12th August 2014, 21:45 | #12721 | Link | ||
There is no sense store a wav file from a lossy format, if you decode to wav is for edit and after recompress, then preserve the best aproach you can manage until you recode to the desired format. Quote:
12th August 2014, 22:54 | #12724 | Link | |
Decoders do the opposite thing: They decompress the data, which is then still in frequency domain, and then convert back to time domain, which produces floating point data. So a lossy decoder natively outputs 64bit floating point. |
12th August 2014, 23:55 | #12725 | Link |
How does one show the stdout when piping the output to a second audio encoder? I do something like this:
eac3to I: 1) 2: video.mkv 3: audio.ac3 3: stdout.wav -downDpl | D:\Apps\qaac\qaac -V 32 --ignorelength -o audio.m4a - |
13th August 2014, 00:43 | #12726 | Link |
Does eac3to have a hard limit of being able to read just 300 playlists from a disc? The Redbox version of the Divergent Blu-ray has hundreds of playlists and despite other tools like MakeMKV detecting them all, eac3to stops at 300). This is a problem, since playlist 810.mpls is the correct one.
UPDATE: Disregard. The .mpls was 810, but I see that eac3to simply enumerates them sequentially Last edited by bennynihon; 13th August 2014 at 01:08. |
13th August 2014, 10:55 | #12727 | Link | |
Does it mean there is less differences between dts 16 bits and dts 24 bits than between pcm 16 bits and pcm 24 bits ? Despite the fact that the input bitdepth doesn't matter at all, is there a way to evaluate the quality (or the corresponding bitdepth) of a lossy compressed file ? |
13th August 2014, 12:12 | #12728 | Link |
What do you mean by "dts 16 bits" and "dts 24 bits"?
As just explained, most compressed formats don't save "samples" (the volume at discrete moments of time), but instead a limited sound spectrum over brief durations. The less precision the original audio had, if it was stored as integer samples, the harder this lack of precision can be transformed into a sound spectrum; imagine it like laying a smooth but slightly stiff carpet over a stairway with stairs of different heights, just the same depth. The compressed format saves the curves in the shape of the carpet. You can have the same shape of carpet laying over different kinds of stairs, with more or less distance of the stair edges to the carpet shape... The "quality" of the encode may represent the distance of the carpet shape to the edges of the original staircase. If you don't have the staircase available anymore, you can't judge how good the carpet once fit it when it was bent over it with more or less pressure. Decoding means building a new staircase which fits under the carpet. You can do that with more or less precision, but only compared to the carpet shape, not to the original staircase. Last edited by LigH; 13th August 2014 at 12:15. |
13th August 2014, 12:26 | #12729 | Link |
Ok, thanks.
dts is supposed to exist in several levels of quality, I guess you have heard of dts 96/24 (while generally dts is supposed to be 48/16 or 48/20), but now I understand that this only concerns the accepted input formats for the dts encoder (however, one can see the dts 96/24 logo on some dvd's). |
13th August 2014, 12:52 | #12730 | Link |
In case of DVD Video, dts Coherent Acoustics was primarily supposed to reduce 6-channel 16 bit PCM to the bitrate of mono or stereo 16 bit PCM, because S/P-DIF is not able to submit higher bitrates than the one of 48 kHz 16 bit stereo (1536 kbps) to A/V receivers. Similar goals will have been used for "dts Audio CDs", to stay below the bitrate of 44.1 kHz 16 bit stereo (1411.2 kbps) but support multi-channel audio.
More precise dts variants are possibly extensions to the "core" format. But in any case, it doesn't mean that 16 or 24 bit samples are stored inside the compressed audio, just that the encoding is precise enough to reproduce up to 16 or 24 bits of precision when decoded to PCM again and compared to the original. I would believe that in "best cases". In complex cases (like hardrock), precision may drop by a few bits, but won't be noticable due to psychoacoustic effects. Last edited by LigH; 13th August 2014 at 12:56. |
13th August 2014, 14:19 | #12731 | Link |
Ok.
I'm astonished you consider hardrock as a complex case, I believed it was simpler than classical music which contains a lot of frequencies and harmonics. Or you mean it is more complex because of its higher dynamic compression (which is often the case in hardrock), which makes instruments more difficult to detach from each other ? |
13th August 2014, 15:13 | #12732 | Link |
Classical music is often easier to compress due to a quite restricted spectrum, having mostly clean sounds based on a few dominating tones with harmonics. Most audio compression algorithms (except Opus) can handle simple tones and sounds with only few harmonics quite easily.
In contrast, especially the sound of overdriven electro guitars is much closer to "noise" than to "sound", it is quite hard to predict for common audio compression. |
13th August 2014, 19:37 | #12733 | Link | ||
The question here is not the bitdepth (16, 20 or 24) but in the word equivalent, when the user read this info can wrong supose than the decoded output have a precission of 16/24 bits and that is not true, the precission is always less than 16 bits in lossy formats. Quote:
A DTS have in the header a bitdepth info of the original PCM source (not always true, some Surcode versions put always 24 even if the source is 16 bits), of course the compressed file can be better if the source have a better precission, but, like I say before, associate a bitdepth info to a lossy format only mistake the users like you can see in this discussion.
13th August 2014, 19:51 | #12734 | Link | |
ffx264/ffhevc author
13th August 2014, 20:36 | #12735 | Link | |
Life's clearer in 4K UHD
Mathematically a 96/24 DTS file size should be much larger than a 48/16 DTS file size... But they're the same!
13th August 2014, 22:45 | #12736 | Link | |
eac3to title.mkv 1: video.mkv 2: audio.ac3 2: stdout.wav -downDpl | tee con | D:\Apps\qaac\qaac -V 32 --ignorelength -o audio.m4a - Last edited by bennynihon; 13th August 2014 at 23:16. |
14th August 2014, 08:06 | #12737 | Link |
There are three common ways to create text output on the console:
a) STDOUT = file descriptor 1, redirectable via '>' and '|' b) STDERR = file descriptor 2, redirectable via '2>' c) direct video memory access, not redirectable (for those who used Turbo Pascal: when using unit CRT) I wouldn't know without testing which output technique eac3to prefers for its usual progress reports while writing to a file. If it is STDOUT, then it will possibly suppress the progress output completely while piping? Last edited by LigH; 14th August 2014 at 08:12. |
14th August 2014, 10:53 | #12739 | Link | ||
And thus, why encode from 24 bits sources ? And sample frequency, right ? |
14th August 2014, 21:31 | #12740 | Link | ||
For what? The samples in frequency domain are stored with a precission equivalent but when recover the samples in time domain don't exist the precission of the source. For that is lossy compression and not lossless.
eac3to |
