25th September 2018, 21:18 | #1021 | Link |
I dusted off my own automated codec testing setup so I can track AV1-development. Of course, objective metrics do not replace subjective testing, but this should still be okay to get some very rough estimates.
The following graph takes about 45 minutes to generate on my Ryzen 2700 (8 cores, 16 threads). To keep things sane, I'm using --cpu-used=4, which is a somwhat "fast" setting. The modern codecs may perform even better on HD resolutions. |
26th September 2018, 00:56 | #1022 | Link | ||
The following graph takes about 45 minutes to generate on my Ryzen 2700 (8 cores, 16 threads). To keep things sane, I'm using --cpu-used=4, which is a somwhat "fast" setting. Quote:
It's hard to say with AV1 since the encoders are so slow that there isn't a substantial corpus of high-quality HD AV1 encodes to evaluate yet. In theory it should also scale well, but today's encoders obviously haven't been able to get a lot of resolution-tuned psychovisual optimization yet. A whole lot of AV1's discussed capabilities are more informed speculation than anything based on real-world demonstrations of real-world scenarios. |
26th September 2018, 01:36 | #1023 | Link |
Would it make sense just drop a bitdepth of 8 bits already? Especially now when AV1 was just realesed. All right, decoder optimizations and hardware support will come anyway.
Yes, 8 bits is faster to encode/decode but banding ruins a major part of quality gains at quite large range of bitrates. VP9 8-bits vs 10 bits is a day and night difference. https://sonnati.files.wordpress.com/2016/06/10bit2.png https://sonnati.wordpress.com/2016/0...ntion-part-ii/ Even VP9/HEVC 10-12bit are already so advanced to produce block-free video even at quite low bitrates. I wouldn't be surprised if AV1 8 bits would look worse than VP9/HEVC 10-12 bits (or just comparable) |
26th September 2018, 03:28 | #1024 | Link | |
Just curious whether the Ateme demo was done with existing TV hardware (assuming software decoding with ARM based SOC), or the TV was just been used as a display for decoding done with PC. |
26th September 2018, 16:57 | #1026 | Link | |
But yeah, it would be great if the “Main” profile for future codecs always supported at least 10-bit. That’s required for HDR, which is quickly becoming mainstream. It’s not like the SoC or GOU vendors are developing 8-bit only decoders anymore, even if some display pipelines are 8-bit RGB. But 10-bit 64-960 4:2:0 Y’CbCr makes for better 0-255 RGB 4:4:4 anyway. |
26th September 2018, 17:01 | #1027 | Link | |
If it’s a fast 8-core ARM or something, software decode should be feasible, especially if the GPU was leveraged for some operations. Decoder optimization is a LOT easier and faster than encoder optimization, since there is only one right answer for decoding. We’ll have a good idea of the potential performance of AV1 decoders way before we will for encoders. |
28th September 2018, 09:52 | #1028 | Link |
Interesting discussion: https://www.reddit.com/r/linux/comme...utube_netflix/
It points some FSF licensing issues from 2010: - https://www.fsf.org/blogs/community/...p8-for-youtube :"Until we move to free formats, the threat of patent lawsuits and licensing fees hangs over every software developer, video creator, hardware maker, web site and corporation -- including you." - https://www.fsf.org/blogs/licensing/...d-webm-license : "Unfortunately, the interaction between the copyright license and the patent license made the result GPL-incompatible. Based on the concerns of developers writing GPL-covered software, Google publicly stated that they would take some time to review the WebM license and try to address the community's concerns. Today, they released a revised license, and it is GPL-compatible." "The most important part of the change is that Google has separated the patent license from the copyright license. Now the copyright license on the software is a totally standard three-clause BSD license, which is clearly compatible with the GPL. The patent license, in turn, provides distributors with permission to exercise all the rights, and meet all the conditions, in the GPL, as required by GPLv2 section 7; and those permissions are consistent with the ones provided by the patent grant in GPLv3 section 11. All this means that developers distributing GPL-covered software can take advantage of the patent license without running afoul of the GPL's conditions, whether they're using GPLv2 or GPLv3." Does it still apply to AV1? |
29th September 2018, 06:43 | #1029 | Link |
I am maddo saientisto!
MSYS2/GCC 8.2 builds:
av1-1.0.0-692-g16c9affcb: https://mega.nz/#!U1AVFI5R!jPhrtngqf...l8p05ACp9Fn4Ok dav1d-0.0.1-103-deab253: https://mega.nz/#!xpAHSYwB!hA4Unc81j...3oODqiV3cs3ZP8 dav1d builds are also available here: https://code.videolan.org/videolan/dav1d/pipelines Cloud button on the right The first ASM routines for dav1d have been checked in! Time to benchmark again Last edited by SmilingWolf; 29th September 2018 at 07:05. |
30th September 2018, 00:32 | #1031 | Link | |
Member
https://www.twoorioles.com/
30th September 2018, 19:28 | #1032 | Link | |
Member
Alibaba Cloud Joins the Alliance for Open Media
1st October 2018, 00:01 | #1033 | Link | |
Honestly, finding real-world scenarios where libvpx can deliver better quality @ bitrate @ perf than x264 is a challenge, although I suspect that's primarily due to x264's massively greater psychovisual tuning and perf optimization efforts, not differences in the bitstream standards. |
1st October 2018, 06:56 | #1034 | Link | |
I remember the days when x265 was claiming 50% more compression for the same quality compared to x264, but you have to dig too much to find such a case, if any.
1st October 2018, 07:41 | #1035 | Link | |
If this is the case, it seems like the purpose was to showcase the AV1 encoding/transcoding capability rather than decoding of AV1 on existing SOC hardware. Last edited by olduser217; 1st October 2018 at 07:43. |
1st October 2018, 08:35 | #1037 | Link | |
So, a big company can (in 2019) store in AV1 format and transcoding to ANY format LIVE. Or encoding from ANY format to AV1. At this moment, they are changing their solution to be Public Cloud Server friendly. Changing to microservices architecture capable to scale any number of servers automatically. PS: They don’t have anything magically, so encoding it’s still slow and expensive. Last edited by marcomsousa; 1st October 2018 at 11:35. |
1st October 2018, 09:38 | #1038 | Link | |
Thanks for the explanation. So, for the exhibition, the AV1 bitstream (I heard during the demo, the AV1 source was from an USB thumbdrive which was plugged into the TV) was uploaded to their server and downloaded as HEVC bitstream, then playback from the TV which support HEVC decoding? |
1st October 2018, 15:16 | #1039 | Link |
Video Dev Days 2018 videos:
https://www.youtube.com/watch?v=1bSsP0Wi46E - AV1: in the end, what got in? https://www.youtube.com/watch?v=ytsRYKQc6kQ - rav1e: the best rust AV1 encoder https://www.youtube.com/watch?v=UhIgBdrKyNM - Dav1d: a fast new AV1 decoder Last edited by hajj_3; 1st October 2018 at 15:48. |
