Old 30th May 2016, 21:13   #1641  |  Link
Groucho2004
Originally Posted by fAy01 View Post
avs-plus suggests otherwise
Odd. I use this tool to install/switch Avisynth versions and I assure you that Avisynth 2.6 and Avisynth+ 64 bit each work perfectly fine:
Groucho2004 is offline
Old 30th May 2016, 21:26   #1642  |  Link
qyot27
qyot27's Avatar
@fAy01:
You do realize that AviSynth+ installs both 32 and 64 bit versions, right? There's no reason whatsoever to use classic AviSynth for 32-bit and only Plus for 64-bit, instead of Plus for both. You can't put both the 32-bit-only classic AviSynth and a 32-bit AviSynth+ in sysWOW64, you have to choose one or the other. It is exactly the same reason you can't put AviSynth 2.5 and AviSynth 2.6 in sysWOW64 at the same time, not that there's some kind of 'incompatibility' involved.
Although if you need to use FFmpeg, you have to use AviSynth+ r1779, r1825, or pinterf's test builds, not r1576. This is because FFmpeg no longer supports the pre-2.6 AviSynth API.
qyot27 is offline
Old 30th May 2016, 21:42   #1643  |  Link
Groucho2004
@fAy01:
I just tried the installer and got the same warning dialog. However, I clicked "Next" and selected only the 64 bit version. The original 32 bit version as well as the 64 bit version are working fine.
I agree however with qyot27 - just uninstall the old version and install AVS+ 32 and 64 bit.
Old 31st May 2016, 07:07   #1644  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
As several mentioned, you can only have one 32-bit version and one 64-bit version of AviSynth.dll, but they can be different, as one is in Windows\System32 and the other is in Windows\Syswow64. You can manually place the AviSynth DLL version you like into each of these folders.
In addition to that, you can use a separate version per application by placing another AviSynth.dll version into the same folder as the EXE and that version will be used instead.
Knowing this is especially useful for testing and comparing various versions.
MysteryX is offline
Old 31st May 2016, 09:32   #1645  |  Link
pinterf
Originally Posted by MysteryX View Post
I posted some time ago about AviSynth+ x64 taking HUGE amounts of memory. The fault is mine. AviSynthShader takes more than twice the memory in x64, trying to figure out why. If I remove that, all the other filters take slightly more memory but perform faster.
From what I tested so far, AviSynthShader may be the only x64 filter that isn't working as expected.
Pointers are double in size in x64. Although there are arrays and structs with pointers in your code but it does not explain the difference. Perhaps DirectX?
pinterf is offline
Old 31st May 2016, 09:41   #1646  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Yes it's most likely related to a difference in the way DX9 manages its texture memory buffers in x64. The issue is being discussed here.
MysteryX is offline
Old 31st May 2016, 09:42   #1647  |  Link
tormento
Acid fr0g
tormento's Avatar
What about creating a installer with latest versions from pinterf?
@turment on Telegram
tormento is offline
Old 31st May 2016, 10:07   #1648  |  Link
fAy01
he's busy porting other plugins to x64.
fAy01 is offline
Old 31st May 2016, 11:25   #1649  |  Link
pinterf
And I have no experience in installers.
pinterf is offline
Old 31st May 2016, 11:44   #1650  |  Link
pinterf
Is it intentional that ColorbarsHD is 1288x720 and not 1280x720?
The avisynth doc also mentions 1288.
pinterf is offline
Old 31st May 2016, 12:24   #1651  |  Link
jpsdr
Is it possible for a filter to set its MT mode on the constructor instead of inside AvisynthPluginInit3 ?
It's, for example, if a filter is MT_NICE_FILTER if parameter x=0, and MT_MULTI_INSTANCE if parameter x=1.
jpsdr is offline
Old 31st May 2016, 12:24   #1652  |  Link
pinterf
New maintenance release for 32 bit/64 bit Avisynth+, also with XP versions.
Avisynth+ MT r1858
Changes from r1849:
r1858 MT-pfmod (20160531)
- fix: RGB resizers shift horizontally to the opposite direction when src_left param is used (reported by MysteryX)
- prevent fragmentation vfb buffer list for small sized vfbs
- fix: x64 compatible type in acmDriverEnum call in VD_Audio
The r1849 build was downloaded by 522 times from github in the last six weeks.
I hope the previous authors' enormous amount of time has not been wasted.
pinterf is offline
Old 31st May 2016, 13:06   #1653  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
no.
ARIB STD-B28 says it should be 16:9 (and 75% colorbars should be 4:3).
The difference with the standard has occured because that's calculating the location of each colors with integer arithmatic.
I don't know why original author(IanB?) didn't calculate with floating point.
my repositories
Chikuzen is offline
Old 31st May 2016, 13:08   #1654  |  Link
Groucho2004
@pinterf
Thanks for the new build.
@all
I made a "lean" installer for this new build, no docs/Filter SDK. It does however include the latest 2015 redistributables.
(AviSynth+ r1858.7z)
Old 31st May 2016, 13:24   #1655  |  Link
Reel.Deel
@pinterf
Thanks!
Just yesterday I added installers for r1841 and r1847 to the wiki (courtesy of stax76). Whenever he updates it I'll update the wiki also.
Thanks, I'll add a link to on the wiki.
Reel.Deel is offline
Old 31st May 2016, 15:56   #1656  |  Link
qyot27
qyot27's Avatar
Sidenote: similar to what happened a couple years ago with VS 2013 builds, Wine 1.9.x (i.e. the current dev branch) cannot use binaries built with VS 2015 yet. Even if you do have all the correct redist dlls available.
qyot27 is offline
Old 31st May 2016, 16:10   #1657  |  Link
burfadel
@pinterf
@all
The installer is 21.6 MB versus one for 1847 which is 4.02 MB. Also, once installed it didn't even seem to work. I use Staxrip, and Staxrip came up with an app error saying Avisynth wasn't installed. When I reinstalled 1847 and used the pinterf replacement archive files for 1858 it works fine!
burfadel is offline
Old 31st May 2016, 16:28   #1658  |  Link
real.finder
Avisynth+ MT r1858
Changes from r1849:
thanks, and do you include 2.6.1 alpha 1 changes?
See My Avisynth Stuff
real.finder is offline
Old 31st May 2016, 16:49   #1659  |  Link
Groucho2004
I don't know how staxrip determines if Avisynth is installed. It worked fine for me (32 and 64 bit).
Old 31st May 2016, 17:55   #1660  |  Link
Groucho2004
The staxrip AVS+ installer is heavily modified, does not have the MS redistributables and is 64 bit only.
I used the original AVS+ installer script and just removed the FilterSDK and Docs.
