21st February 2010, 03:31 | #6941 | Link | |
21st February 2010, 09:44 | #6943 | Link |
Just found a disc that I cannot make a bd-25 of, full movie backup, getting reading buffer overflow errors on some of the tracks, any suggestions on how to maybe change some settings to fix it?
Its the The Police - Certifiable, This is what I get in my log : [00:45:55] BD Rebuilder v0.31.06 (beta) - Source: TPC - Input BD size: 44,88 GB - Approximate total content: [02:57:32.475] - Target BD size: 23,24 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [00:45:55] PHASE ONE, Encoding - [00:45:55] Extracting A/V streams [VID_00000] - [00:59:29] Reencoding: VID_00000 (1 of 14) - [04:16:22] Extracting A/V streams [VID_00001] - [04:17:21] Reencoding: VID_00001 (2 of 14) - [04:36:12] Extracting A/V streams [VID_00002] - [04:37:09] Reencoding: VID_00002 (3 of 14) - [04:57:52] Extracting A/V streams [VID_00003] - [05:03:51] Reencoding: VID_00003 (4 of 14) - [06:48:42] Extracting A/V streams [VID_00004] - [06:49:31] Reencoding: VID_00004 (5 of 14) - [07:05:15] Extracting A/V streams [VID_00005] - [07:06:21] Reencoding: VID_00005 (6 of 14) - [07:24:13] Extracting A/V streams [VID_00006] - [07:28:29] Reencoding: VID_00006 (7 of 14) - [08:39:10] Extracting A/V streams [VID_00007] - Extracting video streams [VID_00007] - Extracting audio streams [VID_00007] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\TPC\BDMV\STREAM\00007.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: D:\TPC\BDMV\STREAM\00007.m2ts [08:52:04] - Failed to retrieve audio, aborted Thanks for this really cool tool jdobbs! |
21st February 2010, 11:51 | #6944 | Link | |
BTW, I re-started the encode job several times last night and told BD-RB to resume the job. After a couple of aborted runs, VID_00015 went through all of a sudden and the job resumed normally - until VID_00033 which was another 1080i/AVC/25fps title. I'll install the newer FFDShow and we'll see if that helps any. Code:
----------------------- [00:25:59] BD Rebuilder v0.31.08 (beta) - Source: (BD38)_IN_THE_LOOP - Input BD size: 37,81 GB - Approximate total content: [03:20:05.058] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [00:26:00] PHASE ONE, Encoding - [00:26:00] Reencoding: VID_00015 (16 of 24) - [00:26:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 40*493 frames - Bitrate: 13*309 Kbs - [00:26:00] Reencoding: VID_00015, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - [00:47:36] Reencoding: VID_00015, Pass 2 of 2 - [02:35:14] Video Encode complete - [02:35:14] Reencoding audio tracks (if req'd) - [02:35:14] Multiplexing M2TS - [02:37:04] Extracting A/V streams [VID_00029] - [02:37:07] Reencoding: VID_00029 (17 of 24) - [02:37:07] Collecting video information - Source Video: MPEG-2, 720x576 - Rate/Length: 25,000fps, 3*525 frames - Bitrate: 3*425 Kbs - [02:37:07] Reencoding: VID_00029, Pass 1 of 2 - [02:37:28] Reencoding: VID_00029, Pass 2 of 2 - [02:38:43] Video Encode complete - [02:38:43] Reencoding audio tracks (if req'd) - [02:38:43] Multiplexing M2TS - [02:38:46] Extracting A/V streams [VID_00030] - [02:38:46] Reencoding: VID_00030 (18 of 24) - [02:38:46] Collecting video information - Source Video: MPEG-2, 720x576 - Rate/Length: 25,000fps, 106 frames - Bitrate: 2*204 Kbs - [02:38:46] Reencoding: VID_00030, Pass 1 of 2 - [02:38:47] Reencoding: VID_00030, Pass 2 of 2 - [02:38:50] Video Encode complete - [02:38:50] Reencoding audio tracks (if req'd) - [02:38:50] Multiplexing M2TS - [02:38:50] Extracting A/V streams [VID_00031] - [02:38:51] Reencoding: VID_00031 (19 of 24) - [02:38:51] Collecting video information - Source Video: MPEG-2, 720x576 - Rate/Length: 25,000fps, 25 frames - [02:38:51] Reencoding: VID_00031, Pass 1 of 1 - [02:38:51] Video Encode complete - [02:38:51] Reencoding audio tracks (if req'd) - [02:38:51] Multiplexing M2TS - [02:38:51] Extracting A/V streams [VID_00033] - [02:39:10] Reencoding: VID_00033 (20 of 24) - [02:39:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 12*627 frames - Bitrate: 7*746 Kbs - [02:39:10] Reencoding: VID_00033, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3111) [12:34:45] - Failed video encode, aborted ----------------------- [12:34:53] BD Rebuilder v0.31.08 (beta) - Source: (BD38)_IN_THE_LOOP - Input BD size: 37,81 GB - Approximate total content: [03:20:05.058] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [12:34:55] PHASE ONE, Encoding - [12:34:55] Reencoding: VID_00033 (20 of 24) - [12:34:55] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 12*627 frames - Bitrate: 7*746 Kbs - [12:34:55] Reencoding: VID_00033, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3111) [12:35:08] - Failed video encode, aborted ----------------------- [12:35:52] BD Rebuilder v0.31.08 (beta) - Source: (BD38)_IN_THE_LOOP - Input BD size: 37,81 GB - Approximate total content: [03:20:05.058] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [12:35:54] PHASE ONE, Encoding - [12:35:54] Reencoding: VID_00033 (20 of 24) - [12:35:54] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 25,000fps, 12*627 frames - Bitrate: 7*746 Kbs - [12:35:54] Reencoding: VID_00033, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3111) [12:36:13] - Failed video encode, aborted Oops, spoke too soon. Pass 2 at 3.70%, and something went kablooie. x264.exe is taking a gig of memory but CPU usage is 0%. I killed the x264 process manually and the job is now resuming. I think I'll start the entire job from scratch. Last edited by colinhunt; 21st February 2010 at 12:15. |
21st February 2010, 14:28 | #6946 | Link | |
21st February 2010, 19:15 | #6947 | Link |
BD Rebuilder v0.32.01 (beta)
I've updated the first post of this thread with a link to a new release of BD-RB (v0.32.01). The changes included in this release are:
- Added an option to modify the audio stream that is to be considered "default" for movie-only backups. Normally that would be the first stream kept. Now you can right click on any "kept" audio stream in the streams list and select it as the default audio. - Corrected an error in which the "FORCE_NEW_CHAPTERS" option could result in incorrect output for BD-5/9 movie-only encodes. - Added code to append ExtensionData() information to AVCHD output (BD-5/9) movie-only encodes. This will provide a greater compatibility of the movie-only format across different player types/brands. Many thanks to DeanK for his helpful insight into AVCHD formats. - Updated the included version of X264.EXE to the latest release (r1442 w/nal-hrd patch). - Other minor corrections and cosmetic fixes. |
21st February 2010, 20:03 | #6948 | Link |
@DK and others who have had issues with movie-only AVCHD (BD-5/9) on their players
If you could, please try the new version with your movie-only encodes. I think it should work without any adjustment on most players now. I'd appreciate any feedback. Last edited by jdobbs; 21st February 2010 at 20:05. |
21st February 2010, 21:08 | #6949 | Link |
BD Rebuilder v0.32.02 (beta)
I've updated the first post of this thread with a link to a new version of BD-RB (v0.32.02). Changes for this version:
- Corrected an "off-by-one" error in movie-only MPLS file's ExtensionData() structure for AVCHD discs created with v0.32.01 - Other minor corrections and cosmetic fixes. |
21st February 2010, 21:18 | #6950 | Link | |
my last "problem" was FULL movie burned to DVD-DL, which did not work until i had multiavchd rewrite the rb output of course i will report back as soon as i will have used this latest release for the first time no matter what the result may be or would the latest version perhaps create slightly different material with FULL movie for BD9 so i should repeat the conversion which did not work last time? thanx for all your effort! Last edited by DK; 21st February 2010 at 21:21. |
21st February 2010, 21:29 | #6951 | Link | |
I guess I misunderstood at least to some degree. I'd thought there were issues with movie-only on some (Panasonic/Samsung?) players. If you could keep that (full backup) disc handy, I'll PM you with a link to a test copy as soon as I think I have it ready. Last edited by jdobbs; 21st February 2010 at 21:41. |
21st February 2010, 21:42 | #6952 | Link | |
Anyhoo, I rebooted the box, deleted temp files and started over. It's currently doing pass 2 of VID_00015. No problems yet. Update: job finished without errors. Last edited by colinhunt; 21st February 2010 at 23:42. |
21st February 2010, 22:58 | #6953 | Link |
Hmm didnt have any issues with movie only mode to bd25 for some time now, but I Robot is giving me some errors again.. didnt change anything to my setup.. anyone else having problems with this disc?
[14:09:52] BD Rebuilder v0.31.06 (beta) - Source: IROBOT - Input BD size: 27,05 GB - Approximate total content: [01:54:44.252] - Target BD size: 23,24 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [14:09:52] PHASE ONE, Encoding - [14:09:52] Extracting A/V streams [VID_00001] - [14:17:42] Reencoding: VID_00001 (1 of 2) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3130) [14:20:45] - Failed video encode, aborted |
21st February 2010, 23:05 | #6954 | Link | |
21st February 2010, 23:27 | #6955 | Link | |
dts with bd9 will not be played by this Samsung (on BD-RE it runs fine however) BD25 with movie only or full movie never failed i'll be glad to test/help |
21st February 2010, 23:41 | #6956 | Link | |
I would think also that any disc that uses java (has JAR files) can't be converted (as a full-backup) at all to BD-9 and used on the Samsung (even if it is run through multiAVCHD). Can you confirm that? Last edited by jdobbs; 21st February 2010 at 23:44. |
21st February 2010, 23:58 | #6957 | Link | |
i have never - with one exception - tried a full movie backup on bd5/9 but i will run a test to bd5 with fastest settings now, which i can burn to a dvd-rw and let you know |
22nd February 2010, 05:59 | #6959 | Link |
is this normal behaviour?
Hello, I was trying to rebuild Surrogates
made a custom size of 26000 to avoid reencoding the main movie, just removed an audio. Full disk Backup, Quicker encode on extras it reencoded all but the main movie, came to a 98% BD-RE size, which was fine. I then tried to rebuild without Quicker encode for extras with all of the same settings and now it is trying to re-encode the main movie, when Quicker encode for extras is not setected, does it gives bigger files and that is why it's re-encoding the movie? Thanks |
22nd February 2010, 10:39 | #6960 | Link | |
----------------------- [18:57:56] BD Rebuilder v0.32.02 (beta) - Source: TRANSFORMERS_D1_EU - Input BD size: 42.95 GB - Approximate total content: [02:24:17.398] - Target BD size: 22.66 GB - Windows Version: 6.0 [6002] - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [18:57:58] PHASE ONE, Encoding - [18:57:58] Extracting A/V streams [VID_00013] - [18:58:06] Reencoding: VID_00013 (1 of 2) - [18:58:06] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,201 frames - [18:58:06] Reencoding: VID_00013, Pass 1 of 1 - [18:58:52] Video Encode complete - [18:58:52] Reencoding audio tracks (if req'd) - [18:58:52] Multiplexing M2TS - [18:58:53] Extracting A/V streams [VID_00010] - [19:33:33] Reencoding: VID_00010 (2 of 2) - [19:33:33] Reencoding secondary video [TRK_02] - [19:46:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 206,369 frames - Bitrate: 15,292 Kbs - [19:46:07] Reencoding: VID_00010, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) [19:46:30] - Failed video encode, aborted |
