Old 6th June 2011, 23:33   #641  |  Link
jmone
Hi Hawk you may remember a few posts last year on HD-DVD conversion http://forum.doom9.org/showthread.ph...96#post1460296 ... Just restested in 0.5.2 and still have the "Unknown" stream issue for TrueHD, and Subtitles.
I'm just trying to remux the streams as is into MKV (the only thing that may be slightly different is that the HD-DVD use an extended version of DVD subtitles so I don't know if they need to be converted or not at this stage).
Latest log info:
[6/7/2011 8:13:51 AM] Getting playlist info...
[6/7/2011 8:13:51 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\"
[6/7/2011 8:13:51 AM] 1) feature_IWOJIMADOMNVC1_HD.EVO+feature_IWOJIMADOMNVC1_HD_Divide.EVO+Interpol_16x9.EVO, 2:21:01
[6/7/2011 8:13:51 AM] "feature"
[6/7/2011 8:13:51 AM] - VC-1, 1080p (16:9)
[6/7/2011 8:13:51 AM] - E-AC3, English, 5.1, 48kHz
[6/7/2011 8:13:51 AM] - TrueHD, English, 5.1, 48kHz
[6/7/2011 8:13:51 AM] 2) redSun.EVO, 0:21:02
[6/7/2011 8:13:51 AM] "redSun"
[6/7/2011 8:13:51 AM] - E-AC3, English, 2.0, 48kHz
[6/7/2011 8:13:51 AM] 3) facesOfCombat.EVO, 0:18:40
[6/7/2011 8:13:51 AM] "facesOfCombat"
[6/7/2011 8:13:51 AM] 4) images.EVO, 0:03:27
[6/7/2011 8:13:51 AM] "images"
[6/7/2011 8:13:51 AM] 5) pressConference.EVO, 0:24:29
[6/7/2011 8:13:51 AM] "pressConference"
[6/7/2011 8:13:51 AM] - MPEG2, 480p (4:3)
[6/7/2011 8:13:51 AM] 6) worldPremiere.EVO, 0:16:08
[6/7/2011 8:13:51 AM] "worldPremiere"
[6/7/2011 8:13:51 AM] 7) trailer.EVO, 0:02:17
[6/7/2011 8:13:51 AM] "trailer"
[6/7/2011 8:13:51 AM] Return code: 0
[6/7/2011 8:13:51 AM] Done.
[6/7/2011 8:13:51 AM] Getting title info...
[6/7/2011 8:13:51 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 1)
[6/7/2011 8:13:52 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 2 audio tracks, 4 subtitle tracks, 2:21:00
[6/7/2011 8:13:52 AM] 1: Joined EVO file
[6/7/2011 8:13:52 AM] 2: Chapters, 33 chapters
[6/7/2011 8:13:52 AM] 3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
[6/7/2011 8:13:52 AM] 4: E-AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
[6/7/2011 8:13:52 AM] 5: TrueHD, English, 5.1 channels, 48kHz, dialnorm: -27dB
[6/7/2011 8:13:52 AM] 6: Subtitle (DVD), English
[6/7/2011 8:13:52 AM] 7: Subtitle (DVD), English
[6/7/2011 8:13:52 AM] 8: Subtitle (DVD), French
[6/7/2011 8:13:52 AM] 9: Subtitle (DVD), Spanish
[6/7/2011 8:13:52 AM] Return code: 0
[6/7/2011 8:13:52 AM] Done.
[6/7/2011 8:13:52 AM] Getting title info...
[6/7/2011 8:13:52 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 2)
[6/7/2011 8:13:52 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 2 subtitle tracks, 0:21:02
[6/7/2011 8:13:52 AM] 1: VC-1, 1080i60 /1.001 (16:9)
[6/7/2011 8:13:52 AM] 2: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
[6/7/2011 8:13:52 AM] 3: Subtitle (DVD), English
[6/7/2011 8:13:52 AM] 4: Subtitle (DVD), French
[6/7/2011 8:13:52 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 3)
[6/7/2011 8:13:52 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 2 subtitle tracks, 0:18:40
[6/7/2011 8:13:53 AM] Getting title info...
[6/7/2011 8:13:53 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 4)
[6/7/2011 8:13:53 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 0:03:27
[6/7/2011 8:13:53 AM] 1: VC-1, 1080i60 /1.001 (16:9)
[6/7/2011 8:13:53 AM] 2: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
[6/7/2011 8:13:53 AM] Return code: 0
[6/7/2011 8:13:53 AM] Done.
[6/7/2011 8:13:53 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 5)
[6/7/2011 8:13:54 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 2 subtitle tracks, 0:24:28
[6/7/2011 8:13:54 AM] 1: MPEG2, 480i60 /1.001 (4:3)
[6/7/2011 8:13:54 AM] 2: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, 16ms
[6/7/2011 8:13:54 AM] 3: Subtitle (DVD), English
[6/7/2011 8:13:54 AM] 4: Subtitle (DVD), French
[6/7/2011 8:13:54 AM] Return code: 0
[6/7/2011 8:13:54 AM] Done.
[6/7/2011 8:13:54 AM] Getting title info...
[6/7/2011 8:13:54 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 6)
[6/7/2011 8:13:55 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 2 subtitle tracks, 0:16:07
[6/7/2011 8:13:55 AM] 1: MPEG2, 480i60 /1.001 (4:3)
[6/7/2011 8:13:55 AM] 2: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, 16ms
[6/7/2011 8:13:55 AM] 3: Subtitle (DVD), English
[6/7/2011 8:13:55 AM] 4: Subtitle (DVD), French
[6/7/2011 8:13:55 AM] Return code: 0
[6/7/2011 8:13:56 AM] Done.
[6/7/2011 8:13:56 AM] Getting title info...
[6/7/2011 8:13:56 AM] Command: X:\transcodes\eac3to\eac3to.exe "E:\" 7)
[6/7/2011 8:13:56 AM] -------------------------------------------------------------------------------        EVO, 1 video track, 1 audio track, 0:02:17
[6/7/2011 8:13:56 AM] 1: MPEG2, 480p24 /1.001 (4:3) with pulldown flags
[6/7/2011 8:13:56 AM] 2: AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
[6/7/2011 8:13:56 AM] Return code: 0
[6/7/2011 8:14:15 AM] Unknown tracks selected - please report log to developer
jmone is offline   Reply With Quote
Old 10th July 2011, 07:02   #642  |  Link
quasit
This is open source right? As it seems it's not developed anymore couldn't someone pick it up? At least fix the current bugs.
quasit is offline   Reply With Quote
Old 23rd August 2011, 08:38   #643  |  Link
_hawk_
BluRip author
Will start to work on it again the next days...
Would be helpfull if someone has a list of bugs that need to be fixed.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 23rd August 2011, 10:59   #644  |  Link
7ekno
This is a great project _hawk_ , I actually don't run into any "bugs" as such!!
However, there is some functionality improvements that would make the whole process a little more streamline! Like:
Autocrop:
- There should be an option to disable it outright (maybe in the "Advanced Settings" > "AutoCrop settings" recognise "Zero" in "Number of frames to analyse" as "disabled")
- For a title like Alice in Wonderland (1951) remastered on BD autocrop only does vertical croping, not horizontal autocropping (final res used was 1424 x 1080, but is this even possible with Autocrop!)
Subtitles:
- Selecting "Mux only first normal/forced subtitle" with forced subtitles presently results in two subtitle tracks (my impression is this option should generate 1 subtitle track being the first one if no forced subtitles are found, or just the forced subtitle if present, but not both)
Advanced Setting > "Audio"
- Maybe some way of "remembering" the "advanced" alterations made with right clicking streams (I often select the lossless audio track, but use that to convert to 640kbps AC3 with the eac3to parameter of "normalize", would be great of somehow remembering these advanced settings so I can use them on all projects!) ...
But either way, it's a great project and I haven't had any real "bugs" to report at all!!
Cheers,
7ek
Old 3rd November 2011, 19:53   #645  |  Link
sosh
Hi _Hawk_
Iam glad to hear that development is continued.
So far i dont have any bugs to post.
Blurip is the best tool to extract the movie, different audio streams, subtitles and mux into one *.mkv.
But i have a question concering Haali splitter blurip uses.
On my HTPC i'am using LAV filters instead of Haali. But if i unregister Haali filters, BluRip fails to generate the *.mkv file.
So are there any options to get BluRip to use LAV filters instead of Haali ?
Thanks in advance
best regards
sosh
sosh is offline   Reply With Quote
Old 3rd November 2011, 22:00   #646  |  Link
eac3to requires haali
Old 3rd November 2011, 22:48   #647  |  Link
sosh
Hi Atak_Snajpera
Thanks for your quick response.
oh, i see, its an eac3to issue.
seems like there is no way to get rid of Haali :-|
Thanks and best regards
sosh
Old 4th January 2012, 21:01   #648  |  Link
ivar
Other container formats
Would it be possible to have the option to mux the output in an m2ts container? I use blurip-rips with my wdtv live, and it seems to be a problem when using mkv`s with TrueHd audio. I have not tried yet, but read somewhere that TrueHd is not good in mkv with the wdtv, but that it should work in an m2ts container. I`m not sue if it the problem is the wdtv or the mkv container, either way I read it should work with m2ts... Could it also be possible to implement so that the file-prefix, target filename and movie title are automatically filled in with something sensible after reading the disc? And by the way, great program! Does everything I looked for, I especially like that one can convert the pgs subtitles.
ivar is offline   Reply With Quote
Old 12th January 2014, 07:37   #649  |  Link
odino
When I extract the movie I often run into the Haali limitation that it should be using the -seektoiframes option. I don't see a way to add this argument into the GUI but this would be really useful otherwise I have to do all the command prompts.
Besides, does the seektoiframes option make any difference for 1:1 video extraction? I don't see anything when I watch it later.
odino is offline   Reply With Quote
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
