Old 22nd July 2018, 21:07   #27521  |  Link
MrVideo
MrVideo's Avatar
How does one tell BDRB not to re-encode one of the files? Six of the files are ~5GB each and the 7th is ~267MB (a little less than 4 min). I do not want the short file re-encoded, only the large files.
Old 22nd July 2018, 21:51   #27522  |  Link
Ch3vr0n
It should be somewhere in the hidden options. Min_file_size or something. Or something to do with minimum duration
Sent from my Nexus 6P with Tapatalk
Old 23rd July 2018, 03:41   #27523  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by Wolfe999 View Post
It was my intention no to say anything else about this matter (and I promise this will be the last, no matter what I read from here, not even if this gets censored), even when I see that it seems that some people feel the need to intervene in something that doesn't concern them: an exchange of words (no matter how justified) among two adults.
"I really hope to be forgotten by you. I promise to reciprocate." - This line is hypocritical to your reply. That means opposite to your reply, I thought I'd help you. :-) I didn't include the Other part of my MrVideo reply because I was attempting to keep things "cool" here..and I thought You might savvy. Since you didn't -- I adore Rod Serling, (Pagan) Buddha, and Inner Awareness, and you're good at adjusting words together, like my Son, but you might want to consider People Beyond The Words more so (he's getting it).
"Thinking yourself adept at reading between the lines, you get to some conclusions just analysing my 'bolding' of names and decide to throw in some stuff just to fulfill your role of adulator." - You MIGHT want to be inside my mind and eternal energy a bit more before drawing those ideas together. You're a bit off base with me. Surprise!
Don't PM me unless you have something to reply with that is a bit more progressive or constructive.
Back to BD-RB, eh?
Old 23rd July 2018, 04:00   #27524  |  Link
Lathe
Lathe's Avatar
Don't PM me unless you have something to reply with that doesn't contradict your reply and is a bit more progressive or constructive.
Back to BD-RB, eh?
Groovy Baby...
Old 23rd July 2018, 06:42   #27525  |  Link
MrVideo
MrVideo's Avatar
MIN_M2TS_SIZE wasn't it. That won't stop it from re-encoding, it stops BDRB from using the file at all.
Back to the drawing board.
Old 23rd July 2018, 06:48   #27526  |  Link
AmigaFuture
Groovy Baby...
Swallloowwww it Deep, Lathe, babe......there you go. Heh...heh..
Old 23rd July 2018, 19:45   #27527  |  Link
worknstiff
Has anyone used BD_Rebuilder to process Rampage 3D? I can't seem to get FRIM to access the 00252.m2ts, as it hangs after extraction and encoding fails. If you look in the folder the 00252.m2ts is missing and the supposedly 35GB folder is only 2.9GB. I wonder if it's just my machine or AnyDVD or something else that's problematic with the file? I have tried ripping it on 3 different pc's using 3 different burners and all fail with the same file.
Old 23rd July 2018, 23:37   #27528  |  Link
Lathe
Lathe's Avatar
Hey Hey HEY! No talking dirty now...
Old 25th July 2018, 08:04   #27529  |  Link
AmigaFuture
Bad mastering? All 3 machines might have optics that require cleaning. I'm met people who have several machines and that was the case with all. But some people think because they have several machines that ONE should function and do the job. Well, if stuff IS dirty..hope and the none existent luck won't help.
Do you only use AnyDVD HD?
You and my girlfriend are depravity related.
@DJ
I noticed a bug with BD-RB, after repeating it a few times I'll post. It's related to creating MP4..
Old 25th July 2018, 13:29   #27530  |  Link
It's a brave man who admits this.
Old 25th July 2018, 14:12   #27531  |  Link
MrVideo
MrVideo's Avatar
@jdobbs:
Is there is hidden option in which to keep BDRB from recoding a video file that is under a particular size?
Old 25th July 2018, 14:28   #27532  |  Link
worknstiff
@ AmigaFuture, RE:Bad mastering? Well, if stuff IS dirty..hope and the none existent luck won't help.
No I don't think it is a "dirty" problem cause logic dictates that it would fail at either ripping it or burning it. I have made a BD50 that has the "complete" rip so I don't think it is a burner problem. And BD Rebuilder has no problems accessing and compressing other 3D movies, and even works when accessing other files on this rip but coughs up a hairball when FRIM wants this supposedly "extracted" 00252.m2ts file. I am leaning towards some anomaly that this file has that prevents either AnyDVD HD or BD Rebuilder from using it properly.
RE: I don't really use any other programs for 3D except AnyDVD and BD_Rebuilder.
Old 25th July 2018, 14:56   #27533  |  Link
Ch3vr0n
Then you should post a full processing log with any potential errors. Right now, all ya do is talk talk talk, but no log log log for jdobbs to work with and problem diagnose
Old 25th July 2018, 17:22   #27534  |  Link
@jdobbs:
MIN_M2TS_SIZE will do it, but only if there is other M2TS's as well. When you set it, it won't show on the list -- but will be copied intact.
Old 25th July 2018, 17:59   #27535  |  Link
AmigaFuture
Ancient Alien Episode MP4 out of sync.
Also confidence in more than only myself. She and I have read Abbott and Costello of gonca and Lathe pushing some boundaries that some online would be very bothered by. Personally, we enjoy great twisted banter as long as that's all it is. Lots of unsavory things happening in the world, as well as absolute beauty that you gotta poke fun at to keep a balance inside. [Some] relationships are worthy of great trust, too.
After a few tests..I can confirm that BD-RB (by way, MP4Box) has a sync problem. I'm able to import some TS/MKV files and Alternatively create MKV/MP4 and only MKV sync is fine. I've only done episodes from my TiVo files. More checking to go.
[07/25/18] BD Rebuilder v0.50.25
[08:48:11] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
  - Input BD size: 2.23 GB
  - Approximate total content: [01:23:34.192]
  - Windows Version: 6.1 [7601]
  - Mode: MP4, Intact Video, Intact Audio
  - Quality: Good (Very Fast)
[08:48:11] PHASE ONE, Encoding
 - [08:48:11] Processing: VID_00000 (1 of 1)
 - [08:48:11] Extracting A/V streams [VID_00000]
 - [08:49:05] Reencoding video [VID_00000]
 - [08:49:05] Keeping original video (no reencode)
 - [08:49:05] Processing audio tracks
[08:49:05]PHASE ONE complete
[08:49:05]PHASE TWO - Rebuild Started
 - [08:49:05] Building ALTERNATE OUTPUT Structure
[08:50:25] - Encode and Rebuild complete
[08:50:25] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
[08:50:34] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
  - Mode: MKV, Intact Video, Intact Audio
[08:50:35] PHASE ONE, Encoding
 - [08:50:35] Processing: VID_00000 (1 of 1)
 - [08:50:35] Extracting A/V streams [VID_00000]
 - [08:51:08] Reencoding video [VID_00000]
 - [08:51:08] Keeping original video (no reencode)
 - [08:51:08] Processing audio tracks
[08:51:08]PHASE ONE complete
[08:51:08]PHASE TWO - Rebuild Started
 - [08:51:08] Building ALTERNATE OUTPUT Structure
[08:52:13] - Encode and Rebuild complete
[08:52:13] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
[08:54:08] Importing MKV: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)
  - Preparing MKV for processing...
  - Collecting audio/video streams from source...
  - Building pseudo-BD source structure...
[08:55:20] Video import completed successfully.
[08:55:46] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
[08:55:47] PHASE ONE, Encoding
 - [08:55:47] Processing: VID_00000 (1 of 1)
 - [08:55:47] Extracting A/V streams [VID_00000]
 - [08:56:42] Reencoding video [VID_00000]
 - [08:56:42] Keeping original video (no reencode)
 - [08:56:42] Processing audio tracks
[08:56:42]PHASE ONE complete
[08:56:42]PHASE TWO - Rebuild Started
 - [08:56:42] Building ALTERNATE OUTPUT Structure
[08:58:01] - Encode and Rebuild complete
[08:58:01] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
[08:59:50] Importing TS: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)
  - Preparing TS for processing...
[09:01:44] Video import completed successfully.
[09:04:16] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
  - Decoding/Frame serving: DGDecNV [3-way]
[09:04:17] PHASE ONE, Encoding
 - [09:04:17] Processing: VID_00000 (1 of 1)
 - [09:04:17] Extracting A/V streams [VID_00000]
 - [09:05:13] Reencoding video [VID_00000]
 - [09:05:13] Keeping original video (no reencode)
 - [09:05:13] Processing audio tracks
[09:05:13]PHASE ONE complete
[09:05:13]PHASE TWO - Rebuild Started
 - [09:05:13] Building ALTERNATE OUTPUT Structure
[09:06:51] - Encode and Rebuild complete
[09:06:51] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
[09:08:37] Importing TS: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)
[09:10:36] Video import completed successfully.
[09:10:48] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
  - Decoding/Frame serving: DirectShow [3-way]
[09:10:49] PHASE ONE, Encoding
 - [09:10:49] Processing: VID_00000 (1 of 1)
 - [09:10:49] Extracting A/V streams [VID_00000]
 - [09:11:45] Reencoding video [VID_00000]
 - [09:11:45] Keeping original video (no reencode)
 - [09:11:45] Processing audio tracks
[09:11:45]PHASE ONE complete
[09:11:45]PHASE TWO - Rebuild Started
 - [09:11:45] Building ALTERNATE OUTPUT Structure
[09:12:54] - Encode and Rebuild complete
[09:12:54] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
[09:13:55] Importing MKV: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_02
[09:15:12] Video import completed successfully.
[09:15:25] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_02_00000
[09:15:26] PHASE ONE, Encoding
 - [09:15:26] Processing: VID_00000 (1 of 1)
 - [09:15:26] Extracting A/V streams [VID_00000]
 - [09:16:23] Reencoding video [VID_00000]
 - [09:16:23] Keeping original video (no reencode)
 - [09:16:23] Processing audio tracks
[09:16:23]PHASE ONE complete
[09:16:23]PHASE TWO - Rebuild Started
 - [09:16:23] Building ALTERNATE OUTPUT Structure
[09:17:42] - Encode and Rebuild complete
[09:17:42] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_02 finished.
[09:19:16] Importing TS: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)
[09:21:13] Video import completed successfully.
[09:21:27] Source:  ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W)_00000
[09:21:27] PHASE ONE, Encoding
 - [09:21:27] Processing: VID_00000 (1 of 1)
 - [09:21:27] Extracting A/V streams [VID_00000]
 - [09:22:18] Reencoding video [VID_00000]
 - [09:22:18] Keeping original video (no reencode)
 - [09:22:18] Processing audio tracks
[09:22:18]PHASE ONE complete
[09:22:18]PHASE TWO - Rebuild Started
 - [09:22:18] Building ALTERNATE OUTPUT Structure
[09:24:07] - Encode and Rebuild complete
[09:24:07] JOB: ANCIENT_ALIENS_-_S13_E07_-_''EARTH_STATION_EGYPT''_(HISTHD-W) finished.
Nothing out of the ordinary in logs.. Want the source?
Old 25th July 2018, 19:16   #27536  |  Link
Lathe
Lathe's Avatar
Old 25th July 2018, 21:16   #27537  |  Link
gonca
And Lathe is Costello
Old 25th July 2018, 21:56   #27538  |  Link
AmigaFuture
Never wondered.
Old 25th July 2018, 22:32   #27539  |  Link
gonca
Now he has to go upstairs from the basement and ask mom and dad "who is Abbott and Costello?"
He might be "googling it" as I type
Old 25th July 2018, 23:54   #27540  |  Link
Lathe
Lathe's Avatar
Heh...
