11th May 2018, 14:49 | #4061 | Link | |
Groucho's Avisynth Stuff |
11th May 2018, 17:57 | #4063 | Link | |
Test build 2 fixes it. Sorry guys, I should have provided a sample so problem would be found faster. Last edited by bxyhxyh; 11th May 2018 at 18:18. |
14th May 2018, 20:26 | #4064 | Link | |
Acid fr0g
@turment on Telegram |
29th May 2018, 16:15 | #4067 | Link |
Unofficial test build (x86/x64 installer w/o VC2017 redistributables)
https://drive.google.com/open?id=1sj...8nwIRavOU0PqmF I hope some of you will find some new exiting features in this build. (And report bugs if they are found) Code:
- AviSource to support more formats with 10+ bit depth. http://avisynth.nl/index.php/AviSource When pixel_type is not specified or set to "FULL", AviSource will try to request the formats one-by-one in the order shown in the table below. When a classic 'pixel_type' shares more internal formats (such as YUV422P10 first tries to request the v210 then P210 format) you can specify one of the specific format directly. Note that high bit-depth RGBP is prioritized against packed RGB48/64. The 'FourCCs for ICDecompressQuery' column means that when a codec supports the format, it will serve the frame in that one, Avisource then will convert it to the proper colorspace. Full support list (* = already supported): 'pixel_type' Avs+ Format FourCC(s) for ICDecompressQuery YV24 YV24 *YV24 YV16 YV16 *YV16 YV12 YV12 *YV12 YV411 YV411 *Y41B YUY2 YUY2 *YUY2 RGBP10 RGBP10 G3[0][10] r210 R10k r210 RGBP10 r210 R10k RGBP10 R10k RGBP RGBP10 G3[0][10] r210 R10k RGBP12 G3[0][12] RGBP14 G3[0][14] RGBP16 G3[0][16] RGBAP10 G4[0][10] RGBAP12 G4[0][12] RGBAP14 G4[0][14] RGBAP16 G4[0][16] RGB32 RGB32 *BI_RGB internal constant (0) with bitcount=32 RGB24 RGB24 *BI_RGB internal constant (0) with bitcount=24 RGB48 RGB48 BGR[48] b48r RGB64 RGB64 *BRA[64] b64a Y8 Y8 Y800 Y8[32][32] GREY YUV422P10 YUV422P10 v210 P210 v210 YUV422P10 v210 P210 YUV422P10 P210 YUV422P16 YUV422P16 P216 P216 YUV422P16 P216 YUV420P10 YUV420P10 P010 P010 YUV422P10 P010 YUV420P16 YUV420P16 P016 P016 YUV422P16 P016 YUV444P10 YUV444P10 v410 v410 YUV444P10 v410 - Changed (finally): 32bit float YUV colorspaces: zero centered chroma channels. U and V channels are now -0.5..+0.5 (if converted to full scale before) instead of 0..1 Note: filters that relied on having the U and V channel center as 0.5 will fail. Why: the old UV 0..1 range was a very-very early decision in the high-bitdepth transition project. Also it is now compatible with z_XXXXX resizers (zimg image library, external plugin at the moment). - New function: bool IsFloatUvZeroBased() For plugin or script writers who want to be compatible with pre r2672 Avisynth+ float YUV format: Check function availablity with FunctionExists("IsFloatUvZeroBased"). When the function does not exists, the center value of 32 bit float U and V channel is 0.5 When IsFloatUvZeroBased function exists, it will return true (always for official releases) if U and V is 0 based (+/-0.5) - Fix: RGB64 Turnleft/Turnright (which are also used in RGB64 Resizers) - Fix: Rare crash in FrameRegistry - Enhanced: Allow ConvertToRGB24-32-48-64 functions for any source bit depths - Enhanced: ConvertBits: allow fulls-fulld combinations when either clip is 32bits E.g. after a 8->32 bit fulls=false fulld=true: Y: 16..235 -> 0..1 U/V: 16..240 -> -0.5..+0.5 - Fix: couldn't see variables in avsi before plugin autoloads (colors_rgb.avsi issue) - Fix: LoadVirtualdubPlugin: Fix crash on exit when more than one instances of a filter was used in a script - New: LoadVirtualdubPlugin update: - Update from interface V6 to V20, and Filtermod version 6 (partial) - VirtualDub2 support with extended colorspaces Allow RGB24, RGB48, RGB64 besides RGB32 AutoConvert 8 bit Planar RGB to/from RGB24, RGBPA to/from RGB32 (lossless) AutoConvert RGB48 and 16 bit Planar RGB(A) to/from RGB64 (lossless) Support YUV(A) 8 bits: YV12, YV16, YV24, YV411, YUVA420P8, YUVA422P8, YUVA444P8 Support YUV(A) 10-16 bits (properly set "ref_x" maximum levels, no autoconvert) - Supports prefetchProc2 callback (API >= V14 and prefetchProc2 is defined) for multiple input frames from one input clip PrefetchFrameDirect and PrefetchFrame are supported. PrefetchFrameSymbolic not supported - Supports prefetchProc callback (API >= V12 and prefetchProc is defined) - Supports when filter changes frame count of the output clip - Extra filter parameter added at the end of filter's (unnamed) parameter list Imported Virtualdub filters are getting and extra named parameter to the end: String [rangehint] This parameter can tell the filter about a YUV-type clip colorspace info Allowed values: "rec601": limited range + 601 "rec709": limited range + 709 "PC.601": full range + 601 "PC.709": full range + 709 "" : not defined (same as not given) Parameter will be ignored when clip is non-YUV How it works: the hint will _not_ change the internal VirtualDub colorspace constant (e.g. kPixFormat_YUV420_Planar -> kPixFormat_YUV420_Planar_709 will not happen). Instead the base color space is kept and colorSpaceMode and colorRangeMode will set in PixmapLayout.formatEx. Filter can either use this information or not, depending on supported API version and its implementation. E.g. Crossfade(20,30) -> Crossfade(20,30,"rec601") though this specific filter won't use it. - New function: BuildPixelType Creates a video format (pixel_type) string by giving a colorspace family, bit depth, optional chroma subsampling and/or a template clip, from which the undefined format elements are inherited. "[family]s[bits]i[chroma]i[compat]b[oldnames]b[sample_clip]c" string family: YUV, YUVA, RGB, RGBA, Y int bits: 8, 10, 12, 14, 16, 32 string chroma: for YUV(A) 420,422,444,411. Ignored for RGB(A) and Y bool compat (default false): returns packed rgb formats for 8/16 bits (RGB default: planar RGB) bool oldnames (default false): returns YV12/YV16/YV24 instead of YUV420P8/YUV422P8/YUV444P8 clip sample_clip: when supported, its format is overridden by specified parameters (e.g. only change bits=10) Example#1: define YUV 444 P 10 family = "YUV" bits = 10 chroma = 444 compat = false oldformat = false s = BuildPixelType(family, bits, chroma, compat, oldformat) BlankClip(width=320,height=200,length=len,pixel_type=s,color=$008080).Info() Example#2: Change only the bit depth of the format to 16 newbits = 16 c = last s = BuildPixelType(bits=newbits, sample_clip=c) BlankClip(width=320,height=200,length=len,pixel_type=s,color=$008080).Info() - Source: move to c++17, 'if constexpr' requires. Use Visual Studio 2017 (or GCC 7?). CMakeLists.txt changed. - Source: C api: AVSC_EXPORT to dllexport in capi.h for avisynth_c_plugin_init - Source: C api: avs_is_same_colorspace VideoInfo parameters to const - Project struct: changelog to git. Last edited by pinterf; 30th May 2018 at 12:57. Reason: Change download link |
29th May 2018, 17:00 | #4069 | Link | |
VirtualDub2 |
29th May 2018, 17:32 | #4070 | Link | |
Soul Architect
29th May 2018, 18:06 | #4071 | Link |
Soul Architect
Would it be a good idea to add an option for VirtualDubFilter to pass YUV data in RGB format without converting it? This would be useful for filters that support only RGB format but if YUV was sent in that format it would work as well.
29th May 2018, 18:44 | #4073 | Link |
29th May 2018, 19:03 | #4075 | Link |
It's in the list under pixel type. Or were you asking for something else like fourcc code ? It doesn't have a fourcc
Or did you mean the *new* list posted by pinterf above ? Code:
YUV420 YUV420PS 32 Last edited by poisondeathray; 29th May 2018 at 19:06. |
30th May 2018, 12:48 | #4077 | Link | |
http://avisynth.nl/index.php/CombinePlanes |
30th May 2018, 12:50 | #4078 | Link |
I'm trying to access Pinterf upload,
Getting blocked by SonicWall, for reason 'radicalism and extremism', (something you aint tellin' us Pinterf) Second time this has happened, currently on Cloud network wifi in pub, last time got an apology, but still now reblocked. EDIT: Problem seems to be with MediaFire, rather than Pinterf upload.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 30th May 2018 at 12:55. |
30th May 2018, 12:58 | #4080 | Link |
Thanx P, but you should be more careful about the types of terrorist you associate yourself with.
