13th August 2008, 19:42 | #2201 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th August 2008 at 19:44. |
13th August 2008, 22:58 | #2202 | Link |
Atak heres one for you. I know you said HD DVD is dead to you but I just stumbled across a disc that looks like it has an intro before the movie starts and the playlist shows the intro + the main movie. Problem is for audio it only shows 2 channel source which I presume is because of the intro.
I have uploaded the job file for you if you wish to take a look. Cheers http://www.mediafire.com/?sharekey=5...07ac82cce1d6c2 |
13th August 2008, 23:18 | #2203 | Link |
try this
copy /b "FEATURE1.EVO"+"FEATURE2.EVO" "c:\combined_evos.evo" open combined_evos.evo in ripbot264
14th August 2008, 03:45 | #2204 | Link |
I recently installed Windows Server 2008 on a Vmware machine (because Windows Server 2008 supports more than 2 CPU's). I try to do my rendering on that machine now, to off-load my regular one. Okay, installed RipBot264, and tried my first VC-1 source. Getting an error (from Media Player Classic):
"Cannot play back the video stream: no suitable decompressor could be found." I tried installing a Vista Codex pack, but to no avail. Same error. There's nothing in the RipBot264 log, either. Anyone know what I should add/do to make this error go away? Obviously, a codec issue of sorts, but obviously not clear which one. Thanks.
Gorgeous, delicious, deculture! Last edited by asarian; 14th August 2008 at 03:48. |
14th August 2008, 05:46 | #2205 | Link |
I dont care so should you
Codec packs suck un install them..
Vista 64 supports multiple cpus (more then two) Server 2008 though great for virtualization (new feature by the way) and server tasks Sucks for video encoding... The FFDshow filters have not been made to run in a virtualized environment hence "Cannot play back the video stream: no suitable decompressor could be found." error.. Though it has been known to work...
My Installer's || Last edited by Ajax_Undone; 14th August 2008 at 05:49. |
14th August 2008, 06:14 | #2206 | Link | |
When I press the triangle on the PS3 it says that there are no subtitle option. I must be doing something wrong or picking the wrong option when I choose the subtitles. |
14th August 2008, 12:06 | #2207 | Link | |
Thanks for the quick suggestion. |
14th August 2008, 13:45 | #2208 | Link |
н∂-ƒαиαтι¢
finally i have managed to work out an ipod crf profile which works!
for any1 who may be interested..crf used=21 Code:
[x264settings] DeblockingStrength=0 DeblockingSensitivity=0 AdaptQuant=1 MotionEstimationAlgorithm=3 - UMH SubpixelRefinement=6 - RDO I4X4=1 P4X4=0 P8X8=1 B8X8=1 AdaptDCT=0 I8X8=0 NumberOfRFrames=1 mixedRFrames=0 TrellisQuant=0 CABAC=0 NumberOfBFrames=0 AdaptBFrames=0 BPyramid=0 WeightBPrediction=0 BidirectionalME=0 RDOBFrames=0 Level=level 3.0 HRD=0 BufferSize=1000 MaxBitrate=10000 Code:
General Complete name : D:\iTunes\iTunes Music\Movies\Doomsday.mp4 Format : MPEG-4 Codec ID : M4V File size : 348 MiB Duration : 1h 52mn Overall bit rate : 431 Kbps Album : Movies Genre : Movie Encoded date : UTC 2008-08-13 12:29:33 Tagged date : UTC 2008-08-14 13:33:56 Cover : Yes Video Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Duration : 1h 52mn Bit rate mode : Variable Bit rate : 331 Kbps Maximum bit rate : 1847 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4/3 Frame rate mode : Constant Frame rate : 23.976 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.180 Stream size : 268 MiB (77%) Writing library : x264 core 61 Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy_rd=1.000000 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=crf / crf=21.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=10000 / vbv_bufsize=1000 / ip_ratio=1.40 / aq=2:1.00 Encoded date : UTC 2008-08-13 12:29:33 Tagged date : UTC 2008-08-13 12:30:03 Audio Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 1h 52mn Bit rate mode : Variable Bit rate : 96.0 Kbps Maximum bit rate : 103 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 77.7 MiB (22%) Encoded date : UTC 2008-08-13 12:29:45 Tagged date : UTC 2008-08-14 13:33:56 Last edited by ~bT~; 14th August 2008 at 13:49. |
14th August 2008, 14:04 | #2209 | Link | |
big thx tried them already: 1280x720-23_976fps.mp4 and 1280x720-25fps.mp4 are working. The other won't be played and itunes wants to convert them. But I just get a white video. Playback in itunes is working with all of them. Could you tell me the Settings u used please.. Regards |
14th August 2008, 16:22 | #2210 | Link |
Why is eac3to used to demux the audio from a ts file containing? Shouldn't DGindex be used?
eneral ID : 1 Complete name : C:\Personal\Videos\Hellboy.ts Format : MPEG-TS File size : 189 MiB Duration : 2mn 24s Overall bit rate : 10.9 Mbps Video ID : 16 (0x10) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, Matrix : Standard Duration : 2mn 24s Bit rate mode : Constant Bit rate : 10.1 Mbps Nominal bit rate : 38.8 Mbps Width : 1920 pixels Height : 1080 pixels Display aspect ratio : 16/9 Frame rate : 29.970 fps Colorimetry : 4:2:0 Scan type : Progressive Scan order : 2:3 Pulldown Bits/(Pixel*Frame) : 0.625 Audio ID : 17 (0x11) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 48.0 KHz Video delay : -710ms Language : English |
14th August 2008, 21:28 | #2214 | Link | |
A BD9 looks perfect to me on my 67" DLP. DL-DVD's are a lot cheaper and l dont even need a Blu-ray burner!!! |
14th August 2008, 22:36 | #2216 | Link |
?? ok so whats your question. Do you want pre sets for DVD-9's or BD-25's???
Or is that even your question...
My Installer's || |
14th August 2008, 22:42 | #2217 | Link | |
BD5, BD9, and BD25. Hopefully at some point in the near future BD-25's will come down in price along with the burners. Thanks |
