Old 13th December 2018, 08:51   #121  |  Link
Godwin
Godwin's Avatar
Version 14.5 beta 3 has been released.
Download:
http://inmatrix.com/files/zoomplayer_beta.shtml
Changes in this beta:
* New feature!
+ Changed feature!
- Fixed feature!
* TheMovieDB.org media library scraping plugin has been enhanced and can
now return non-english meta-data (texts and images).
+ The Install Center now includes two configuration profiles for the
3DYD YouTube Source filter that enable HD/4K streaming.
+ Visualization are now enabled when the 3DYD YouTube Source filter is set
to "audio only" output.
- TheAudioDB.com scraper plugin is now functional after the API used by
the site moved to encrypted communication (https), breaking backward
compatibility.
- If a media title contained a 'line feed' or 'return' characters, it would
corrupt the play history.
- Fixed a possible TheMovieDB.org scraper freeze (could have caused
slow-downs on exit or more rarely, a player freeze) when used in
combination with the "Scrape using media derived title (instead
of file name)" category setting.
- When the "Scrape using media derived title (instead of file name)" category
setting was enabled, under some conditions, the media's thumbnail would not
display after closing and reopening the media library.
Previous beta changes since the release of version 14.4:
http://inmatrix.com/files/zoomplayer...new_beta.shtml
Godwin is offline   Reply With Quote
Old 16th December 2018, 16:31   #122  |  Link
Godwin
Godwin's Avatar
Version 14.5 beta 4 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
- When the "Force the navigation list or thumb view display to full width"
setting was enabled in combination with the "Use dynamically visible
scroll bar" setting, the thumbnail would not highlight correctly.
- TheAudioDB.com media library scraper can now better handle artist names
containing the "-" character, for example "Alt-J - This Is All Yours"
will now properly scrape.
Old 26th December 2018, 14:39   #123  |  Link
Godwin
Godwin's Avatar
Version 14.5 beta 5 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* New "Thumb rendering threads" setting (Adv. Options / Interface /
Fullscreen Navigation / Thumb View) to specify the number of CPU threads
used to render the thumbview display.
Previously, this setting was hard-coded to use 2 threads, but now you
can specify any value from "Auto" to "16".
Auto mode uses either 2 or 3 threads depending on your PC, but
performance can be improved further with additional threads on systems
containing many cores or high bandwidth RAM.
* New "Support folders as playlist entries" Setting (Adv. Options /
Interface / Playlist). This setting was previously hardcoded and
is still enabled by default to support advanced playlist functionality.
However, supporting folders as playlist entries triggers a spun-down HDD
drive to spin back up when a playlist is loaded. With this new setting
disabled, you can now prevent drives from accidentally spinning up.
* New Setting (Adv. Options / Playback / Controls) to mute the audio when
enabling Slow Motion or Fast Play.
* New "fnToggleOverlayCover" function to toggle the "Video covers entire
display area" setting on and off.
+ Optimized the Media Library's thumbnail drawing code, increasing update
speed and smoothness.
+ The Maximum number of scraping threads used by the media library has
increased from 8 to 16.
+ When a media library scraped movie did not contain a backdrop image,
the default background image is now used instead of a black screen.
+ Updated the PNG and zLib libraries to newer versions.
- Starting Zoom Player with the "Do not check if a file exists when adding
to the playlist" setting enabled no longer triggers spun-down HDD drives
to spin-up.
- The GuardDog feature would try to restart Zoom Player if Zoom Player's
load time was taking too long (due to HDD drive spin-ups or a network
drive reconnection).
- The Media Library's Jukebox mode would not enable if the only file in
the folder was a playlist.
- Fixed a case where a media library scraped movie not containing a
backdrop image showed a backdrop from another movie.
Old 8th January 2019, 14:42   #124  |  Link
Godwin
Godwin's Avatar
Version 14.5 beta 6 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* Extended video streaming support for the following web sites:
Facebook (facebook.com)
Vimeo (vimeo.com)
Dailymotion (dailymotion.com)
VK (vk.com)
LiveLeak (liveleak.com)
Break.com (break.com)
Veoh (veoh.com)
eBaum's World (ebaumsworld.com)
VKMag.com (vkmag.com)
Team Four Star (teamfourstar.com)
GodTube (godtube.com)
StreetFire.net (streetfire.net)
Daily HaHa (dailyhaha.com)
TCMag.com (tcmag.com)
Bofunk (bofunk.com)
Some sites (e.g. facebook) may require you to enable the extended analysis
mode for the 3DYD filter through the Zoom Player Install Center.
* Automatic fullscreen navigation skin switching based on the display's
aspect ratio.
For example, by specifying a 16:10 and selected a Zoom Player navigation
skin designed for 16:10 displays.
(e.g. https://www.inmatrix.com/zplayer/nav/default1610.shtml)
Note:
Skin switching is currently only triggered when opening a navigation
interface.
* New "Refresh" option (Media Library Category Editor / Configure Category)
for YouTube channels and RSS Streams that refreshes the channel's Name &
Thumbnail.
+ Entering a media library TV JukeBox folder that contains no media files
will no longer switch to thumbnail view for the empty folder, instead
remaining in file list mode.
- When viewing the media library's TV/Movie in JukeBox mode, the backdrop
images was not scaled and cropped properly on non-16:9 displays
(e.g. 1920x1200 monitor) leaving black bars instead of filling with
the backdrop.
- Zoom Player will no longer try running MediaInfo.dll when playing a URL,
removing the 'unknown error' message from the play information dialogs.
- Using the "^" character in a file name to cause the media library
scraper to ignore any text after this character did not work in
some cases.
- The "Mute audio during forward and backward seeks" setting was muting
audio when attempting to seek forward/backward in a live stream even
in cases seeking was not possible.
Old 17th January 2019, 12:47   #125  |  Link
Godwin
Godwin's Avatar
Zoom Player v14.5 final has been released:
Download:
http://inmatrix.com/files/zoomplayer_download.shtml
Highlights:
  • Streaming support for:
    Facebook, Vimeo, Dailymotion, VK, LiveLeak,
    Break.com, Veoh, eBaum's World, VKMag.com,
    Team Four Star, GodTube, StreetFire.net,
    Daily HaHa, TCMag.com and Bofunk.
  • Enhanced media library multi-core threading support for extra smoothness.
  • Localization support for TheMovieDB scraper (get posters and information for any language).
  • TheAudioDB scraping is now functional again after changes were made to the API.
  • Automatic fullscreen navigation skin switching based on the display's aspect ratio.
  • Playlist entry highlighting & UX enhancements to the Advanced Playlist Control.
  • Many important bug fixes and speedy optimizations.
What's new in Zoom Player v14.5:
Vimeo (vimeo.com)
VK (vk.com)
Veoh (veoh.com)
Bofunk (bofunk.com)
aspect ratio.
Note:
interface.
* The playlist editor (when using the default Onyx skin or the bundled
Alba skin) now draws alternating line highlights making the playlist
easier to track visually.
* The playlist editor's right-click menu now features Colorize actions
that let you easily color-code track(s) text and background colors.
The color information is automatically saved and restored when using
Zoom Player's default ZPL format playlists.
* New "PlayListData/Background2" skin script parameter that specifies
the alternating playlist editor line highlight color.
* New Setting (Adv. Options / Playback) that automatically tries to use
the YouTube IFRAME player if DirectShow playback of a YouTube stream
fails.
* New Setting (Adv. Options / Playback / Controls):
"Next / Previous Track" plays the next/prev media in the same folder if
playlist contains 1 file.
This function behind this setting was previously always enabled.
This setting remains enabled by default, but from now you can disable
this behavior from the advanced options dialog.
* New Setting (Adv. Options / Fullscreen Navigation / Customization) to
force the navigation list or thumb view to maximum width.
Unlike the "full width" setting, this setting will make the navigation
list area take the display device's maximum resolution, which can cause
some cosmetic issues (like the thumbnail highlight getting cropped).
* The advanced playlist control (accessible through the playlist editor
or by pressing "J") now shows the number of items remaining in the
playlist as the search filters the playlist.
Thumbnail.
* New "exVidMoveHorz" and "exVidMoveVert" extended functions that move
the video area (fullscreen) or player window (when not in fullscreen)
horizontally and vertically.
Command line usage example:
zplayer.exe /exfunc:exvidmovehorz,-200 /exfunc:exvidmovevert,-100
+ The advanced playlist control's filter search was searching the
entire playlist on each letter pressed, this caused a sluggish
user experience when dealing with very larger playlists (over
30,000 entries).
To enhance the user experience, the search action is now only
performed 350-400ms after the last key-stroke, ensuring that
the user interface does not stall while typing.
+ Zoom Player now does a better job at extracting album art images from
media files if the JPEG image contains junk in front of the actual image.
+ Visualization are now supported when the 3DYD YouTube Source filter is
set to "audio only" output.
+ The Command & Control API now notifies when subtitles are enabled/
disabled when using the "fnToggleSub" and "fnDisableDVDsub" functions.
- TheAudioDB.com scraper plugin is now functional again after the API used
by the site moved to encrypted communication (https), breaking backward
compatibility.
to spin-up.
- The GuardDog feature tried to restart Zoom Player if Zoom Player's
drive reconnection), from now the guard dog feature will only start
functioning once Zoom Player has finished loading.
the backdrop.
- Kinetic scrolling in the media library did not work well using a mouse
cursor, stopping when attempting to scroll multiple times while the
kinetic movement was still in mid process.
- Playing media that contained certain special characters in the media's
title caused multiple unplayable entries to appear in the play history.
- With the "Adv. Options / Interface / Position & Size - Auto-Size User
Interface to maintain Video Aspect Ratio (when resizing)" setting enabled,
playing audio files with folder/album art could cause Zoom Player's main
window to display partially off-screen.
- The latest version of mediainfo DLL changed how it extracts cover art
for audio files, breaking Zoom Player support for displaying the album
art with some audio formats (mainly M4A).
- Better album art image extraction from audio files with ID3v2 TAGs when
the image header included some junk data.
- When opening a media file by double-clicking from explorer (or other
file managers), the currently playing track wouldn't highlight correctly
and show the playing position in the playlist editor.
- Using the "Stop" function while a JPEG/PNG image was loading, combined
with a setting that closes the playing media when using the "Stop"
function, caused the image to remain on screen under some conditions.
- Double-clicking an entry on the skin selection dialog could sometimes
trigger an access violation error.
- When opening the playlist editor, under some conditions the bottom
entries would not show up until the playlist screen was refreshed
by a click or scroll.
- The "&" character wasn't showing up in the playlist editor.
- Pressing under the last item in the playlist editor did not
visually select the last item in the list. Then if you pressed
the "Enter" key, it would start playing the last item in the
playlist which was a bit confusing without the visual cue of
a selected entry.
- Fixed a crash when trying to play a video file with too many
external audio tracks. External audio tracks are now limited
to a maximum of 10 tracks.
- Using the "^" character in a file name to force the media library
scraper to ignore any text after this character did not work properly
in some cases.
in cases where seeking was not possible.
Previous changes since the release of version 14.4:
http://inmatrix.com/files/zoomplayer_whatsnew.shtml
Old 31st January 2019, 16:14   #126  |  Link
saman
saman's Avatar
Why does not sound after the run mov file
saman is offline   Reply With Quote
Old 13th February 2019, 14:50   #127  |  Link
Godwin
Godwin's Avatar
Version 14.6 beta 1 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ The Media Library category editor has been restructured to make it
easier to use when working with many categories.
- Deleting the currently playing file did not remove the file from the
current playlist.
- Under some condition, the previously played media title would appear
in the timeline area and invalid entries were being added to the
play history.
- Erasing entries from the favorite media list did not actually save the
list your drive. Unless a new entry was added (which did save the list),
restarting Zoom Player would restore the erased entries.
- Removing entries from the playlist editor did not always select the
current remaining track.
- The chapter selection pop-up OSD appeared in the wrong screen position.
- In the playlist editor, clicking the blank area under the playlist
entries would select the last entry without clearing the currently
selected entry.
Previous beta changes since the release of version 14.5:
Old 5th March 2019, 14:52   #128  |  Link
Godwin
Godwin's Avatar
Version 14.6 beta 2 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ YouTube changed their text encoding scheme which caused Zoom Player
to show the encoding of certain characters instead of the actual
characters.
+ Trying to open a navigation interface while in audio mode simply
didn't do anything, now Zoom Player will automatically switch to
media mode and show the navigation interface.
+ Trying to seek backward/forward on a live stream with no duration
will no longer show an OSD message as if a seek was performed.
- Manually editing a Zoom Player ".CHP" chapter file using an external
text editor could have triggered a freeze when trying to load the
associated media file.
- Changing the internal screen saver's slideshow path did not take
affect until the next player restart if the screen saver was
previously active (changing the folder didn't clear the cache).
Old 5th April 2019, 06:25   #129  |  Link
Godwin
Godwin's Avatar
Version 15 beta 3 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* Live YouTube stream support using the latest version of the
3DYD YouTube source and LAV Filters.
* New YouTube channel listing strategy (not enabled by default)
which you can now enable through the Media Library category
editor.
The new strategy works by listing videos in a channel's "Uploads"
playlist. The downside to this strategy is that some videos
may not be ordered by Publish date. For this reason, 50 videos
are requested instead of the usual 25 and these videos are then
sorted by the plugin instead of just listing them as-is. The upside
is that you get longer descriptions for the videos.
* The media library can now display a format icon for the new
AV1, DTS:X and Dolby Atmos audio/video codecs.
* Support for the ADTS audio wrapper format.
* New "/SHOWOSD:[Text]" command line parameter used to show a pop-up
OSD on an already running instance of Zoom Player.
characters.
- The "Refresh" button on the media library category configuration
dialog was accidentally left enabled for folder based categories.
Clicking it would trigger a "list index out of bounds" error.
- Streaming audio-only YouTube with visualizations would not always
enable the ZP DSP Filter, causing synchronization issues between
the audio and visualization.
- Trying to close the Install Center during an install could have
resulted in a crash.
Old 8th April 2019, 14:38   #130  |  Link
Godwin
Godwin's Avatar
Version 15 beta 4 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* The Play History fullscreen navigation interface now lists the
last play time (not just the date), the last play position and
the full path to the currently highlighted entry.
* The Favorite media fullscreen navigation interface now shows the
full path to the highlighted entry.
* New "Close on Play" checkbox on the Advanced Playlist Control dialog
to control whether the dialog remains open or closed after playing a
new media from the dialog.
+ Enhanced detection for Dolby Atmos tracks.
+ Changed the how information (text/icons) are aligned on the right side of
fullscreen navigation interfaces so the information does not shift around
when the selected line is changed.
+ Tweaked the list based fullscreen naviation interfaces to squeeze out
a little more horizontal space.
- The sub-folder selection within the media scanner fullscreen
navigation interface would draw outside the defined line boundries.
- The media scanner no longer allows you to add folders to plugin
based categories (which are not folder based).
Old 11th April 2019, 13:42   #131  |  Link
Godwin
Godwin's Avatar
Version 15 beta 5 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* New Smart Play profile for the ".DSF" file format.
* New Smart Play profile for the "DSD" (Direct Stream Digital) codec.
+ When safe mode is enabled, instead of completely hiding the main
navigation interface's "System" sub-menu, now only the "Exit Zoom Player"
entry is hidden.
- Enabling fullscreen navigation's "Safe Mode" broke the functions screen
on the "Favorites" navigation interface.
- Enabling fullscreen navigation's "Safe Mode" prevented access to the
stream selection navigation interface.
Old 18th April 2019, 13:36   #132  |  Link
Godwin
Godwin's Avatar
Version 15 beta 6 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ Newly created YouTube media library categories will no longer show
a video icon overlay by default (as all content from YouTube is
video).
+ The fullscreen navigation information interface no longer closes
automatically when opening a new media file.
- It's no longer possible to erase files in safe mode from within the media
library mini-menu.
- Accidentally forgot to include the DSF/DSD smart play profiles with
the previous beta.
Old 29th April 2019, 14:03   #133  |  Link
Godwin
Godwin's Avatar
Version 15 beta 7 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* Zoom Player Command & Control API has been expanded:
1. New command to open a streaming URL.
2. New command to Get & Set the current playlist
sorting order (Ascending/Descending).
3. New command to sort the playlist (by name, size, date, etc).
+ The Next/Previous frame functions are now ignored when playing
audio-only content (there was no real use for it and it caused weird
behavior with some decoders).
- Enabling "Force the navigation list or thumb view display to full width"
or "Force the navigation list or thumb view to maximum width" settings
would break the visual integrity of the information fullscreen navigation
interface (and the Main navigation interface if it was used in list mode).
- The Media Library's "Run Application" plug-in did not run applications
correctly if some command line parameters were used.
- Fixed an issue where certain characters used in a media library's
category path could corrupt the category list or prevent the afflicted
category from functioning correctly.
Old 9th May 2019, 08:10   #134  |  Link
Godwin
Godwin's Avatar
Version 15 beta 8 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* New Setting "Adv. Options / System" (disabled by default) to allow the
Command & Control API to remotely control the PC's mouse cursor.
* Zoom Player Command & Control API has been expanded with support
for remotely controlling the PC's mouse cursor. For additional
security, this capability requires you to enable the new
"Allow remote mouse control" setting.
- Playing a media through the Advanced Playlist Control dialog and then
trying to close the dialog before the media finished loading would
cause a non-fatal crash.
Old 28th May 2019, 13:14   #135  |  Link
Godwin
Godwin's Avatar
Version 15 beta 9 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ TheMovieDB scraper plugin will now scrape movies that do not contain
a poster image.
- Using the Advanced Playlist Control to move items to the top or
bottom while a media was playing messed up the playlist active item
display as well as the ID3/TAG on-screen information.
- When the media library displayed a movie with no poster in JukeBox
mode, the poster area showed random junk.
- Trying to switch to Audio or DVD modes while a media was in the
process of loading triggered a crash.
- Trying to close the Playlist editor while a track was in the process
Old 24th June 2019, 09:10   #136  |  Link
Godwin
Godwin's Avatar
Version 15 beta 10 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ Forgot to include the updated TheMovieDB scraper plugin in the
previous beta.
- Rewrote the entire system that handles the currently selected audio
device. Previously, if you were to disconnect an audio device
(e.g. a BlueTooth headset), Zoom Player would switch to the default
audio device, but when the the audio device was reconnected,
Zoom Player would continue to use the default device instead of the
previously selected device.
Now Zoom Player always tries to use the previously selected device
and only temporarily switches to the default device if the selected
device is not currently available.
- Pressing the next-track button with the next tracks being a series of
executable files would execute all files at once instead of just the
first executable and pausing.
- A bug introduced in a recent beta prevented Zoom Player from automatically
switching between DVD and Media modes.
Old 2nd July 2019, 12:55   #137  |  Link
Godwin
Godwin's Avatar
Version 15 release candidate 1 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
+ Hovering with the mouse cursor over the timeline no longer pops up a
"00:00" position hint when playing a live stream with no duration.
- Rewind, Fast Forward and Slow Motion are now disabled when playing
live streams with no duration (these functions were interfering
with playback).
- Fixed a freeze when using the MPC Audio Renderer combined with the
"Show all filters in Stream Selection sub-menu" setting.
- The DVD Audio Renderer setting was not being saved due to a bug
introduced in the previous beta.
Old 17th July 2019, 13:23   #138  |  Link
Godwin
Godwin's Avatar
Version 15 release candidate 2 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* New Setting (Adv. Options / Playback / Controls) that lets you
specify the number of milliseconds Zoom Player should wait after
closing a streaming media before resuming operations.
+ To prevent instability, if Zoom Player's options dialog is open,
all API/Keyboard processing (for the main window) are now disabled.
- Fix for a possible freeze when opening the media library.
- The default 16:10 skin was showing a 1px clear line to the right of
the movie poster in jukebox mode.
- Fixed an issue where pressing next track in a playlist containing an
executable file would not stop playing the previous media track after
executing the playlist entry, which also caused a cosmetic glitch in
- Furiously Clicking the mouse's right button to open the context menu
while a track was loading caused multiple context menus to appear on
screen and could even lead to a crash in some cases.
- Under some rare conditions, Mouse Gesture actions could trigger without
the left mouse button being held down.
- Unchecking "Limit 'Hot Corners' to fullscreen mode" caused issues trying
to move the player windows in Audio Mode.
- Pressing DEL to erase the currently playing media will no longer prompt
you to delete to recycle bin if the playing media is a URL.
- Stopped the two settings that control automatic switching between Audio
and Media mode from working while the player is in fullscreen mode:
Auto Switch to Audio Mode when a Media File does not contain a Video Stream
Auto Switch to Media Mode when a Media File contains a Video Stream
- Deleting the active entry in the playlist editor (orange highlight when
using the default onyx skin), did not reset the active entry if that
track wasn't currently playing.
- Using the "fnPLEditMetaData" function (for example using the command line
"/func:fnPLEditMetaData" parameter) several times would cause multiple
windows to appear.
- The internal screen saver no longer activates if a track is currently
in the process of loading or if an error dialog is currently visible.
Old 21st December 2019, 07:42   #139  |  Link
hay178
Can some tell me what the last basic version of player was? my computer is getting old, i want to run as efficiently as possible; and i rarely use htpc mode. I realy love this player. I have a bunch of versions over the years still on backup hdds
hay178 is offline   Reply With Quote
Old 20th January 2020, 13:26   #140  |  Link
Godwin
Godwin's Avatar
Version 15 release candidate 3 has been released.
Download:
* New feature!
+ Changed feature!
- Fixed feature!
* New "Go" button on the station editor to make search practical
without access to a keyboard.
* New Setting (Adv. Options / Playback / Audio) to control whether
the Equalizer and Pre-Amp controls should process DTS/Dolby audio
(and their sub-formats such as DTS-HD, Dolby Atmos, E-EAC, etc).
By default, these formats are not processed as they are intended
for decoding by an external receiver over S/PDIF or BitStreaming.
However if you decode these formats on your PC, disabling this
setting will allow the Equalizer and Pre-Amp controls to function.
* New setting (Adv. Options / System / Screen Saver & Capture) that
controls whether playback should be paused before trying to capture
a video frame. Please note that it's possible that some video
renderers may not be able to capture a frame if the media is playing.
* New setting on the media library YouTube plugin to enable listing
live streams. To playback live YouTube streams you must use the
IFRAME player or use D3D YouTube Source filter v2 or newer.
* New setting on the media library YouTube plugin to use the maximum
thumbnail resolution YouTube provides (now disabled by default).
In previous versions getting the maximum resolution thumbnail was
the default behavior, however there are rare instances where the
maximum resolution and extra bandwidth are merited.
Additionally, there is a YouTube bug that lists a URL for the
maximum resolution thumbnail without the file actually being
available, so this change works around this issue.
+ The GoTo time fullscreen navigation interface has been enhanced to
work more intuitively and with less clicking required to reach
the desired time.
+ The Torrents download plugin has been updated to support q**********
API v2, requiring q********** v4.2 or newer, please upgrade.
+ You can now drag the meta-data edit window more easily by dragging
from anywhere in the windows.
+ Using the "fnTitleToClipboard" function with no media playing will
now try to get the title from the currently highlighted playlist
entry.
+ The "Close Navigator when opening a new file" setting now applies
to the streaming fullscreen navigation interface. Previously it
would always close the interface regardless of the setting.
+ Ctrl+"V" now works in the playlist editor's search box.
+ You can now use the Space character to activate buttons on the skinned
confirmation dialog (previously only the Enter key would work).
+ Opening a streaming URL now closes the fullscreen navigation interface.
+ Extended the Command & Control API message 1870 to support passing
a title along with the URL to stream.
+ When playing an MP3 with ID3v2 TAGs that contain multiple images, now
the first embedded image is displayed instead of the last.
+ Right clicking a track in the playlist editor will now select the
track less than 2 other tracks are currently selected.
- A major bug that was introduced in v13.5 prevented the Equalizer and
Pre-Amp controls from functioning when decoding audio using a filter
that outputs the WAVE_FORMAT_EXTENSIBLE" structure (Which LAV Audio
Decoder uses for most audio formats it decodes).
- Streaming audio with non-English characters encoded in the stream's
meta-data would sometimes display the wrong characters.
- Trying to open the last used fullscreen navigation interface did
not work if the player was in audio mode. Now the window automatically
switches back to media mode and shows the navigation interface.
- The "Trash" icon no longer shows up at the bottom of the media library
fullscreen navigation mode when Safe Mode is enabled.
- Since they were causing playback issues, the Fast Play, Slow Motion,
Half Speed Fast-Play, Half Speed Slow Motion and Increase/Decrease
Play Rate functions are no longer accessible when playing a live
- Using Shift+Delete to delete the currently selected playlist entries
did not work properly if one of the selected entries was the currently
playing media.
- When Zoom Player was minimized to the taskbar, instructing Zoom Player
to switch to fullscreen mode did not work as intended.
- Trying to play a URL straight from the windows clipboard will no longer
try playing if the clipboard does not actually contain a URL.
- Opening the previously open navigation interface did not work when the
previous navigation interface was the 'Favorites'.
- Going back from the favorites fullscreen navigation interface to the
main interface highlighted the playlist icon instead of the favorites
icon.
- Using the play history fullscreen navigation with safe mode enabled
would trigger a crash or cosmetic glitches when trying to access
the functions page.
- Assigning functions that auto-execute when a secondary screen is attached
or detached did not execute under some conditions.
- Some functions called from command line using the "/func" or "/exfunc"
parameters could have run before Zoom Player finished loading, triggering
unexpected behavior.
- You can no longer try to erase the "refresh" and "more" (plus) entries
in the media library.
- The "Scrapers file name blacklist:" label disappeared under
"Adv. Options / Interface / Fullscreen Navigation / Thumb View".
- TheMovieDB scraper plugin can now display information on multiple
directors of one movie instead of just the first director.
- The delete icon was visible in the download manager fullscreen
navigation while safe mode was enabled.
- The playlist editor's right-click menu's "Add Streaming URL" feature
caused a visual glitch where the highlighted playlist entry was not
the one actually playing.
- Pressing the Enter key on the playlist editor right after running
the player would play the first track instead of the last played track.
- Under some rare conditions, the play history dialog could show duplicate
entries of the same media.
- When playing certain live feeds, right-clicking the timeline could
wrongfully show a "Seeking 0 seconds" OSD.
- Hovering with the mouse cursor over the timeline will no longer show
the timeline position or a preview image if the playing media has
no duration (e.g. when viewing a jpeg image).
- Some UTF8 encoded ".txt" files did not display anything when viewed.
- Loading ".wpl" playlists that contain URLs did not load the URL
entries correctly.
- Using the Advanced Playlist Control's "Move to Bottom" function caused
issues if the currently playing media was moved.
dvd, htpc, media player, tablet, zoom player
