4th January 2017, 23:33 | #5261 | Link | |
Anyway, I was able to find the correct PCG due to it's duration (DVDShrink and MPC-HC display it as Title 27). I ripped the subtitles directly from the disc with MeGUI, Unfortunately the timings were still wrong, but it must be something peculiar to this DVD. I don't think I've ever had this problem before. |
5th January 2017, 11:55 | #5262 | Link |
Zathor, I'm trying File Indexer with pgcdemux now.
Couple of questions: 1) It doesn't extract the chapters (another thing I always do with pre-extracting vobs on my own). The chapters are extracted on OCE though. 2) There is an option with DGIndex to choose which audios to keep, but it's greyed out (I think it's been like that for a long time?) : https://s23.postimg.org/899ffb20b/pgc.png OCE and subs: You said I can add edit a profile to include more/all subs. From what I can see, if I want to include all subs I need to add all the languages on the langs menu? Last edited by mini-moose; 5th January 2017 at 11:59. |
6th January 2017, 22:33 | #5263 | Link | |
It's been greyed out for quite a while. I've wondered about that myself, but because I only ever keep the required audio streams when ripping/re-authoring, I generally don't need to select specific ones, so I've kept forgetting to mention it. |
8th January 2017, 11:58 | #5264 | Link | |||||
Thanks, uploaded
Yes, or no selection at all (no entry, no even [none]) and then the option "languages to select if selection does not match" to all. But yes, an [all] option would make more sense. |
8th January 2017, 14:54 | #5265 | Link | |
Tried OCE with encode phases disabled. Sadly, it won't work for what I wanted. |
15th January 2017, 07:42 | #5267 | Link |
Is anyone here using MeGUI for 2 pass x264 encoding on a 64bit Windows?
There's a log file attached to a post at VideoHelp here which seems to indicate the command line is broken. If you're around Zathor, could you please take a quick look? Thanks. |
15th January 2017, 12:19 | #5268 | Link | |
Sadly the person there does not post a full log including the versions stuff. Also it seems to me that the first pass for him/her fails with Code:
---[Error] [15/01/2017 7:47:47 AM] x264 [error]: can't parse qpfile for frame 0 https://forum.doom9.org/showthread.php?t=167736 |
17th January 2017, 19:52 | #5270 | Link | |
Thanks. |
23rd January 2017, 13:58 | #5271 | Link |
Taking a look at the "Add pre-rendering job", it looks like ffmpeg is running the huffyuv encode in the same thread as Avisynth. (opening in process explorer, I don't see anything that looks like a separate thread.) Since Avisynth is single-thread limited, can the encode be split out into its own thread?
23rd January 2017, 14:04 | #5272 | Link |
Only if ffmpeg can create separate threads for reading the input and encoding it. AviSynth will then be used by ffmpeg, not by MeGUI.
The ffmpeg option "-threads auto" should enable multithreading in general. Last edited by LigH; 23rd January 2017 at 14:10. |
23rd January 2017, 14:51 | #5273 | Link | |
[Information] [1/23/2017 1:02:48 AM] Job command line: "C:\Users\Documents\MeGUI\tools\ffmpeg\ffmpeg.exe" -y -i "C:\Users\Documents\4.avs" -c:v ffvhuff -threads 0 -sn -an -context 1 -vstrict -2 -pred 2 "C:\Users\Documents\hfyu_4.avi" I guess I'll be running some test later to see if lossless x264 works better. Last edited by kuchikirukia; 24th January 2017 at 05:09. |
6th February 2017, 20:40 | #5275 | Link | |
Just out of curiosity: Which indexer did you use? Tried all available, just the normal pause at the indexing stage. Avisource, directshowsource and dss2 should load almost instantly. |
6th February 2017, 20:41 | #5276 | Link | |
A couple of times I've loaded a script into the video section and clicked the Queue button before MeGUI had finished whatever checking it does, and ended up with the previous script added to the job queue only with the name of the current script as the output file.... or something like that.... but I learned to be a bit more patient after that did my head in. Last edited by hello_hello; 6th February 2017 at 20:48. |
6th February 2017, 20:49 | #5277 | Link |
The index files are in different formats, I believe (one binary, one in plain text), thus have different sizes. Also don't forget, one of them may only index audio streams when audio is indexed first, the other instead may always; but I can't keep in mind which does what.
7th February 2017, 04:10 | #5279 | Link | |
