Old 27th June 2016, 05:19   #1841  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
DitherTools isn't working well with MT.
Try this script repeatedly and it will crash in dither.dll, when all dither functions are set to either MT=1 or 2
Dither_convert_8_to_16()
SMDegrain(thsad=200, prefilter=2, lsb_in=true, lsb_out=true)
DitherPost(mode=6)
Prefetch(8)
A solution I found is to set DitherPost to MT mode 3. However, it then causes a severe slowdown when using SMDegrain(prefilter=4) where performance goes from 2.2 to 1.6fps.
Without setting DitherPost to MT mode 3, I can't get rid of the crashes, so it would be nice for someone to investigate.
MysteryX is offline   Reply With Quote
Old 27th June 2016, 05:51   #1842  |  Link
Issues with DitherPost have been reported before; I remember the statement that it is sufficient to limit one function of this family if there are several dither function used, may not matter much which of them...
Old 27th June 2016, 08:02   #1843  |  Link
Groucho2004
Groucho2004's Avatar
Do you have avstp.dll in your auto-load directory? If so, remove it and try again.
Groucho's Avisynth Stuff
Old 27th June 2016, 08:09   #1844  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
No I don't have that
Old 27th June 2016, 08:37   #1845  |  Link
jpsdr
Originally Posted by Chikuzen View Post
@ultim or someone
I have a question about multi-threading.
Is it possible to implement a temporal IIR filter as MT_NICE_FILTER ?
I am affraid you have to be MT_SERIALIZED with this kind of filter, you can't even be MT_MULTI_INSTANCE. At least, from what i've understood.
But there is also a MT_MODE_COUNT, i don't know what it does.
Old 27th June 2016, 12:16   #1846  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Here's another bug. I tried using Deshaker.
http://www.guthspot.se/video/deshaker.htm
Here's a script that will run the first pass and generate a log file to be used for the second pass.
P="Encoder\"
LoadVirtualDubPlugin(P+"deshaker.vdf", "deshaker", preroll=0)
LoadPlugin(P+"LSMASHSource.dll")
file="Source.MOV"
LWLibavVideoSource(file, cache=True)
ConvertToRGB32()
deshaker("19|1|30|4|1|0|1|0|640|640|1|2|1000|1000|1000|1000|4|1|3|2|8|30|300|4|Preview_Deshaker.log|0|0|0|0|0|0|0|0|0|0|0|0|0|1|15|15|5|15|0|0|30|30|0|0|0|0|1|0|0|10|1000|1|88|1|1|20|5000|100|20|1|0")
PointResize(8,8)
To run the second pass, re-insert the deshaker line in your full script wherever you want and change the 2nd argument from 1 to 2 to run the 2nd pass from that log file.
With AviSynth 2.6 it works fine. With AviSynth+, I get a crash in the destructor. Whenever I close the preview I get a crash.
Deshaker doesn't seem to work with MT but a single thread tops all 8 CPU cores anyway.
Old 27th June 2016, 13:56   #1847  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
The VD plugin bug seems easy to fix so I thought I might take a look myself. Trying to compile AVS+ in VS2015, however, there is this error: redefinition of 'y'. This code really doesn't look right... it's using y for the loop and redefining y twice more within the loop. Pinterf I'll let you look into that one.
For now I'll rename the 2 redefinitions as y2.
static void af_horizontal_yuy2_c(BYTE* p, int height, int pitch, int width, int amount) {
  const int center_weight = amount*2;
  const int outer_weight = 32768-amount;
  for (int y = height; y>0; --y)
    BYTE yy = p[0];
    BYTE uv = p[1];
    BYTE vu = p[3];
    int x;
    for (x = 0; x < width-2; ++x)
      BYTE y = ScaledPixelClip(p[x*2+0] * center_weight + (yy + p[x*2+2]) * outer_weight);
      yy   = p[x*2+0];
      p[x*2+0] = y;
      BYTE w = ScaledPixelClip(p[x*2+1] * center_weight + (uv + p[x*2+5]) * outer_weight);
      uv   = vu;
      vu   = p[x*2+1];
      p[x*2+1] = w;
    yy       = p[x*2+0];
    p[x*2+0] = y;
    p[x*2+1] = ScaledPixelClip(p[x*2+1] * center_weight + (uv + p[x*2+1]) * outer_weight);
    p[x*2+2] = ScaledPixelClip(p[x*2+2] * center_weight + (yy + p[x*2+2]) * outer_weight);
    p[x*2+3] = ScaledPixelClip(p[x*2+3] * center_weight + (vu + p[x*2+3]) * outer_weight);
    p += pitch;
Old 27th June 2016, 14:27   #1848  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
The VDub destructor bug isn't so easy to fix; but shouldn't be hard for someone who understands the code better.
  // VDubFilter.cpp
  void CallEndProc() {
    if (fd->endProc) {
      int result = fd->endProc(&fa, &g_filterFuncs);
      if (result != 0) {
        throw AvisynthError("VirtualdubFilterProxy: error calling endProc");
Basically, Deshaker's EndProc is trying to access "something" within fa that is no longer accessible at that time.
Commenting both of these lines does solve the problem, but I doubt it is the right fix
// in FilterAdd
fm->env->AtExit(FreeFilterDefinition, fd);
// in LoadVirtualdubPlugin
env->AtExit(FreeFilterModule, fm);
The destructor needs to be called before these 2 functions.
I'll let you fix it before I start adding a "release timer" to fix the sequence
Old 27th June 2016, 14:58   #1849  |  Link
pinterf
In my source it is fixed already in focus.cpp.
https://github.com/pinterf/AviSynthP...ters/focus.cpp
Which branch or version are you working on?
pinterf is offline   Reply With Quote
Old 27th June 2016, 15:03   #1850  |  Link
Groucho2004
    BYTE yy = p[0];
    BYTE uv = p[1];
    BYTE vu = p[3];
    int x;
      yy   = p[x*2+0];
      p[x*2+0] = y;
      uv   = vu;
      vu   = p[x*2+1];
      p[x*2+1] = w;
    yy       = p[x*2+0];
    p[x*2+0] = y;
    p += pitch;
Earlier compilers didn't complain about re-definitions if they had a different scope. That led to sloppy programming.
The above function is just horrible, it also defines a variable with different types (BYTE y, int y).
Old 27th June 2016, 15:08   #1851  |  Link
pinterf
  // VDubFilter.cpp
    if (fd->endProc) {
      if (result != 0) {
// in FilterAdd
Did you checked the last commit? It is not yet in the last pfmod release, there were changes integrated from classic avs regarding "Fix VDub plugin race on cleanup"
Old 27th June 2016, 15:10   #1852  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Pinterf, I took your branch.
The destruction sequence is the problem. This is something to be very careful about so it's better if I don't touch it; it touches the core of AVS and will affect every plugin.
ScriptEnvironment::~ScriptEnvironment() {
  closing = true;
  // Before we start to pull the world apart
  // give every one their last wish.
  at_exit.Execute(this);
Here it wants to execute these functions before pulling the world apart, and with VDubFilter we must call the destructor before calling these functions.
Old 27th June 2016, 15:17   #1853  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I see, I forgot to manually select the right branch after downloading the code.
Now it compiles fine right away. The VDub bug is still the same. Good luck Pinterf.
Old 27th June 2016, 21:16   #1854  |  Link
pinterf
Let's look at this silly code fragment
lsmashvideosource(film, stacked=true, format="YUV444P16")
# Open Prores422 10 bit as YUV444P16
ConvertStackedToNative()
Spline64Resize(400,300)
Crop(9,7,-9,-7)
FlipHorizontal().FlipVertical()
TurnLeft().TurnRight().Turn180()
PointResize(3200,2400)
GrayScale()
BilinearResize(1600,1200)
ConvertNativeToStacked()
source1=last
Nothing special, we are in 2016, UHD era, with 14-16 bit linear uncompressed raw in cameras. I was a bit surprized when this very basic 16 bit workflow started to work on my bench. Funny last minute techdemo from Avisynth. A kind of Second Reality
For everything else there's DitherTools.
Old 27th June 2016, 22:51   #1855  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
lsmashvideosource(film, stacked=false, format="YUV444P16")
Why do you take a side trip and waste your time?
You can open the source as NativeFormat
my repositories
Chikuzen is offline   Reply With Quote
Old 27th June 2016, 22:52   #1856  |  Link
You might know that Smash Designs created a C=64 version of the Future Crew PC VGA demo. Maybe that's how we used to feel with only 8 bits per component...
Old 27th June 2016, 23:04   #1857  |  Link
real.finder
lsmashvideosource(film, stacked=false, format="YUV444P16", dr=true)
We discussed this in #avs-plus@irc.rizon.net
Currently lsmashvideosource without stacked will out in interleavexbit not in NativeFormat, so this will need something like ConvertInterleaved16ToNative() and ConvertNativeToInterleaved16()
Interleaved16 will be like the clip that out from dither_out()
more clearly details in flash3kyuu_deband.txt, input_mode and output_mode and stacked bool in f3kdb_dither
My Avisynth Stuff
Old 28th June 2016, 03:33   #1858  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
VDub destructor crash fixed
Fixed crash on exit due to FreeFilterModule being called before VirtualdubFilterProxy's destructor
diff --git a/plugins/VDubFilter/VDubFilter.cpp b/plugins/VDubFilter/VDubFilter.cpp
index df512ee..7d97fef 100644
--- a/plugins/VDubFilter/VDubFilter.cpp
+++ b/plugins/VDubFilter/VDubFilter.cpp
@@ -365,10 +365,11 @@ typedef struct FilterDefinition {
 class FilterDefinitionList {
 public:
+	FilterModule* fm;
   FilterDefinition* fd;
   FilterDefinitionList* fdl;
-  FilterDefinitionList(FilterModule* fm, FilterDefinition* _fd) : fd(_fd), fdl(fm->fdl) { };
+  FilterDefinitionList(FilterModule* _fm, FilterDefinition* _fd) : fm(_fm), fd(_fd), fdl(fm->fdl) { };
@@ -575,6 +576,7 @@ public:
 class VirtualdubFilterProxy : public GenericVideoFilter {
   PVideoFrame src, dst, last;
   VFBitmap vbSrc, vbDst, vbLast;
+  FilterDefinitionList* const fdl;
   FilterDefinition* const fd;
   FilterStateInfo fsi;
   FilterActivation fa;
@@ -602,9 +604,11 @@ class VirtualdubFilterProxy : public GenericVideoFilter {
 public:
-  VirtualdubFilterProxy(PClip _child, FilterDefinition* _fd, AVSValue args, IScriptEnvironment* env)
-    : GenericVideoFilter(_child), fd(_fd), fa(vbDst, vbSrc, &vbLast)
+  VirtualdubFilterProxy(PClip _child, FilterDefinitionList* _fdl, AVSValue args, IScriptEnvironment* env)
+    : GenericVideoFilter(_child), fdl(_fdl), fd(_fdl->fd), fa(vbDst, vbSrc, &vbLast)
+	if (!fd)
+		env->ThrowError("VirtualdubFilterProxy: No FilterDefinition structure!");
     if (!vi.IsRGB32())
       throw AvisynthError("VirtualdubFilterProxy: only RGB32 supported for VirtualDub filters");
@@ -763,16 +767,29 @@ public:
   ~VirtualdubFilterProxy() {
     CallEndProc();
+	FreeFilterModule(fdl->fm);
     if (vbSrc.hdc)
       ReleaseDC(NULL, vbSrc.hdc);
+  void __cdecl FreeFilterModule(FilterModule* fm) {
+	  for (FilterDefinitionList* fdl = fm->fdl; fdl; fdl = fdl->fdl) {
+		  delete fdl->fd;
+		  fdl->fd = 0;
+	  fm->deinitProc(fm, &g_filterFuncs);
+	  FreeLibrary(fm->hInstModule);
+	  if (fm->prev)
+		  fm->prev->next = fm->next;
+	  if (fm->next)
+		  fm->next->prev = fm->prev;
+	  delete fm;
   static AVSValue __cdecl Create(AVSValue args, void* user_data, IScriptEnvironment* env) {
     FilterDefinitionList* fdl = (FilterDefinitionList*)user_data;
-    if (!fdl->fd) env->ThrowError("VirtualdubFilterProxy: No FilterDefinition structure!");
-    return new VirtualdubFilterProxy(args[0].AsClip(), fdl->fd, args, env);
+    return new VirtualdubFilterProxy(args[0].AsClip(), fdl, args, env);
@@ -803,24 +820,6 @@ FilterDefinition *VDcall FilterAdd(FilterModule *fm, FilterDefinition *pfd, int
-void __cdecl FreeFilterModule(void* user_data, IScriptEnvironment* env) {
-  FilterModule* fm = (FilterModule*)user_data;
-  for (FilterDefinitionList* fdl = fm->fdl; fdl; fdl = fdl->fdl) {
-    delete fdl->fd;
-    fdl->fd = 0;
-  fm->deinitProc(fm, &g_filterFuncs);
-  FreeLibrary(fm->hInstModule);
-  if (fm->prev)
-    fm->prev->next = fm->next;
-  if (fm->next)
-    fm->next->prev = fm->prev;
-  delete fm;
 AVSValue __cdecl LoadVirtualdubPlugin(AVSValue args, void*, IScriptEnvironment* env) {
   const char* const szModule = args[0].AsString();
   const char* const avisynth_function_name = args[1].AsString();
@@ -879,7 +878,6 @@ AVSValue __cdecl LoadVirtualdubPlugin(AVSValue args, void*, IScriptEnvironment*
     fm->next->prev = fm;
   env->SetGlobalVar("$LoadVirtualdubPlugin$", (const char*)fm);
-  env->AtExit(FreeFilterModule, fm);
   return AVSValue();
Git isn't allowing me to push the changes; is there something I'm doing wrong or you just have to add those changes yourself?
git.exe push -v --progress "origin" master:MT-pfmod
remote: Permission to pinterf/AviSynthPlus.git denied to mysteryx93.
fatal: unable to access 'https://github.com/pinterf/AviSynthPlus.git/': The requested URL returned error: 403
Pushing to https://github.com/pinterf/AviSynthPlus.git
Old 28th June 2016, 05:41   #1859  |  Link
qyot27
qyot27's Avatar
You have to have your own account on Github, use Github's tools* to spawn your own AviSynthPlus repo, and then push up to your own account. You can then open a pull request through Github to have the change integrated.
*well, technically you don't need to use Github's tools to do it so long as the SSH remotes are correct and you've authenticated your keys on your Github account, but it won't show up on the Network graph.
Old 28th June 2016, 06:20   #1860  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
OK I created a new Fork into my account, but MT-pfmod doesn't show up in the list of branches
