14th November 2012, 02:14 | #481 | Link | ||
VidCoder Author
14th November 2012, 16:46 | #482 | Link | |
17th November 2012, 17:54 | #485 | Link |
VidCoder Author
Not really to me. The UI comes too close to the command bar; the Aero theme gives better margins on the buttons. Though it might look okay if the command bar extended all the way across the top and there was a bit more room. What particularly do you like about the coloring on that one?
19th November 2012, 03:57 | #487 | Link | ||
VidCoder Author
I have a little tougher time since I try to display all bitrates that are valid for any source file (so as to not mess up someone's preset when they load the wrong file). I can still do something here; I'll code in some limits that I know exist, like for MP3 and AC3. Quote:
Ahh, a casualty of my extracting everything to string resources. I'll get that fixed up. |
19th November 2012, 04:04 | #488 | Link | |
VidCoder Author
As far as docking, I've had vague plans to allow you to drag around the helper windows and do nicer things with them but WPF doesn't give you very much to work with. There's some solutions to do "docking" ala Visual Studio but those are a problem because VidCoder windows have minimum sizes and the docking systems I've seen don't support that. I don't think anything is going to happen with this anytime soon unless some great solution with no downsides comes up. |
19th November 2012, 18:35 | #489 | Link |
VidCoder Author
Released VidCoder 1.4.6 Beta.
* Brought back the x264 advanced options panel due to popular demand. Thank you for all the feedback. * x264 Preset/Profile/Tune/Level has been moved back to the Video tab, along with a copy of the "extra options" string. * Added Fast Decode and Zero Latency checkboxes to support multiple Tunes. * Added cropping option "None". * Audio bitrates that are incompatible with the encoder (such as MP3 > 320 kbps) are no longer preset on the list. * Fixed crash on opening VidCoder after de-selecting "remember locations". * Fixed problem with some H.264 levels getting incorrectly grayed out. * Fixed problem where preview picture dimensions could "drift" when in Strict or Loose Anamorphic mode. * Fixed "Video Codec" label in the audio tab. * Renamed ffmpeg to Libav in encoder names to better reflect the library they're coming from, and improved capitalization of encoder libraries. Last edited by RandomEngy; 19th November 2012 at 18:41. |
20th November 2012, 02:50 | #491 | Link | |||||
VidCoder Author
It is a little bit crowded, but I think that is mostly from the logical "areas" of the panel running together (Framerate, Quality, Passes, x264 options). I moved the controls around a bit and I think this is a bit nicer: Quote:
The "Type" tells you DVD/Blu-ray/File. And we're not crunched for space in that column, so eliminating it wouldn't help. |
20th November 2012, 05:51 | #492 | Link | |||||
VidCoder Author
Not happy with having to go to 2 rows for the controls but maybe I can do something about that later. Quote:
Here it is post-rejiggering: Quote:
20th November 2012, 20:58 | #493 | Link | |||||||||||
VidCoder Author
The large amount of activity that continues for a while after moving the slider is something I can deal with. Currently it's just saving the settings in the background every time a change is made but I can make it so that if multiple changes come in while one operation is completing only the latest one will actually run. That will probably result in a lot less useless hard disk activity when you move sliders about or hold down the buttons on a number box. Quote:
Given that, there's really no reason to have an option to turn it off. It's just a tab that doesn't get in your way if you don't use it. Maintenance isn't too bad since I've got a good system to let me easily tweak the choices and automatically construct the options string from them. Quote:
I suppose I could add the feature as a security blanket but it's not very high on my priority list. Quote:
This shows that you shouldn't thank people in advance because they might not do what you're asking! |
20th November 2012, 23:04 | #494 | Link |
VidCoder Author
I've got a new wiki page up describing how to translate VidCoder to another language. Looking for volunteers, particularly for Spanish and German. Had one guy but he's been missing for weeks now.
21st November 2012, 01:11 | #495 | Link | |||
VidCoder Author
21st November 2012, 21:07 | #496 | Link | |
VidCoder Author
About adding controls to the Advanced panel, I'm a bit tired of poking controls around to make room. Why don't you submit a patch for fitting those VBV controls in? But please, no abbreviations.
21st November 2012, 21:26 | #497 | Link |
VidCoder Author
Released VidCoder 1.4.7 Beta:
* Added view modes to the Preview window. Now you can see the image in 1:1 or in "Corners" mode to show a close-up of cropping results. * Added the ability to set a custom completion sound. * Gave the encoding settings command bar a more distinctive background color and extended it to the whole width of the window. Added the preview button to the command bar. * Rearranged UI in Video tab and added back the section headers. * Added the "Most" choice for the advanced x264 analysis option. * Updated HandBrake core to SVN 5071. * Fixed excessive hard disk activity when quickly changing encoding settings by moving a slider or holding down a number box button. * Fixed cropping output not updating when switching cropping modes (regression in 1.4.6). |
22nd November 2012, 19:13 | #500 | Link |
VidCoder Author
Released VidCoder 1.4.8 Beta:
* Fixed encode failures when including chapter markers (Regression in 1.4.7). |
