Old 22nd December 2017, 13:20   #21  |  Link
sneaker_ger
So it's async even with simple script like:
a=ffaudiosource("source.mkv")
v=ffvideosource("source.mkv", fpsnum=24000, fpsden=1001)
AudioDub(v, a)
Also tested ffms2000?
Then please report to ffms devs: https://github.com/FFMS/ffms2/issues
But if it's the same problem with all source filters .... fishy.
Old 22nd December 2017, 15:04   #22  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by darkelf5 View Post
Can't attach the timecodes as they exceed the 300kb limit
http://www12.zippyshare.com/v/d7CYgXUP/file.html
Sorry, I can't help you with that kind of timestamps (irregulars in video and audio).
I don't know how can be managed inside AviSynth.
Old 22nd December 2017, 16:14   #23  |  Link
poisondeathray
I've edited thousands of vfr files. In avisynth and other programs. I'm telling you from a lot of experience, this is the 1 case where directshow is 10x better than everything else . (Usually you should avoid it like the plague). Much more consistent and places frames more accurately than the others.
DirectShowSource("video.ext" , fps=23.976, convertfps=true)
Whether or not you can use Trim() directly in that script, depends on your directshow filters, your splitter and decoder. The safest thing to do would be to encode that to an I-frame intermediate first, then apply whatever filters you want.
Old 22nd December 2017, 16:48   #24  |  Link
manolito
manolito's Avatar
Basically I do agree, but there are some misconceptions about DSS2Mod here...
DSS2Mod is DirectShow based. It will always convert VFR to CFR, i.e. "convertfps=true" is not needed. It will NOT index the source, but there is a "preroll" parameter which is extremely useful for difficult sources (default is 0, a value of 15 works well for most sources, and it should be raised to 100 or even higher for difficult sources). In my experience it works best when LAV Filters are used as the DirectShow source filters.
DSS2Mod does not handle audio, DirectShowSource should be used for audio. IMO this combination beats ffms2 for most sources (it probably does not beat DG's tools).
Cheers
manolito
Old 22nd December 2017, 17:17   #25  |  Link
poisondeathray
The problem with DSS2Mod, is it often drops one or two frames on some sources (usually at the end) , sometimes green frame at the beginning , regardless of preroll. This is repeatable behaviour.
I've literally done thousands (closer to tens of thousands) of tests on several different setups from different sources - capture sources, camera sources, web source - This is a huge sample size. I'm very confident making these claims
And for FFMS2 / lsmash - the conversion usually puts frames in not quite the right spots . You can tell in a NLE when looking at the audio waveform. Directshow is closer to correct. Again tested on thousands of sources
Old 22nd December 2017, 20:17   #26  |  Link
Midzuki
Unavailable
Midzuki's Avatar
When ffms2 gives me sync issues, DirectShowSource on the graphs themselves is the solution.
Together with LAV Splitter, LAV Video and LAV Audio, bien entendu.
vide0=DirectShowSource("video.grf", audio=false)
audi0=DirectShowSource("audio.grf", video=false)
AudioDub(vide0, audi0)
Old 22nd January 2018, 11:43   #27  |  Link
Midzuki
Unavailable
Midzuki's Avatar
For the record...
1) Last week I messed around with some ancient ASF files, and I have to say that FFMS2 is unable to deal with them properly;
2) This morning I downloaded a couple of .WEBMs from YouTube and verified that they too are "problematic" to FFMS2 :/
But again, GraphStudioNext and DirectShowSource() saved the day.
