26th May 2017, 22:06 | #2041 | Link |
What about DPI scaling in last build /1.4.5.5 on LTSB 14393/? I've a "little bit" non-scalable StaxRip in miniature window on my 4K monitor? See - https://postimg.org/image/i14fqov07/a4653bec/
Hmm... and on Creators Update on my other machine - same behaviour. Оn both systems are installed .NET 4.7 /on CU machine it is by default/. Last edited by mcjordan; 26th May 2017 at 22:41. |
26th May 2017, 23:01 | #2042 | Link | |
Just download .net 4.7 and install. https://www.microsoft.com/en-us/down....aspx?id=55167 |
26th May 2017, 23:58 | #2043 | Link |
Hi Stax:
In windows 10 you can have several desktops. I have 2. When using staxrip I usually do that in "Desktop 2". I realized that everytime it finishes a job, staxrip would move to "Desktop 1" then continue with the next job. Is there way for staxrip to remain in "Desktop 2" until it finishes all the jobs?
27th May 2017, 00:19 | #2044 | Link |
@mcjordan
What's your DPI setting? @Magik Mark I don't know if there is an API or something to control this.
27th May 2017, 01:23 | #2045 | Link |
There was a StaxRip.exe.config file missing and the function that restores the windows positions was accidentally removed.
https://github.com/stax76/staxrip/bl.../test-build.md
27th May 2017, 06:35 | #2047 | Link |
Next build includes 0.150.2833 Vanilla both 10 and 8 bit.
27th May 2017, 11:51 | #2049 | Link |
Sorry for delay. I must have to sleep from time to time ;-) My setting based on standart scaling factor - 150%.
Anyway, last build 1.4.5.7 and the new config file work together seamlessly. Thank you, Frank, and sorry for disturbance. |
28th May 2017, 03:32 | #2050 | Link |
ParseException
所在位置 行:1 字符: 1 + Using namespace StaxRip; + ~~~~~ 此语言版本中不支持“using”关键字。 所在位置 行:2 字符: 1 + Using namespace StaxRip.UI; + ~~~~~ 此语言版本中不支持“using”关键字。 System.Management.Automation.ParseException: 所在位置 行:1 字符: 1 + Using namespace StaxRip; + ~~~~~ 此语言版本中不支持“using”关键字。 所在位置 行:2 字符: 1 + Using namespace StaxRip.UI; + ~~~~~ 此语言版本中不支持“using”关键字。 在 System.Management.Automation.Runspaces.PipelineBase.Invoke(IEnumerable input) 在 StaxRip.Scripting.RunPowershell(String code) 位置 D:\Projekte\VS\VB\StaxRip\General\Scripting.vb:行号 26 |
28th May 2017, 05:30 | #2051 | Link | |
A Man Eating Duck |
28th May 2017, 06:35 | #2052 | Link |
@qjb2016
When you run powershell from the start menu what do you see when you execute each of following lines: $PSVersionTable.PSVersion [Environment]::OSVersion
28th May 2017, 09:26 | #2053 | Link |
Version 1.5.0.0 has been released today.
Thanks everybody for the feedback provided since the least release. https://github.com/stax76/staxrip/releases
28th May 2017, 10:21 | #2054 | Link | |
Major Minor Build Revision ----- ----- ----- -------- 4 0 -1 -1 PS C:\Users\Administrator> PS C:\Users\Administrator> [Environment]::OSVersion Platform ServicePack Version VersionString -------- ----------- ------- ------------- Win32NT 6.3.9600.0 Microsoft Windows NT 6.3.9... |
28th May 2017, 11:19 | #2055 | Link |
I'm sorry for asking but is it possible to do the same with ffmpeg as decoder?
Background is, i always wanna use the latest opus alpha/beta/stable encoder as external encoder. Latest release is opusenc 1.2 beta and i only can find ffmpeg versions with opusenc 1.1.4 stable. Last edited by VincAlastor; 28th May 2017 at 11:30. |
28th May 2017, 11:30 | #2056 | Link |
@qjb2016
Next build has a better error message: MsgError("PowerShell Setup Problem", "Ensure you have at least PowerShell 5.1 installed.") https://www.microsoft.com/en-us/down....aspx?id=54616 @VincAlastor Sure it's possible, if you can't find out how and nobody answers then please create a new thread. A guess would be: Code:
ffmpeg -i %input% - | opusenc - %output%
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 28th May 2017 at 11:32. |
29th May 2017, 06:56 | #2059 | Link |
nvenc not supported even though i have gtx1070
I am not sure if i am getting this error in stax because it's trying to use my nvs510 card that i have in the same computer instead of the gtx1070.
Any help is appreciated why i am getting this error. thanks |
29th May 2017, 07:48 | #2060 | Link |
In the NVIDIA options dialog there is a 'Device' option on the 'Other' tab, on the bottom of the dialog is a small button with a drop down menu with some features to show hardware info.
