Old 9th January 2021, 13:52   #361  |  Link
Jamaika
Originally Posted by FranceBB View Post
so, again, they're working on it, but we can't see it yet, so all we have is the encoder_app.exe reference encoder
There is actually something, but I don't know what it is.
For sure gcc won't compile.
What language will it be in? It is not known.
The creator dreams of x266, but currently works in vvc.
I don't know what single file x266.cpp files are. There is probably some assembler.
https://github.com/chenm001/x266
https://github.com/fraunhoferhhi/vvd...uthor=chenm001
The ?266's RISC-V NON-Standard Vector Extension ONLY compile and disassembly by ?266 project modified llvm suite. You may build bu yourself or please contract to get prebuilt Centos-6 binary package.
Old 9th January 2021, 14:08   #362  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Well, I contacted Multicoreware anyway with my Sky email, asking them for some info.
Let's see if they reply.
Old 9th January 2021, 20:15   #363  |  Link
ksec
Originally Posted by birdie View Post
ffmpeg hasn't even begun adding support for VVC. That looks weird, the codec uptake seems to be extremely slow.
The spec is barely out. Finalised last August, but profiles were still not set then. VTM Reference Software was barely catching up in October and VTM 11.0 only released two days ago. Conformance test wasn't finalised either.
I mean normally these sort of "cleaning up" takes up to a year. So I think they are doing well so far.
Previously iwod
ksec is offline   Reply With Quote
Old 10th January 2021, 21:24   #364  |  Link
MeteorRain
結城有紀
Cutting edge technologies take time to be implemented.
22.2 channel aac audio spec was released years ago, and we barely just had a preliminary support in the latest version, implemented by jeeb.
Sometimes you have to be patient ;)
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 14th January 2021, 03:12   #365  |  Link
Jamaika
ffplay's humble beginnings
https://github.com/FFmpeg/FFmpeg/com...ee630d53c30d3f
Old 14th January 2021, 09:16   #366  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Originally Posted by Jamaika View Post
That is indeed something!
Having a decoder is basically the first thing you want when supporting a codec, so those commits are more than welcomed.
Old 14th January 2021, 12:43   #367  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
https://github.com/fraunhoferhhi/vvdec
https://github.com/fraunhoferhhi/vvenc
plus my fix
I have added codecs and compilation issues in my threads
I'm clearly doing something wrong.
Selecting Windows SDK version 10.0.18362.0 to target Windows 10.0.19042.
The C compiler identification is MSVC 19.27.29112.0
The CXX compiler identification is MSVC 19.27.29112.0
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe
Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe - works
Detecting C compiler ABI info
Detecting C compiler ABI info - done
Detecting C compile features
Detecting C compile features - done
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe
Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.27.29110/bin/Hostx64/x64/cl.exe - works
Detecting CXX compiler ABI info
Detecting CXX compiler ABI info - done
Detecting CXX compile features
Detecting CXX compile features - done
CMAKE_MODULE_PATH: updating module path to: C:/Users/Frank/Desktop/vvenc-master/cmake/modules
Looking for pthread.h
Looking for pthread.h - not found
Found Threads: TRUE
Configuring done
Generating done
Old 16th January 2021, 23:29   #368  |  Link
Jamaika
New codecs VVC
https://www.sendspace.com/file/09xyse
Old 16th January 2021, 23:41   #369  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thank you for building it for me! I'll test it on Monday as soon as I'll get back to work!
Old 17th January 2021, 10:08   #370  |  Link
Jamaika
The Streaming Codec Landscape in 2021
What Happened in 2020?
This past year saw the launch of two MPEG codecs — VVC and Low Complexity Enhancement Video Coding (LCEVC) — and the continued development of Essential Video Coding (EVC). You can read more about VVC’s technical background here. I reviewed Fraunhofer’s VVC encoder and decoder, respectively called VVenC and VVdeC, for Streaming Media Magazine here. As Table 2 shows, VCVenC proved 39% more efficient than x265 in terms of quality, but it took 10x longer to encode, and it was 3.7x slower during decode.
Regarding royalties, the intellectual property that was contributed to VVC came from many parties, and VVC will be royalty-bearing, although we probably won’t know what the royalty policy will look like until mid-2021 or later.
Old 17th January 2021, 23:40   #371  |  Link
benwaggoner
An error in the quoted statement here - LCEVC isn't a codec. It's a standardized postprocessing with metadata technology that sits on top of codecs. It could be applied to H.264, HEVC, and/or VVC.
Ben Waggoner
My Compression Book
Old 18th January 2021, 08:09   #372  |  Link
Jamaika
Is LCEVC mpeg5 paid? I don't see free libraries, and the final standard was in October 2020.
https://www.lcevc.org/
Weird. nothing is said about the new AV2 codec.
Old 18th January 2021, 11:19   #373  |  Link
hajj_3
Interestingly that image from ateme shows that AV2 will be ratified in ~2026. I haven't seen a timeline for AV2 before. I'm glad they aren't going to try and release a new one every 3 years which i think was the original intention. This way AV1 will have time to become popular. Also nearly all the h264 patents will have expired by then. I'm sure that some of the patents that Sisvel claim AV1 violates will have expired by then too.
Old 18th January 2021, 19:40   #374  |  Link
ksec
Giving too much credit for Google or Alliance Open Media, their original goal was new codec every "2" years. /s
Speaking of H264 patents, I am eagerly waiting for the patent free EVC baseline to test. Which is pretty much all H.264 expired or soon to be expired patents.
Previously iwod
Old 19th January 2021, 18:14   #375  |  Link
benwaggoner
There are certainly people interested in getting AV2 standardized before 2026. VVC's technical superiority over AV1 is pretty substantial. And essential patents are expiring every year, so there are plenty of techniques that couldn't be implemented in AV1 that are already available for AV2.
Ben Waggoner
My Compression Book
Old 27th January 2021, 22:02   #376  |  Link
hajj_3
BAD NEWS GUYS... The Media Coding Industry Forum (MC-IF) whose members make up the majority of VVC patents have been unable to achieve concencus in picking a patent licensing pool administrator so there will be 2 PATENT POOLS!!!!! One of the pools is 'Access Advance', the other is 'MPEG-LA'. Source: https://a7dce6fd-e8f0-45f7-b0b0-255c...0482debab7.pdf
Clearly they haven't learnt their lesson from the HEVC patent licensing problems!
Old 27th January 2021, 22:47   #377  |  Link
ksec
LOL, It is Access Advance ( Previously HEVC Advance ) and MPEG LA again. I am starting to think there are some bad blood between the two.
And even Google is part of Access Advance Licensor.
Despite the public hatred against MPEG-LA, they have been the one offering cheaper HEVC licensing.
Previously iwod
Old 28th January 2021, 09:04   #378  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yeah... this is not good news for general availability...
Let's see how it's gonna play out...
Old 28th January 2021, 15:27   #379  |  Link
ksec
Well We are only 1 year away from 3nm. Whatever cost, power or other obstacles AV1 had with mobile hardware decoder will diminish with the advance of computing and design.
Previously iwod
Old 28th January 2021, 19:42   #380  |  Link
excellentswordfight
Lost my old account :(
TSMC 5nm node has higher transistor cost then 7nm, and 3nm will probably follow that trend, so not sure how 3nm will help if the reason for the lack of av1 decoders was cause of roi on transistor budget.
Edit. initially ofc, but the trend is that transistor cost isnt drastically reduced anymore from die shrinks.
excellentswordfight is offline   Reply With Quote
