5th May 2010, 19:11 | #8101 | Link |
Both working m2ts + clpi and mpls files were replaced in the original folder. So I don't compare apples and oranges. Maybe I didn't explained myself corectly. I also re-authored a seamless branched disc ( theatrical and extended version ) for tests purposes only and kept both versions including original structure and after that I ran it through BD-RB to make it BD5 and worked like a charm ( menus, extras, playthrough ). That's why I am almost certain that those ATC entries are not the real issue. BUT, MAYBE, for some players ATC entries do matter. I can't test every player from Earth.
In other order, you are doing a fine job with BD-RB, I'm a fan of DVD Rebuilder since it was released and I have it with license. Now I'm a fan of BD-RB too. |
5th May 2010, 21:28 | #8105 | Link |
Or even better, buy a real player like the Sony BDP-S360 (about $100) instead of a game that pretends to be a player. Hey Jdobbs what about the Sony BDP-S460 would it play BD5/BD9 full backups. I have an eye on it in the web for only $149. Or any one have this player and are succesfull with full BD5/BD9 backups. thanks. |
5th May 2010, 23:49 | #8106 | Link | |
6th May 2010, 09:16 | #8108 | Link |
Lots of thanks jdobbs for this really nice program working perfectly without any problems for me. Just one (maybe silly) question… Why while most of the commercial Blu-rays have a RefFrame of 4 images do BD-Rebuilder only use 3 images? It seems (if I’m not wrong) that 3 is the default value in x264, but why if from what I’ve seen in commercial Blu-rays the “default” value is 4? This question comes from a newbie without any technical knowledge of what under video compression algorithms, so maybe going from 3 to 4 RefFrames will increase a lot encoding time and the image quality gained isn’t worth it… Greetings EDIT: As it seems jdobbs still hasn't read this post, I'll add that selecting Highest (Very Slow) setting doesn't change ref to 5 (as it should do?) and that adding this two lines to bdrebuilder.ini doesn't work either: TWEAK_PASS_ONE=--ref 5 TWEAK_PASS_TWO=--ref 5 Last edited by chompy; 7th May 2010 at 15:26. |
6th May 2010, 13:10 | #8109 | Link |
BD REbuilder give to me an Error Condition: Code:
----------------------- [21:55:17] BD Rebuilder v0.33.06 (beta) - Source: FAME_2009 - Input BD size: 46,38 GB - Approximate total content: [03:31:22.369] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [21:55:17] PHASE ONE, Encoding - [21:55:17] Extracting A/V streams [VID_00477] - [21:55:19] Reencoding: VID_00477 (1 of 79) - [21:55:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 120 frames - [21:55:19] Reencoding: VID_00477, Pass 1 of 1 - [21:55:21] Video Encode complete - [21:55:21] Reencoding audio tracks (if req'd) - [21:55:21] Multiplexing M2TS - [21:55:22] Extracting A/V streams [VID_00478] - [21:55:22] Reencoding: VID_00478 (2 of 79) - [21:55:22] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 120 frames - [21:55:22] Reencoding: VID_00478, Pass 1 of 1 - [21:55:25] Video Encode complete - [21:55:25] Reencoding audio tracks (if req'd) - [21:55:25] Multiplexing M2TS - [21:55:25] Extracting A/V streams [VID_00369] - [21:55:28] Reencoding: VID_00369 (3 of 79) - [21:55:28] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 969 frames - [21:55:28] Reencoding: VID_00369, Pass 1 of 1 - [21:55:47] Video Encode complete - [21:55:47] Reencoding audio tracks (if req'd) - [21:55:47] Multiplexing M2TS - [21:55:49] Extracting A/V streams [VID_00386] - [21:55:52] Reencoding: VID_00386 (4 of 79) - [21:55:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*031 frames - [21:55:52] Reencoding: VID_00386, Pass 1 of 1 - [21:56:12] Video Encode complete - [21:56:12] Reencoding audio tracks (if req'd) - [21:56:12] Multiplexing M2TS - [21:56:14] Extracting A/V streams [VID_00377] - [21:56:17] Reencoding: VID_00377 (5 of 79) - [21:56:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*054 frames - [21:56:17] Reencoding: VID_00377, Pass 1 of 1 - [21:56:38] Video Encode complete - [21:56:38] Reencoding audio tracks (if req'd) - [21:56:38] Multiplexing M2TS - [21:56:39] Extracting A/V streams [VID_00361] - [21:56:42] Reencoding: VID_00361 (6 of 79) - [21:56:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*179 frames - [21:56:42] Reencoding: VID_00361, Pass 1 of 1 - [21:57:06] Video Encode complete - [21:57:06] Reencoding audio tracks (if req'd) - [21:57:06] Multiplexing M2TS - [21:57:08] Extracting A/V streams [VID_00373] - [21:57:11] Reencoding: VID_00373 (7 of 79) - [21:57:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*277 frames - [21:57:11] Reencoding: VID_00373, Pass 1 of 1 - [21:57:37] Video Encode complete - [21:57:37] Reencoding audio tracks (if req'd) - [21:57:37] Multiplexing M2TS - [21:57:39] Extracting A/V streams [VID_00363] - [21:57:42] Reencoding: VID_00363 (8 of 79) - [21:57:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*295 frames - [21:57:42] Reencoding: VID_00363, Pass 1 of 1 - [21:58:08] Video Encode complete - [21:58:08] Reencoding audio tracks (if req'd) - [21:58:08] Multiplexing M2TS - [21:58:09] Extracting A/V streams [VID_00383] - [21:58:13] Reencoding: VID_00383 (9 of 79) - [21:58:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*322 frames - [21:58:13] Reencoding: VID_00383, Pass 1 of 1 - [21:58:40] Video Encode complete - [21:58:40] Reencoding audio tracks (if req'd) - [21:58:40] Multiplexing M2TS - [21:58:42] Extracting A/V streams [VID_00364] - [21:58:46] Reencoding: VID_00364 (10 of 79) - [21:58:46] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*413 frames - [21:58:46] Reencoding: VID_00364, Pass 1 of 1 - [21:59:16] Video Encode complete - [21:59:16] Reencoding audio tracks (if req'd) - [21:59:16] Multiplexing M2TS - [21:59:18] Extracting A/V streams [VID_00385] - [21:59:21] Reencoding: VID_00385 (11 of 79) - [21:59:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*418 frames - [21:59:21] Reencoding: VID_00385, Pass 1 of 1 - [21:59:51] Video Encode complete - [21:59:51] Reencoding audio tracks (if req'd) - [21:59:51] Multiplexing M2TS - [21:59:53] Extracting A/V streams [VID_00403] - [21:59:57] Reencoding: VID_00403 (12 of 79) - [21:59:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*535 frames - [21:59:57] Reencoding: VID_00403, Pass 1 of 1 - [22:00:27] Video Encode complete - [22:00:27] Reencoding audio tracks (if req'd) - [22:00:27] Multiplexing M2TS - [22:00:28] Extracting A/V streams [VID_00381] - [22:00:33] Reencoding: VID_00381 (13 of 79) - [22:00:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*549 frames - [22:00:33] Reencoding: VID_00381, Pass 1 of 1 - [22:01:02] Video Encode complete - [22:01:03] Reencoding audio tracks (if req'd) - [22:01:03] Multiplexing M2TS - [22:01:04] Extracting A/V streams [VID_00362] - [22:01:08] Reencoding: VID_00362 (14 of 79) - [22:01:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*694 frames - [22:01:08] Reencoding: VID_00362, Pass 1 of 1 - [22:01:43] Video Encode complete - [22:01:43] Reencoding audio tracks (if req'd) - [22:01:43] Multiplexing M2TS - [22:01:45] Extracting A/V streams [VID_00384] - [22:01:50] Reencoding: VID_00384 (15 of 79) - [22:01:50] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*867 frames - [22:01:50] Reencoding: VID_00384, Pass 1 of 1 - [22:02:28] Video Encode complete - [22:02:28] Reencoding audio tracks (if req'd) - [22:02:28] Multiplexing M2TS - [22:02:30] Extracting A/V streams [VID_00342] - [22:02:35] Reencoding: VID_00342 (16 of 79) - [22:02:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*102 frames - [22:02:35] Reencoding: VID_00342, Pass 1 of 1 - [22:03:00] Video Encode complete - [22:03:00] Reencoding audio tracks (if req'd) - [22:03:02] Multiplexing M2TS - [22:03:04] Extracting A/V streams [VID_00336] - [22:03:09] Reencoding: VID_00336 (17 of 79) - [22:03:09] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*158 frames - [22:03:09] Reencoding: VID_00336, Pass 1 of 1 - [22:03:39] Video Encode complete - [22:03:39] Reencoding audio tracks (if req'd) - [22:03:42] Multiplexing M2TS - [22:03:44] Extracting A/V streams [VID_00330] - [22:03:49] Reencoding: VID_00330 (18 of 79) - [22:03:49] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*186 frames - [22:03:49] Reencoding: VID_00330, Pass 1 of 1 - [22:04:17] Video Encode complete - [22:04:17] Reencoding audio tracks (if req'd) - [22:04:19] Multiplexing M2TS - [22:04:21] Extracting A/V streams [VID_00392] - [22:04:27] Reencoding: VID_00392 (19 of 79) - [22:04:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*517 frames - [22:04:27] Reencoding: VID_00392, Pass 1 of 1 - [22:05:38] Video Encode complete - [22:05:38] Reencoding audio tracks (if req'd) - [22:05:38] Multiplexing M2TS - [22:05:40] Extracting A/V streams [VID_00337] - [22:05:45] Reencoding: VID_00337 (20 of 79) - [22:05:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*358 frames - Bitrate: 13*968 Kbs - [22:05:45] Reencoding: VID_00337, Pass 1 of 1 - [22:06:29] Video Encode complete - [22:06:29] Reencoding audio tracks (if req'd) - [22:06:32] Multiplexing M2TS - [22:06:34] Extracting A/V streams [VID_00398] - [22:06:41] Reencoding: VID_00398 (21 of 79) - [22:06:41] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*625 frames - [22:06:41] Reencoding: VID_00398, Pass 1 of 1 - [22:07:48] Video Encode complete - [22:07:48] Reencoding audio tracks (if req'd) - [22:07:48] Multiplexing M2TS - [22:07:50] Extracting A/V streams [VID_00382] - [22:07:56] Reencoding: VID_00382 (22 of 79) - [22:07:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2*508 frames - [22:07:56] Reencoding: VID_00382, Pass 1 of 1 - [22:08:47] Video Encode complete - [22:08:47] Reencoding audio tracks (if req'd) - [22:08:47] Multiplexing M2TS - [22:08:50] Extracting A/V streams [VID_00393] - [22:08:57] Reencoding: VID_00393 (23 of 79) - [22:08:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*692 frames - [22:08:57] Reencoding: VID_00393, Pass 1 of 1 - [22:10:05] Video Encode complete - [22:10:05] Reencoding audio tracks (if req'd) - [22:10:05] Multiplexing M2TS - [22:10:07] Extracting A/V streams [VID_00400] - [22:10:14] Reencoding: VID_00400 (24 of 79) - [22:10:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*715 frames - [22:10:14] Reencoding: VID_00400, Pass 1 of 1 - [22:11:27] Video Encode complete - [22:11:27] Reencoding audio tracks (if req'd) - [22:11:27] Multiplexing M2TS - [22:11:29] Extracting A/V streams [VID_00394] - [22:11:37] Reencoding: VID_00394 (25 of 79) - [22:11:37] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*738 frames - [22:11:37] Reencoding: VID_00394, Pass 1 of 1 - [22:12:50] Video Encode complete - [22:12:50] Reencoding audio tracks (if req'd) - [22:12:50] Multiplexing M2TS - [22:12:53] Extracting A/V streams [VID_00399] - [22:13:00] Reencoding: VID_00399 (26 of 79) - [22:13:00] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*750 frames - [22:13:00] Reencoding: VID_00399, Pass 1 of 1 - [22:14:15] Video Encode complete - [22:14:15] Reencoding audio tracks (if req'd) - [22:14:15] Multiplexing M2TS - [22:14:17] Extracting A/V streams [VID_00395] - [22:14:25] Reencoding: VID_00395 (27 of 79) - [22:14:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*894 frames - [22:14:25] Reencoding: VID_00395, Pass 1 of 1 - [22:15:48] Video Encode complete - [22:15:48] Reencoding audio tracks (if req'd) - [22:15:48] Multiplexing M2TS - [22:15:51] Extracting A/V streams [VID_00396] - [22:15:58] Reencoding: VID_00396 (28 of 79) - [22:15:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 2*898 frames - [22:15:58] Reencoding: VID_00396, Pass 1 of 1 - [22:17:19] Video Encode complete - [22:17:19] Reencoding audio tracks (if req'd) - [22:17:19] Multiplexing M2TS - [22:17:22] Extracting A/V streams [VID_00370] - [22:17:29] Reencoding: VID_00370 (29 of 79) - [22:17:29] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*747 frames - [22:17:29] Reencoding: VID_00370, Pass 1 of 1 - [22:18:10] Video Encode complete - [22:18:10] Reencoding audio tracks (if req'd) - [22:18:13] Multiplexing M2TS - [22:18:16] Extracting A/V streams [VID_00397] - [22:18:23] Reencoding: VID_00397 (30 of 79) - [22:18:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 3*021 frames - [22:18:23] Reencoding: VID_00397, Pass 1 of 1 - [22:19:49] Video Encode complete - [22:19:49] Reencoding audio tracks (if req'd) - [22:19:49] Multiplexing M2TS - [22:19:53] Extracting A/V streams [VID_00390] - [22:20:01] Reencoding: VID_00390 (31 of 79) - [22:20:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 3*054 frames - [22:20:01] Reencoding: VID_00390, Pass 1 of 1 - [22:21:23] Video Encode complete - [22:21:23] Reencoding audio tracks (if req'd) - [22:21:23] Multiplexing M2TS - [22:21:26] Extracting A/V streams [VID_00391] - [22:21:34] Reencoding: VID_00391 (32 of 79) - [22:21:34] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 3*104 frames - [22:21:34] Reencoding: VID_00391, Pass 1 of 1 - [22:23:02] Video Encode complete - [22:23:02] Reencoding audio tracks (if req'd) - [22:23:02] Multiplexing M2TS - [22:23:05] Extracting A/V streams [VID_00355] - [22:23:12] Reencoding: VID_00355 (33 of 79) - [22:23:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*718 frames - [22:23:12] Reencoding: VID_00355, Pass 1 of 1 - [22:23:53] Video Encode complete - [22:23:53] Reencoding audio tracks (if req'd) - [22:23:56] Multiplexing M2TS - [22:23:58] Extracting A/V streams [VID_00343] - [22:24:06] Reencoding: VID_00343 (34 of 79) - [22:24:06] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1*679 frames - Bitrate: 14*327 Kbs - [22:24:06] Reencoding: VID_00343, Pass 1 of 1 - [22:25:03] Video Encode complete - [22:25:03] Reencoding audio tracks (if req'd) - [22:25:06] Multiplexing M2TS - [22:25:09] Extracting A/V streams [VID_00348] - [22:25:17] Reencoding: VID_00348 (35 of 79) LOG PART 1/3
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 6th May 2010 at 13:13. |
6th May 2010, 13:11 | #8110 | Link |
log part 2/3
- [22:25:17] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1 728 frames - [22:25:17] Reencoding: VID_00348, Pass 1 of 1 - [22:26:03] Video Encode complete - [22:26:03] Reencoding audio tracks (if req'd) - [22:26:07] Multiplexing M2TS - [22:26:10] Extracting A/V streams [VID_00319] - [22:26:18] Reencoding: VID_00319 (36 of 79) - [22:26:18] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 141 frames - [22:26:18] Reencoding: VID_00319, Pass 1 of 1 - [22:27:21] Video Encode complete - [22:27:21] Reencoding audio tracks (if req'd) - [22:27:21] Multiplexing M2TS - [22:27:24] Extracting A/V streams [VID_00378] - [22:27:32] Reencoding: VID_00378 (37 of 79) - [22:27:32] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1 815 frames - [22:27:32] Reencoding: VID_00378, Pass 1 of 1 - [22:28:12] Video Encode complete - [22:28:12] Reencoding audio tracks (if req'd) - [22:28:15] Multiplexing M2TS - [22:28:17] Extracting A/V streams [VID_00387] - [22:28:26] Reencoding: VID_00387 (38 of 79) - [22:28:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 295 frames - [22:28:26] Reencoding: VID_00387, Pass 1 of 1 - [22:29:35] Video Encode complete - [22:29:35] Reencoding audio tracks (if req'd) - [22:29:35] Multiplexing M2TS - [22:29:38] Extracting A/V streams [VID_00404] - [22:29:47] Reencoding: VID_00404 (39 of 79) - [22:29:47] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 291 frames - [22:29:47] Reencoding: VID_00404, Pass 1 of 1 - [22:30:54] Video Encode complete - [22:30:54] Reencoding audio tracks (if req'd) - [22:30:54] Multiplexing M2TS - [22:30:59] Extracting A/V streams [VID_00332] - [22:31:11] Reencoding: VID_00332 (40 of 79) - [22:31:11] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1 832 frames - Bitrate: 14 432 Kbs - [22:31:11] Reencoding: VID_00332, Pass 1 of 1 - [22:32:19] Video Encode complete - [22:32:19] Reencoding audio tracks (if req'd) - [22:32:23] Multiplexing M2TS - [22:32:26] Extracting A/V streams [VID_00405] - [22:32:35] Reencoding: VID_00405 (41 of 79) - [22:32:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 448 frames - [22:32:35] Reencoding: VID_00405, Pass 1 of 1 - [22:33:53] Video Encode complete - [22:33:53] Reencoding audio tracks (if req'd) - [22:33:53] Multiplexing M2TS - [22:33:57] Extracting A/V streams [VID_00331] - [22:34:06] Reencoding: VID_00331 (42 of 79) - [22:34:06] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1 898 frames - Bitrate: 14 009 Kbs - [22:34:06] Reencoding: VID_00331, Pass 1 of 1 - [22:35:13] Video Encode complete - [22:35:13] Reencoding audio tracks (if req'd) - [22:35:16] Multiplexing M2TS - [22:35:19] Extracting A/V streams [VID_00365] - [22:35:29] Reencoding: VID_00365 (43 of 79) - [22:35:29] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4 056 frames - [22:35:29] Reencoding: VID_00365, Pass 1 of 1 - [22:36:51] Video Encode complete - [22:36:51] Reencoding audio tracks (if req'd) - [22:36:51] Multiplexing M2TS - [22:36:55] Extracting A/V streams [VID_00350] - [22:37:04] Reencoding: VID_00350 (44 of 79) - [22:37:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 223 frames - Bitrate: 14 151 Kbs - [22:37:04] Reencoding: VID_00350, Pass 1 of 1 - [22:38:23] Video Encode complete - [22:38:23] Reencoding audio tracks (if req'd) - [22:38:27] Multiplexing M2TS - [22:38:30] Extracting A/V streams [VID_00357] - [22:38:39] Reencoding: VID_00357 (45 of 79) - [22:38:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 349 frames - Bitrate: 13 670 Kbs - [22:38:40] Reencoding: VID_00357, Pass 1 of 1 - [22:39:56] Video Encode complete - [22:39:56] Reencoding audio tracks (if req'd) - [22:40:00] Multiplexing M2TS - [22:40:03] Extracting A/V streams [VID_00358] - [22:40:13] Reencoding: VID_00358 (46 of 79) - [22:40:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 287 frames - [22:40:13] Reencoding: VID_00358, Pass 1 of 1 - [22:41:05] Video Encode complete - [22:41:05] Reencoding audio tracks (if req'd) - [22:41:09] Multiplexing M2TS - [22:41:11] Extracting A/V streams [VID_00402] - [22:41:22] Reencoding: VID_00402 (47 of 79) - [22:41:22] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 12 358 frames - [22:41:22] Reencoding: VID_00402, Pass 1 of 1 - [22:42:14] Video Encode complete - [22:42:14] Reencoding audio tracks (if req'd) - [22:42:14] Multiplexing M2TS - [22:42:17] Extracting A/V streams [VID_00352] - [22:42:27] Reencoding: VID_00352 (48 of 79) - [22:42:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 436 frames - [22:42:27] Reencoding: VID_00352, Pass 1 of 1 - [22:43:25] Video Encode complete - [22:43:25] Reencoding audio tracks (if req'd) - [22:43:30] Multiplexing M2TS - [22:43:32] Extracting A/V streams [VID_00347] - [22:43:43] Reencoding: VID_00347 (49 of 79) - [22:43:43] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 845 frames - Bitrate: 13 043 Kbs - [22:43:43] Reencoding: VID_00347, Pass 1 of 1 - [22:45:23] Video Encode complete - [22:45:23] Reencoding audio tracks (if req'd) - [22:45:28] Multiplexing M2TS - [22:45:32] Extracting A/V streams [VID_00360] - [22:45:44] Reencoding: VID_00360 (50 of 79) - [22:45:44] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2 750 frames - Bitrate: 13 770 Kbs - [22:45:44] Reencoding: VID_00360, Pass 1 of 1 - [22:47:22] Video Encode complete - [22:47:22] Reencoding audio tracks (if req'd) - [22:47:27] Multiplexing M2TS - [22:47:31] Extracting A/V streams [VID_00389] - [22:47:45] Reencoding: VID_00389 (51 of 79) - [22:47:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5 026 frames - [22:47:45] Reencoding: VID_00389, Pass 1 of 1 - [22:49:57] Video Encode complete - [22:49:57] Reencoding audio tracks (if req'd) - [22:49:58] Multiplexing M2TS - [22:50:05] Extracting A/V streams [VID_00353] - [22:50:19] Reencoding: VID_00353 (52 of 79) - [22:50:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 166 frames - Bitrate: 13 921 Kbs - [22:50:19] Reencoding: VID_00353, Pass 1 of 1 - [22:52:10] Video Encode complete - [22:52:10] Reencoding audio tracks (if req'd) - [22:52:15] Multiplexing M2TS - [22:52:20] Extracting A/V streams [VID_00366] - [22:52:35] Reencoding: VID_00366 (53 of 79) - [22:52:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 536 frames - [22:52:35] Reencoding: VID_00366, Pass 1 of 1 - [22:54:00] Video Encode complete - [22:54:00] Reencoding audio tracks (if req'd) - [22:54:07] Multiplexing M2TS - [22:54:10] Extracting A/V streams [VID_00359] - [22:54:26] Reencoding: VID_00359 (54 of 79) - [22:54:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 460 frames - Bitrate: 14 570 Kbs - [22:54:26] Reencoding: VID_00359, Pass 1 of 1 - [22:56:31] Video Encode complete - [22:56:31] Reencoding audio tracks (if req'd) - [22:56:37] Multiplexing M2TS - [22:56:42] Extracting A/V streams [VID_00374] - [22:57:01] Reencoding: VID_00374 (55 of 79) - [22:57:01] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 941 frames - Bitrate: 13 326 Kbs - [22:57:01] Reencoding: VID_00374, Pass 1 of 1 - [22:59:15] Video Encode complete - [22:59:15] Reencoding audio tracks (if req'd) - [22:59:22] Multiplexing M2TS - [22:59:27] Extracting A/V streams [VID_00379] - [22:59:45] Reencoding: VID_00379 (56 of 79) - [22:59:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 821 frames - Bitrate: 13 930 Kbs - [22:59:45] Reencoding: VID_00379, Pass 1 of 1 - [23:01:51] Video Encode complete - [23:01:51] Reencoding audio tracks (if req'd) - [23:01:58] Multiplexing M2TS - [23:02:03] Extracting A/V streams [VID_00341] - [23:02:22] Reencoding: VID_00341 (57 of 79) - [23:02:22] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 842 frames - Bitrate: 14 338 Kbs - [23:02:22] Reencoding: VID_00341, Pass 1 of 1 - [23:04:33] Video Encode complete - [23:04:33] Reencoding audio tracks (if req'd) - [23:04:40] Multiplexing M2TS - [23:04:45] Extracting A/V streams [VID_00356] - [23:05:04] Reencoding: VID_00356 (58 of 79) - [23:05:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3 910 frames - Bitrate: 14 160 Kbs - [23:05:04] Reencoding: VID_00356, Pass 1 of 1 - [23:07:15] Video Encode complete - [23:07:15] Reencoding audio tracks (if req'd) - [23:07:22] Multiplexing M2TS - [23:07:27] Extracting A/V streams [VID_00375] - [23:07:48] Reencoding: VID_00375 (59 of 79) - [23:07:48] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4 241 frames - Bitrate: 14 101 Kbs - [23:07:48] Reencoding: VID_00375, Pass 1 of 1 - [23:10:06] Video Encode complete - [23:10:06] Reencoding audio tracks (if req'd) - [23:10:13] Multiplexing M2TS - [23:10:19] Extracting A/V streams [VID_00345] - [23:10:39] Reencoding: VID_00345 (60 of 79) - [23:10:39] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 4 217 frames - [23:10:39] Reencoding: VID_00345, Pass 1 of 1 - [23:12:14] Video Encode complete - [23:12:14] Reencoding audio tracks (if req'd) - [23:12:21] Multiplexing M2TS - [23:12:25] Extracting A/V streams [VID_00401] - [23:12:52] Reencoding: VID_00401 (61 of 79) - [23:12:53] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9 815 frames - [23:12:53] Reencoding: VID_00401, Pass 1 of 1 - [23:16:43] Video Encode complete - [23:16:43] Reencoding audio tracks (if req'd) - [23:16:43] Multiplexing M2TS - [23:16:50] Extracting A/V streams [VID_00367] - [23:17:15] Reencoding: VID_00367 (62 of 79) - [23:17:15] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5 462 frames - Bitrate: 14 559 Kbs - [23:17:15] Reencoding: VID_00367, Pass 1 of 1 - [23:20:18] Video Encode complete - [23:20:18] Reencoding audio tracks (if req'd) - [23:20:28] Multiplexing M2TS - [23:20:35] Extracting A/V streams [VID_00346] - [23:20:59] Reencoding: VID_00346 (63 of 79) - [23:20:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5 617 frames - Bitrate: 14 393 Kbs - [23:20:59] Reencoding: VID_00346, Pass 1 of 1 - [23:23:56] Video Encode complete - [23:23:56] Reencoding audio tracks (if req'd) - [23:24:06] Multiplexing M2TS - [23:24:13] Extracting A/V streams [VID_00333] - [23:24:40] Reencoding: VID_00333 (64 of 79) - [23:24:40] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5 564 frames - Bitrate: 14 826 Kbs - [23:24:40] Reencoding: VID_00333, Pass 1 of 1 - [23:27:41] Video Encode complete - [23:27:41] Reencoding audio tracks (if req'd) - [23:27:50] Multiplexing M2TS - [23:27:57] Extracting A/V streams [VID_00372] - [23:28:25] Reencoding: VID_00372 (65 of 79) - [23:28:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 5 509 frames - Bitrate: 15 169 Kbs - [23:28:25] Reencoding: VID_00372, Pass 1 of 1 - [23:31:28] Video Encode complete - [23:31:28] Reencoding audio tracks (if req'd) - [23:31:37] Multiplexing M2TS - [23:31:44] Extracting A/V streams [VID_00376] - [23:32:18] Reencoding: VID_00376 (66 of 79) - [23:32:18] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6 394 frames - Bitrate: 15 278 Kbs - [23:32:18] Reencoding: VID_00376, Pass 1 of 1 - [23:36:17] Video Encode complete - [23:36:17] Reencoding audio tracks (if req'd) - [23:36:29] Multiplexing M2TS - [23:36:37] Extracting A/V streams [VID_00344] - [23:37:10] Reencoding: VID_00344 (67 of 79) - [23:37:10] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6 964 frames - Bitrate: 14 842 Kbs - [23:37:10] Reencoding: VID_00344, Pass 1 of 1 - [23:41:38] Video Encode complete - [23:41:38] Reencoding audio tracks (if req'd) - [23:41:54] Multiplexing M2TS - [23:42:12] Extracting A/V streams [VID_00349] - [23:43:25] Reencoding: VID_00349 (68 of 79) - [23:43:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 6 881 frames - Bitrate: 15 468 Kbs - [23:43:25] Reencoding: VID_00349, Pass 1 of 1 - [23:47:26] Video Encode complete - [23:47:26] Reencoding audio tracks (if req'd) - [23:47:37] Multiplexing M2TS - [23:47:46] Extracting A/V streams [VID_00339] - [23:48:21] Reencoding: VID_00339 (69 of 79) - [23:48:21] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7 159 frames - Bitrate: 14 964 Kbs - [23:48:21] Reencoding: VID_00339, Pass 1 of 1 - [23:52:26] Video Encode complete - [23:52:26] Reencoding audio tracks (if req'd) - [23:52:39] Multiplexing M2TS log 2/3
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
6th May 2010, 13:12 | #8111 | Link |
log 3/3
- [23:52:48] Extracting A/V streams [VID_00335] - [23:53:27] Reencoding: VID_00335 (70 of 79) - [23:53:27] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7 969 frames - Bitrate: 15 078 Kbs - [23:53:27] Reencoding: VID_00335, Pass 1 of 1 - [23:57:56] Video Encode complete - [23:57:56] Reencoding audio tracks (if req'd) - [23:58:10] Multiplexing M2TS - [23:58:21] Extracting A/V streams [VID_00329] - [23:59:04] Reencoding: VID_00329 (71 of 79) - [23:59:04] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 7 761 frames - Bitrate: 15 981 Kbs - [23:59:04] Reencoding: VID_00329, Pass 1 of 1 - [00:03:06] Video Encode complete - [00:03:06] Reencoding audio tracks (if req'd) - [00:03:20] Multiplexing M2TS - [00:03:31] Extracting A/V streams [VID_00338] - [00:04:12] Reencoding: VID_00338 (72 of 79) - [00:04:12] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8 152 frames - Bitrate: 15 440 Kbs - [00:04:12] Reencoding: VID_00338, Pass 1 of 1 - [00:08:50] Video Encode complete - [00:08:50] Reencoding audio tracks (if req'd) - [00:09:04] Multiplexing M2TS - [00:09:15] Extracting A/V streams [VID_00354] - [00:09:57] Reencoding: VID_00354 (73 of 79) - [00:09:58] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8 502 frames - Bitrate: 15 183 Kbs - [00:09:58] Reencoding: VID_00354, Pass 1 of 1 - [00:14:28] Video Encode complete - [00:14:28] Reencoding audio tracks (if req'd) - [00:14:42] Multiplexing M2TS - [00:14:54] Extracting A/V streams [VID_00334] - [00:15:46] Reencoding: VID_00334 (74 of 79) - [00:15:46] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 8 730 frames - Bitrate: 15 208 Kbs - [00:15:46] Reencoding: VID_00334, Pass 1 of 1 - [00:20:18] Video Encode complete - [00:20:18] Reencoding audio tracks (if req'd) - [00:20:32] Multiplexing M2TS - [00:20:42] Extracting A/V streams [VID_00380] - [00:21:33] Reencoding: VID_00380 (75 of 79) - [00:21:33] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9 502 frames - Bitrate: 15 173 Kbs - [00:21:33] Reencoding: VID_00380, Pass 1 of 1 - [00:25:06] Video Encode complete - [00:25:06] Reencoding audio tracks (if req'd) - [00:25:22] Multiplexing M2TS - [00:25:32] Extracting A/V streams [VID_00371] - [00:26:20] Reencoding: VID_00371 (76 of 79) - [00:26:20] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 9 771 frames - Bitrate: 15 336 Kbs - [00:26:20] Reencoding: VID_00371, Pass 1 of 1 - [00:31:26] Video Encode complete - [00:31:26] Reencoding audio tracks (if req'd) - [00:31:42] Multiplexing M2TS - [00:31:53] Extracting A/V streams [VID_00340] - [00:32:55] Reencoding: VID_00340 (77 of 79) - [00:32:55] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12 631 frames - Bitrate: 15 629 Kbs - [00:32:55] Reencoding: VID_00340, Pass 1 of 1 - [00:39:44] Video Encode complete - [00:39:44] Reencoding audio tracks (if req'd) - [00:40:05] Multiplexing M2TS - [00:40:19] Extracting A/V streams [VID_00351] - [00:41:25] Reencoding: VID_00351 (78 of 79) - [00:41:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12 832 frames - Bitrate: 15 884 Kbs - [00:41:25] Reencoding: VID_00351, Pass 1 of 1 - [00:48:19] Video Encode complete - [00:48:19] Reencoding audio tracks (if req'd) - [00:48:40] Multiplexing M2TS - [00:48:55] Extracting A/V streams [VID_00368] - [00:50:19] Reencoding: VID_00368 (79 of 79) - [00:50:19] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 15 312 frames - Bitrate: 16 262 Kbs - [00:50:19] Reencoding: VID_00368, Pass 1 of 1 - [00:58:28] Video Encode complete - [00:58:28] Reencoding audio tracks (if req'd) - [00:58:53] Multiplexing M2TS [00:59:10]PHASE ONE complete [00:59:10]PHASE TWO - Rebuild Started - [00:59:10] Rebuilding BD file Structure - [00:59:10] Rebuilding BD file Structure - [00:59:11] CopyDirStructure() 00076 1200 - [08:11:53] CopyDirStructure() 00076 1200 - [08:12:00] CopyDirStructure() 00076 1200 - [08:12:05] CopyDirStructure() 00076 1200 - [08:12:06] CopyDirStructure() 00076 1200 - [08:12:07] CopyDirStructure() 00076 1200 - [08:12:07] CopyDirStructure() 00076 1200 - [08:12:08] CopyDirStructure() 00076 1200 - [08:12:08] CopyDirStructure() 00076 1200 - [08:12:09] CopyDirStructure() 00076 1200 - [08:12:09] CopyDirStructure() 00076 1200 - [08:12:10] CopyDirStructure() 00076 1200 - [08:12:10] CopyDirStructure() 00076 1200 [08:12:14] - Aborted at user request
6th May 2010, 23:44 | #8114 | Link |
Doing a backup of "Tropic Thunder" right now. Just saw something that makes no sense to me. VID_00009 was 1920X1080 @ 29.97 (6,397 frames). I'm resizing everything to 1280X720. The new VID_00009 is 1280X720 @ 59.940 (12,794 frames).
The idea with resizing is to maximize the quality/ bits per pixel. But doubling the framerate/number of frames defeats that purpose. Any idea why that happened? |
7th May 2010, 01:25 | #8118 | Link | |
Sony their good... good player, fast and easy to use. Another of my friend purchass the new model samsung bluray with streaming play mkv, videos, musics from the pc to the tv. I have also an Xtreamer HD media box witch i love it! it play ISO bluray, and ALL FORMATS. ALL OF THEM ! They update firmware for further technology. I like it!
7th May 2010, 01:27 | #8119 | Link | |
Former Kanenite
========================== [17:21:04] BD Rebuilder v0.33.06 (beta) [17:21:04] BEGIN - BATCH SEQUENCE ========================== ----------------------- [17:21:04] PROCESSING BATCH FILE [1] ----------------------- [17:21:05] BD Rebuilder v0.33.06 (beta) - Source: STAR_TREK_S2D4 - Input BD size: 27.48 GB - Approximate total content: [03:13:01.019] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [17:21:05] PHASE ONE, Encoding - [17:21:05] Extracting A/V streams [VID_00209] - [17:21:06] Reencoding: VID_00209 (1 of 31) - [17:21:06] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 193 frames - Bitrate: 3,914 Kbs - [17:21:06] Reencoding: VID_00209, Pass 1 of 1 - [17:21:10] Video Encode complete - [17:21:10] Reencoding audio tracks (if req'd) - [17:21:10] Multiplexing M2TS - [17:21:10] Extracting A/V streams [VID_00024] - [17:21:11] Reencoding: VID_00024 (2 of 31) - [17:21:11] Reencoding secondary video [TRK_02] - [17:21:12] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 125 frames - Bitrate: 9,297 Kbs - [17:21:12] Reencoding: VID_00024, Pass 1 of 1 - [17:21:16] Video Encode complete - [17:21:16] Reencoding audio tracks (if req'd) - [17:21:16] Multiplexing M2TS - [17:21:17] Extracting A/V streams [VID_00012] - [17:21:18] Reencoding: VID_00012 (3 of 31) - [17:21:18] Reencoding secondary video [TRK_02] - [17:21:19] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 263 frames - Bitrate: 10,668 Kbs - [17:21:19] Reencoding: VID_00012, Pass 1 of 1 - [17:21:27] Video Encode complete - [17:21:27] Reencoding audio tracks (if req'd) - [17:21:27] Multiplexing M2TS - Error in attempt to multiplex: MUX_00012.meta - Can't open file: F:\FULL DISC\WORKFILES\00012.track_6656.DTS [17:21:27] - Failed to build structure, aborted |
7th May 2010, 01:31 | #8120 | Link | ||
It was the original bluray i took and decrypted with anydvd hd. I dont work by network mapped drive. Hard disc is in the same pc. thanks.
