#101 | Link |
I don't know how to compile z_Windows_NT-586_asm.asm. Without this I can't close the file object in gcc. I suppose you can do it, but I don't know how.
https://github.com/llvm-mirror/openmp |
#102 | Link |
I wonder what happens for you ... MABS could compile the 32 bit version of VVC for me. But I got stuck in another faulty project, and I hate disabling many other tools just to get one compiled. I will test it soon™ ...
#103 | Link |
What do you mean? Bugs in the VVC project.
I had to add everywhere for GCC 9.0.1: (MsgLevel) ERROR, correct include: Code:
#include "CommonLib/CacheModel.h" in DecLib.h #include "CommonLib/MCTS.h" in EncCu.cpp #include "Utilities/program_options_lite.h" in decmain.cpp for( int ctuTsAddr = startCtuTsAddr; ctuTsAddr < boundingCtuTsAddr; ctuTsAddr += pcPic->cs->pcv->widthInCtus ) encodeCtus( pcPic, bCompressEntireSlice, bFastDeltaQP, ctuTsAddr, ctuTsAddr + pcPic->cs->pcv->widthInCtus, m_pcLib ); CHECK(cs.sps == 0, "No SPS present"); writeBlockStatisticsHeader(cs.sps); in EncSlice.cpp #if ENABLE_WPP_PARALLELISM // static #endif in EncSlice.h in VLCReader.cpp Code:
ptl->setBitDepthConstraint( ( ptl->getProfileIdc() == Profile::MAINREXT || ptl->getProfileIdc() == Profile::NEXT ) ? 12 : 8 ); Code:
("InputBitDepth", m_inputBitDepth[CHANNEL_TYPE_LUMA], 0, "Bit-depth of input file") m_bitDepthConstraint = ( ( m_profile == Profile::MAINREXT || m_profile == Profile::NEXT ) ? 12 : 8 ); xConfirmPara(m_bitDepthConstraint!=((m_profile==Profile::MAINREXT || m_profile==Profile::NEXT)?12:8), "BitDepthConstraint must be 8 for NEXT profile and 12 for MAINREXT profile."); Code:
/* std::string SIMD; df::program_options_lite::Options optsSimd; optsSimd.addOptions()( "SIMD", SIMD, string( "" ), "" ); df::program_options_lite::SilentReporter err; df::program_options_lite::scanArgv( optsSimd, argc, ( const char** ) argv, err );*/ fprintf( stdout, "[SIMD=NONE] "/*, read_x86_extension( SIMD )*/ ); Code:
// case AVX512/AVX2/AVX/SSE42/SSE41: // _init...X86<AVX512/AVX2/AVX/SSE42/SSE41>(...); // break; in InitX86.cpp Last edited by Jamaika; 18th April 2019 at 10:03. |
#104 | Link | |
I hope we talk about the same topic... by "another faulty project", I meant anything else compiled by MABS. In this case, rav1e and vulkan. Not VVC.
VVCSoftware: VTM Encoder Version 4.2 [Windows][GCC 7.4.0][32 bit] [SIMD=SSE42] [SPLIT_PARALLEL (6 jobs)][OMP: WAIT_POLICY=,THREAD_LIMIT=] VVCSoftware: VTM Encoder Version 4.2 [Windows][GCC 8.3.0][64 bit] [SIMD=AVX] [SPLIT_PARALLEL (6 jobs)][OMP: WAIT_POLICY=,THREAD_LIMIT=] Last edited by LigH; 14th April 2019 at 10:17. |
#105 | Link |
ангел смерти
![]() Join Date: Nov 2004
GCC 9.0.1 was tagged at the beginning of February, they've started the release-candidate cycle toward the 9.1 release, which is supposed to be within a week or two. Presumably it's pretty stable at this point, though I'd definitely compare any issues to 8.3 as well.
#106 | Link | |
I understand that there is an open secret. I know that there is an MSYS2 compiler. He contains components in this GCC 8.3, but with GCC 9.0 doesn't work anymore and contains something to assembler. This thing is a secret.
The second thing. If added the function split paralleism why was the function wpp paralleism not added? Are they interchangeable? I see that both functions can be added in the project. Quote:
#107 | Link |
The MSYS2 environment may be a bit conservative, regarding provided packages, but usually quite well groomed. I will leave the "bleeding edge technology" to other people and keep using a toolset I can usually handle with little efforts. And in most cases, the result was reliable.
#108 | Link | |
Helenium(Easter)
VTM fails to build when WPP_PARALLELISM is enabled as of now.
Monochrome Anomaly |
#110 | Link |
My recent vvc-git/build-64bit/ab-suite.build.log only reports "Building CXX object" ...
#111 | Link |
New version 5.0rc1
VVCSoftware: VTM Encoder Version 5.0rc1 [Windows][GCC 9.0.1][64 bit] [SIMD=NONE] [ENABLE_TRACING] [SPLIT_PARALLEL (6 jobs)][WPP_PARALLEL][OMP: WAIT_POLICY=,THREAD_LIMIT=] https://www.sendspace.com/file/gydtlw #define JVET_N0415_CTB_ALF 1 // JVET-N0415: CTB-based ALF switch #define JVET_N0105_LFNST_CTX_MODELLING 1 // LFNST index signalled without intra mode dependency and with on ctx-coded bin #define JVET_N0193_LFNST 1 //Low Frequency Non-Separable Transform (LFNST), previously, Reduced Secondary Transform (RST) #define JVET_N0217_MATRIX_INTRAPRED 1 // matrix-based intra prediction (MIP) #define JVET_N0400_SIGNAL_TRIANGLE_CAND_NUM 1 // JVET-N0400, JVET-N0447, JVET-N0500, JVET-N0851, align triangle merge candidate number and regular merge candidate number #define JVET_N0413_RDPCM 1 // Residual DPCM JVET-N0413/N0214 #define JVET_N0866_UNIF_TRFM_SEL_IMPL_MTS_ISP 1 // JVET-N0866: unified transform derivation for ISP and implicit MTS (combining JVET-N0172, JVET-N0375, JVET-N0419 and JVET-N0420) #define JVET_N0340_TRI_MERGE_CAND 1 #define JVET_N0302_SIMPLFIED_CIIP 1 #define JVET_N0327_MERGE_BIT_CALC_FIX 1 #define JVET_N0324_REGULAR_MRG_FLAG 1 #define JVET_N0251_ITEM4_IBC_LOCAL_SEARCH_RANGE 1 #define JVET_N0435_WAIP_HARMONIZATION 1 #define JVET_N0168_AMVR_ME_MODIFICATION 1 // Correct the cost and bits calculation in encoder side #define JVET_N0068_AFFINE_MEM_BW 1 // memory bandwidth reduction for affine mode #define JVET_N0308_MAX_CU_SIZE_FOR_ISP 1 #define JVET_N0280_RESIDUAL_CODING_TS 1 #define JVET_N0103_CGSIZE_HARMONIZATION 1 // Chroma CG sizes aligned to luma CG sizes #define JVET_N0146_DMVR_BDOF_CONDITION 1 // JVET-N146/N0162/N0442/N0153/N0262/N0440/N0086 applicable condition of DMVR and BDOF #define JVET_N0470_SMVD_FIX 1 // remove mvd_l1_zero_flag condition, align to spec text. #define JVET_N0235_SMVD_SPS 1 #define JVET_N0671 1 #if JVET_N0671 #define JVET_N0671_CHROMA_FORMAT_422 1 #define JVET_N0671_RGB 1 #define JVET_N0671_CCLM 1 #define JVET_N0671_AFFINE 1 #define JVET_N0671_DMVR 1 #define JVET_N0671_RDCOST_FIX 1 #define JVET_N0671_INTRA_TPM_ALIGNWITH420 1 #endif //JVET_N0671 #define JVET_N0843_BVP_SIMPLIFICATION 1 #define JVET_N0448_N0380 1 // When MaxNumMergeCand is 1, MMVD_BASE_MV_NUM is inferred to be 1. #define JVET_N0266_SMALL_BLOCKS 1 // remove 4x4 uni-pred, 4x8/8x4 bi-pred from regular inter modes #define JVET_N0054_JOINT_CHROMA 1 // Joint chroma residual coding mode #define JVET_N0317_ADD_ZERO_BV 1 #define JVET_N0318_N0467_IBC_SIZE 1 // IBC flag dependent on CU size and disabling 128x128 IBC mode #define JVET_N0462_FIX_CTX_MODELING 1 // Fix context modeling of inter_pred_idc #define JVET_N0175_N0251_N0384_IBC_SMALL_CTU 1 // IBC search range arrangement for small CTU sizes #define JVET_N0127_MMVD_SPS_FLAG 1 #define JVET_N0286_SIMPLIFIED_GBI_IDX 1 // Simplified coding of the GBi index #define JVET_N600_AMVR_TPM_CTX_REDUCTION 1 #define JVET_N0188_UNIFY_RICEPARA 1 #define JVET_N0334_MVCLIPPING 1 // prevention of MV stroage overflow and alignment with spec of MV/CPMV modular for AMVP mode #define JVET_N0481_BCW_CONSTRUCTED_AFFINE 1 #define JVET_N0483_DISABLE_SBT_FOR_TPM 1 #define JVET_N0180_ALF_LINE_BUFFER_REDUCTION 1 // Line buffer reduction for ALF using symmetric padding #define JVET_N0242_NON_LINEAR_ALF 1 // enable CE5-3.2, Non-linear ALF based on clipping function #define JVET_N0329_IBC_SEARCH_IMP 1 // IBC encoder-side improvement #define JVET_N0325_BDOF 1 // unified right-shifts for BDOF derivation #define JVET_N0247_HASH_IMPROVE 1 // Improve hash motion estimation #define JVET_N0449_MMVD_SIMP 1 // Configurable number of mmvd distance entries used #define JVET_N0363_INTRA_COST_MOD 1 // Modified cost criterion for intra encoder search #define JVET_N0137_DUALTREE_CHROMA_SIZE 1 #define JVET_N0335_N0085_MV_ROUNDING 1 // MV rounding unification #define JVET_N0332_LTRP_MMVD_FIX 1 // MMVD scaling considering LTRPs from N0332 #define JVET_N0477_LMCS_CLEANUP 1 #define JVET_N0220_LMCS_SIMPLIFICATION 1 #define JVET_N0185_UNIFIED_MPM 1 #define JVET_N0271_SIMPLFIED_CCLM 1 // Simplified CCLM parameter derivation in JVET-N0271 #define JVET_N0178_IMPLICIT_BDOF_SPLIT 1 #define JVET_N0383_N0251_IBC_COL_VPDU_REMOVE 1 #define JVET_N0407_DMVR_CU_SIZE_RESTRICTION 1 // Disable 4xN/8x8 CUs for DMVR #define JVET_N0196_SIX_TAP_FILTERS 1 // 6-tap filters for affine motion compensation #define JVET_N0213_TMVP_REMOVAL 1 // Remove TMVP candidates from merge and amvp mode with samples <= 32 #define JVET_N0492_NO_HIERARCH_CBF 1 // Allow CBFs writing for leaf TU only #define JVET_N0473_DEBLOCK_INTERNAL_TRANSFORM_BOUNDARIES 1 // JVET-N0473, JVET-N0098: Deblocking of ISP/SBT TU boundaries #define INCLUDE_ISP_CFG_FLAG 1 #define JVET_N0246_MODIFIED_QUANTSCALES 1 delete #define HEVC_TILES_WPP 1 #define JVET_MMVD_OFF_MACRO 0 Last edited by Jamaika; 1st May 2019 at 03:22. |
#112 | Link |
Short test additional function for yuv420p 8bit QP=32 CTU=32 LCTUFast=0 with encoder_randomaccess_vtm.cfg
no function = effect blur add full paralleism = much smaller effect blur only frame I add tracing = test encoder, longer total time add rext = much smaller effect blur only frame I add rext + paralleism = effect banding add only split paralleism = file is the same as no function Conclusions: LCTUFast should be enabled for small CTUs. The frames have more details. Last edited by Jamaika; 4th May 2019 at 11:05. |
#113 | Link |
vvc2 -i "E:\Morocco8K-8b-444.yuv" -b vvc-test.vvc -wdt 1920 -hgt 1080 -fr 60 --InputBitDepth=8 --InputChromaFormat=444 VVCSoftware: VTM Encoder Version 5.0rc1 [Windows][GCC 9.0.1][64 bit] [SIMD=AVX2] [ENABLE_TRACING] [SPLIT_PARALLEL (6 jobs)][WPP_PARALLEL][OMP: WAIT_POLICY=,THREAD_LIMIT=] terminate called after throwing an instance of 'Exception' what(): ERROR: In function "xCheckParameter" in EncAppCfg.cpp:1979: Next profile with an alternative partitioner has to be enabled if HEVC_USE_RQT is off! |
#114 | Link |
Add more commands, e.g.
![]() https://www.sendspace.com/file/ki5wkj Code:
VVCSoftware: VTM Encoder Version 5.0rc1 [Windows][GCC 9.1.1][64 bit] [SPLIT_PARALLEL (6 jobs)][WPP_PARALLEL][OMP: WAIT_POLICY=,THREAD_LIMIT=] TOOL CFG: IBD:0 HAD:1 RDQ:1 RDQTS:1 RDpenalty:0 LQP:0 SQP:0 ASR:1 MinSearchWindow:96 RestrictMESampling:0 FEN:1 ECU:0 FDM:1 CFM:0 ESD:0 TransformSkip:1 TransformSkipFast:1 TransformSkipLog2MaxSize:5 Slice: M=0 Tiles:1x1 MCTS:0 CIP:0 SAO:0 ALF:1 PCM:0 TransQuantBypassEnabled:0 WPP:0 WPB:0 PME:2 WaveFrontSynchro:0 WaveFrontSubstreams:1TMVPMode:1 DQ:1 SignBitHidingFlag:0 RecalQP:0 NEXT TOOL CFG: LFNST:1 MMVD:1 Affine:1 AffineType:1 SubPuMvp:1+0 DualITree:1 IMV:1 BIO:1 LMChroma:1 CclmCollocatedChroma:0 MTS: 1(intra) 0(inter) SBT:1 ISP:1 SMVD:1 CompositeLTReference:0 GBi:1 GBiFast:1 LADF:0 MHIntra:1 Triangle:1 AllowDisFracMMVD:1 AffineAmvr:1 AffineAmvrEncOpt:1 DMVR:1 MmvdDisNum:6 RDPCM:0 IBC:0 HashME:0 WrapAround:0 Reshape:1 (Sigal:HDR-PQ ) MIP:1 EncDbOpt:0 FAST TOOL CFG: LCTUFast:1 FastMrg:1 PBIntraFast:1 IMV4PelFast:1 MTSMaxCand: 3(intra) 4(inter) ISPFast:1 FastLFNST:0 AMaxBT:1 E0023FastEnc:1 ContentBasedFastQtbt:0 UseNonLinearALFLuma:1 UseNonLinearALFChroma:1 FastMIP:0 NumSplitThreads:1 NumWppThreads:1+0 EnsureWppBitEqual:1 started @ Tue May 07 02:17:04 2019 *** SPS numBytesInNALunit: 67 *** PPS numBytesInNALunit: 10 *** APS numBytesInNALunit: 45 *** IDR_W_RADL numBytesInNALunit: 2889 POC 0 TId: 0 ( I-SLICE, QP 29 ) 24200 bits [Y 54.4181 dB U 62.1299 dB V 999.9900 dB] [WY 54.2387 dB WU 65.1402 dB WV 999.9900 dB] [ET 26 ] [L0 ] [L1 ] |
#115 | Link |
VVC VTM 5.0 is released!
Can someone confirm if these AppVeyor builds are functioning? --help functions correctly, but I can't get it to encode anything. |
#116 | Link | |
https://vcgit.hhi.fraunhofer.de/jvet...access_vtm.cfg |
#117 | Link | |
vvc -i "E:\Morocco8K-8b-444.yuv" -b vvc-test.vvc -wdt 1920 -hgt 1080 -fr 60 --InputBitDepth=8 --InputChromaFormat=444 -f 60 -c cfg_encoder_randomaccess_vtm.cfg Also: Huge MR ahead: JVET-N0857: slices/tiles/bricks Last edited by EwoutH; 9th May 2019 at 16:50. |
#120 | Link |
JVET-N0857: slices/tiles/bricks is merged!
