Old 14th October 2017, 17:11   #5721  |  Link
Zetti
MKVToolNix v17.0.0 is released.
Old 14th October 2017, 17:58   #5722  |  Link
Zathor
Thx, new versions of eac3to, mkvtoolnix and mp4box are not online. mp4box update is required to properly support hevc/h265.
Old 14th October 2017, 18:02   #5723  |  Link
sneaker_ger
Can you link to further info about this?
Old 14th October 2017, 18:19   #5724  |  Link
Zathor
Sure, I run with the sample file I have in this issue:
https://github.com/gpac/gpac/issues/834
Interestingly only if demuxed with eac3to in a hevc file extension. If demuxed to h265 it did not occur. In any case the update of mp4box fixed it.
EDIT: ffmpeg also updated
Old 14th October 2017, 18:50   #5725  |  Link
Zathor
2771 [HD Streams Extractor] added support for HEVC video tracks (requires eac3to 3.32+)
     [Muxer]                added support for the h265 file extension
Old 15th October 2017, 21:28   #5726  |  Link
Megalith
I updated eac3to to 3.32, but the Streams Extractor is unable to extract any h265/HEVC files despite having them listed (Type: Unknown). Is this normal?
Megalith is offline   Reply With Quote
Old 15th October 2017, 21:29   #5727  |  Link
Zathor
Do you have updated MeGUI also to 2771? If yes, please post a log - if not, please update MeGUI.
Old 15th October 2017, 21:39   #5728  |  Link
Megalith
Thank you; updating did the trick. I did not realize I had to go into the options menu and change the update server to the development one.
Old 24th October 2017, 15:58   #5729  |  Link
skywalker
Hi, good morning!
Could someone help me with the error below.
I can not encode any videos in 2pss 1st pass, this same error always occurs.
Does anyone know what is happening and could help me?
[Error] Log
-[Information] Versions
--[Information] [24/10/2017 12:36:46] MeGUI: 2715
--[Information] [24/10/2017 12:36:46] Operating System: Windows 10 Home x86 (10.0.0.15063)
--[Information] [24/10/2017 12:36:46] .NET Framework: 4.0 (4.0.0.0)
--[Information] [24/10/2017 12:36:46] .NET Framework: 4.7 (4.7.02046)
--[Information] [24/10/2017 12:36:50] AviSynth: 2.6.0.6 (31-03-2015) (active)
--[Information] [24/10/2017 12:36:50] AviSynth portable: 2.6.0.6 (21-09-2015) (inactive)
--[Information] [24/10/2017 12:36:50] AvisynthWrapper: (02-01-2009)
--[Information] [24/10/2017 12:36:50] Haali Media Splitter: not installed
--[Information] [24/10/2017 12:36:50] Haali DSS2: not installed
--[Information] [24/10/2017 12:36:50] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [24/10/2017 12:36:50] MediaInfo: 0.7.94.0 (30-03-2017)
--[Information] [24/10/2017 12:36:50] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [24/10/2017 12:36:50] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [24/10/2017 12:36:50] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [24/10/2017 12:36:50] 7z: 9.20 (18-11-2010)
-[Information] Update detection
--[Information] [24/10/2017 12:36:46] Using cached update config and server: http://megui.org/auto/stable/
--[Information] [24/10/2017 12:36:46] No package requires an update
-[Warning] Log for job9 (video, FGTR3.avs -> FGTR3.264)
--[Information] [24/10/2017 12:37:37] Started handling job
--[Information] [24/10/2017 12:37:37] Preprocessing
--[Information] [24/10/2017 12:37:38] Avisynth input script
---[NoImage] LoadPlugin ("C:\Program Files\AviSynth\plugins\DGDecode.dll")
---[NoImage] Video = mpeg2source ("C:\Users\danni\Videos\FGTR\FGTR.d2v", cpu=4, info=3)
---[NoImage] Audio = FFAudioSource ("C:\Users\danni\Videos\FGTR\FGTR.ac3")
---[NoImage] AudioDub (Video, Audio)
---[NoImage] ColorMatrix (interlaced=true, hints=true, threads=0)
---[NoImage] TDeint (mode=1, order=1, mtnmode=1)
---[NoImage] BlendBob ()
---[NoImage] Decimate (cycle=5, mode=2, quality=3)
---[NoImage] Crop (10, 4, -6, 0, align=true)
---[NoImage] BlackmanResize (1464, 1080)
---[NoImage] Deblock (quant=25, aOffset=0, bOffset=0)
---[NoImage] AddGrain (var=7)
---[NoImage] EnsureVBRMP3Sync ()
--[Information] [24/10/2017 12:37:38] resolution: 1464x1080
--[Information] [24/10/2017 12:37:38] frame rate: 24000/1001
--[Information] [24/10/2017 12:37:38] aspect ratio: 61:45 (1.356)
--[Information] [24/10/2017 12:37:38] changing --ref to 5
--[Information] [24/10/2017 12:37:38] Job command line: "C:\Users\danni\Documents\MeGUI\tools\x264\x264.exe" --level 4.2 --preset veryslow --tune film --pass 1 --bitrate 29999 --stats "C:\Users\danni\Videos\FGTR\FGTR3.stats" --keyint 288 --min-keyint 28 --vbv-bufsize 78125 --vbv-maxrate 62500 --sar 1:1 --output NUL "C:\Users\danni\Videos\FGTR\FGTR3.avs"
--[Information] [24/10/2017 12:37:38] Process started
--[Information] [24/10/2017 12:37:38] Standard output stream
--[Warning] [24/10/2017 12:37:38] Standard error stream
---[Information] [24/10/2017 12:37:48] avs [info]: 1464x1080p 1:1 @ 24000/1001 fps (cfr)
---[Information] [24/10/2017 12:37:48] x264 [info]: using SAR=1/1
---[Warning] [24/10/2017 12:37:48] x264 [warning]: VBV bitrate (62500) > level limit (50000)
---[Warning] [24/10/2017 12:37:48] x264 [warning]: VBV buffer (78125) > level limit (62500)
---[Information] [24/10/2017 12:37:48] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
---[Information] [24/10/2017 12:37:48] x264 [info]: profile Main, level 4.2
---[Information] [24/10/2017 12:47:32] x264 [info]: frame I:67 Avg QP:15.73 size:346311
---[Information] [24/10/2017 12:47:32] x264 [info]: frame P:1569 Avg QP:19.56 size:184281
---[Information] [24/10/2017 12:47:32] x264 [info]: frame B:4244 Avg QP:20.18 size:143176
---[Information] [24/10/2017 12:47:33] x264 [info]: consecutive B-frames: 7.0% 6.1% 7.9% 18.3% 20.1% 34.2% 4.4% 0.8% 1.2%
---[Information] [24/10/2017 12:47:33] x264 [info]: mb I I16..4: 33.4% 0.0% 66.6%
---[Information] [24/10/2017 12:47:33] x264 [info]: mb P I16..4: 73.4% 0.0% 0.0% P16..4: 26.6% 0.0% 0.0% 0.0% 0.0% skip: 0.0%
---[Information] [24/10/2017 12:47:33] x264 [info]: mb B I16..4: 47.9% 0.0% 0.0% B16..8: 30.0% 0.0% 0.0% direct:20.0% skip: 2.1% L0:15.6% L1:17.3% BI:67.1%
---[Information] [24/10/2017 12:47:33] x264 [info]: final ratefactor: 17.09
---[Information] [24/10/2017 12:47:33] x264 [info]: direct mvs spatial:99.8% temporal:0.2%
---[Information] [24/10/2017 12:47:33] x264 [info]: coded y,uvDC,uvAC intra: 99.9% 22.0% 1.0% inter: 80.2% 24.5% 0.1%
---[Information] [24/10/2017 12:47:33] x264 [info]: i16 v,h,dc,p: 3% 3% 75% 19%
---[Information] [24/10/2017 12:47:33] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 12% 19% 9% 9% 9% 10% 9% 11%
---[Information] [24/10/2017 12:47:33] x264 [info]: i8c dc,h,v,p: 67% 14% 17% 3%
---[Information] [24/10/2017 12:47:33] x264 [info]: Weighted P-Frames: Y:6.4% UV:3.3%
---[Information] [24/10/2017 12:47:33] x264 [info]: kb/s:30010.07
---[Information] [24/10/2017 12:47:33] encoded 5880 frames, 9.92 fps, 30010.06 kb/s
--[Information] [24/10/2017 12:47:33] Postprocessing
---[Information] [24/10/2017 12:47:33] Deleting intermediate files
--[Information] [24/10/2017 12:47:33] Job completed
-[Error] Log for job10 (mux, FGTR3.264 -> FGTR3.mkv)
--[Information] [24/10/2017 12:47:33] Started handling job
--[Information] [24/10/2017 12:47:33] Preprocessing
--[Error] [24/10/2017 12:47:33] Error starting job
---[Error] [24/10/2017 12:47:33] Exception message: Calling setup of processor failed with error 'Required file 'C:\Users\danni\Videos\FGTR\FGTR3.264' is missing.'
---[Error] [24/10/2017 12:47:33] Stacktrace: em MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job)
---[Error] [24/10/2017 12:47:33] Inner exception: null
skywalker is offline   Reply With Quote
Old 24th October 2017, 17:53   #5730  |  Link
Apparently you run a 1st pass with x264 which generates no video output (--output NUL), but it is still supposed to be multiplexed to an MKV?!
LigH is online now   Reply With Quote
Old 28th October 2017, 19:23   #5731  |  Link
Zathor
Originally Posted by skywalker View Post
Hi, good morning!
How do you have created these jobs?
Old 29th October 2017, 16:03   #5732  |  Link
mini-moose
x265
from what I can tell x265 config is only showing very basic options:
preset / encoding method / crf #.
Are there plans to add a more detailed view with all the various setting the encoder offers (like in x264 config show advanced settings) ?
thanks.
mini-moose is offline   Reply With Quote
Old 29th October 2017, 20:16   #5733  |  Link
disklib
I'm getting a muxing error that seems to be caused by using MKVmerge 17.0 with an audio delay.
When I let MKV Muxer GUI auto-set the delay I get...
Error: Invalid sync option specified in '--sync 0:20ms'.
When I manually change the delay to 0 in the GUI it muxes without issue.
When I revert MKVmerge to the previous 15.0 version it muxes the delay without issue.
Here's the full log...
[Error] Log
--[Information] MeGUI: 2771 x86
--[Information] System Information
---[Information] Operating System: Windows 7 Professional x64 SP1 (6.1.65536.7601)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.7 (4.7.02053)
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 0.7.99.0 (12-09-2017)
---[Information] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2721.0
----[Information] Date: 29-04-2017
----[Information] Interface: 3
----[Information] File Version: 2.6.0.6
----[Information] Date: 31-03-2015
----[Information] Name: Avisynth 2.6
----[Information] Version: AviSynth 2.60, build:Mar 31 2015 [16:38:54]
----[Information] AviSynth+: false
----[Information] MT: false
----[Information] Status: active
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] Date: 29-06-2017
----[Information] Name: AviSynth+ 0.1 (r2508, MT, i386)
----[Information] Status: inactive
--[Information] [2017.10.29 11:54:27 am] Using cached update config and server: http://megui.org/auto/
--[Information] [2017.10.29 11:54:27 am] No package requires an update
-[Error] Log for job1 (mux, VTS_01_1.mp4 -> VTS_01_1-muxed with delay.mkv)
--[Information] [2017.10.29 11:56:01 am] Started handling job
--[Information] [2017.10.29 11:56:01 am] Preprocessing
--[Information] [2017.10.29 11:56:01 am] frame rate (job): 23.976
--[Information] [2017.10.29 11:56:01 am] device type: Standard
--[Information] [2017.10.29 11:56:01 am] MediaInfo
---[Information] [2017.10.29 11:56:01 am] File: C:\test\VTS_01_1.mp4
---[Information] General
----[Information] Format: MPEG-4
----[Information] FormatString: MPEG-4
----[Information] FileSize: 948342991
----[Information] PlayTime: 01:50:56.398
---[Information] Video
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] Width: 712
----[Information] Height: 272
----[Information] FrameCount: 159594
----[Information] FrameRate: 23.976
----[Information] FrameRateOriginal:
----[Information] FrameRateMode: CFR
----[Information] ScanType: Progressive
----[Information] Codec: AVC
----[Information] CodecString: AVC
----[Information] Bits Depth: 8
----[Information] Format: AVC
----[Information] AspectRatio: 2.387
----[Information] AspectRatioString: 2.40:1
----[Information] Delay:
----[Information] Title:
----[Information] Language:
----[Information] LanguageString:
----[Information] Default:
----[Information] DefaultString:
----[Information] Forced:
----[Information] ForcedString:
---[Information] [2017.10.29 11:56:01 am] File: C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3
----[Information] Format: AC-3
----[Information] FormatString: AC-3
----[Information] FileSize: 319506432
----[Information] PlayTime: 01:50:56.384
---[Information] Audio
----[Information] FormatProfile:
----[Information] FormatSettingsSBR:
----[Information] FormatSettingsPS:
----[Information] Muxing Mode:
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 6
----[Information] ChannelsString: 6 channels
----[Information] ChannelPositionsString2: 3/2/0.1
----[Information] BitRateMode: CBR
----[Information] [2017.10.29 11:56:02 am] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [2017.10.29 11:56:02 am] Job command line: "C:\Program Files (x86)\MeGUI\tools\mkvmerge\mkvmerge.exe" -o "C:\test\VTS_01_1-muxed with delay.mkv" --engage keep_bitstream_ar_info --default-duration 0:24000/1001fps "--compression" "0:none" -d "0" --no-chapters -A -S "C:\test\VTS_01_1.mp4" --sync 0:20ms "--compression" "0:none" -a 0 --no-chapters -D -S "C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3" --engage no_cue_duration --engage no_cue_relative_position --ui-language en
--[Information] [2017.10.29 11:56:02 am] Process started
--[Error] [2017.10.29 11:56:02 am] Standard output stream
---[Information] [2017.10.29 11:56:02 am] mkvmerge v17.0.0 ('Be Ur Friend') 64-bit
---[Error] [2017.10.29 11:56:02 am] Error: Invalid sync option specified in '--sync 0:20ms'.
--[Information] [2017.10.29 11:56:02 am] Standard error stream
--[Error] [2017.10.29 11:56:02 am] Process exits with error: 2
--[Information] [2017.10.29 11:56:02 am] Job completed
-[Information] Log for job2 (mux, VTS_01_1.mp4 -> VTS_01_1-muxed without delay.mkv)
--[Information] [2017.10.29 11:56:02 am] Started handling job
--[Information] [2017.10.29 11:56:02 am] Preprocessing
--[Information] [2017.10.29 11:56:02 am] frame rate (job): 23.976
--[Information] [2017.10.29 11:56:02 am] device type: Standard
--[Information] [2017.10.29 11:56:02 am] MediaInfo
---[Information] [2017.10.29 11:56:02 am] File: C:\test\VTS_01_1.mp4
---[Information] [2017.10.29 11:56:02 am] File: C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3
--[Information] [2017.10.29 11:56:02 am] Job command line: "C:\Program Files (x86)\MeGUI\tools\mkvmerge\mkvmerge.exe" -o "C:\test\VTS_01_1-muxed without delay.mkv" --engage keep_bitstream_ar_info --default-duration 0:24000/1001fps "--compression" "0:none" -d "0" --no-chapters -A -S "C:\test\VTS_01_1.mp4" "--compression" "0:none" -a 0 --no-chapters -D -S "C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3" --engage no_cue_duration --engage no_cue_relative_position --ui-language en
--[Information] [2017.10.29 11:56:02 am] Standard output stream
---[Information] [2017.10.29 11:56:02 am] 'C:\test\VTS_01_1.mp4': Using the demultiplexer for the format 'QuickTime/MP4'.
---[Information] [2017.10.29 11:56:02 am] 'C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3': Using the demultiplexer for the format 'AC-3'.
---[Information] [2017.10.29 11:56:02 am] 'C:\test\VTS_01_1.mp4' track 0: Using the output module for the format 'AVC/h.264'.
---[Information] [2017.10.29 11:56:02 am] 'C:\test\VTS_01_1 T80 3_2ch 384Kbps DELAY 20ms.ac3' track 0: Using the output module for the format 'AC-3'.
---[Information] [2017.10.29 11:56:02 am] The file 'C:\test\VTS_01_1-muxed without delay.mkv' has been opened for writing.
---[Information] [2017.10.29 11:56:12 am] The cue entries (the index) are being written...
---[Information] [2017.10.29 11:56:12 am] Multiplexing took 10 seconds.
--[Information] [2017.10.29 11:56:12 am] MediaInfo
---[Information] [2017.10.29 11:56:12 am] File: C:\test\VTS_01_1-muxed without delay.mkv
----[Information] Format: Matroska
----[Information] FormatString: Matroska
----[Information] FileSize: 1267612690
----[Information] PlayTime: 01:50:56.400
----[Information] Codec: V_MPEG4/ISO/AVC
----[Information] AspectRatio: 2.386
----[Information] Delay: 0
----[Information] Default: Yes
----[Information] DefaultString: Yes
----[Information] Forced: No
----[Information] ForcedString: No
----[Information] ID: 2
----[Information] StreamOrder: 1
----[Information] [2017.10.29 11:56:12 am] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [2017.10.29 11:56:12 am] Postprocessing
---[Information] [2017.10.29 11:56:12 am] Deleting intermediate files
--[Information] [2017.10.29 11:56:12 am] Job completed
disklib is offline   Reply With Quote
Old 30th October 2017, 11:03   #5734  |  Link
tebasuna51
tebasuna51's Avatar
Seems than MkvMerge 17.0 now:
* mkvmerge: command line options: an error message will be output if the single-value-form of the `--sync` option is used and it isn't a number (e.g. `--sync 0:asd`). Fixes #2121.
then '--sync 0:20ms' must be now '--sync 0:20' without the 'ms'
Old 31st October 2017, 17:43   #5735  |  Link
Zathor
Thanks, fixed in 2772.
As I am not using x265 myself and have very limited time: yes, it is on the road map but do not expect it soon.
Old 10th November 2017, 22:03   #5736  |  Link
wthreex
1/1 - updating package LAME
Error: Failed to download package LAME: File cannot be found on the server.
wthreex is offline   Reply With Quote
Old 11th November 2017, 14:36   #5737  |  Link
Zathor
Please try it again. If it still fails please post the full log.
Old 11th November 2017, 19:22   #5738  |  Link
wthreex
Fixed.
Old 12th November 2017, 20:48   #5739  |  Link
ratpack
Aargh, I eagerly got the new MeGUI 2774 but the sar issue still isn't working. Additionally now it also ignores the option to not demux the entire video stream.
So if I try and add a custom sar, the space between sar and the numbers gets entered as a letter r. This throws an error in the job. If I don't use a space then the custom sar values get ignored.
https://imgur.com/SDPjwj0
Also, now when I try and start off using the File Indexer (FILE > Open > browse to the first VOB) it always creates a duplicate set of all the VOBs. Checking or unchecking the box to "Demux Video Stream" now has no effect - it's getting demuxed every time and creating an additional 7.9GB of duplicate VOB files.
ratpack is offline   Reply With Quote
Old 12th November 2017, 22:00   #5740  |  Link
Zathor
Please add always proper custom command lines otherwise they cannot be parsed. Therefore add "--sar 95:79" with the leading --.
Regarding the file indexer - please post the full log.
