#28841 | Link |
![]() Join Date: Oct 2001
@FilipeAmadeuO and Acerjen
I found the issue you were describing. After a remux is done by TSMUXER, the MPLS's sequence table was updated with the new start/end presentation timestamps (PTS). It just so happens, though, that TSMUXER loses frames when it muxes UHD. I'd written code in BD-RB that corrects that issue by remuxing the video. The corrected length information was updated in a new CLPI (generated by BD-RB) but that information was never transferred to the MPLS. So individual M2TS playback times on UHD sources (specified in the MPLS) were off by the number of frames that were lost in the original TSMUXER process. I've fixed it for the next release, which will probably be posted sometime later today after I do some testing. Last edited by jdobbs; 30th September 2019 at 18:56. |
#28843 | Link | |
Just curious, any further thoughts on not remuxing streams that are not being touched? Could also ensure that streams don't see any regression due to issues with TSMuxer that you may not always foresee and compensate for! |
#28846 | Link |
BD Rebuilder v0.60.26
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.60.26). Changes for this release:
- Corrected an issue in which stopping an encode of a source that is being inverse telecined -- and then restarting without exiting could (on rare occasions) cause an incorrect framecount that truncates the the video output. - Added a new hidden option FORCE_MONO_RATE which allows the user to force the bitrate used for monophonic audio. - Corrected an error in which MPLS sequence end times could be incorrectly updated on UHD sources due to TSMUXER losing HEVC frames. This could cause stutter between M2TS files on multipart sources -- or early playback termination on singlepart sources. - Other minor corrections and cosmetic fixes. |
#28847 | Link | |
Jdobbs Can you please check the transition between chapter 7 and 8 on SOLO - STAR WARS STORY (UHD) of the rebuilded version ? Seems there is still a stuttering... Last edited by FilipeAmadeuO; 1st October 2019 at 22:43. |
#28850 | Link | |
I'm testing it on a standalone Sony UBP-X800 UHD-BD Player. Last edited by jdobbs; 1st October 2019 at 23:06. |
#28854 | Link | |
![]() Only in the "rebuilt" version (no change in video, audio neither subtitles) Last edited by FilipeAmadeuO; 2nd October 2019 at 18:28. |
#28856 | Link |
Guess there is such a word as rebuilded
https://www.dictionary.com/browse/rebuilded https://www.google.com/search?client...-d&q=rebuilded |
#28857 | Link |
I am still having playback problems with Solo: A Star Wars Story.
Same as before. It will hit the chapter points right at the transition from one M2TS file to the next and will pause and stay paused. I can chapter rewind and then chapter forward to the scene it just paused at and it will resume smooth playback till the next transition to the next M2TS file occurs and it stops and pauses again. On solo, once you get to chapter 9, the rest of the film is contained in a one large M2TS file, so no more pausing. And it does play all the way to the end of the credits like it is supposed to. I ran it through the newest version of BD Rebuilder on a new PC I built with a fresh installation of everything. If you have any ideas, please share. Attached are my logs and related files. Thanks. Later. Acerjen |
#28859 | Link | |
#28860 | Link | |
Edit: I am curious as to what player you have? It might be worth investing in one if more and more rebuilt discs have problems playing on the Xbox One X. Thanks. Last edited by Acerjen; 3rd October 2019 at 16:22. |
