21st March 2019, 21:04 | #1441 | Link |
VidCoder 5.6 Beta
Hi RandomEngy,
today I started to test version 5.6 and noticed a small issue. When postprocessing encoded MP4 files created with Vicoder 3.16 with MP4Box the handler names for audio streams are reported as "Stereo" or "Surround". The latest version just outputs "SoundHandler". You can check by using a commandline like %MP4Box% -info STREAM_NUMBER %FILE% Maybe this is a setting you can control. It was extremely handy for me. ggtop VidCoder 5.6 Beta: Code:
Track # 2 Info - TrackID 2 - TimeScale 48000 - Duration 00:58:32.917 Media Info: Language "German" - Type "soun:mp4a" - 164668 samples Handler name: SoundHandler MPEG-4 Config Audio Stream - ObjectTypeIndication 0x40 MPEG-4 Audio MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 48000 Decoding Buffer size 0 - Average bitrate 192 kbps - Max Bitrate 192 kbps No stream dependencies for decoding StreamPriority 0 Code:
Track # 2 Info - TrackID 2 - TimeScale 48000 - Duration 00:41:18.997 Media Info: Language "English" - Type "soun:mp4a" - 116203 samples Handler name: Stereo MPEG-4 Config Audio Stream - ObjectTypeIndication 0x40 MPEG-4 Audio MPEG-4 Audio AAC LC - 2 Channel(s) - SampleRate 48000 Decoding Buffer size 1512 - Average bitrate 190 kbps - Max Bitrate 233 kbps No stream dependencies for decoding StreamPriority 0 |
25th March 2019, 06:31 | #1442 | Link | |
VidCoder Author
25th March 2019, 07:06 | #1444 | Link |
VidCoder Author
Released VidCoder 5.7 Beta:
27th March 2019, 06:15 | #1445 | Link |
VidCoder Author
Released VidCoder 4.35:
8th April 2019, 21:18 | #1447 | Link |
request = allow edit current encoding in progress
basically u can reencode something u encoded from history lets say u choose qrf20 it goes too big u go to history left click edit change qrf to 22 and add to queue this is impossible for items currently encoding u need to either wait for it to finish (1-2 hours) or stop it also an other thing also when u edit an item in queue it gets removed from queue so when u make changes and readdd to queue it wont encode it twice is it possible to add an option (for advance users at least) to NOT remove it from queue (will basically encode twise) thanks also 1 last thing probably irrelevant to this thread i cant reallly beta test the latest thing cauze i am using a modified version of HB.dll with fdk-aac enabled and the latest version probably uses a newer library with the latest handbrake core however i dont have lunix to compile it myself if some1 around here has that capability and could upload such thing in a free hosting place or just email me the file would be eternaly greatfull . if u can plz send me private message thanks |
12th April 2019, 13:16 | #1448 | Link |
@RandomEngy
I was reading your blog on dark theme in WPF and it was very helpful. One thing I couldn't workout yet is how to style the radio button, ideally it would look like the one in the Windows 10 settings but it's my first WPF app so it'll take me time to get there. I was looking in your code how you do it but couldn't find where it's located. https://postimg.cc/cKzWnyfR edit: Turns out my only problem was changing the background brush so my problem is solved. Last edited by stax76; 12th April 2019 at 14:17. |
21st April 2019, 08:55 | #1449 | Link | |
VidCoder Author
You can't change encoding settings in the middle of encoding a file, and it's not possible to add that functionality. As for editing a queued item without removing it from the queue, in which cases would this be helpful? |
23rd April 2019, 22:56 | #1450 | Link |
found an other bug (carefull is in 5.1 version so might have been fixed already - cant test newer version cauze i still have an old handbrake core ( )
when a movie is loaded with multiple tracks the indicator shows a false number than the tracks actually processed (and probably encoded) due to probably removing the unknown tracks so for instance a movie with 3 tracks from wich 1 is unknown for number of reasons - maybe its unknown bitrate due to TRUEHD or something - the indicator shows 2/3 however if u press the triangle it will show all 3 tracks and checked. and if u press encode it will process all 3 tracks so some times the picker says no audio but the movie has and vidcoder produces a fine encode with audio (it just doesnt process the language or the bitrate correctly and thus saying "no audio" "You can't change encoding settings in the middle of encoding a file, and it's not possible to add that functionality." you misanderstood me i didnt ask to create a program that can change settings in the middle of the encoding process what i am asking for is while the encoding is in progress , the item encoding exists also first item in the queue despite however the ability to right click and edit its settings liek the other items in queue u cant do it for the 1st cauze its locked now u might say well why do u care so much about the 1st queued item. ussually the movie encoding curretly is also open in the program and u can change the settings on it. yes. however if u have a large queue with 50 items the opened one might be an old item while currently the program might have reached item 30. u cant however bring the item 30 in the active settings to change qrf etc as to why u asked. well maybe u encoding a movie currently and it gets too big. but u are not sure so u dont want to stop the encoding just add an other one with different settings . or u maybe want to create different samples of the same thing with different settings u can do that if the item in question is in the finished items queue u can do that if the item is not the first in line or u can just add the movie with drag and drop from the explorer obviusly all these things are extremely minor and not really serious the program runs fine with or without the above issues |
24th April 2019, 06:49 | #1451 | Link |
VidCoder Author
Released VidCoder 5.8 Beta:
24th April 2019, 06:51 | #1452 | Link |
VidCoder Author
@napouser: Pretty sure the bug you described is fixed in later versions.
About editing the first item in the queue while the encode is running: That first item represents the currently executing encode. That's why you can't change the settings. To change it, stop the encode, edit it, re-queue and resume. |
27th April 2019, 18:57 | #1455 | Link |
"@napouser: Pretty sure the bug you described is fixed in later versions."
nope it hasnt just seen it in 5.7 steps to reproduce find said movie (lets say unknown trueHD track + 2 known tracks) add to vidcoder program correctly recognizes 3 audio tracks add to queue add an other movie (so the current active movie is changed) add to queue restore first movie boom 2/3 audio tracks (but program correctly encodes all 3) |
30th April 2019, 07:59 | #1456 | Link |
VidCoder Author
Hmm. Not sure what you mean by "Unknown" tracks. VidCoder doesn't have special handling for them, so they should work just like any other audio track, just named "Unknown". What was your picker set to do with audio tracks when you saw this happen?
30th April 2019, 16:43 | #1457 | Link | |
have 2 pickers 1 is set to get all audio no subs and then i remove the audio selections through preset (samples) 2 is set to get all audio and some subs (movies) so in all cases i get all the audio tracks in some cases however i see no audio or 2/3 or 1/2 the audio that doesnt come is ussually unknown language (program cant identify it even tho its still english - probably due to TRUE HD maybe?) the fact that the program cant identify it and appears as 2/3 doesnt mean that its not encoding it the result is still with 3 audio tracks so basically this is just a visual bug and has no impact in the encodings also one more bug that i see for some months now when u restore from completed the item gets a name of the type blabla - restored from compelted.mkv there is also a new restored from completed preset now thats fine since i restore a ton of items every day (samples - certain movies that need reencoding) some times i see alot of restored from completed presets the issue is that after some weeks those presets persist even when u close the program so basically every couple of months i have to manually delete them all (4-5) dunno if this is cauze in cases of sudden close of the program so they get saved automatically or if they saved if the program switches to an other "restored from completed" preset or something also i dont mind deleting 3-4 presets every couple of months just pointing it in case u want to do some clean up on the preset saving code |
6th May 2019, 21:22 | #1458 | Link |
DVD - MP4 with 2 audio tracks
I discovered an issue today using 5.8 Beta. I am converting from a DVD to a custom preset with audio to AAC and AC3 passthrough. The DVD contains contains 3 audio tracks. I pick another audio track and VidCoder shows 4 audio tracks for output as expected. But the final file has only 1 language (AAC + AC3). Will test again with 3.16 tomorrow and 5.8 Beta using a picker rather than choosing manually. But maybe someone can confirm the same. ggtop |
