Old 7th July 2016, 19:03   #2041  |  Link
ultim
AVS+ Dev
ultim's Avatar
forget it i found it
EDIT: ok, looks promising. might be interesting for us too to just use this.
AviSynth+
ultim is offline
Old 7th July 2016, 19:19   #2042  |  Link
pinterf
Originally Posted by ultim View Post
Ok so I got home, and since I know that at least for RGB 16-bit images pixels are scaled to 65535, I wanted to make sure that this 256-factor for YUV is not just some shit from MS. I fired up the bt709 spec, and it's true. While I haven't found a direct mention of how to scale to larger bitdepths (it doesn't define 16bit at all, only 10), it still implies simple power-of-two factors simply from the allowed data ranges in 8- and 10-bits. So I guess we should switch to this scale too. EDIT: Oh, I see pinterf already changed it. Good work :thumbs up:
Changed after reading this one, which mentiones 12 bit rec 2020 with the exact black and white levels
pinterf is offline
Old 7th July 2016, 19:27   #2043  |  Link
pinterf
Wilbert, it was then you, who put those planar RGB constants in avisynth.h? The current development unfortunately phase lacks the high bit depth RGB.
When I uncommented and renamed the YUV planar constants in the header three weeks ago, I was thinking what to do with the RGB 48 bit, but wasn't familiar at all with that planar RGB, so the option remained in silence.
pinterf is offline
Old 7th July 2016, 21:02   #2044  |  Link
Wilbert
Ianb added them in avisynth.h. I just uncommented them and added the necessary stuff in order to be able to open and write 16-bit images with DevIL. It was fun to do that, but lost interest and didn't bother to clean it up.
Btw, regarding the functions ConvertTo8Bits(), etc ...
What about replacing them with a single one:
ConvertToBitDepth(bit-depth=8/16/float, dither=none/random/ordered/...)
Then you can add several dither methods later. I only implemented random dithering at that time (because that was a fast method).
Wilbert is offline
Old 8th July 2016, 09:33   #2045  |  Link
ajp_anton
ajp_anton's Avatar
What about dithering to 10 bits, but still using 16 bits to preserve those two extra bits beyond 8? Like when encoding 10 bits with x264. I think dithering should be a separate function where you can set the target bitdepth to dither to (which can then be any integer below the current bitdepth), and the "convert to some bitdepth" should just round/truncate.
ajp_anton is offline
Old 8th July 2016, 09:59   #2046  |  Link
feisty2
I'm Siri
feisty2's Avatar
actually I think it's a bit more complicated than that..
so, uint8_t->uint16_t
tv range should be
y = x * 256
full range should be
x -> y
0 -> 0
128 -> 32768
255 -> 65535
and obviously not a linear conversion
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline
Old 8th July 2016, 10:14   #2047  |  Link
feisty2
I'm Siri
feisty2's Avatar
and "128 -> 32768" is a must in full range case cuz pure black is [0, 128, 128] at uint8_t and [0, 32768, 32768] at uint16_t, and simple * 257 makes [0, 128, 128] go [0, 32896, 32896] and that's not pure black no more so incorrect conversion
feisty2 is offline
Old 8th July 2016, 11:49   #2048  |  Link
asteri
Here. This installer does not include the VC runtimes. If you need them, use the ones from ultim's dl location. I highly recommend to use ricktendo's All In One runtime installer, very compact and all versions you'll ever need included.
r2022? I thought latest version is r1858 MT-pfmod. I became lost in number of releases and their versions. Can you explain what your r2022 has against 1858 MT-pfmod ?
asteri is offline
Old 8th July 2016, 11:55   #2049  |  Link
colours
colours's Avatar
x -> y
0 -> 0
128 -> 32768
255 -> 65535
… No? Where the hell do you even get these funny ideas?
The midpoint is 127.5 for full-range 8-bit video, and multiplying by 257 just gives you 32767.5, which is the midpoint for full-range 16-bit video.
It is a known problem that this convention for full-range YCbCr fails to accurately represent any pure grey colour, which is why there's another convention where the nominal minimum is 0 and the nominal maximum is 2^n, which in turn runs into the problem of failing to accurately represent pure red (#FF0000) and pure blue (#0000FF).
Neither of these conventions is nonlinear, but what you're proposing is.
Also, please type English.
Say no to AviSynth 2.5.8 and DirectShowSource!
colours is offline
Old 8th July 2016, 12:01   #2050  |  Link
Please learn how to read previous pages of forum.
http://forum.doom9.org/showthread.ph...57#post1772657
http://forum.doom9.org/showthread.ph...44#post1772944
ryrynz is offline
Old 8th July 2016, 12:29   #2051  |  Link
asteri
Thank you!
I would recommend ultim to publish these builds as "test builds" also on official page: http://avs-plus.net/
asteri is offline
Old 8th July 2016, 12:37   #2052  |  Link
Thank you!
I don't think that will happen. The most recent changes break some previously compatible plugins plus there has been a lot of code committed recently. A proper build will be posted when ready.
ryrynz is offline
Old 8th July 2016, 12:53   #2053  |  Link
feisty2
I'm Siri
feisty2's Avatar
127.5 agreed, theoretically (0+255)/2=127.5, and 127.5 is not an integer.
agreed, and instead of assuming representing any pure gray color is impossible, I think it makes sense to round 127.5 to 128 and gray colors will be representable, and I will hold on to my point before you link me a doc that explains how full range YCbCr works in detail, got noda last time I googled about full range YUV
I'm 19 not 91 and I'm good with the language I'm typing, and I will roll with it, you don't like it? suck it, bite me! bi-o-tch
feisty2 is offline
Old 8th July 2016, 13:33   #2054  |  Link
feisty2
I'm Siri
feisty2's Avatar
oh, and btw, just say if 127.5 is exactly how standards defined it, and gray colors are not representable, pure black will be rounded to its closest color [0, 128, 128] at uint8_t and [0, 32768, 32768] at uint16_t, your way, * 257, it's gonna be [0, 32896, 32896], my way, [0, 32768, 32768], and obviously the error between 32768 and 32767.5 << the error between 32896 and 32767.5
feisty2 is offline
Old 8th July 2016, 16:26   #2055  |  Link
pinterf
New internal filters ported to 16 bit/float
  • AddBorders
  • LetterBox
  • HorizontalReduceBy2
  • VerticalReduceBy2
  • ReduceBy2 (= Horiz + Vert)
  • BlankClip/Blackness (->FadeXXX )
  • Tweak (todo: sat=0 + Float source = little greenish),
    new param: bool realcalc, always true for 16/float: no integer lookup table arithmetic, pure double
Took a list from here and made a summary of YUV related functions that have NO 16/32 bit version.
Color conversion and adjustment filters
  • ColorYUV
  • Invert
  • Levels
  • Limiter
  • MergeARGB / MergeRGB
Overlay and Mask filters
  • MaskHS
  • Overlay
  • Subtract
Geometric deformation filters
  • SkewRows
Pixel restoration filters
  • Blur / Sharpen
Debug filters (most of it)
  • ColorBars / ColorBarsHD
  • Compare
  • Histogram
  • Info
  • ShowFrameNumber / ShowSMPTE / ShowTime
  • Subtitle
Last edited by pinterf; 8th July 2016 at 22:13. Reason: 16/32 bit ready BlankClip added + Tweak
pinterf is offline
Old 8th July 2016, 21:12   #2056  |  Link
colours
colours's Avatar
The only standard I know of defining what to do with full-range YCbCr is JFIF, and it has a nominal luma range of 0 to 255 and a nominal chroma range of 0.5 to 255.5. (libjpeg-turbo implements this. Z also assumes this convention, as does Dither_convert_rgb_to_yuv/yuv_to_rgb. I think swscale also does this, but the source code is a nightmare to read so I'm not 100% sure.)
AVS (and by extension, AVS+) uses a different convention for the Convert* filters, where the nominal luma range is 0 to 255 and the nominal chroma range is 1 to 255.
The "correct" convention is obviously 0 to 255 for both luma and chroma, but for whatever reason that's not what we ended up with. Apart from JFIF (which, you know, defines only what to do for JFIF files), no standard in common use defines what the nominal levels for full-range YCbCr should be; BT.601, BT.709, etc. only define the nominal levels for TV-range YCbCr.
Edit: Since vivan mentioned H.264, I went and checked that, and it defines a nominal chroma range of 0.5 to 2^n−0.5 in Annex E. (I assume HEVC says the same thing.) But really, my original point was that these all map RGB values to YCbCr values linearly; the exact endpoints to use for the range is something we can decide after we get rid of the strange idea of mapping 0 to 0, 128 to 32768, and 255 to 65535.
In case you're bad at arithmetic, 127.5 is equally close to both 127 and 128.
Also, dithering exists and anyone who cares about colour accuracy is already using it when converting between colourspaces with limited precision.
colours is offline
Old 8th July 2016, 21:33   #2057  |  Link
real.finder
  • AddBorders
  • LetterBox
  • VerticalReduceBy2
  • ColorYUV
  • Invert
  • Levels
  • Limiter
  • Tweak
  • MaskHS
  • Overlay
  • Subtract
  • SkewRows
  • Blur / Sharpen
  • Compare
  • Histogram
  • Info
  • Subtitle
Compare has a bug in Y8 http://forum.doom9.org/showthread.ph...37#post1773137
what about UToY8(clip clip) and VToY8(clip clip)?
UToY and VToY was already there
so for 16 bit/float will have a new UToYx and VToYx or UToYUV400 and VToYUV400 to output in HBD?
See My Avisynth Stuff
real.finder is offline
Old 8th July 2016, 21:57   #2058  |  Link
tormento
Acid fr0g
tormento's Avatar
Any modernization to SMDegrain with newer 16 bit filters would be glad
@turment on Telegram
tormento is offline
Old 8th July 2016, 22:16   #2059  |  Link
pinterf
Edited the summary above with:
And now one week holiday mode ON.
Probably I will read the forum but my internet will be limited.
pinterf is offline
Old 8th July 2016, 22:21   #2060  |  Link
pinterf
Unfortunately UtoY and VToY is reserved already, and works with 16/32 bit. They do not truncate to a Y8/Y16/Y32 clip.
So UtoY8 and VToY8 is silently working like UtoY16/32 and VtoY16/32. The result clip is greyscale one.
I did not like the names like UtoLumaOnly, etc... so it remained with the Y8 ending, until someone finds a proper name for it and everybody agrees with it
pinterf is offline
