Old 9th June 2010, 05:26   #81  |  Link
Zachs
Suptitle, MediaPlayer.NET
Could you try with just a BlankClip followed SupTitle?
I really can't see how it would only fail on your machine when so many others have reported that it works just fine.
Old 9th June 2010, 05:28   #82  |  Link
Zachs
Also, have you tried with other SUP files?
Old 9th June 2010, 05:34   #83  |  Link
asarian
Already tried it with BlankClip (see my previous post; I think we were just writing a post at the same time); makes no difference, unfortunately.
Yeah, I was just gonna say: might be it's tripping over the SUP-file; then I saw you post the same question just now. :) It's a SUP from 2010, the Blu-Ray, extracted with eac3to. I'll try some others, and see how that works out.
Thanks for your continued help, at least.
Old 9th June 2010, 05:51   #84  |  Link
Zachs
Post the SUP file somewhere and I'll take a look into it.
It could be that SupTitle's run out of memory.
Old 9th June 2010, 05:54   #85  |  Link
Zachs
When you tried blankclip, did you have other plugins loaded as well or just SupTitle?
Old 9th June 2010, 06:15   #86  |  Link
asarian
Good call, Zachs! :) Turns out it actually was the SUP file causing the crash! I tried the first one (faulting Japanese), and that's the one which crashes. I then just now tried the English SUP , and that one doesn't crash; but it doesn't show the subs either, whichever mode I try (forcedOnly true/false, relocate true/false). It doesn't cause a crash, though; so at least that impossible part is solved. I feel we're nearing a solution. :)
This is the exact script I use:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\FFMS2.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\SupTitle.dll")
video=FFVideoSource("D:\Temp\video.mkv").ConvertToYV12()
video=SupTitle(video, "D:\subs\00004 - 12 - Subtitle (PGS).sup", forcedOnly=false, swapCbCr=false, relocate=true, relocOffset="0,142,0,142")
video=Crop(video, 0, 142, 0, -142)
video=ConvertToRGB(video)
return video
Last edited by asarian; 9th June 2010 at 06:25. Reason: Added faulting Japanese subs
Old 9th June 2010, 12:46   #87  |  Link
sneaker_ger
I can't get the new version running: "LoadPlugin: unable to load"
Windows XP SP3 32bit
.NET 4.0 (and all the older ones) is installed
Old 9th June 2010, 13:53   #88  |  Link
Zachs
Try copying the two MS Visual C++ CRT dll files into your system32 folder.
Old 9th June 2010, 14:20   #89  |  Link
sneaker_ger
That did it, thank you.
Old 9th June 2010, 18:24   #90  |  Link
asarian
Zach, any verdict yet on the SUP samples I posted? :)
Old 10th June 2010, 01:02   #91  |  Link
asarian
Zachs, I just tried SupTitle on my Avatar Blu-Ray, and it works flawlessly there. :) So, we have established that my install is working now.
Only thing that rests now is for you (or any other volunteer, for that matter) to kindly have a look at the two SUPS which I posted above, onegai shimasu! :) :thanks:
EDIT: Also, relocOffset doesn't appear to be working on the Avatar SUP file (version 2.0.1): no matter how hard I try, I can't lower the subs.
Old 10th June 2010, 02:10   #92  |  Link
Zachs
Will take a look at the SUPs later if I've got some time to spare.
Avatar's forced subs are 1920x1080, relocOffset can't move it since it's taking up the full screen already.
Old 10th June 2010, 15:01   #93  |  Link
asarian
Thanks, Zachs. Wakatta!
Would make for an interesting feature request, though: to be able to move the SUPS, regardless of whether they already fill the screen (like crop them internally first, then position them to allow for the relocation). The Avatar subs, for one, appear too high up in the screen, for my taste.
Overall, I don't understand why this thread is so short. Your plugin really was a godsent to me, and I don't get why it isn't wildly popular here. :) To be able to add subs in their original, non-fubarred, non-OCR-ed, shape really is a major thing.
Old 11th June 2010, 01:32   #94  |  Link
Zachs
The biggest issue I have with that is you won't know if you've over cropped until you review all the frames with subs of the entire movie.
I've had a quick look at the faulting sup - the previous versions would've thrown an exception with message saying the sup's format is unexpected (i.e. I haven't written the part of code that handles that particular format).
The english sup is fine though - perhaps you've cropped away the sup?
Old 11th June 2010, 02:15   #95  |  Link
asarian
Thank for looking into it, Zachs.
Does it matter? I mean, cropping is just the user's responsibility anyway, right? In the case of Avatar, the subs appear unusually high; I wouldn't have minded lowering them substantially. Should it turn out I had overcropped somewhere after all, I'd just re-encode.
Could very well be, come to think of it. :) I tried it as follows:
video=SupTitle(video, "D:\subs\2.sup", forcedOnly=true, swapCbCr=false, relocate=true, relocOffset="0,142,0,142")
return video
That may actually be wrong, as relocOffset shouldn't be applicable at that stage yet (after all, I only crop afterwards). I can't test it yet, as the only machine available to me which has a working SupTitle install on it is doing Avatar now. But I bet that was wrong.
Old 11th June 2010, 11:19   #96  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
@asarian: You can accomplish what you want by loading your SUP file in BDsup2sub, and select "EDIT/Move all captions". Then select "Move outside bounds" and set "Offset Y:" to bottom offset of your choice.
You'll get a new SUP file, which you can then use with SupTitle plugin.
Dean
Old 11th June 2010, 13:51   #97  |  Link
asarian
, Dean! This is exactly what I was looking for!
Old 17th June 2010, 07:49   #98  |  Link
asarian
Hmm, trying this again, and I still can't get the English subs to show, try as I might. This should have worked:
video=SupTitle(video, "D:\subs\2010.sup", forcedOnly=true, swapCbCr=false, relocate=false)
return video
Even without the crop, the subs are still a no-show. :( May I ask, what script did you use to get the subs I posted to work?
Old 17th June 2010, 14:29   #99  |  Link
sneaker_ger
Are you sure that these are forced subs? Try "forcedOnly=false" if you haven't.
Old 17th June 2010, 22:03   #100  |  Link
asarian
I tried them every which way I could think of: forced on/off, relocate on/off, etc. They just don't show up ever, under any circumstance.
avisynth, hard sub, plugin, subtitle, suptitle
