14th February 2016, 16:43 | #121 | Link | |
Basically I don't think that your drive is missing something... it's more likely that my implementation is still not 100% correct... |
14th February 2016, 16:57 | #122 | Link |
Big Bit Savings Now !
Here we go:
C:\Users\l>C:\enumcd\EnumCD.exe Properties for Device 1 Device ID: IDE\CdRomMATSHITA_BD-MLT_UJ260AF_________________1.00____ Adapter Properties ------------------ Bus Type : Printer Device Max. Tr. Length: 0x20000 Max. Phy. Pages: 0x21 Alignment Mask : 0x1 Device Properties ----------------- SCSI Device Type: CDROM Device (0x5) Media Type : DVD (0x33) Removable Media : Yes Product ID : MATSHITA BD-MLT UJ260AF Product Revision: 1.00 Inquiry Data from Pass Through ------------------------------ Device Type: CDROM Device (0x5) Vendor ID : MATSHITA Product ID : BD-MLT UJ260AF Product Rev: 1.00 Vendor Str : 12121200 CD Drive Capabilities from Pass Through --------------------------------------- CD Reader : Yes CD-R disc : Yes CD-RW disc: Yes CD writer : Yes CD-R disc : Yes CD-RW disc: Yes DVD Reader : Yes DVD-ROM disc: Yes DVD-R disc : Yes DVD-RAM disc: Yes DVD writer : Yes DVD-R disc : Yes DVD-RAM disc: Yes *** End of Device List *** C:\Users\l>
27th February 2016, 22:37 | #123 | Link |
@Emulgator
Sorry - took a little bit longer than expected. For the moment I've transcoded EnumCD to Purebasic - please try this executeable: EnumCdPurebasic.exe It should do exactly the same things as the original EnumCD (with only one difference - I've enhanced the list of Adapter-BusTypes - so it should tell you 'SATA' and not 'Printer Device' in case of an Sata drive ) If it is working for you I'll start to check for the differences between this implementation and my findvuk-code. |
1st March 2016, 01:01 | #124 | Link |
Here we go:
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten. C:\Users\l>E:\_SOFT\EnumCdPurebasic.exe Properties for Device 1 Device ID: IDE\CdRomMATSHITA_BD-MLT_UJ260AF_________________1.00____ Adapter Properties ------------------ Bus Type : SATA Max. Tr. Length: 0x20000 Max. Phy. Pages: 0x21 Alignment Mask : 0x1 Device Properties ----------------- SCSI Device Type: CDROM Device (0x5) Media Type : DVD (0x33) Removable Media : Yes Product ID : MATSHITA BD-MLT UJ260AF Product Revision: 1.00 Inquiry Data from Pass Through ------------------------------ Device Type: CDROM Device (0x5) Vendor ID : MATSHITA Product ID : BD-MLT UJ260AF Product Rev: 1.00 Vendor Str : 12121200 CD Drive Capabilities from Pass Through --------------------------------------- CD Reader : Yes CD-R disc : Yes CD-RW disc: Yes CD writer : Yes CD-R disc : Yes CD-RW disc: Yes DVD Reader : Yes DVD-ROM disc: Yes DVD-R disc : Yes DVD-RAM disc: Yes DVD writer : Yes DVD-R disc : Yes DVD-RAM disc: Yes Properties for Device 2 *** End of Device List *** C:\Users\l>
1st March 2016, 23:23 | #125 | Link |
How do I know FindVuk has found something and finished. But most importantly, thank you for this thread and tool. I started to run out of disk space when I had to make a MKV copy of my disks to watch them.
Edit: Well, now I know, with second disk I got more info. Last edited by LM2005; 1st March 2016 at 23:32. Reason: Added info |
24th March 2016, 23:11 | #126 | Link |
Just released 0.93 - just a small maintenance release, nothing really new...
@LM2005: I'm still thinking about your problem and already started to add something to 'EnumCdPurebasic' to get more details about your problem.., hopefully I can finish it within the next couple of days. |
25th March 2016, 02:06 | #127 | Link | |
With thanks LM2005 |
25th March 2016, 20:37 | #128 | Link | |||
Problem with iHOS104 BD-ROM
I am using a Liteon iHOS104 drive (vendor is "ATAPI"). Part 1 (GetVUK) is successful and retrieves the correct VUK (the VUK works if you manually add it to to the key file). However, validation of the VUK in step 2 fails: Quote:
Cheers, Steve |
25th March 2016, 23:00 | #129 | Link |
Hi, i'm still not sure if it has been a smart idea to include this check if not.
Please enable the debug log setting in the ini file and Post the logfile e.g. on pastebin.com and i'll try to fix this asap Gesendet von meinem D5803 mit Tapatalk |
30th March 2016, 21:38 | #130 | Link | |
@smiller667
@LM2005 Please try this special 'EnumCD' version and report your results: EnumCdPurebasic-3 I've added 2 custom commands at the end that request the same information that I'll try to retrieve from the drives in FindVUK - just want to know if it's working this way or not. On my computer the output at the end looks like this: Quote:
31st March 2016, 18:42 | #131 | Link | |
EnumCdPurebasic-3 produces the following output on the Liteon iHOS104: Quote:
Steve |
31st March 2016, 21:02 | #132 | Link |
Thanks for testing - please try this one here as well:
EnumCdPurebasic 4 I've changed only a small detail and will continue to release new versions with only small changes until it stops working And at this point I'll know how to fix this stupid bug (I already have an idea.. but need to make one step after the other to be on the safe side) |
31st March 2016, 21:21 | #133 | Link | |
Here is the EnumCdPurebasic 4 output:
Steve Last edited by smiller667; 31st March 2016 at 21:23. |
1st April 2016, 18:45 | #134 | Link |
Here comes the next try
This time I changed the way how the handle to the drive is retrieved to the method I'm using in FindVUK. Please report your result after trying EnumCdPurebasic5 Thanks! |
1st April 2016, 19:48 | #135 | Link | |
Here is the next output:
Steve |
2nd April 2016, 15:35 | #136 | Link |
Next try - changed 2 constants to the values I'm using in FindVUK - eventually those make the difference:
EnumCdPurebasic - Mod6 |
2nd April 2016, 16:56 | #137 | Link |
And another one:
EnumCdPurebasic Mod7 Now I've also copied the procedure that requests the data from the drive directly from FindVuk. @smiller667 - please execute both versions (Modification 6 & 7) and post your results - thanks! |
2nd April 2016, 21:16 | #138 | Link | ||
Here is the output from #6 & 7
#6: Quote:
28th April 2016, 21:17 | #140 | Link |
Released FindVUK 0.95
It's again just a small update - added all dvdfab and passkey versions released in the last weeks as tested versions and fixed a small bug that I've noticed after starting FindVUK from a batch file (and changed the procedure to read drive details one more time - in case somebody notices a regression please tell me - thanks ) The download link is in the first post! |
