Old 3rd December 2017, 03:57   #26781  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by AmigaFuture View Post
Leave me out of that our statement.
Huh?
I don't accept luck as a truth, I'm not into superstitions.
Who said anything about luck being truth? You consider luck a superstition?
Old 3rd December 2017, 04:17   #26782  |  Link
Lathe
Lathe's Avatar
Huh?
Ahhhhh.... Now, THIS is interesting.
On one side we have the ever proper, ever precise Mr. Video...
On the other side, we have the Eastern flavoured, philosophical, enigmatic AF...
I think the Universe is just about ready to implode...
Old 3rd December 2017, 08:50   #26783  |  Link
AmigaFuture
AmigaFuture's Avatar
Huh?
I was...in part..having fun with you.
Luck, lucky, etc.. are colloquialism. Live the life I've lived and experiences I've had in this life (as well as previous) and...you'll know without a doubt luck doesn't have anything to do with anything (nor is anything preordained). Thus, yes. There is a reason why Science and Churches butt heads. But Quantum brings things together. Luck doesn't fit into anything, except to be a silly phrase to be used as an excuse for deeper understanding--or "general" conversations (Weee!!). But I don't wish to stray too much off topic. Superstitions are funny.. Does a Black Cat crossing your Path really cause bad luck? I have had 3 Black Cats in 30+ years...Uhh, they don't. I'm very aware of my movements and actions through the moments of a day. Depends on your Mind and what You accept/reject. I'm very open but not to "luck/magic". Love to know how and why, which totally removes luck/superstition.
@ Lathe
"I think the Universe is just about ready to implode... " -- Hahahha!! Nice! Yeah, and Armageddon will ever actually BE something real. Funny. More like Multi-Verse.. Wink!
Old 7th December 2017, 18:35   #26784  |  Link
LowDead
Elit Amans
UHD backups
@jdobbs: Hi! Don't know if you made any progress on UHD backups. Have you successfully encode anything yet? Anyhow, the bad monkey have gotten around to make uhd backups work (currently full disc with all available streams and movie only with ability to remove streams.) I made a backup and have info on working video stream if that can help you... I can also volunteer to test on a standalone Samsung UDP-K8500 when you come closer to working version
Have a nice day!
//LD
General
Complete name                            : F:\WORK\FullDisc\The Smurfs 2\BDMV\STREAM\00001.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 38.7 GiB
Duration                                 : 1 h 53 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 49.0 Mb/s
Maximum Overall bit rate                 : 48.0 Mb/s
Video
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
Codec ID                                 : 36
Duration                                 : 1 h 44 min
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 23.976 (24000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : SMPTE ST 2084
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Content Light Level              : 1132 cd/m2
Maximum Frame-Average Light Level        : 923 cd/m2
Old 7th December 2017, 19:04   #26785  |  Link
I have it working -- and in fact have done a couple backups. But there is still a lot of work to be done in automating the entire process and lots and lots of testing. I'm also sure I will find that there is a lot of tweaking to be done when I try more sources. I also have to consider that the holidays are coming up and which I will be entertaining visitors. I'm guessing I might have a UHD-BD version released by the end of the month -- but more probably it will be some time in January.
My biggest challenge is that I don't have a copy of the updated UHD-BD standard. So I've had to spend a lot of time going through files scanning and/or dumping information that would have been easy to look up. It's also no help that even my fastest processor is performing these encodes at a snail's pace. But I simply can't afford to replace it. I was stretching it by buying a UHD-BD player.
Old 7th December 2017, 20:42   #26786  |  Link
Ch3vr0n
There's not just UHD jd. 4K doesnt automatically mean UHD and reverse. Then you also have the "high dynamic range" bonus thing too. and apparently something new "Ultra HD Premium"
Old 7th December 2017, 23:38   #26787  |  Link
LowDead
Elit Amans
Ultra HD Premium is just a "certificate" that says the media is above a certain quality. Nothing special about that.. HDR is another thing though.
//LD
Old 8th December 2017, 01:13   #26788  |  Link
The correct terminology, according to everything I’ve read, when it is applied to BD is UHD-BD. So that’s what I call it as well. That includes HDR, 2160p, 10 bit color, etc. If I find a more definitive term - then I’ll call it that. Trying to call it anything else right now is just symantics.
Old 8th December 2017, 12:06   #26789  |  Link
abbadon
Can someone remind me of avisynth scrip or some other way to rotate the video 90 degress before encoding? Couple short cell phone videos i want to burn to dvd
Win7x64...I had to...
RIP WinXP
abbadon is offline   Reply With Quote
Old 8th December 2017, 17:33   #26790  |  Link
meadrocks
Ran Avatar last night 1080p, x265 to a mkv, 21 CRF. Every time a Na'vi language subtitle of the appears on screen the video stutters. Are there any work arounds for this?
meadrocks is offline   Reply With Quote
Old 8th December 2017, 19:23   #26791  |  Link
joubel
faild to "re-encode" BD-25 to BD50 with secondary audio/video
Hi!
I have installed the new version to a clean windows 7 64bit, with all the additional software (just like in the readme), after that, it started to "fail re-encode" (+ the old one still can run after the windows re-install, but it fails too now). Most of the time i had to continue 1-2 times to finish, but it can't get through on one BD (Priest 2011 1080p GBR AVC). I'm not compressing, just demuxing unnecessary audio dubs). What should i do to make it work? Do i need to post some log file in the thread?
joubel is offline   Reply With Quote
Old 9th December 2017, 00:11   #26792  |  Link
gonca
look for Rotate plugin
Old 9th December 2017, 00:12   #26793  |  Link
gonca
Originally Posted by joubel View Post
Hi!
Please post the log file
Old 9th December 2017, 00:13   #26794  |  Link
gonca
Could be a player issue
Old 9th December 2017, 04:36   #26795  |  Link
abbadon
thanks
RIP WinXP
Old 9th December 2017, 06:43   #26796  |  Link
meadrocks
I use kodi as a player on all my TVs, it plays x264 & x265 content with no problems with hundreds of movies output from BD-RB. Also stutters on vlc & mplayer on my ubuntu pc. According to the subtitle db (https://docs.google.com/spreadsheets...Ek/edit#gid=20) there are issues with the subtitles with bdsup2sub, not sure if BD-RB uses that util.
Old 9th December 2017, 13:56   #26797  |  Link
gonca
Don't think it does, and the issues are frame rate based and shouldn't cause stutters
Are your subtitle hard coded
Old 9th December 2017, 15:59   #26798  |  Link
joubel
solved
Thanks, but it seems the problem is solved by check in the option: use x264/lav filter
Old 10th December 2017, 17:43   #26799  |  Link
meadrocks
Na'vi translation is part of the main English subtitle track, however is in a different font and tagged as forced.
Old 10th December 2017, 17:51   #26800  |  Link
gonca
Try it without the subtitles and see if there any issues at those points
