Old 9th May 2013, 00:50   #17101  |  Link
Originally Posted by Ch3vr0n View Post
Well aslong as the menu's work correctly "eg: watch film in RealD > triggers SBS copy". For movies like the most recent resident evil it may be a little tricky. There's 3 versions on it. 2D, anaglyph & RealD. The 1st 2 can easily be shrinked. Afaik the anaglyph one from what i can see on my iso probably uses some kind of "anaglyph overlay" on the 2D stream as there is no seperate anaglyph stream. It's the RealD (2nd eye stream) that as you know prevents shrinking.
An anaglyph feature would not be flagged as 3D, it would be contained in an M2TS just like 2D. Only MVC 3D has special settings (e.g. the packet indexes into the SSIF are different from the M2TS and has to be specified independently).
Old 9th May 2013, 03:15   #17102  |  Link
Ch3vr0n
The disc i was talking about was Resident evil: afterlife. After reading your post i went back to double check. you're right. I must have missed anaglyph stream initially. There's the 2D stream (14GB on the dot) and a 2nd anaglyph stream (15.7GB) in the stream root folder. If you manage to pull of that 3D half-SBS you'll probably succeed at shrinking my 3D backup rips from a 471GB folder to arround 200 tops ^^
I've been wanting to do this for a while but never had the funds available till now. I've been using this wonderful piece of software ever since i found it 2+ years ago. I've been able to make backups ever since. You've also implemented quite some feature requests i've asked for and have gotten. Check your account. Just made a $30 donation You've more than earned it and way overdue
** edit ** in the (auto?) response i got there is a claim of name being added to the contributors list? Can't find it on the site though ^^
Old 9th May 2013, 04:30   #17103  |  Link
sojourner353
If I did this it would have to be to ALTERNATE MKV or MP4 only -- as the size would not be compliant with AVCHD or Blu-ray.
Thanks for the info jdobbs and nice to hear it can be done and is it something you might consider? I am looking for other program's that can do this at the moment, the reason for seeking this is it would be the closest one could get to a 3D Remux, have done a few 3D's now with new BDRB and it works great but can defiantly see a loss in quality on my projected image, cheers.
sojourner353 is offline   Reply With Quote
Old 9th May 2013, 12:41   #17104  |  Link
colinhunt
BD-RB v0.44.04
Disc: Django Unchained (US)
Job: Tried to create a 1080p MKV with intact audio of 00002.m2ts
Error log:
[14:30:55] Importing M2TS: 00002
- Preparing M2TS for processing...
- Collecting audio/video streams from source...
- Warning: Framerate [23,976fps] not BD compliant.
- Building pseudo-BD source structure...
[14:33:14] Video import completed successfully.
[05.09.13] BD Rebuilder v0.44.04 (beta)
[14:35:06] Source: 00002_00000
- Input BD size: 2,02 GB
- Approximate total content: [00:14:22.043]
- Windows Version: 6.1 [7601]
- Mode: MKV Container, 1920x1080, Intact Audio
- X264 Tweak(s) enabled
[14:35:06] PHASE ONE, Encoding
- [14:35:06] Processing: VID_00000 (1 of 1)
- [14:35:06] Extracting A/V streams [VID_00000]
- [14:35:45] Reencoding video [VID_00000]
- Error: Video framerate is illegal/unknown.
[14:35:45] - Failed video encode, aborted
Old 9th May 2013, 12:54   #17105  |  Link
Sharc
A problem of , versus . ?
Old 9th May 2013, 13:13   #17106  |  Link
colinhunt
Change notes from 44.02:
- Corrected an error in the importing function
in which framerates can be incorrectly read
on systems the use "," as a decimal point.
Didn't take, it seems
Old 9th May 2013, 13:19   #17107  |  Link
Actually it is your e-mail address that is added. The list isn't available to the public. In the event I ever decide to create a "Pro" version anyone on that list gets it for free. However, my current plan is to keep it freeware based on voluntary donations.
Old 9th May 2013, 13:20   #17108  |  Link
If you see a loss of quality -- you're doing something wrong.
Old 9th May 2013, 13:22   #17109  |  Link
Originally Posted by colinhunt View Post
BD-RB v0.44.04
Error log:
That's caused by the "," as a decimal point. I thought I'd fixed that, but I'll check again.
Old 9th May 2013, 14:50   #17110  |  Link
colinhunt
Well you do lose half of the resolution when going from BD3D to side-by-side 3D... but maybe he meant something else.
Old 9th May 2013, 15:38   #17111  |  Link
sojourner353
Yes that is what I meant, I can defiantly notice a quality difference on a 130" screen when watching Half SBS hence why I want to go Full SBS, thanks.
Old 9th May 2013, 16:37   #17112  |  Link
Mark_Venture
Total Recall 2012 audio out of sync
(as mentioned here -> http://forum.doom9.org/showpost.php?p=1627263&postcount=2 )
When the movie starts, the audio is in sync. By the end, it is noticeably off.
The attached text file has the BD-Rebuilder LOG, INF, and INI files.
I ripped the bluray to hard drive (folders, not ISO), with AnyDVD HD like I have with all others to date.
This is the only bluray I've noticed audio sync issues with.
I tried again after I updated to 0.44.04, but it failed to complete the rebuild, and I rolled back to 0.43.06. The attached text file also contains the log of the failed rebuild from when I tried after upgrading to 44.04..
Old 9th May 2013, 16:38   #17113  |  Link
Thanks. I'll take a look at it today.
I did Total Recall a while back and don't remember any issues... but I'll do it again with your settings.
Old 9th May 2013, 16:49   #17114  |  Link
I see. Of course you'll lose horizontal resolution at half SBS -- there's really not anything you can do about that. I thought he meant the extra compression for BD-5/9/25 was showing degradation. While a full backup to DVD-5 is probably a little much on some discs -- none of the others should show a noticeable quality drop.
No need to be defiant, though.
I've added full SBS to the next release. It is turned on with a hidden setting, and only works with MKV or MP4 ALTERNATE output selections that aren't inherently being resized.
Old 9th May 2013, 17:15   #17115  |  Link
Sharc
Wouldn't L/R interleaved instead of SBS keep the resolution intact? Don't know if this is standard compliant and compatible 3-D TVs.
Old 9th May 2013, 17:24   #17116  |  Link
Most TVs only support SBS and Over/Under (Top/Bottom).
At the HDMI level they all support full O/U with 45 lines of blank between them. Some support interleaved and SBS -- but getting that sent to the HDMI input from a non-specialized player is almost impossible. So even if you create the file -- what good is it if you can't play it back?
I also think there would be a significant loss of efficiency in encoding interleaved. It could be that X264 has a way to compensate for it, but if it does I don't know about it.
Old 9th May 2013, 18:22   #17117  |  Link
colinhunt
As far as I know, very few displays are compliant with full SBS. The frame size is simply way too large.
Old 9th May 2013, 18:46   #17118  |  Link
Sharc
That's why I thought interleaving could be a possibility. By this I meant L/R arranged in alternating full frames, means doubling the frame rate. But as jdobbs explained this seems to be beyond a standard. I noticed that "double framerates" for blu-ray are only specified for the reduced resolution of 1280x720@50fps or 59.94fps. So no luck ......
Old 9th May 2013, 19:14   #17119  |  Link
From the WIKI:
HDMI 1.4a requires that 3D displays support the frame packing 3D format at either 720p50 and 1080p24 or 720p60 and 1080p24, side-by-side horizontal at either 1080i50 or 1080i60, and top-and-bottom at either 720p50 and 1080p24 or 720p60 and 1080p24.
Old 9th May 2013, 19:18   #17120  |  Link
RobertM
Back at Christmas time, when I reported the problem on Total Recall, didn't you say that you could reproduce it?
