Old 27th December 2018, 06:38   #1041  |  Link
supercoolman
there are issue with XySubFilter 3.1.0.746 BETA3 where last line of an external SSA subtitle is not displayed if it doesn't end with line break. in a text editor, this means SSA file must end with a blank/empty line
haven't test the latest version to see if it's fixed, but also don't see this fixed in the newer releases' Bug Fix section
confirmed 3.1.0.752 also has the same behaviour
supercoolman is offline   Reply With Quote
Old 29th December 2018, 03:12   #1042  |  Link
Mano
Is it normal that when i enable sub in video the color of the movie changed?
Default no sub
https://imgur.com/oprrT9R
With english sub selected
https://imgur.com/SSo0l5f
Mano is offline   Reply With Quote
Old 30th December 2018, 00:54   #1043  |  Link
cyberbeing
Broadband Junkie
@supercoolman Thanks for reporting that. Looks like it is caused by a bug this Read Buffering commit written by the Aegisub author. Since Aegisub always adds a new line at end of file this must have been overlooked. I'll try to see if he's still around to push a fix.
@Mano That is a bug in madVR, I believe. XySubFilter only provides subtitles, it never touches the video. I seem to remember someone reporting a bug like that with HDR video in one of the madVR threads months ago, but if it still isn't fixed you should probably open a bug report so it isn't forgotten about.
Old 30th December 2018, 09:10   #1044  |  Link
pinterf
I was reported a similar issue, see issue and fix here:
https://github.com/pinterf/xy-VSFilter/issues/1
https://github.com/pinterf/xy-VSFilt...2c7414fc5072f0
As I recall there had been other similar parts in the code but I could test and fix only this specific one.
@cyberbeing: if the project is still somewhat live again, I'd recommend this x64 fix as well:
https://github.com/pinterf/xy-VSFilt...2d32806f8c24cf
pinterf is offline   Reply With Quote
Old 31st December 2018, 21:15   #1045  |  Link
cyberbeing
Broadband Junkie
Thanks pinterf, I'll merge those in. Looks like you only fixed it for SRT, I assume the same change could be used for SSA/ASS?
Test Build [previous 750 test build + pinterf SRT & x64 fixes + pinterf fix used for SSA/ASS (untested)]
Any idea if your fix for the missing last line could be moved from STS.cpp to TextFile.cpp, since that is where the regression occurred? It would prevent the need to add that fix for every text subtitle format in STS.cpp, and simply things.
The project is still pretty much dead, aside from minimal maintenance on my part.
Old 1st January 2019, 22:33   #1046  |  Link
supercoolman
I have been manually fixing that (adding newlines) on all ASS subs over the years. just decided to bring it up. didn't know bug was filed on that already
btw/ot, what's going on with aegisub? is it in not, less or similarly active than XySubFilter ?
Old 2nd January 2019, 02:10   #1047  |  Link
cyberbeing
Broadband Junkie
Pretty much, though back in June 2018 he did push out a new trunk build on his site with some fixes from his Github. With the original MPC-HC team dying off, and even Libass updating rather rarely nowadays, everything has sort of stagnated. Or rather the state of subtitle development has returned to the status quo from before we first released xy-VSFilter in 2011 which triggered a large peak in interest in the following years, so you could argue this is actually the normal state of things.
Old 2nd January 2019, 13:55   #1048  |  Link
pinterf
I don't remember, unfortunately I don't have overview on the project as a whole, tried to find a more practical place for it but due to my ignorance the actual fix remained where I put it first.
Old 2nd January 2019, 18:51   #1049  |  Link
supercoolman
finishing OT...
I was wondering since this GitHub project has been getting commits, but not a single release since 2014
Old 5th January 2019, 00:18   #1050  |  Link
krmit
finishing OT...
Well, last release (r8942) was 06/09/18, and previous - about 2 years ago.
krmit is offline   Reply With Quote
Old 28th February 2019, 16:07   #1051  |  Link
clsid
Any reason why the vertical padding option is disabled/broken?
It seems to work fine if I re-enable the relevant settings in IDirectVobSubXy.h
Of course it can b0rk accurate ASS positioning, but that is the users choice.
Old 16th June 2019, 19:56   #1052  |  Link
supercoolman
found another weird behaviour. when there are 2 external ASS subs do the following steps and XySubFilter will switch sub on its own
1. pause playback
2. make change or edit XySubFilter's current rendering subtitle
3. resume playback
4. XySubFilter automatically switch to the other subtitle
5. manually selecting the edited subtitle and XySubFilter happily use it without any error/issue
this means there was no error, mistake or issue for the edited subtitle. not sure why XySubFilter would switch the rendering subtitle
Old 23rd June 2019, 09:18   #1053  |  Link
zvans18
zvans18's Avatar
Is lag at typesetting just par for the course or is my XySubFilter misconfigured? It even happens with the basic stuff Crunchyroll, and therefore Horriblesubs, has been doing lately.
MPC-BE 1.5.3 x64 + madvr + LAV filters + XySubFilter
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter
zvans18 is offline   Reply With Quote
Old 13th December 2019, 01:19   #1054  |  Link
kedautinh12
can you share me link download last release??
Old 14th December 2019, 00:42   #1055  |  Link
krmit
http://plorkyeran.com/aegisub/
Old 20th December 2019, 07:10   #1056  |  Link
kedautinh12
Old 26th December 2019, 18:24   #1057  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Aegisub 06/09/18 - r8942
- Update to Visual Studio 2017
- Drop Windows XP support
Ah, for God's sake, is it even necessary? Can't XP really be targeted when the code is built with Visual Studio?
Old 26th December 2019, 18:59   #1058  |  Link
lvqcl
"Who knows? More importantly, who cares?" (C)
Old 27th December 2019, 11:15   #1059  |  Link
jpsdr
XP can still be targeted with VS 2017 and 2019 (in deprecated status for this last one), but, it's possible that there is some code, codec/display/etc... interface wich is not XP compatible anymore. So in that case, even if you build targeting XP, it will not make your program XP compatible.
My github.
Old 27th December 2019, 12:31   #1060  |  Link
StainlessS
StainlessS's Avatar
FranceBB, just consider the plugin dead.
I sometimes post sober.
