test adding these parameters to the encode improved the quality in parts with motion "--rskip 2 --max-merge 2 --rd-refine" with about the same bitrate. The artifacts are still there but far less (and much less perceptible when playing the video). I'll see if i can experiment some more with the settings later, maybe it can be improved even more. Thanks to everyone for the usefull input and suggestions! Last edited by K.i.N.G; 17th June 2020 at 22:00. |
17th June 2020, 20:47 | #7650 | Link | |
And then there's the fact it also depends on the type of source. HDR needing a lower CRF than SDR etc. I dont think 'normalizing' the CRF with x264 is that important if it is even possible... since result will always be different depending on the footage imho. |
18th June 2020, 02:01 | #7651 | Link |
Yeah. CRF fundamentally maps to QP, and while AVC and HEVC have similar QP scales, HEVC can do more with higher QP than AVC can. Any QP delta between x264 and x265 is going to vary based on profile and content. That said, I think the average CRF delta for the same subjective quality would be less than 4. That said, CRF 16 IS generally very high quality with x265. 10-12 are almost always psychovisually indistinguishable from 14 except for some heavy noise edge cases.
18th June 2020, 09:14 | #7652 | Link |
Pig on the wing
At CRF 10-14, I wouldn't be surprised if the encode sometimes ended up at a higher average bitrate than the source itself
18th June 2020, 11:40 | #7654 | Link |
A test encode I did come out like this:
Source: HEVC, Main 10@L5.1@High, 3840x2160, 23.976 FPS, 57.5 Mbps Settings: x265.exe --crf 14 --preset slower --output-depth 10 Result: HEVC, Main 10@L5@Main, 3840x2160, 23.976 FPS, 32.9 Mbps It was a sample from the movie Snow White and the Huntsman, had some noise, not particular much. It would also be possible to add additional items, very, super, extreme, ludicrous... My sample with the highest bitrate is: HEVC, Main 10@L5.1@High, 3840x2160, 23.976 FPS, 70.0 Mb/s Some old boring movie called Crash.
18th June 2020, 20:00 | #7656 | Link | |
HDR always being 10-bit also helps. Ballpark, HDR needs ~20% fewer bits than 8-bit SDR to get to a similar subjective quality. |
18th June 2020, 21:14 | #7657 | Link |
Derek Prestegard IRL
Worth mentioning, x265 does require special tuning for good quality HDR.
The default hdr-opt is pretty good for PQ YCbCr (HDR10), but when encoding for Dolby Vision Profile 5 using PQ IPT (quite similar to ICtCp) masquerading as YCbCr, some additional tuning is needed to mitigate banding artifacts, even at high bitrates. I've seen some proprietary patches to x265 to improve performance here. Hopefully MCW makes something like this in mainline x265 |
18th June 2020, 21:23 | #7658 | Link | |
Pig on the wing
19th June 2020, 03:25 | #7659 | Link | |
Sent from my SM-T837V using Tapatalk |
