Old 18th October 2018, 08:07   #6441  |  Link
Forteen88
Herr
Originally Posted by Boulder View Post
What I already found strange is that deblock doesn't really affect bitrate. For example deblock 6:6 ended up around the same size as deblock 0:0.
But did the avg QP, or visual quality remain the same?
Forteen88 is offline   Reply With Quote
Old 18th October 2018, 15:58   #6442  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The average QP remained pretty much the same, differences were around 0.01-0.03 units between 1:1 - -3:-3. Based on my tests, the higher values did soften the image more at least in places I checked, so maybe the bits were allocated elsewhere in the image.
Old 18th October 2018, 16:40   #6443  |  Link
benwaggoner
Originally Posted by RieGo View Post
in my personal experience avx512 isn't generating much more heat than avx2 - on x265
so as long as you are only using it on x265 and use a safe thermal throttling setting u should be fine imho
That’s what I’d expect; TDP is TDP, and thermal throttling should kick in regardless of where the heat is coming from.
Picojoules per pixels is the more relevant metric here. Heat produced is equal to power draw. Better coolers can get the heat away from the CPU power better of course, but watts to the CPU is going to be the same as watts of heat to dissipate.
Ben Waggoner
My Compression Book
Old 18th October 2018, 16:45   #6444  |  Link
benwaggoner
I'll post my results as soon as I finish the 720p tests. From what I can tell is that 1080p requires slightly different parameters, but of course it could be that things have changed so much under the hood that my set of parameters have been obsolete all the time
Pretty much any settings from before x264 2.4 are invalid now due to the new lambda tables. Lots of other things have improved, but that was probably the biggest change.
Lots of codecs’ internal decisions are done ignoring in-loop deblocking to improve speed. So that’s not terribly surprising. And if this is CRF, it is a delta from QP based on spatial complexity, so it’s not surprising that it would change.
It IS surprising that you wouldn’t see bitrate OR QP change, even with a significant loss of detail. Not that using 6:6 is something anyone is likely to do in practice. But reduced detail should result in lower bitrate and/or QP. With lowered detail (including grain/gain noise), prediction should be more efficient...
Maybe log your repro for this as an issue for MCW?
Ben Waggoner
My Compression Book
Old 18th October 2018, 16:48   #6445  |  Link
benwaggoner
Hmmm. You should look at it in motion then; maybe the improvements are there.
Playing back at 1/4 speed is generally okay to see temporal artifacts better while still keeping temporal coherence. You can still detect discontinuities between IDR/i/P/B/b that way.
Testing at a higher CRF, like maybe 28, can also make differences at lot more obvious. Working at a quality where most things look pretty good can make differences much harder to detect.
Ben Waggoner
My Compression Book
Old 18th October 2018, 17:24   #6446  |  Link
Would it be hotter? Or would it just be slower due to thermal throttling.
I wouldn't be surprised if Intel's next big microarchitecture revision makes AVX512 useful in cases where it isn't today. We saw the same thing with Skylake and AVX2.
The real problem with AVX512 is the strong downclock on stock CPUs, and the high density of the AVX512 instructions, causing a high power draw in a small die area.
With overclockable CPUs, you can control the AVX512 offset and make it useful for x265, but on Xeons or the like, you probably don't get that level of control, and the downclock during AVX512 might offset the advantages it offers.
Additionally, x265 is a pretty "light" AVX512 load. If you change the offset for a lower downclock and then run a strong AVX512 load (like pure math, ie. FFTs, for a prolonged time), your system may become unstable, due to the extreme density of all the heat and power draw. So its really hard to balance.
Old 19th October 2018, 07:47   #6447  |  Link
DotJun
You should encode whole movie (130k frames) instead of ultra short clip with few hundred of frames.
The longer you encode the more heat your cpu will produce and hence more aggressive AVX negative offset will be activated.
I encoded a full length movie and temps did not go over 80c which I think is ok for my chip? I should have stated that this computer is in a climate controlled area set to 70F.
My chip is OC'd to 4.5ghz with a -4 offset so that it drops to 4.1 when using avx. I guess I should have tried to compare encoding speed with avx on and off instead of just avx-512 enabled and disabled. I have no throttling issues and the load is a pretty consistent 100% with the occasional 1 second dip down to 87% every 30 seconds or so.
What is the command to disable avx entirely?
afaik avx512 enabled and disabled should produce exact same output. at least on my tests it did. can you share your command line?
This is what I use for 4k source since there is no Film preset:
--preset slower --crf 17 --profile main10 --me 3 --subme 5 --psy-rd 1.5 --psy-rdoq 5.0 --rdoq-level 1 --qcomp 0.8 --deblock -1:-1 --no-sao --repeat-headers --hdr-opt --range limited --colorprim 9 --transfer 16 --colormatrix 9 --master-display "G(13250, 34500)B(7500, 3000)R(34000, 16000)WP(15635, 16450)L(10000000, 1)"
DotJun is offline   Reply With Quote
Old 19th October 2018, 12:21   #6448  |  Link
It is funny how you in USA use two different scales for temperature
Bad idea! AVX2 is very useful in x265.
Old 19th October 2018, 13:53   #6449  |  Link
Ma
--asm sse4
Main asm levels are:
--asm no
--asm sse2
--asm ssse3
--asm sse4
--asm avx2
--asm avx512
--asm avx512 works a bit different -- it only enable possibility to use AVX-512 in auto-detection of CPU capabilities. For hard use of AVX-512 code (without checking) please use
--asm avx,avx512
Old 19th October 2018, 19:36   #6450  |  Link
excellentswordfight
Lost my old account :(
Not sure if there is anyone that works on x265 is active in this thread anymore, but I've seen some discussion regarding --CTU and --merange both in this thread in the past and recently in a few threads.
From what I’ve read here and from what I’ve experienced from my testing is that using a CU size of 64 is overkill for 1080p and bellow, I see both a speed increase and a multithread increase when lowering it together with merange with no apparent loss in compression. I also saw some posts way back in this thread that suggested that the default CTU size should be based on resolution, wasn’t this implemented for any specific reason or is it just that no one has committed a patch for it?
I also have a question for merange, it says in the docs that the value of 57 is based on CTU-size and search method, but the value is set to 57 for all presets even though CTU-size and search method vary. How come?
excellentswordfight is offline   Reply With Quote
Old 19th October 2018, 20:37   #6451  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I finished my short tests today, and these are the settings that I found to suit my requirements.
1080p:
--deblock -3:-3 --no-strong-intra-smoothing --merange 44 --no-sao --qcomp 0.75 --aq-mode 3 --aq-strength 0.8 --ctu 32
--max-tu-size 32 --qg-size 8 --tu-inter-depth 4 --tu-intra-depth 4 --limit-tu 4 --limit-refs 3 --max-merge 3 --rd-refine
--ref 6 --bframes 10 --crf 20.5
720p:
--deblock -3:-3 --no-strong-intra-smoothing --merange 38 --no-sao --qcomp 0.8 --aq-mode 3 --aq-strength 0.8 --ctu 16
--max-tu-size 16 --qg-size 8 --tu-inter-depth 3 --tu-intra-depth 3 --limit-tu 4 --limit-refs 3 --max-merge 3 --rd-refine
--ref 6 --bframes 10 --crf 19.5
Very few changes between the two, but the CTU/TU size was an obvious change based on the comparison I made. Upon playback, the video looks very good in both resolutions on my 65" LCD even when watched from 1 meter or so. As a test source, I used the first episode of Black Sails as it's generally considered a very high quality Blu-ray release.
I did try finding out differences between deblock 1:1 and -3:-3 in motion but couldn't tell. If someone had ABX'd me, I probably wouldn't have been able to say which one is which. Mind you, the scene I used contained quite a lot of motion and some fast cuts so maybe they were just not visible there. Anyway, I chose a low value as I think it will retain detail and sharpness better. I watch everything from about 3-3.5 meters anyway, so any small blocking won't be that visible.
Edit: both encodes using the preset "veryslow".
Old 20th October 2018, 00:30   #6452  |  Link
Dclose
Did you see any issues with using 0:0?
I did a 4k down to 1080 encode the other day, with an accidental 0:0 deblock setting. It looks good in a "slick," "photoshopped" way, but it definitely loses a lot of detail, at least at CRF 23.
That's too much deblocking for me. Though I do put db at 0:0 when increasing CRF and dropping resolution a lot.
Dclose is offline   Reply With Quote
Old 20th October 2018, 05:53   #6453  |  Link
DotJun
x265 HEVC Encoder
Originally Posted by Ma View Post
--asm sse4
--asm no
--asm sse2
--asm ssse3
--asm sse4
--asm avx2
--asm avx512
--asm avx,avx512
Thanks, I’ll put up three test runs of default, sse4 and avx512 to see what changes there are in FPS and efficiency.
Will medium or fast preset be ok to use or it has to be slower or higher?
Will it be ok to use “asm sse4” or do I have to specify sse4.2 like my log file shows?
Old 20th October 2018, 10:42   #6454  |  Link
Boulder
Pig on the wing
Boulder's Avatar
--qg-size 16, tested values from 64 to 8, 16 looked best (in terms of distortion in small details again) when compared frame-by-frame. Tested with a 720p encode, so I'll need to check that also with 1080p later.
I would expect it would look better, but at some cost to efficiency due to the signaling overhead. --opt-cu-delta-qp might help that some.
I was wondering about this parameter. Does it actually shift bits inside the frame so that the distribution is closer to the average - so that some areas with fine detail could suffer at the cost of flat areas looking better? Or the other way around as flat areas could be compressed using a lower QP to make them look equally good?
Old 20th October 2018, 22:39   #6455  |  Link
benwaggoner
AFAIK it works by reducing signaling overhead without changing actual pixels. There are several bitstream options that do things like that. This is the one likely to have the most impact, as WP signaling can take place MANY times per frame. The others are per frame or per GOP.
Sent from my iPhone using Tapatalk
Ben Waggoner
My Compression Book
Old 21st October 2018, 07:23   #6456  |  Link
DotJun
I did a few more test runs with the same parameters I stated before using 50k frames test clip. Here are the results.
Normal Preset:
sse4 2.19fps
avx2 2.89fps
512 3.18fps
They all had the exact same kbps of 23463.
Slower Preset:
sse4 0.71fps
avx2 0.89fps
512 0.95fps
All of them ended up with the exact same kbps of 22868.
My previous test from the other day seems to be a failure since I didn't use correct the correct switches for --asm.
Old 21st October 2018, 13:21   #6457  |  Link
Boulder
Pig on the wing
Boulder's Avatar
There is a quite clear difference in the frame, it was quite obvious in this flat area (zoomed in though). The filesize difference was about 5% (the optimized version was smaller).
Without the optimization:
Optimization enabled:
In higher detailed area, the optimized encode looked better. I think I need to find a scene with some still background like sky, and see which one looks better in motion. The banding in flat areas can be quite eye-catching once you notice it.
Old 21st October 2018, 18:54   #6458  |  Link
benwaggoner
Wow, awesome info! Thanks! I will iterate on further.
Was there any measurable perf difference?
Ben Waggoner
My Compression Book
Old 21st October 2018, 19:37   #6459  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I just ran a longer encode to measure, and the difference is quite high. 4.95 fps for the normal encode and 5.22 fps for the one with optimization enabled. The normal encode is about 8% bigger.
I also checked how the optimization works in normal playback, and my eyes didn't like the result. The flat areas suffered a bit too much, there was a short scene with a nice, slightly noisy but flat coloured background which was lit by some flickering candlelight. The normal encode was slightly better looking there, there was not as much swimming blocks effect as there was with the optimized version.
Old 21st October 2018, 20:35   #6460  |  Link
benwaggoner
An 8% file size reduction for a 5.5% speed increase would be an incredible optimization. An optimization can that give 1% reduction for a 5% speed increase is a big deal.
...but only if that 8% reduction doesn't impact quality, alas.
It would be interesting to see what the difference was in a stream analyzer. Or just looking at the log-level 2 csv files.
Ben Waggoner
My Compression Book
