27th July 2024, 21:52 | #20781 | Link | |
https://www.rarewares.org/index.php |
27th July 2024, 22:40 | #20782 | Link | |
Select no audio Press Avisynth button, go to Output speed, select 25 fps Encode the video Use mkvmerge to manually join the audio
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
28th July 2024, 01:21 | #20783 | Link | |||
I couldn't even load it until I removed the audio track Last edited by FTLOY; 28th July 2024 at 01:34. |
28th July 2024, 05:37 | #20784 | Link |
In an update the movie worked fine after removing subtitles from file before encoding and left resolution untouched. I removed the forced subtitles and foreign subtitles as well and just left the english subtitles intact.
28th July 2024, 13:22 | #20791 | Link | |
Remux that file with added fps value
28th July 2024, 13:42 | #20793 | Link |
If you fix fps directly in mkv container then audio will work fine as well. Deinterlace option will also be available in ripbot.
That's the proper way of dealing with incorrectly created mkvs.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th July 2024 at 13:47. |
29th July 2024, 03:56 | #20796 | Link |
Annoying random video glitches..
I have noticed that I am getting random glitches in some of recent encodes.
I just finished GoT, and in all those episodes, I only had 1 or 2 instances, in the early going, but I figured out what was causing that, and didn't have any problems. I have started encoding some movies, and they have returned. I'd be interested in what part of the process could cause this, would it be the initial demuxing, or the encoding (x265 / ffmpeg, etc) or the muxing of all the chunks Here's a sample of what I am talking about:- (thanks to the segment feature of RB, made this easy ) Note:- the originals are good to go.... https://www.mediafire.com/file/lr958...itches.7z/file 148Mb |
29th July 2024, 10:34 | #20797 | Link |
Intel CPU?
