#7961 | Link |
If you're using mingw (as I am), they are in the generated build folder. For example, CMakeFiles\cli.dir\linklibs.rsp. If you generated msvc project, it's somewhere in the linker options.
#7962 | Link | |
The only *.rsp files I see are objects1.rsp in 8bit/CMakeFiles/x265-shared.dir (I'm trying to make a multi-lib static build). It contains only obj files created by the basic x265 compilation.
With -DENABLE_AVISYNTH=ON in the cmake configuration, the x265.exe contains avs_ symbols; AviSynth+ headers are present in local includes. With -DENABLE_VPYSYNTH=ON in the cmake configuration, the x265.exe contains vsscript_ symbols; libvapoursynth.a + vapoursynth[-script].pc are present in local libs[/pkgconfig]. With -DENABLE_LSMASH=ON in the cmake configuration, the x265.exe contains LSMASH_ symbols and even a version number (printed in the version console output); liblsmash{a|pc} are present in local libs[/pkgconfig]. With -DENABLE_ZIMG=ON in the cmake configuration, the x265.exe contains zimg5graph12_ symbols; libzimg.a + zimg.pc are present in local libs[/pkgconfig]. All that works without any other *.rsp files. {libavcodec|libavdevice|libavfilter|libavformat|libavif|libavutil}.{a|pc} are present in local libs[/pkgconfig]. Apparently, with -DENABLE_LAVF=ON in the cmake configuration, cmake detects them (or would error out otherwise), so I assume ld can find them like all the other libraries (especially like lsmash and zlib). Headers and libraries should match because MABS compiled a whole ffmpeg the other day, before I tried to build x265_Asuna afterwards. Therefore I agree with: Quote:
![]() PS: x265cli.cpp.obj and objects.a contain libav* version string format templates; lavf.cpp.obj and objects.a contain avformat_close_input. Does the command line need more extra parameters that ff libs can be linked correctly? Last edited by LigH; 15th January 2021 at 09:15. |
#7963 | Link |
#7964 | Link |
@qyot27:
ENABLE_STATIC_LAVF should be enabled by default (if LAVF and CLI are enabled), if I read that first location correctly; I already found this option, still tried to enable it explicitly in the cmake command line parameters (-DENABLE_STATIC_LAVF=ON), but it did not help as such... VapourSynth, LSMASH and ZIMG packages are found without CMAKE_PREFIX_PATH, and I believe libav libraries (via the "FF" package) are found too; just linking them fails for a different reason. As if they are found but not used, maybe... |
#7965 | Link | |
What CLI option(s) should I be tweaking to help stop chroma bleed? It seems that no matter how low I go with CRF, my reds will still bleed out into neighboring areas
My options are roughly a mix of veryslow and placebo, with some other options thrown in. Here's one from a recent 1080p/HDR test: Quote:
I know my settings are a bit absurd, I'm getting around 1.2FPS on a 3900X with around 60% load, but my goal is transparency mostly, with a tiny hint of keeping speeds above 1FPS Side question: Is there anyway to increase load usage with command line x265 without affecting PQ? Ie without using something like RipBot's distributed encoding |
#7966 | Link |
Broadcast Encoder
Chroma bleeding is actually really weird, it shouldn't really happen and I think I know why it's happening to you!
Your input is an AVS Script from what I see, which handles 4:2:0 Type 1 but not 4:2:0 Type2! So, the chroma location is wrong, hence the "bleeding". Can you try with: Code:
ffmpeg.exe -i "AVS Script.avs" -vf scale=out_color_matrix=bt2020nc:out_h_chr_pos=0:out_v_chr_pos=0 -pix_fmt yuv420p16le -strict -1 -an -f yuv4mpegpipe - | x265.exe --y4m - --dither ![]()
Broadcast Encoder Avisynth memes Videotek - Audacity XP LUT Collection - FFAStrans SafeColorLimiter - AAA |
#7967 | Link |
Success! With the great support of Christopher Degawa, main supporter of the media-autobuild suite, I was able to tweak my workflow until I could build an x265 binary with Yuuki-Asuna mod (Asuna branch = based on v3.4-stable). It required some pkgconfig tuning and I found a way to use the "video decoders only" light ffmpeg build as already used by m-ab-s in its x264 binary (option 6); so it should contain support for AVS input, VPY input, LAVF input, MP4 output (L-SMASH), MKV output (Haali, obsolete), and ZIMG scaling.
x265 3.4-Asuna+54 Code:
x265 [info]: HEVC encoder version 3.4+-+54 x265 [info]: build info [Windows][GCC 10.2.0][64 bit] Asuna 8bit+10bit+12bit x265 [info]: (lsmash 2.16.1) x265 [info]: (libavformat 58.65.101) x265 [info]: (libavcodec 58.117.101) x265 [info]: (libavutil 56.63.101) |
#7968 | Link | |
![]() Join Date: Jan 2006
At 4K resolutions, getting it wrong is pretty hard to see, but the lower the frame size, the more screen area an error will take up. |
#7969 | Link |
Update with correct version numbering
x265 3.4+13-g729a838d3+41 (Asuna) Code:
x265 [info]: HEVC encoder version 3.4+13-g729a838d3+41 x265 [info]: build info [Windows][GCC 10.2.0][64 bit] Asuna 8bit+10bit+12bit x265 [info]: (lsmash 2.16.1) x265 [info]: (libavformat 58.65.101) x265 [info]: (libavcodec 58.117.101) x265 [info]: (libavutil 56.63.101) |
#7970 | Link |
x265 v3.4+37-dd1101b6d (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.2.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/Release_3.5 |
#7971 | Link | |
Broadcast Encoder
#7972 | Link | |
#7974 | Link |
ffx264/ffhevc author
there hasn't been any work on SAO for a long time. So doubtful
TV: Samsung 50" QE50Q60T AVR: Yamaha RX-V481 5.1 CD Player: Yamaha CD-S300 DAB+ Tuner: Yamaha T-D500 BD Player: Samsung UBD-M8500 UHD Speakers: Klipsch 5.1 Reference Phono: TEAC TN-180BT |
#7975 | Link | |
SAO can definitely be helpful at moderate-low bitrates. But the x265 implementation has fixed parameters for SAO. Adjusting them some based on bitrate or QP or content analysis could make it a more reliable net benefit even at high bitrates and high detail. |
#7976 | Link | |
Software Developer
![]() Join Date: Jun 2005
#7978 | Link |
Software Developer
I usually include 32-Bit and 64-Bit binaries with my GUI, so we can pick the "best" one for the specific machine at runtime.
Of course, you could ask whether it still makes sense to support 32-Bit systems these days. But the code for supporting multiple architectures is already there in the GUI, so I don't see much reason to drop this feature. ...unless it becomes too cumbersome to obtain 32-Bit encoder binaries ![]() (Another possible use case is Avisynth input: If you want to use "official" AviSynth 2.6, you'll be locked to 32-Bit. And yes, I know there is Avisynth+ as well as VapurSynth now)
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 27th January 2021 at 23:52. |
#7979 | Link | ||
Not that I have any skin in the game or anything, just an aversion to 32-bit for anything performance-critical ![]() |
#7980 | Link | ||
Software Developer
So "best" means we select the 64-Bit binary, if we detect that we are running on 64-Bit system; otherwise 32-Bit binary will be selected. As said before: You can argue that support for 32-Bit OS is mostly irrelevant these days. But since support for multiple CPU architectures has already been implemented in the GUI, supporting 32-Bit OS pretty much comes for free. (provided 32-Bit encoder binaries are easily available ![]() Quote:
(If you pipe from Avs2YUV or similar tool, then we don't need Avisynth support in x265 to begin with)
There was of course no way of knowing whether you were being watched at any given moment. How often, or on what system, the Thought Police plugged in on any individual wire was guesswork. Last edited by LoRd_MuldeR; 28th January 2021 at 02:38. |
